Engine Fault Workshop
Mama Omide
Ai o singura sonda lambda pe acest motor,
Ok, poti sa-mi dai un cod sau o poza cum arata sonda?
Va salut,
Am facut o diagnoza la masina mea Passat B6 cond motor BMP si am gasit erorile urmatoare...poate am puteti ajuta cu ceva sfaturi:
Multumesc anticipat.
Chassis Type: 3C0
 Mileage: 141960km/88209miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 MR    HW: 028 101 211 9
   Component: R4 2,0L EDC G000SG  9389
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 10151 599 174676
   VCID: 7BFE40863A3276C6DA7
2 Faults Found
001031 - EGR Sensor 2
               P0407 - 000 - Signal too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 5
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Lambda: 0.8 %
                    Mass Air / Rev.: 745.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
                    Bin. Bits: 00000000
001027 - EGR Valve (N18)
               P0403 - 000 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 141814 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 08:25:55
             Freeze Frame:
                    RPM: 2541 /min
                    Speed: 90.0 km/h
                    Duty Cycle: 82.1 %
                    Voltage: 14.29 V
                    Mass Air / Rev.: 565.0 mg/str
                    Duty Cycle: 7.2 %
                    Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: Redir Fail!
   Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0658514579
   Coding: 0013602
   Shop #: WSC 00028 028 00001
   VCID: 2F66A4D6BECA5A6626F
1 Fault Found
00650 - Clutch Pedal Switch (F36)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 191
                    Mileage: 141954 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 12:35:
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
   Component:    KSG PQ46 ELV 038 0455
   Revision: 00038000    Serial number: VWZCZ000000000
   Coding: 18910A0801860E763804941570084F0E303C00
   VCID: 3260ADA2ADF8778E491
   Subsystem 1 - Part No: 1K0 951 605 B
   Component: LIN BACKUP HORN H07 7001
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found
01179 - Incorrect Key Programming
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 135525 km
                    Time Indication: 0
                    Date: 2015.02.03
                    Time: 18:23:55
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Component: Tuer-SG         024 2365
   Coding: 0000180
   VCID: 37769CB6469A92A67EF
1 Fault Found
00933 - Electric Window Motor; Passenger Side (V148)
            005 - No or Incorrect Basic Setting / Adaptation
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 2D5ABEDEB4C62876143
1 Fault Found
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End   ---------------------------------------------------------------------
Jetta20tdiHLDSG6
Am rezolvat problema. Din pacate eu fac parte din categoria celor care nu au decat notiuni elementare de mecanica si electrica auto asa ca nu pot sa va spun decat ca persoana in service-ul auto la care a ajuns masina, mi-a spus ca a gasit o defectiune pe platoul de la electromotor si a trebuit schimbat cu totul. Sincer am dubii ca l-a schimbat si nu a fost ceva minor. Am vazut electromotorul dat jos de pe masina dar normal trebuia sa-mi arate si mie platoul schimbat si ce era defect. A profitat ca eu eram in spital si m-a vazut doar cand a luat masina si la plecare. Pretul a fost de 1100 ron din care a explicat a cerut 200 platforma, 400 platoul, 300 demontat-montat electromotorul, 200 diverse....teste, schimbat un bec, o siguranta....pret fara factura, garantie nimic !!!
ma scuzi dar, "Factura, garantie, nimic" trebuie sa ceri. chiar si dupa
si daca nu primesti suni la ANAF
verifica mufa de la egr, berifica functionarea electrovalvei n18,
Si de refacut lipiturile la elementul de incalzie auxiliara.
