Probleme clima/climatronic
gmy
Am revenit cu scanarea:)
Tuesday,25,March,2014,18:42:12:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ5W023269   Mileage: 220110km/136770miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CD    HW: 028 101 194 5
   Component: R4 1,9L EDC G000SG  6246
   Revision: 12345678    Serial number: VWZ7Z0D0121845
   Coding: 0000072
   Shop #: WSC 01324 785 00200
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0021190
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 -  -
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000858001
   Coding: 01890F020004200000120C000000000000
   Part No: 1T0 955 119 C
   Component: Wischer VW358  012  0401
   Coding: 00065493
   Shop #: WSC 00000
3 Faults Found:
01064 - Terminal 58d; Interior Dimming
            012 - Electrical Fault in Circuit
00526 - Brake Light Switch-F
            008 - Implausible Signal - Intermittent
00988 - Lamp for Brake Light; Right (M10)
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 B    HW: 1T0 909 605 B
   Component: 02 AIRBAG VW62 0506 1400
   Revision: 07023000    Serial number: 0037SD0857YJ
   Coding: 0012338
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000042
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1T0 920 861 A
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003103
   Shop #: WSC 10900 264 12980
00003 - Control Module
            014 - Defective
Address 18: Aux. Heat        Labels: None
   Part No: 1K0 815 071 H
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
5 Faults Found:
00664 - Fuel gauge
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 131
                    Reset counter: 6
                    Mileage: 219567 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 26:45:28
01444 - Under-Voltage Shut-Off (Automatic)
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 6
                    Mileage: 219567 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 26:45:28
01410 - Heater Over-Temp
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 230
                    Mileage: 215261 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 29:32:48
             Freeze Frame:
                        OFF
                    Temperature: 158.0°C
                    Temperature: 66.0°C
01411 - Temperature Sensor (G18)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 0
                    Reset counter: 56
                    Mileage: 219956 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:25:39
             Freeze Frame:
                        Malfunction
                    Temperature: 205.0°C
                    Temperature: 69.0°C
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 56
                    Mileage: 219956 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:25:39
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 26001046070BB0
   Coding: 3D3F1340078002
01304 - Radio
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 61
                    Mileage: 188700 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:00:00
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO            VDD 0814
   Shop #: WSC 10105 599 10484
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0157
   Coding: 0000116
3 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00120 - Outside Warning Light/Door exit Light Driver Side
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.0       1401
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0201
   Coding: 00E800087F2D8404084F0100
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000116
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0201
   Coding: 0000048
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Component: Tuersteuergeraet 06 0214
   Coding: 0000048
End   ---------------------------------------------------------------------
Modificat de Extreme
Verifica cuplul absorbit de compresor in primele minute cand acesta nu baga rece.
  • 10 months later...
Salutare am facut azi o diagnoza si mi-a aratat o roare 01274 v71  Intrebare unde se afla motorasul respectiv si care este din cele 5 (am inteles ca trebuie dat jos torpedoul dar nu stiu care din cele 5 servomotoare este cel defect )Mentionez ca atunci cand a fost puse pe automat di tester sa lucre toate 4 mergeau bine numai ultimul parca caraia ceva rotite se forta ceva  merci
Ai mai pus odata aceeasi intrebare in alt topic. Crezi ca daca faci asta o sa iti răspundă cineva mai repede? Te rog citeste putin si tu regulamentul si vezi ce si cum e treaba aici pe forum
Avand radiatorul spart , l-am schimbat si am pus antigel iar dupa pornire nu mai da caldura . Mentionez ca am A.C. ,nu climatronic. Masina e un touran 2.0 tdi azv din 2004 . Care ar fi motivul pt care nu mai da caldura?
Modificat de herko_cristi
hmm.... fa o scanare sa vedem daca ai vreo eroare pe servomotoarele de la AC
in teorie, daca ai completat antigelul, instalatia se aeriseste... si nu ai de ce sa nu bage caldura
Si in vag com unde ar trebui sa fac o scanare pentru servomotarele de AC? In ce modul sa intru?
La mine in vag com am asa
Adresa 18: Încălzire staţionară        Eticheta: ROJ\1K0-815-007.clb
   Număr VAG: 1K0 815 007 R
   Componenta comandată: Standheizer     011 1403
   Revizie:        D    Numar serial: 09008375
   Codare: 0000112
   Atelier: WSC 01324 785 00200
   VCID: 336F743952D0C580ECE
5  coduri de defecte:
01411 - Senzor temperatura  -G18-
            010 - întrerupt sau scurt la plus - intermitent
             împrejurări cod:
                    Starea defectului: 00101010
                    Priorit.defectului: 0
                    Frecv. defectului: 1
                    Resetare contor: 76
                    rulaj: 215181 km
                    Indicator de timp: 0
                    Data: 2000.00.00
                    timp: 06:07:22
             împrejurări cod:
                        perturbare
                    temperatură: -50.0*C
                    temperatură: 34.0*C
01305 - Bus de date pentru Infotainment
            004 - lipsă semnal / nu comunică - intermitent
             împrejurări cod:
                    Starea defectului: 00100100
                    Frecv. defectului: 9
                    Resetare contor: 93
                    rulaj: 298651 km
                    Data: 2000.00.00
                    timp: 09:24:36
00664 - Indicator nivel combustibil
            002 - limita inferioară depăsită - intermitent
             împrejurări cod:
                    Starea defectului: 00100010
                    Frecv. defectului: 194
                    Resetare contor: 86
                    rulaj: 215336 km
                    Data: 2000.00.00
                    timp: 19:22:13
02251 - Unitate de încalzire blocata
            000 - - - intermitent
             împrejurări cod:
                    Resetare contor: 86
                    rulaj: 215336 km
                    Data: 2000.00.00
                    timp: 19:22:13
01415 - Pompa recirculare lichid racire -V55-
             împrejurări cod:
                    Resetare contor: 63
                    rulaj: 309054 km
                    Data: 2000.00.00
                    timp: 20:11:15
             împrejurări cod:
                        Dec.
