Ceasuri noi Polo 9N3
astratc
daca in urma verificarilor/diagnozelor pe care le-ai facut, a rezultat ca este din ceasuri... atunci, schimba ceasurile.
Asa mi se comporta masina:
Acum nu mai porneste, am schimbat o siguranta arsa de la baterie.. cea din mijloc insa cea care era inainte nu avea nimic inscriptionat pe ea. Puteti sa-mi spuneti va rog de cati amp. trebuie sa fie ?
Am aici atasate si erorile care imi apar in urma scanarii
VCDS Version: Release 15.7.3 Running on Windows 7 x86
Data version: 20151216
www.Ross-Tech.com
Monday,11,January,2016,15:27:35:44410
Chassis Type: 9N - VW Polo (2002 > 2010)
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
Address 01: Engine        Labels: 03E-906-033-AZQ.lbl
   Part No: 03E 906 033 L
   Component: 1.2l/4V SIMOS3  00HS4726
   Coding: 00031
   Shop #: WSC 31414
   VCID: 2959073DD354587606-5122
   WVWZZZ9NZ3D124459     VWZ7Z0B6410285
6 Faults Found:
18057 - Powertrain Data Bus
            P1649 - 35-00 - Missing Message from ABS Controller
18044 - Powertrain Data Bus
            P1636 - 35-00 - Missing Message from Airbag Controller
18058 - Powertrain Data Bus
            P1650 - 35-00 - Missing Message from Instrument Cluster
18045 - Powertrain Data Bus
            P1637 - 35-00 - Missing Message from Electric Load Controller
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-00 -
18018 - Internal Control Module
            P1610 - 35-00 - Memory Check Sum Error
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ABS2.lbl
   Part No: 6Q0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0001097
   Shop #: WSC 31414 000 00000
   VCID: 4683AC81320A970E0B-5104
3 Faults Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
01312 - Powertrain Data Bus
            014 - Defective
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 25742
   Shop #: WSC 31414
   VCID: 3B75CD7529C8DAE664-5104
7 Faults Found:
01598 - Drive Battery Voltage
            07-00 - Signal too Low
01309 - Power Steering Control Module (J500)
            49-00 - No Communications
01317 - Control Module in Instrument Cluster (J285)
01321 - Control Module for Airbags (J234)
01316 - ABS Control Module
            37-00 - Faulty
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 09 GATEWAY  CAN    1S33
   Coding: 00014
   Shop #: WSC 31414
   VCID: 70EF2A59300E69BE81-5104
6 Faults Found:
            37-00 - Faulty
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6Q0 423 156 R
   Component: LenkhilfeKYO        V913
   Coding: 10120
   Shop #: WSC 31414
   VCID: 3E73C4613ADACFCE43-5104
5 Faults Found:
            37-00 - Faulty
            79-00 - Please Check Fault Codes
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 H
   Component: 1G Komfortgerát     0002
   Coding: 00067
   Shop #: WSC 31414
   VCID: 408FBA99402EB93E31-4ACC
   Subsystem 1 - Part No: 6Q2959802A
   Component: 1G Tőrsteuer.FS TFK 0004
   Subsystem 2 - Part No: 6Q2959801A
   Component: 1G Tőrsteuer.BF TFK 0004
No fault code found.
End-------------------------(Elapsed Time: 03:33)--------------------------
Modificat de alyn21
Ceasurile nu apar la scanare... deci, trebuie vazut ce e cu ele - eventual inlocuite, daca nu merg reparate.
Salut. Am găsit problema. Am sa revin de pe laptop cu un printscreen și sa va spun care era buba defapt. Mulțumesc.
Salut. Revin ceva mai târziu cu detalii despre problema mea. Menționez că sunt ,alyn21,
După ce am pus nenumărate testere si problema părea că e din ceasuri, am fost la băiat cu diagnoza caruia i-am luat nr. de pe net si după ce a umblat o săptămână la ea mi-a descoperit problema si a fost nevoit să tragă un fir de la calculator la nu stiu ce alt calculator, motivul fiind lipsa semnalului. Mi-a explicat mai în detaliu dar nu prea am înțeles. Ideea e ca au trecut aproape două luni și nu am mai avut absolut nicio problemă cu pornirea zi erorile în bord. Am aflat ulterior ca mașina avea probleme de mult, dinainte să o achizitionez.
Acum revin cu ceva nou:
Am apa in Masina. Menționez că am trapa si dupa ce am dus-u la cineva mi-a dat plafonu jos și a umblat la furtunasele de scurgere pe motiv că erau înfundate. Dar tot continuă să îmi între apa in Masina. Scuze daca fac offtopic dar nu am putut crea unul nou.
Mulțumesc mult pentru toate sfaturile acordate până acum.
  • 9 years later...
Salut, am niste ceasuri de vw polo 9n 2006-2007 si vreau sa le pun pe vw polo 2003, stie cineva cum pot citi ceasurile ca sa aflu codul pin?, am diagnoza vag KKL dar nu ma lasa sa citesc epromul pe ceasurile 2006-2007, pe ceasurile mașini din 2003 ma lasă.