catalinpopa1982
Va rog mult sa ma ajutati cu interpretarea erorilor de mai jos:
Thursday,27,August,2015,21:19:30:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3CZAE057441   License Plate:
                Address 01: Engine       Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 QC    HW: 03L 907 309
  Component and/or Version: R4 2,0L EDC G000SG  5582
           Software Coding: 0000072
            Work Shop Code: WSC 83968 280 534120
                      VCID: 76E300530132E6AEBEF-8023
4 Faults Found:
001025 - EGR System
               P0401 - 000 - Insufficient Flow - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100000
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 255
                    Mileage: 187501 km
                    Time Indication: 0
                    Date: 2001.14.24
                    Time: 07:16:24
             Freeze Frame:
                    RPM: 1311 /min
                    Speed: 0.0 km/h
                    Voltage: 14.14 V
                    Load: 14.9 %
                    Load: 100.0 %
                    Mass Air / Rev.: 270.0 mg/str
                    Mass Air / Rev.: 395.0 mg/str
000665 - Boost Pressure Regulation
               P0299 - 000 - Control Range Not Reached - Intermittent - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 12
                    Reset counter: 255
                    Mileage: 188078 km
                    Time Indication: 0
                    Date: 2001.14.27
                    Time: 07:37:45
             Freeze Frame:
                    RPM: 2484 /min
                    Speed: 107.0 km/h
                    Load: 62.0 %
                    Absolute Pres.: 2264.4 mbar
                    Absolute Pres.: 1744.2 mbar
                    Lambda: 92.3 %
                    Lambda: 38.7 %
009253 - Exhaust Gas Recirculation Cooling Valve Control
               P2425 - 000 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 188374 km
                    Time Indication: 0
                    Date: 2001.14.28
                    Time: 10:39:59
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Temperature: 14.4°C
                    Absolute Pres.: 938.4 mbar
                    (no units): 0.0
                    (no units): 3.97
                    Temperature: 13.5°C
009571 - Turbocharger Boost Control Position Sensor Circuit
               P2563 - 000 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 188921 km
                    Time Indication: 0
                    Date: 2001.14.31
                    Time: 21:04:07
             Freeze Frame:
                    RPM: 1403 /min
                    Speed: 0.0 km/h
                    Voltage: 13.91 V
                    Lambda: 36.3 %
                    Lambda: -2.4 %
                    Bin. Bits: 00001110
                    Voltage: 2.888 V
Readiness: 1 2 0 0 0
Din ce am citit pe forum si pe alte site-uri, inteleg ca ar fi problema cu EGR (desi l-am schimbat saptamana trecuta cu unul nou Valeo) si cu actuatorul de la turbina. Problema apare in treapta a 4 -a cand accelerez de la 80 km/h sau daca depasesc in treptele 3,5 si 6 4.000 turatii.
Multumesc anticipat,
Ai inlocuit egr-ul degeaba . Problema e actuatorul de la turbina . Inlocuieste-l , fa reglajul corespunzator si nu o sa mai apara eroarea de la egr
catalinpopa1982
Multumesc pentru raspuns.
EGR-ul l-am inlocuit intrucat aveam eroare doar pe EGR si am circulat asa aprox. 10.000 km. Erorile legate de presiunea in turbo au aparut dupa ce am inlocuit EGR-ul.
Voi merge si la service sa-mi faca test cu manometru, sa stiu exact ce am de inlocuit, ca testele de schimbat piese ma cam costa.
Pe aceeasi eroare(bujia palpaie din cand in cand si martor motor aprins) dar cu motorul functionand normal, de la reprezentanta mi-a sugerat sa schimb senzorii de gaz si temperatura G235 si G448.
I-a schimbat cineva pana acum?
Modificat de VVV
La modelul meu 7L nu exista ulei de completare la filtru de particule?
Eu parca imi aduc aminte ca am completat odata in service si s-a rezolvat problema!
Aditiv, m-am exprimat gresit, sau mai exact m-am exprimat cum spune factura Porsche.
M-am uitat in istoric si am facut aceasta operatie in 2011, 55.000km si am scapat de martorul de pe bord aprins.
Conform facturii de atunci, Ulei G 052143A2 este codul de aditiv.
Acum am masina la delarul VW din Galati care nu gaseste vasul unde vine acest aditiv!
Vreo sugestie?
Schimba service-ul!!!
Scuze ca nu am contribuit cu ceva constructiv, nu m-am putut abtine, dar e uimitor cu mecanicii astia...
Cu atata documentatie si mijloace de informare puse la dispozitia lor, mi-ar fi rusine sa zic asta clientului, mie personal.
as avea nevoie sa ma ghidati pe pm pt passatul meu cbdc 110 cp,wvwzzz3czap088258,de unde as putea lua  senzorul de temperatura gaze esapate dupa filtrul de particole,cod 03L 906 088 CE.la mine in pitesti l-am gasit la 850 kei si mi se pare enorm.aici este schema http://vwforum.ro/topic/60800-engine-fault-workshop/?p=2212868.multumescmult
Mda, asa este.
