Probleme mari si enervante Octavia 2
raz.ro
Posteaza intreg autoscanul.
Am atasat tot autoscanul, inclusiv erorile ramase dupa stergere. Si ar mai fi o chestie! Masina mi se pare ca are un consum excesiv de carburant! Adica undeva la 7% exterior cu clima puternica si mers cuminte si 5.6 % fara clima! In aceleasi conditii masina consuma inainte 4.4% respectiv 5.2%. Am banuit senzorul de temperatura g62, dar valorile indicate de acestea sunt comparabile cu cele din blocul "Instruments". E posibil sa am consumul marit din cauza temperaturilor tropicale de afara sau exista o problema? Multumesc mult!
Saturday,25,August,2012,13:33:48:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Address 17: Instruments Labels: 1K0-920-XXX-17.LBL
Control Module Part Number: 1Z0 920 810 D
Component and/or Version: KOMBIINSTRUMENT VD1 3560
Software Coding: 0003101
Work Shop Code: WSC 00011 888 96745
VCID: 33611BFF2BA5
01314 - Engine Control Module
Address 17: DTCs cleared
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: TMBBS41Z452041184 Mileage: 151510km/94143miles
01-Engine -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Not registered 0011
72-Door, Rear Right -- Status: Not registered 0011
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DJ HW: 028 101 188 3
Component: R4 1,9L EDC 0000SG 6250
Revision: 12345678 Serial number: SKZ7Z0D2799168
Coding: 0000071
Shop #: WSC 10154 599 82256
VCID: 6ED7CA8B0007
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 73430 790 00000
VCID: 3F8947CF17ED
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0304
Shop #: WSC 00000 000 00000
VCID: 3B7133DF03F5
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001370221
Coding: 01080E020004140000110D000000000000087F075C
VCID: 3A7F36DB0CCF
Part No: 1Z1 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 07 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD05D2K6
Coding: 0012343
VCID: 7DF5FDC75D61
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000012
VCID: 356525E725D1
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 810 D
Component: KOMBIINSTRUMENT VD1 3560
Coding: 0003101
Shop #: WSC 00011 888 96745
VCID: 33611BFF2BA5
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104B29029C
Coding: 3D0F0B40071302
VCID: 295DF997F969
5 Faults Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 94
Mileage: 147169 km
Time Indication: 0
Date: 2000.00.00
Time: 00:50:07
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Reset counter: 94
Mileage: 147169 km
Time Indication: 0
Date: 2000.00.00
Time: 00:50:11
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 221
Reset counter: 129
Mileage: 150735 km
Time Indication: 0
Date: 2000.00.00
Time: 11:52:15
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 31
Reset counter: 129
Mileage: 150900 km
Time Indication: 0
Date: 2000.00.00
Time: 19:46:59
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 151350 km
Time Indication: 0
Date: 2000.00.00
Time: 09:13:26
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3560
VCID: 33611BFF2BA5
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0165
Coding: 0000118
VCID: F4E358E3EE2B
011 - Open Circuit
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 306B14F3DAB3
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0562
Coding: 18F802007F2D8505084F010004
VCID: 7BF1F3DF4375
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000118
VCID: F5E565E7E551
011 - Open Circuit
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 A HW: 01. 01. 03
Component: Radio FO3 0008
Coding: 0000400
VCID: 2C530083F69B
01305 - Databus for Infotainment
014 - Defective - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0219
Coding: 0000048
VCID: 2F69178FC78D
011 - Open Circuit
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306B14F3DAB3
011 - Open Circuit
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D550D87CD81
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 56: DTCs cleared
Address 62: DTCs cleared
Address 72: DTCs cleared
Address 7D: DTCs cleared
Chassis Type: 1K0
Coding: 0000071
VCID: 6ED7CA8B0007
Coding: 0017025
VCID: 3F8947CF17ED
VCID: 3B7133DF03F5
VCID: 3A7F36DB0CCF
Coding: 00065525
Shop #: WSC 73430
Coding: 0012343
VCID: 7DF5FDC75D61
Coding: 0000012
VCID: 356525E725D1
Coding: 0003101
VCID: 33611BFF2BA5
VCID: 295DF997F969
VCID: 33611BFF2BA5
Coding: 0000118
VCID: F4E358E3EE2B
011 - Open Circuit
VCID: 306B14F3DAB3
VCID: 7BF1F3DF4375
011 - Open Circuit
Coding: 0000118
VCID: F5E565E7E551
011 - Open Circuit
Coding: 0000400
VCID: 2C530083F69B
Coding: 0000048
VCID: 2F69178FC78D
011 - Open Circuit
Coding: 0000048
VCID: 306B14F3DAB3
011 - Open Circuit
VCID: 2D550D87CD81
Modificat de Delphinul
Codeaza CANgateway corect, adica la instalation list pune si usile din spate.
