Navigation maps
Not_used_calin
Mersi frumos, m-am linistit cu Navigatia, ii fac acum update-ul. Cu update-ul de software va trebui sa-mi fac evident o programare la reprezentanta.
CarPlay/MirrorLink au nevoie de procesorul Tegra prezent pe MIB2.
Necesita fie coduri de activare, fie rescrierea softului (accesand memoria interna printr-o interfata serial->usb, atasata placii interne), fie la reprezentanta.
Modificat de C Z R
On 28.01.2016 at 9:34, skodita100 a scris:
Deci nu merge cu orice sd card . Trebuie folosit NUMAI sdcardul original al masinii . Se pare ca nu merge nici un alt card original dar folosit deja anterior la alta masina . Ori cel al masinii ori altul nou nout ...  .
Discover navigation updates
We are pleased to be able to inform you that our Product Marketing Team has announced the process for navigation updates to be downloaded to The New Golf. As you are aware, the vehicle is supplied with navigation data pre-loaded on an SD card. This card has seven licences built in; the first licence is used by the pre-existing data on the unit. This allows our customers to download 6 updates over a three year period.
You can check the data version in your vehicle by selecting menu and then setup on the navigation system in your vehicle. The latest version available to download is shown on the following website:
http://www.volkswagen.de/de/models/g...n-updates.html
If an update is available, it can be downloaded via www.navigation.com select your manufacturer and follow the onscreen prompts. When you have exhausted your free downloads, you can purchase a new SD card from your local Volkswagen Retailer or pay for individual downloads via the site.
Thank you for contacting Volkswagen UK.
Salut sunt nou pe aici ma puteți ajuta și pe mine? Am cumpărat un golf 7 din Germania e din 2013 luna 10 și nu știu cum sa îmi fac sa îmi meargă navigație..
Salut, incep prin a te intreba daca ai Navigatie? Daca ai, apesi butonul dedicat din dreapta sus: NAV. Daca nu ai buton dedicat, inseamna ca nu ai navigatie si-ti recomand sa cauti pe forumul de Golf 7 Retrofit, o sa gasesti acolo ce ai nevoie sa pui navigatie sau daca se poate.
Sa o stapanesti cu placere!! Fa-i si o descriere in "Masina mea".
Pentru colegii care întâmpină probleme la upgrade-ul HĂRȚILOR pe HU Discover Pro o să postez aici explicații exacte cu procedura de update .
1. Aveți nevoie de un SD CARD de minim 32 Gb clasa 10 (nou sau folosit) pe care va trebui să-l formatați NTFS (NU CU QUICK FORMAT) .
2. După ce a-ți terminat de formatat cardul va trebui să descărcați ultimul update din link-ul pus de mine pe prima pagină sau să căutați cu google asa " VW PASSAT 3G DISCOVER PRO MAP UPGRADE " .
Este al doilea link .
Va selectați din partea stânga (în acel pătrat gri) a paginii modelul dvs Vw și tipul HU
3. Descărcați arhiva integrală (cea de 23 Gb pentru HU Discover Pro - 2017) după care o dezarhivați cu programul 7-Zip .
4. După dezarhivare copiați în rădăcina cardului ceea ce găsiți în folderul format la dezarhivare ( ATENȚIE - NU COPIAȚI FOLDERUL CU TOTUL CI DOAR CONȚINUTUL LUI) .
5. Mergeți la mașină o porniți după care băgați cardul în slotul nr. 2 ( cel din dreapta ) după care mergeți la navigație > setări > sistem information > și apăsați pe UPDATE SOFTWARE .
DISCOVER PRO va începe sa caute dacă sunt update-uri după care vă va cere acordul pentru instalare .
Dați OK și va trebui să așteptați cam 45 de minute .
După terminare va trebui să reporniți HU sau să închideți mașina și să o redeschideți după circa 10 -15 min .
NU AM ÎNCERCAT CU STICK USB.
Modificat de loghy
alexandrupaul
Am incercat cu stick usb. (MIB 1). Merge fara probleme. Dupa ce dezarhivati copiati continutul folderului dezarhivat direct pe stick. Daca puneti direct folderul nu recunoaste updateul.
Știe cineva dacă se poate folosi și un card SDXC ?
As vrea sa iau un SDXC 64GB Speed Class 10 cu UHS-I Speed Class 3 și nu știu dacă este compatibil la fel ca un SDHC class 10.
Intre timp am mai descoperit "lucruri" si se pare ca nu tot ce spune VW e litera de lege .
Pentru Discovery Media (MIB I si MIB II)  se poate folosi un sdcard de la o masina la alta (MIB I la MIB I respectiv MIB II la MIB II) si ... normal se poate folosi si orice sdcard cu doua conditii - una e sa aiba capacitatea de stocare atat cat e nevoie sa incapa hartile .
Modificat de skodita100
Salutare, am descarcat arhiva de 23GB indicata de colegul @DRI@N. Acolo sunt 2 foldere MIB 1 si MIB 2, respectiv un .txt metainfo2 si un fisier .md5 P157_N.....
Eu pentru Golf 7 din 09/2013 cu discover PRO trebuie sa iau doar continutul din folderul MIB 1 sa il pun pe cardul SD? Dar fisierele .txt metainfo2 si .md5 P157_N..... care sunt direct in arhiva? Vad ca fisierul txt este si el in folderul Mib1, insa .md5 nu este.
Nu am inteles prea bine ce se discuta de "cardul masinii", cand am luat masina nu era nici un SD in masina....pot folosi orice card cum a deschis colegul mai sus, de 32GB clasa 10?
Masina are si slot de SIM intre cele 2 carduri, pot vedea google maps pe navi sau se foloseste sim-ul doar pentru hotspot wifi? Eventual cu update de soft la discover pro ar merge google maps?