Mai mult de atat, dupa ce initial dupa constatare au zis ca problema este lipsa aditivului la fitru de particule si trebuie completat, ulterior mi-au spus ca modelul meu nu este prevazut cu acest vas si mi-au inmanat o proforma cu alte piese care trebuie schimbate.
Asta m-a facut sa caut in dosarul masinii.
In fine, eu nu am fost prezent acolo, o sa schimb service ul.
Mai cauta la magazine de piese auto,ar trebui sa gasesti piesa originala la aprox 600 ron
Acum cativa ani, cei de la Scorpion Focsani erau bunicei. Nu am mai fost la ei de ceva vreme. Dar voi apela la ei cat de curand cu un service la cutia de viteze.
Ma poate ajuta un coleg sa imi spuna exact ce as putea avea la erorile de mai jos?
Masina nu mai trage si nici turbina nu intra dupa ce imi apare martorul acela in forma de spira. Astazi mi-a aparut si martorul motor.
Multumesc anticipat!
Sunday,04,October,2015,16:39:32:32264
VCDS Version: Release 11.11.3
Data version: 20120401
                Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 03G 906 021 PB    HW: 03G 906 021 AB
  Component and/or Version: R4 1,9L EDC G000SG  1845
           Software Coding: 0000071
            Work Shop Code: WSC 10169 599 96651
                      VCID: 6ED9D061798C249
3 Faults Found:
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 220566 km
                    Time Indication: 0
                    Date: 2015.10.02
                    Time: 14:34:13
             Freeze Frame:
                    RPM: 1680 /min
                    Speed: 64.0 km/h
                    Temperature: 21.6°C
                    Absolute Pres.: 1009.8 mbar
                    Mass Flow: 17.07 g/s
                    (no units): 1.42
                    Temperature: 83.7°C
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 6
                    Mileage: 220570 km
                    Time Indication: 0
                    Date: 2015.10.02
                    Time: 14:38:04
             Freeze Frame:
                    RPM: 1449 /min
                    Speed: 56.0 km/h
                    Duty Cycle: 19.1 %
                    Voltage: 14.36 V
                    Duty Cycle: 0.0 %
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 220615 km
                    Time Indication: 0
                    Date: 2015.10.03
                    Time: 16:00:39
             Freeze Frame:
                    RPM: 2037 /min
                    Speed: 31.0 km/h
                    Load: 81.6 %
                    Voltage: 14.29 V
                    Bin. Bits: 00001000
                    Absolute Pres.: 1713.6 mbar
                    Absolute Pres.: 1111.8 mbar
Readiness: 1 1 0 0 0
Am inteles ca am problema la asta, dar de la ce? Din ce cauza? daca pornesc masina, merg ce merg cu ea si se aprinde martorul spira. Opresc motorul, pornesc iar motorul,merge ok timp de cativa kilometrii. Masina trage normal pana se aprinde iar martorul ala.
De la turbina. Iei limp. Fa-i un log in mers si posteaza-l in topicul dedicat. Pb la capsula vacumatica sau tija actuator.
Verifica
- debitmetrul si cablajul acestuia
- furtunele de la turbo
- filtrul de aer
Passat 2010 2.0 tdi 110 cp nu mai porneste de dimineata din senin. L-am luat la 214 mii km si acum am 253 mii si pana azi nu a avut nici o problema cat de mica. Saptamana trecuta i-am facut o scanare era tot curat si azi dimineata surpriza.
Se aprobd si se sting si se aprind intr-una toti martorii de bord.
Coduri de eroare 000258, 000256, 01288, 00446.
Am verificat sigurantele din bord si de pe baterie, totul e ok. Am dat curent de la un alt diesel si nu porneste nici asa.
Daca ma poate ajuta cineva
nu ai baterie.... incearca cu o baterie buna, pusa direct pe masina - sau sa ai cabluri de curent de calitate si masina care iti da curent sa fie pornita.
ce sigurante ai tu la B6 pe baterie.....? nu ai... poate ai verificat sigurantele din E box....