Verifica firele la usa pasagerului, ai unul intrerupt, sau problema poate fi in modulul de confort.
mai ai o problema la radio, la fel fir intrerupt (scurt) sau o problema interna.
pai pot spune ca nu imi merg avariile cand inchid si deschid masina, iar la usile spate nu imi merg geamurile electrice! In schimb nu am probleme cu inchiderea centralizata! In ceea ce priveste prima eroare adica 01314 si consumul marit imi poti spune ceva? e posibil sa fie releul 109? unde il gasesc? Banuiesc ca pentru codarea modului CAN am nevoie de o interfata originala, adica nu pot face operatiunea cu o clona. Corect?
poti face si cu o clona.Ideea este sa bifezi dotarile masinii, altfel iti va da eroarea aia cu Control Module Incorrectly Coded. Eu cred ca ai o problema cu interfata(e slaba calitativ), am patit si eu ceva de genul: cu o interfata imi arata o eroare:Databus in Single Wire Operation , cu alta interfata nu.
e posibil si asta, dar totusi mie imi arata la meassuring blocks la modulul CAN cum oscileaza intre conexiune pe un fir si 2 fire, de unde deduc ca e un contact imperfect undeva! O sa incerc zilele astea sa caut mai bine, poate gasesc ceva! Pe mine ma intereseaza mai mult problema cu pornirea si de unde a aparut acea eroare 01314... Poate ma puteti ajuta...
Posibi;l sa ai o problema interna a ECU.
Va salut! am adaugat usile din spate la installation list, iar acum imi apar erorile
01333 - Door Control Module Rear Left (J388): Defective
respectiv
01334 - Door Control Module Rear Right (J388): Defective
ce ar trebui sa verific? Pentru eroarea
01314 - Engine Control Module: No Communications
pot sa incerc sa verific/schimb releul 109? Va multumesc!
MAsina ta nu are 109.
pai si atunci de unde ar putea fi prblema cu pornirea? E ciudat ca asta se intampla la temperaturi de sub 20 de grade! La temperaturi de peste 20 de grade totul e normal. La temperaturi de sub 20 de grade daca ii dau cheie motorul se invarte fara niciun gand de a porni ca si cum nu s-ar alimenta si este oprita de imobilizator, daca pun contactul de 2 ori si apoi dau la cheie masina porneste normal.... Bateria este noua, am crezut la inceput ca ea ar fi cauza...Va rog frumos ajutati-ma.
Se pare ca am rezolvat problema! Era intrerupt cablajul de la senzorul G81, cel care da informatii despre temperatura combustibilului. Multumesc pentru ajutor!
Salut.
La masina am un zgomot ca cel din filmuletul atasat
Am inteles din ce am citit ca ar fi de la distribuitorul de vacuum. L-am inlocuit cu unul de la un prieten si dupa inlocuire nu se mai aude acel bazait electronic, dar acea supapa tot se aude parca la fel de tare.
Intrebare: a reparat cineva acest distribuitor de vacuum, sau are cineva poze cu el desfacut?
Stiu cu unu nou de 800ron.
Astept ceva sfaturi.
Ieri s-a aprins in timpul mersului martorul : sistemul de control al gazelor de esapament.
Masina e skoda octavia ll benzina motor 1.6 In afara de acest martor masina merge ok.
Are intalatie de gpl montata acum 1000 km.
Ce poate sa aiba?
scaneaza cu un Vcds si posteaza eroarea. cauzele pot fi multe
Vezi in lista de prestari servicii sau in semnatura unor membri.
Am incercat sa desfac distribuitorul de vacuum 6Q0906625, am scos un capac de plastic si o garnitura de cauciuc, dar nu reusesc sa dau capacul de, deasupra jos.
Cand il lovesc usor se aude ceva care pare desprins, un fel de arc.
Nu a incercat nimeni sa-l desfaca?
post-18532-0-25485500-1353101345_thumb.j
post-18532-0-31390000-1353101349_thumb.j
post-18532-0-83732800-1353101353_thumb.j
Modificat de mafia
E capsulat, doar daca il tai il desfaci.
Dupa ce am scos acea garnitura, am aspirat duzele cu aspiratorul, am dat si cu WD -40. LA remontare am observat ca nu mai scoate acel zumzet la oprirea masinii. Monitorizez situatia si revin cu informatii. Multumesc.
l-am desfacut eu neavand ce face deoarece nu functioneaza turbo, egr,lipsa vacuum,ramane deschis furtunasul spre filtru, electroventilele din el mergeau un pic mai greu dar nu el era cauza, cauza este tensiunea mai mica, cam 9-10v livrata pe pinii 3-5, 4-6(cel putin la mine), a mai masurat cineva tensiunea pe acele fire?
post-107710-0-82902900-1353406679_thumb.
post-107710-0-48370700-1353406698_thumb.
Multumesc pentru poze. Am fost si am masurat la mine tensiunea pe acei pini, cu contactul pus am 8.75V. Nu stiu care e tensiunea corecta.
