Setări VCDS Superb 3
Liviu_sbn
Stiati ca: Se pot schimba becurile de la torpedou, portbagaj, portiere, stopuri spate cu altele pe led? Iluminarea normal in torpedo/portbagaj este galcuie, daca pui led se face ziua instant. Pentru torpedo nu as recomanda schimbarea deoarece noapte te orbeste :))
Gasiti pe E-bay: "50w or 80w CREE Canbus bulbs on amber and white for reversing and indicator bulbs. The fog lights are a LED headlight conversion kit for H8 fixtures - very bright and good for cornering but a bit pricey too" Multumiri celor de pe Briskoda Forum
Stiati ca: "Purple (or any custom colour) can be achived via VCDS? You can assign custom RGB colour (3x 255 values) to existing presets. I changed "warm white" preset to purple. On screen there is still label "warm white". " End of quote. Atasata o poza, am gasit multe informatii utile pe briskoda forum. Am gasit si diferite poze cu culorile masinii in realitate.
@Liviu_sbn am deschis eu topicul, te rog ataseaza tu din nou pozele.
Ms frumos loghy, dar e singura chestie pe care am aflat-o in legatura cu VCDS. Sper sa mai fie si altii care posteaza in legatura cu asta. Zicea un coleg sa facem un topic de tips and Tricks ca sa punem diverse postari de tips... Voi stiti mai bine oricum cum merge treaba.
Ms frumos inca o data!
Am gasit cateva lucruri pe BRISKODA foarte interesante pe care le puteti imbunatati la S3 cu ajutorul VCDS:
Superb MKIII VCDS Adaptations - tried and tested: http://www.briskoda.net/forums/topic/380829-superb-mkiii-vcds-adaptations-tried-and-tested/
 - Enabling refuel quantity in the maxidot
 - Enabling rear lights with DRLs (Daytime Running Lights)
 - Enabling DRLs menu in the MIB2
 - Changing the upper speed threshold for cornering fogs (pana la max 60 km/h)
 - Enabling fan (blower) speed display in AUTO mode
 - Heated seat level memory
 - Permanently Disable Start-Stop
 - Enabling Traffic Sign Recognition on models with Lane Assist
 - Driving mode display on maxidot
 - Enabling automatic door locking
 - Disable tailgate beep
 - Customize color of ambient lighting
 - Automatically change clock to summertime
 - Trailer activation (INCA NU AM INTELES CE FACE FUNCTIA ACEASTA)
 - Activate ASR/ECS/Sport in Menu
Tot ce va ramane de facut este sa va cumparati un VCDS sau sa gasiti pe cineva care detine asa ceva. Inca nu am gasit cum sa se inchida portbagajul din butonul de pe consola central din masina, proabil inca lucreaza la asta oamenii...
Asta cu Permanently Dismantle Start-Stop e preferata mea :)
Bun postul, multumim de contributie.
Da, fiecare isi allege ce-i place sa schimbe. E bine ca se poate. Am uitat sa precizez sa cititi cu atentie primul post in care se precizeaza clar ce tip de software sa se foloseasca, altfel, daca faceti modificarile cu un software ne-upgradat la versiunea curenta, veti pierde functii din meniu. Se precizeaza acolo care e ultimul software care e compatibil cu MIB2.
In plus, este musai sa nu se foloseasca decat cabluri originale, altfel riscati acelasi lucru. In concluzie, cititi cu atentie primul post! ;)
  • kthor changed the title to Setări VCDS Superb 3
  • 7 months later...
Am facut si eu ceva modificari si as preciza faptul ca la modalitatea de activare ch/lh pe proiectoare in loc de faza scurta m-am lovit de nedumeriri si nu a fost chiar ca in descrierile de pe Briskoda (masina fiind MY17 probabil difera anumite chestii).
Singurul lucru modificat a fost cel din pozele de mai jos, nereusind sa urmez pasii de pe Briskoda pentru ca nu coincideau optiunile pe care le aveam in controller-ele masinii.
De altfel in ultima poza am pus o functie gasita intamplator. Nu am avut timp sa mai testez si sa vad ce/cum functioneaza, dar poate ajuta pe cineva. O sa testez cand o sa am timp si asta. Banuiesc ca e noul mod de a dezactiva start/stop pe MY17. Fara alte modificari de parametri. Din denumire as spune ca se bazeaza pe "inversarea" butonului start/stop, adica atunci cand pornesti masina sa fie deja oprit sistemul si sa apesi pe buton ca sa-l pornesti daca vrei.