                    temperatură: 0.0*C
                    temperatură: 0.0*C
da, intra pe AutoHvac
Salutare, am si eu o problema cu climatronicul. La 22 grade afara pe partea soferului baga aer rece(normal) iar pe partea pasagerului vine aer cald chiar fierbinte. Sa mor de inima nu alta pentru ca abia am schimbat webasto si acu alta belea. Rog daca stie cineva la ce sa ma astept pana merg la un tester(dupa Paste). Multumesc si sarbatori frumoase.
Multumesc d-le Al Bundi, trebuie demontat tot bordul sau doar torpedoul pentru a ajunge la el ?
LA turan nu stiu pe de rost, la G5 nu trebuie dat jos decat torpedoul./
nu trebuie demonta tot bordul... cu ceva indemanare, ajungi la el pe dedesubt.
Salutare. Azi am fost pe tester si am gasit codul de eroare; 0712-servomotor amestec aer dreapta. Ajuns acasa am demontat torpedoul deoarece baiatul de acolo e foarte ocupat si nu are timp de asa ceva momentan;(programare, etc) si nici nu am primit un raspuns exact ce e defect. Am demontat cele 2 motorase ce deschid si inchid 2 clapete pe ventilatorul de aer(documentat de pe forum) si culmea, functioneaza perfect(dau pe LO se duc in stanga dau pe HI se duc in dreapta).Le-am mai pus putina vaselina, le-am montat si i-si fac treaba. Voi a-ti spus de un v-159 dar care o fi si pe unde....In continuare fres pe stinga fierbinte pe dreapta. Nu ma duc la reprezentanta ca aia schimba tot bordul si cred cu ajutorul vostru sa rezolv problema.  :icon_bounce:
Am rezolvat problema cu servomotorasul v159 .In sfarsit l-am gasit. Pe scurt, se demonteaza torpedoul frigorific(6 suruburi torx 15) se scoate furtunul,mufa iluminare si mufa airbag.Se demonteaza tubulatura ce duce la picioare(un surub t-15) si in partea stanga langa furtunul care conduce aer in torpedou se afla acest motoras prins in 3 suruburi M6. Se demonteaza mufa iar la scoatere se roteste inspre motor pentru ai permite parghiei declipsarea. Ajuns cu el pe masa l-am demontat si am constatat ca motorasul era intepenit. Am invartit stanga, dreapta, suflat cu aer, montat la loc...FUNCTIONEAZA . Recomand ca pe timpul iernii sa se mai dea din cand in cand pe LO sa nu intepeneasca aceste motorase si invers. Spor la treaba, nu dureaza mai mult de o ora.
din pacate exista si f. multe cazuri cand cedeaza rotitele dintate... si greu de gasit/confectionat
           Buna ziua. am si eu o problema cu clima la un vw touran 1.9 tdi..cand dau pe LO nu imi da aer rece..am scanat cu vag-com-ul si imi spune urmatoarea eroare(am cautat pe internet si nu gasesc nici o explicatie) :
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105615020B
   Coding: 3F3F53C0078002
   VCID: 2A5D72EA8588434EEA7-807F
01207 - Control Module for Auxiliary Heater (J364)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Reset counter: 58
                    Mileage: 185812 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:21:24
UIte aici ai si tu erorile pe care le ai postate.Cauta si tu ca nu e greu
F l o r i n
nu are nicio legatura cu problema ta - eroarea asta e ca nu comunica cu webasto.
trebuie verificat in blocurile de masura, ce sa intampla acolo.... servomotoarele cum lucreaza, senzori, etc. Verifica daca ai presiune de freon, daca merge ventilatoarele, etc
herko_cristi
cine poate sa ma ajute in legatura ca nu imi baga caldura deloc . tevile de la calorifer sunt fierbinti amandoua , dar la ventilatie baga aer rece. este vreo clapeta inchisa ceva?
in cele din urma merge pe Lo climatronicul...cam greu, dureaza mai mult decat ma asteptam pana sa imi bage aer rece( posibil sa aiba putin freon in instalatie?) ...dar te rog sa ma lamuresti ce este acel webasto ?  multumesc
P.S.  de ce cand scanez cu vag.com-ul la masina mea (vw golf4) nu reuseste sa gaseasca Steering wheel  (servodirectia) ...in schimb pe un vw touran cand am scanat a gasit servodirectia si imi spunea daca e o problema sau e ok.. precizez ca volanul mi se pare ca se misca destul de greu prin parcari fata de multe alte masini.. (p.s.2 ...   am observat ca nu am nici bec( martor) in bord pt servodirectie cu toate ca masina e din 2001 si ar fi trebuit sa aiba)
Modificat de B-dorin
Webasto este pentru incalzirea auxiliara pe timp rece. Adica de la 5 grade in jos porneste automat, incalzeste apa si se opreste cand aceasta ajunge la 80 grade. Nu are nici o legatura cu climatronicul. Verifica freonul si ventilatoarele.In cel mai rau caz supapa de la compresor.
Aici trebuie sa iti discuti tu problema.Foloseste functia search te rog