Eu momentan am scapat de acel zgomot (bazait).
Am si eu ceva probleme care sper sa nu fie grave, adica sa nu ma faca sa vand din casa cand va fi sa le rezolv.
1. De ceva vreme, vreo 2 ani si ceva timp in care am tot incercat sa lersicie Skoda sa-i dau de cap, am o vibratiei in masina, o resimt cel mai bine in volan sau daca tin mana pe cotiera.
vibratia ar fi, scuze comparatia, ca de vibrator, poate nu frecventa atat de mare.
Parca in legatura cu aceste vibratii (ca prea par sincronizate) simt si in pedala de ambreiaj ceva batai dar nu tot timpul.
La relanti nimic, insa cum bag in viteza si plec se simte.
Daca in mers las masina in viteza sa mearga singura, nimic, insa cum incep sa accelerez cum se simt vibratii in pedala de ambreiaj.
Aceste vibratii/batai in pedala nu le simt imediat ce ating ambreiajul ci doar cand apas 1-2 cm, cand ar intra in zona de "decuplare"(scuze, nu sunt priceput la mecanica si posibil sa scot tot felul de perle).
In acelasi timp simt ca nu mai trage cum ar trebui.
E mai zgomotoasa, de ex, in treapta a 3-a la 3000 rpm ca acum 2 ani la 4500 rpm.
Asta cu trasul o simt cand urc in o panta, se infingea mai usor.
2. Tot de vreo 2 ani, pana acum o saptamana, aveam bateria care a venit cu masina, baterie pe duca(concluzie data de teste si de iarna trecuta cand n-a mai pornit), masina achizitionata in Ian 2008.
Cum erau cateva zile reci cu umezeala, cum imediat dupa pornire se zdruncina motorul aproape sa se opreasca, am patiti asta chiar si in urma cu vreo 2-3 saptamani.
Dadeam cheie din nou si pornea cat de cat normal.
Am schimbat bateria cu una noua si pare ca acum totul e ok.
Totusi am inteles ca daca porneste la cheie atunci motivul acelor zdruncinaturi nu ar fi bateria.
3. Si inca ceva, ceva ce se spune ca ar fi din cauza vechimii ("..nu mai e noua").
O las la relanti si o ascult la esapament. Nu se mai aude cursiv ca in primii ani, suna acum cumva metalic si mai cu intreruperi mici, uneori am "surprins-o" cu rateuri.
Bujiile sunt schimbate de 1 an.
Ceva idei?
La scanare VAG-COM nu am erori.
Am uitat sa mentionez ca este vorba despre masina din semnatura.
Modificat de garbage
Furca de debraiere de la rulmentul de ambreiaj,este o posibila cauza.Posibil cu schimbarea ambreajului sa scapi de probleme,asta cand o sa vina vremea sa schimbi ambreajul si cand o sa inceapa sa iti faca figuri.
Zilele trecute am intalnit o problema asemanatoare la un G5 motor BLF.
post-64586-0-53368600-1353595602_thumb.j
Multumesc Gabi, pana la schimbarea ambreiaj mai sap putin cu ajutorul celor de la service.
Acum vad ca am scris anapoda pe alocuri, mai ales la prima fraza de la punctul 2.
Imi cer scuze, m-am grabit si nu mi-am verificat logica.
In loc de "Tot de vreo 2 ani, pana acum o saptamana, aveam bateria care a venit cu masina, baterie pe duca(concluzie data de teste si de iarna trecuta cand n-a mai pornit), masina achizitionata in Ian 2008. Cum erau cateva zile reci cu umezeala, ...."
a se citi:
"Pana acum o saptamana am avut bateria care a venit cu masina, baterie pe duca(concluzie data de teste si de iarna trecuta cand n-a mai pornit), masina achizitionata in Ian 2008. Astfel, tot de vreo 2 ani, cum erau cateva zile reci cu umezeala, imediat dupa pornire se zdruncina motorul aproape sa se opreasca, am patit asta chiar si in urma cu vreo 2-3 saptamani..."
Am uitat sa mentionez, am 82.000 km cu ea pana acum.
Cateodata, doar cateodata, inainte sa apara vibratiile, la iesirea din vreun sat cu era soseaua libera, din 50km/h viteza a 4-a, bagam a 3-a si acceleram pana in 6000 ture, schimbam a 4-a si acceleram iarasi pana in 5500/6000...asta de placerea sunetului scos de motor la turatii mari.
Toate vibratiile aparute sunt dupa cateva delegatii facute la Turnu Severin, cu trasee facute intre Severin si Orsova pe cand se lucra la drum, multe semafoare si decopertat asfaltul de se simtea ca mergi ca pe piatra cubica.
Am PDG, asa ca la unde nu-i asfalt se simt destul de bine hopurile in masina.
  • Marian a închis acest topic