@RzzV: fix asta e prima modificare pe care vreau sa o fac, chiar de la livrare. Mersi mult :)
Legat de Trailer Activation pot sa va spun eu ce face cand e activa (am carlig de remorcare OEM si pe fabia si pe superb)
Atunci cand cuplez platforma in spate (ptr biciclete), se activeaza acest mod care:
- dezactiveaza senzorii parcare spate (cand bagi in marsarie afiseaza o rulota legata de masina - vazuta de sus)
- dezactiveaza modul eco (daca exista) si te duce in normal
- apare un al doilea led de semnalizare, pe langa cele clasice stanga-dreapta
- pe fabia se dezactiveaza functia start-stop. Pe Superb vad ca functioneaza in continuare...
 Enabling rear lights with DRLs (Daytime Running Lights) - Asta mi se pare tare de tot. As vrea si eu ...
Scuzati intrebarea... am tot cautat, dar nu am gasit...
Cum conectati un laptop la VCDS? Nu inteleg cum se poate accesa VCDS.
Din nou... presupun ca e o intrebare supida... dar chiar nu am reusit sa imi dau seama.
@mishou VCDS se numeste interfata cu care se acceseaza sistemele masinii. Dupa ce cumperi interfata, o conectezi la USB la un calculator, instalezi softul de pe site-ul lor si enjoy. Asta puteai gasi foarte usor cu o simpla cautare pe gogu.
@RzzV Wow! Cablul respectiv + licenta la software... $349.00
Modificat de mishou
in Romania undeva la 1600 lei. Il poti contacta pe Dragos Voinea (taticul acestui forum), este distribuitor autorizat.
@RzzV + All : a incercat cineva sa activeze "Performance Monitor" ?
E standard pe SportLine
Eu n-am incercat, nu am vazut nicaieri unde/cum s-ar activa.
Nu cred ca se poate deoarece iti trebuie un senzor de miscare ptr G force.
Exista in schimb aplicatia Performance in Appstore si impreuna cu Smartgate iti afiseaza pe ecranul iphone/ipad.
Eu mi-am pus si e fun; iti inregistreaza si lap time cu viteza, per de franare, % putere etc
Senzorul G force este in modulul de ABS.
@75NOR Te poti uita singur pe net: aplicatiile pe care le poti folosi cu SmartGate sunt urmatoarele:
- G-Meter - o fantezie de aplicatie, nu iti e de folos la nimic, nici macar nu o sa o deschizi mai mult decat prima data cand o folosesti (ca sa vezi cum e)
- MFA Pro - asta iti ofera ceva date utile oarecum, poate singura care merita deschisa dintre toate
- Performance - la fel de inutila ca prima: o sa te uiti pe ea de doua trei ori dupa care o sa o poti sterge
- LittleDriver - un fel de joc stupid, nu il vei folosi probabil pana la final nici prima data, e pentru copii de 5 ani dpmdv
- Drive - la fel de util ca Performance
- Motorsound - se conecteaza la masina si in functie de turatia motorului, imita diferite tipuri de sunete "sport" ale evacuarii/motorului (sunete care sunt redate de difuzorul telefonului, si sunt penibile). Probabil cu aplicatia asta s-a vrut imitarea difuzorului de pe evacuare de la modelele GTD, sau altele pe care se mai pune asa ceva. Practic, e penibila aplicatia pentru 2016, era buna pe vremea cand ne jucam NFS prin anii ~2000.
Mai multe detalii despre aplicatiile astea gasesti pe net. Ce am prezentat mai sus sunt toate aplicatiile pe care ti le aduce SmartGate. Practic, bani aruncati...
P.S. Rog un moderator sa mute postul in Discutii generale Superb, se incadreaza mai bine acolo discutiile despre SmartGate, dar am raspuns aici colegului @75NOR
Modificat de RzzV
Stiti cumva, daca aceste activari/modificari afecteaza garantia?
Daca apare o problema la vreunul dintre modulele pe care ai umblat sau care are legatura cu el, pot invoca cei din service asta, desi poti foarte bine sa pui inapoi codarea initiala inainte sa mergi cu ea in service. Altfel, nu va sta nimeni sa iti caute tie codari si sa le compare cu cele initiale ale masinii la fiecare vizita in service. In rest, nu au legatura cu garantia pe motor de exemplu, cutie de viteze, anticoroziune, sau alte lucruri care nu au legatura cu codarile in sine.
Mi-a venit acum 4 zile masina si m-ar interesa sa stiu daca se gasesc coduri pentru semnalizari dinamice (dynamic turning signal) gen Audi si poate alte coduri gen oglinzile sa coboare in marsarier sau alte trick-uri.
Stiti ceva despre asta?
Ms
Ti-am mutat postul aici. Data viitoare, cu putina atentie, sunt convins ca o postezi unde trebuie.
Ps: sa o stapanesti sanatos.:icon_thumright:
Semnalizari dinamice nu cred ca suporta LED-urile montate pe semnalizare pe masina, nu e doar chestiune de codare.
Oglinda in marsarier - scria in manual cum se seteaza
@75NOR se poate seta oglinda din dreapta doar la masinile cu scaun sofer cu memorie. Eu de exemplu nu o pot face sa coboare.
