zorg
Recommended Posts
Agilu`
Caz clasic, s-a aprins check-ul. Dupa o scanare cu vcds-ul, au aparut erorile atasate.
Masina in cauza este in Seat Leon 5f, 1.6tdi, crkb.
Din cate am citit pe forumuri, ar fi de vina sensorul de presiune  diferentiala al dpf-ului.
Intrebarea 1: cum aflu care din cele doua este cel cu pricina?
Intrebarea 2: ce producator este recomandat pt schimbarea sensorului?
Intrrbarea 3: se face adaptarea sensorului cu vcds-ul, dupa schimbare?
Merci anticipat pt raspunsuri!
Share this post
Link to post
Share on other sites
tanku
salutare, ma poate ajuta cineva cu erorile astea
00931 - Locking Module for Central Locking; Rear Right (F223)
            008 - Implausible Signal - Intermittent
00935 - Electric Window Motor; Rear Right (V27)
01488 - Sensor for Coolant Temperature; Aux. Heating (G241)
            010 - Open or Short to Plus - Intermittent
multumesc...
Share this post
Link to post
spido
Cablaj usa spate dreapta deteriorat,senzor temperatura circuit incalzire auxiliar de inlocuit.
Share this post
Link to post
robertinho3100
Am un Golf 7 GTD si am facut o scanare pentru ca vreau sa rezolv problema cu caldura (nu baga cald pe partea dreapta) si cand am scana am primti urmatoarele erori:
                Address 08: Auto HVAC       Labels: 5G0-907-044.CLB
Control Module Part Number: 5G0 907 044 AN    HW: 5G0 907 044 AN
  Component and/or Version: Climatronic   H03 0907
           Software Coding: 00020114202400011105000200101000
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_ACClimaBHBVW37X 003018 (VW37)
                       ROD: EV_ACClimaBHBVW37X_003_VW37.rod
                      VCID: 73E45CCFDAD934D9E4-8026
2 Faults Found:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 119434 km
                    Date: 2020.07.08
                    Time: 20:42:01
                    Voltage terminal 30: 11.2 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
                    Auxiliary heater: in stages-Act.value: 1
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 119434 km
                    Date: 2020.07.08
                    Time: 20:46:42
                    Voltage terminal 30: 13.8 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Am sters erorile si mi-a ramas doar "1048835 - Functionality limited due to Engine Control Module". Dupa aia am facut un test la motorasele de la clima si nu am primit nicio eroarea in plus, am ramas doar cu "1048835 - Functionality limited due to Engine Control Module", ceea ce tind sa cred ca merg bine atata timp cat e doar prima eroare si nu am alta in plus. M-am uitat si la ce temperaturi arata VCDS-ul pe partea de incalzire si imi zice ca pe partea stanga imi baga aerul cu 64.7 grade si pe partea dreapta cu greu am ajuns la 47.3 grade. Orice sfat/sugestie este bine primita.
Multumesc frumos!
Edited by robertinho3100
Share this post
Link to post
spido
Pe 01 engine ai erori? Functiile climatronic sunt limitate de Ecu.
Share this post
Link to post
EEXCALADE
“Voltage terminal 30: 11.2 V “
Verifica baterie/alternator.
Share this post
Link to post
robertinho3100
Pe engine nu am nicio eroare. In legatura cu bateria, m-am uitat cu VCDS-ul si la baterie si era 11.2V cand aveam contactul pus si cand o porneam sarea la 14.2V.
Nu stiu daca asta are legatura si cu pornirea ca daca o las 2 zile nepornita pleaca greu si bujiile sunt schimbate de vreo 3 luni.
Share this post
Link to post
spido
Asta era cu motorul oprit. La 5 min dupa pornire,are 13.8. Fa si un test al bateriei..posibil sa fie pe duca...
Share this post
Link to post
robertinho3100
Multumesc. O sa mai fac un test la baterie si alternator sa vedem.
Share this post
Link to post
dcpavelescu
aveti idee care ar putea fi cauza?