@Luke am urmat exact pasii indicati de @DRI@N , am descarcat MIB 1 pe laptop, am copiat TOT continutul folderului pe un SD Card, l-am bagat in SD slot 2 de la masina din torpedou, si am urmat instructiunile de mai sus pentru a incepe descarcarea. A mers totul ca uns.
Precizez ca a trebuit sa ma plimb cu masina aproximativ 2 ore pana a terminat de instalat, asa ca am luat-o la o tura pe autostrada la 2 noaptea :)) Am desfundat si DPF cu ocazia asta, am vazut consumul instant la diverse viteze.... sa mai treaca timpul.
Daca merge update de soft la Discover Pro sa ma anunti si pe mine te rog, eu din cate am inteles nu se poate sa rulez Google maps fiindca am MIB 1 nu 2 (tot din 2013 este si a mea)
SIM-ul il poti folosi ptr hot spot WI-FI, nu pentru Google Maps.
Mult success!
Modificat de Liviu_sbn
Buna ziua,
La sistemul meu de navigatie Discovery Media Generatia 1, in momentul in care trec granita in Bulgaria sau Grecia, pe display orasele si localitatile apar in limba locala si nu in limba engleza. Va rog sa imi spuneti daca exista posibilitatea de a seta limba in care sa fie afisate informatiile pe harta.
For your information: Săptămâna trecută au apărut noile hărţi pe site. Au vreo 27 GB parcă, iar update-ul a durat aprox o oră şi jumătate, cu un SDXC cu viteza de scriere de 90 mbps.
Singura care apare este Mai 2017 si are 23,7 GB. Daca ai tu un link cu actualizare de saptamana trecută cu 27 GB, Da-mi si mie. Eu am gasit ce este mai jos!   http://www.navigation.com/is-bin/INTERSHOP.enfinity/WFS/Navteq-NavteqEurope-Site/en_GB/-/GBP/View-Promo?&cwt=application/ApplicationFrame_campaign_light&Page=VW_Europe_Pro_MIB1
Modificat de mah2m2c
Am incercat sa fac un update pentru un golf 7 cu MIB I de la un v3 2013/2014 la may  2017/2018 si am avut o mica surpriza , in sensul ca la copiere pe sdcard (original de 8gb) nu a incaput toata informatia !! Initial am dezarhivat cu winrar si am crezut ca e de la el apoi acelasi lucru si cu 7zip . Totusi am bagat cardul (mai avea1,25mb liber si de copiat vreo 15mb) si vad ca navi functioneaza . Voi copia pe unul de 32gb sa incapa lejer !!
Sa-mi zici si mie daca reusesti sa-l faci sa mearga cu un alt SD card. Eu am facut update de la 2013 la nov 2016 si a incaput pe cardul original. Incercasem la vremea respectiva cu un alt SD card si nu il recunostea deloc. Acum sa vad cum fac si cu update-ul asta.
La fel am patit si eu cu update-ul , nu a incaput pe cardul original. Am incercat cu alt card si nu il recunoaste navigatia.
Deci e clar . Nu incape may 2017 pentru MIB I  pe sdcardul original 8gb . Pentru vreo 15 mb . Astia la vw parca sunt pe alta lume . A mers pus pe un card de 32gb .
Am facut update-ul. Am incercat sa copiez tot si a dat eroare. Asa ca am sters un singur fisier de spell de prin Rusia (ca nu cred ca voi avea nevoie).
@skodita100 ce tip de card ai folosit? ce marca? Eu stiam ca merg doar cele originale VW pt Discovwry Media 1.
Un samsung sd evo+ 32gb .
Eu am bagat asa fara sa copieze tot si vad ca functioneaza in ro . Asa ma gandisem si eu sa sterg ceva cu rusia ... .
catalindarius
Salutare oameni buni! Am incercat si eu un update de harti la Discover pro la golf 7 si a mers! Problema e ca imi spune toate informatiile in engleza! Am umblat in setari absolut peste tot si nu am gasit limba romana. Sfaturi..?
  Salutare! Aveti careva idee de ce nu imi apare optiunea de google maps la view din sistemul de navigatie discover pro 2017? Multumesc!
Salutare baieti,
Am si eu o intrebare hartile merg si la Skoda Amundsen  din 2015 varianta ,,Discovery Media" de la vw?
alexandrupaul
Dicover Pro Gen 1 nu are limba romana. Dupa 2015 (sau 06.2014 parca) au bagat limba romana pe Gen 2. Nu prea ai ce sa ii faci :)
Salutări!
Am cumpărat din Franța un VW Golf 7 Break, Bluemotin, 2014 TDI, 1,6 - 110 CP.
Am navigație mare cu hărțile din 2014.
Întrebare 1: Pot folosi Card de memorie Kingmax SDXC 64 GB clasa 10 PRO ?
Întrebare 2: Știe cineva de ce nu ”vorbește”? În nici o limbă. E mută.... Nu îmi funcționează comenzile de pe volan(partea dreaptă - doar butonul OK). Asta să fie cauza?
Mulțumesc anticipat.
Salutare, poti folosi orice card de memorie SDHC pe care sa incapa ultima versiune de harti. Ai link-ul in topical acesta si instructiuni de download si instalare. Nu mai tin minte exact, dar parca mie mi-au ocupat 25 GB pe un card de 32 GB
Intra in Navigatie / Setari / poti selecta acolo cum sa fie anunturile. Daca ai setat pe CONGESTION ONLY, nu o sa-ti spuna cand sa faci stanga dreapta sau altceva. Sfatul meu e sa-l treci pe short, nici prea multe info nu e bine ca va vorbi mereu si te va deranja.
Despre butoanele de pe volan poti cauta un topic separat pe care sa discutam ca sa nu poluam acest topic.