  • nivelul uleiului DSG-6 este okay, schimbat recent la reprezentanta la 180k (eroarea o aveam inainte de schimb)
  • mi-au zis ca au facut adaptare dupa schimb ulei
  • eroarea reapare dupa stergere (evident problema nu e rezolvata)
  • nu se aprinde niciun martor in bord, masina functioneaza normal
  • mi s-a recomandat "spalare instalatie racire" (nu stiu daca are vreo legatura)
  • la service mi-au zis ca nu pot zice mai exact care e problema ca nu se pricep si maxim pot inlocui mecatronic DSG
Multumesc,
Daniel
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3128
   Revision: 05551213    Serial number: 00001112211338
   Coding: 0000020
   Shop #: WSC 05311 000 00000
   VCID: 2643439F91E704B651-8072
17252 - Transmission Fluid Pressure Adaptation at Limit
            P0868 - 001 -
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 2
                    Mileage: 183686 km
                    Time Indication: 0
                    Date: 2014.11.17
                    Time: 12:03:37
Share this post
Link to post
spido
Daca uleiul este 100% inlocuit, se poate incerca un BS. Daca eroarea persista, se va ajunge la inlocuire mecatronic.Atentie! Daca BS esueaza sau nu o duce pina la capat, masina poate ramane imobilizata.
Share this post
Link to post
spido
Da,asta e procedura. In mod normal ar trebui facuta de service dupa inlocuire ulei.La asta se refera..
Share this post
Link to post
EEXCALADE
Conform elsawin procedura nu are nici o legatura cu inlocuirea uleiului.
Din experienta pot spune ca nu face nimic sau face mai rau (daca nu e facuta dupa inlocuire mecatronic/hub)
Share this post
Link to post
spido
Salut Catalin.Eu am patit cu un CC care a ramas imobilizat in urma BS. Avea aceeasi eroare...dupa BS..pe care l-a facut,nu mai mergea decat inapoi. Mers inainte intra in avarie si nu se mai clintea de pe loc.
Share this post
Link to post
EEXCALADE
Cand sunt probleme/erori merita incercata procedura ,altfel nu-i vad rostul.
Share this post
Link to post
F l o r i n
setare de baza la o cutie cu probleme, uzuri discuri, etc, poate cauza mai multe probleme. Oamenii cred ca acesta rezolva problemele mecanice.....din pacate,nu.
Share this post
Link to post
kicker
salutare,
am aceste erori la  un passat b8
Sunday,12,July,2020,18:37:11:36843
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ3CZGP018400   License Plate: B
                Address 02: Auto Trans       Labels: 0D9-927-770.clb
Control Module Part Number: 0D9 300 041 J    HW: 02E 927 770 AQ
  Component and/or Version: DQ250-6F MQB  H53 4906
           Software Coding: 0014
            Work Shop Code: WSC 00028 028 00024
              ASAM Dataset: EV_TCMDQ250021 001001 (VW48)
                       ROD: EV_TCMDQ250021.rod
                      VCID: 1F0EFB250632377E12-804A
4 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
          Intermittent - Not Confirmed - Tested Since Memory Clear
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
cutia schimba perfect dar erorile persista
Share this post
Link to post
promteu_2000
Salutare lume,
am un Sharan 2.0 TDI 2006, BRT. Dupa un drum de 80 de km s-a aprins spira de la bujii, pe display a aparut mwsajun Engine Workshop. Dupa o testare rapida au rezultat urmatoarele erori:
Sunday,12,July,2020,19:16:31:00005
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ7MZ6V017218   License Plate: NHJCH
Mileage: 258570km-160667mi   Repair Order:
Chassis Type: 7M (7M - VW Sharan (1996 > 2010))
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 35 36 37 39 45 55 56
          76
VIN: WVWZZZ7MZ6V017218   Mileage: 258570km-160667miles
Address 25: Immobilizer        Labels: 7M3-953-257.lbl
   Part No: 7M3 953 257
   Component: IMMO                0008
   Coding: 00003
   Shop #: WSC 00000
   VCID: 76E2DE4452C738F6A0-4B32
   WVWZZZ7MZ6V017218     VWZ1Z0E2828764
No fault code found.
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 03G 906 016 JP    HW:
   Component: R4 2,0L EDC G000SG  8350
   Revision: --H01---    Serial number: VWZ1Z0E2828764
   Coding: 0000072
   Shop #: WSC 49428 001 1048576
   VCID: 7AFACA7436DF5C96C4-515A
3 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 258195 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.32 V
                    Bin. Bits: 11001100
                    Temperature: 22.5°C
                    Bin. Bits: 00110000
012545 - Motor for Intake Manifold Flap (V157)
               P3101 - 000 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 258385 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.91 V
                    Bin. Bits: 11001000
                    Torque: 180.6 Nm
                    Torque: 0.0 Nm
012401 - Reservoir for Additive for Particle Filter
               P3071 - 000 - Empty - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 258556 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 2520 /min
                    Speed: 118.0 km/h
                    (no units): 0.0
                    (no units): 534.0
                    (no units): 534.0
                    (no units): 12.09
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 7M3-907-37x-ESP-F.clb
   Part No: 7M3 907 379 E
   Component: ESP FRONT MK25      0102
   Coding: 0006154
   Shop #: WSC 00020 000 00000
   VCID: 3F8C7B606D7DB9BEB3-515A
Address 08: Auto HVAC        Labels: 7M3-907-040.clb
   Part No: 7M3 907 040 J
   Component: CLIMATRONIC MPV GP  0007
   Coding: 00011
   Shop #: WSC 00020
   VCID: 356019480F4173EE69-259E
Address 09: Cent. Elect.        Labels: None
   Part No: 7M3 962 258 AM
   Component:    Multifunkt.Einh  0003
   Coding: 16411
   Shop #: WSC 62901
   VCID: 0500A9881F21236EB9-50C8
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 F
   Component: 2G AIRBAG VW61 0Q0M 0003
   Coding: 12871
   Shop #: WSC 00020
   VCID: 275CC300C5ED117EEB-515A
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 D
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 00020
   VCID: 326A2254FE2F64D64C-5178
Address 17: Instruments        Labels: 7Mx-920-xxx-17.lbl
   Part No: 7M3 920 841
   Component: KOMBIINSTRUMENT VDO V64
   Coding: 29111
   Shop #: WSC 00006
   VCID: 6FECEB202D9D093E63-513C
Address 18: Aux. Heat        Labels: 7M3-815-071.clb
   Part No: 7M3 815 071 C
   Component: HEIZG. B/D5W       0001
   VCID: 306E285CF02356C63A-5196
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00020
   VCID: 70EEE85C30A316C67A-513C
Address 37: Navigation        Labels: 3B0-919-887.lbl
   Part No: 1J0 919 887 A
   Component: Navigation     BNO 0106
   Coding: 00000
   Shop #: WSC 01271
   VCID: 36621E44124778F660-4B00
Address 56: Radio        Labels: 3B0-035-186.lbl
   Part No: 1J0 035 152 G
   Component: Radio          BNO 0106
   Coding: 01405
   Shop #: WSC 01271
   VCID: 224AD214AECFF456BC-4B00
Address 76: Park Assist        Labels: 7M3-919-283.clb
   Part No: 7M3 919 283
   Component: Parkingsyst. SH RDW D02
   Coding: 00117
   Shop #: WSC 00020
   VCID: 77FCD34055CD41FEBB-5178
4 Faults Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
            37-00 - Faulty
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            37-00 - Faulty
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            37-00 - Faulty
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
            30-10 - Open or Short to Plus - Intermittent
End-------------------------(Elapsed Time: 04:14)--------------------------
Ma poate lamurii cineva, de unde pana unde imi spune ca rezervorul de adblue e gol? Eu stiu ca nu am asa ceva.Va multumesc anticipat @
Share this post
Link to post
spido
Fa diagnoza cu o interfata ok. Asta e pe campii...
Share this post
Link to post
vlahdacoroman
kicker ai probleme la valve sau mecatronic...eu as merge pe mecatronic direct.
Edited by vlahdacoroman
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    No registered users viewing this page.
Important Information
Acest site folosește cookie-uri. Continuarea navigării reprezintă acceptul dvs. pentru această folosință. Pentru mai multe detalii privind gestionarea preferințelor privind cookie-uri, vedeți Politica de utillizare cookie-uri
