Retrofit ACC si Lane Assist
skinny
14 hours ago, F l o r i n said:
3AA
Ti-am scris mai sus, cu 3AA...nu  3c8.
Salut, vin si eu cu o problema daca ma puteti ajuta, am facut retrofit la ACC dar nu pot scapa de erorile astea
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 13 15 16 17 19 25 36 42 44 46 4C 52 53 55 56
          62 6D 72 77
VIN: WVWZZZ3CZAE001955   Mileage: 240900km-149688miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 EN    HW: 03L 907 309 A
   Component: R4 2,0L EDC A000SG  4518
   Revision: 21H20---    Serial number: VWZCZ000000000
   Coding: 0050072
   Shop #: WSC 84224 939 69024
   VCID: 75E154D31CC13F3BE0-8020
   VINID: 9E69EAAAA0D3A91540001245140ACEEE8B
2 Faults Found:
053283 - Please Check Fault Codes in Control Module for Automatic Distance Regulation
               U1023 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 240889 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 18:39:04
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000111
                    (no units): 65.0
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 255
                    Mileage: 240889 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 18:39:04
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000111
                    (no units): 65.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels:. 3AA-698-109.lbl
   Part No SW: 3AA 698 109 N    HW: 3AA 614 109 AQ
   Component: J104   C2 450M VEB9 0042
   Revision: --H07---    Serial number: 00000006950312
   Coding: 0083120
   Shop #: WSC 00046 000 00000
   VCID: 4487F917079BD6B3A7-8010
3 Faults Found:
03075 - Parallel Parking Assistance Control Module (J791)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 184
                    Mileage: 240889 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 18:39:09
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 169
                    Hex Value: 0x0000
01309 - Power Steering Control Module (J500)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 184
                    Mileage: 240889 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 18:39:09
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 281
                    Hex Value: 0x0000
01319 - Control Module for Distance Control (J428)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 184
                    Mileage: 240889 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 18:39:09
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 227
                    Hex Value: 0x0000
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 L    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0021
   Revision: --------    Serial number: 06530903900288
   Coding: 300006
   Shop #: WSC 05314 123 12345
   VCID: 4487F917C79BD6B3A7-8010
No fault code found.
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 M    HW: 3C0 907 567 J
   Component: AC201  RDW M    031 0243
   Revision: 00031000    Serial number: 00000000033831
   Coding: 0010100
   Shop #: WSC 49029 000 104857
   VCID: 356194D35C417F3B20-8060
2 Faults Found:
01316 - ABS Control Module
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 240904 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 18:34:54
             Freeze Frame:
                    Count: 5
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 240904 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 18:34:54
             Freeze Frame:
                    Count: 4
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0172
   Revision:   H14       Serial number: 1021G10908016E
   Coding: F9B5FF06020602002002
   VCID: 2C57B1B78F0B3EF34F-8078
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.148 0703
   Revision: 1AH03256    Serial number: 00091180271702
   Coding: 0000258
   Shop #: WSC 05311 000 00000
   VCID: 3A7B87EF755F9043CD-806E
Am codat ceva gresit sau vreo componenta nu e ce trebuie?
Salutare. Nu imi mai funcționează ACC-ul si după o vizită la service am înțeles că trebuie să schimb radarul. Modelul de pe mașină este 3AA 907 567. Am găsit radar cu codul 3AA 907 567 A. Se potrivește pe mașină?
Trebuie codat? Sau doar pus pe masina si calibrat? Passat B7 2012 DSG CFFB. Mulțumesc
F l o r i n
Montat, codat, calibrat
Seria sasiu a masinii, sa îți verific compatibilitatea
DA, merge. dupa montare trebuie codare si calibrare.
Wvwzzz3czce017377. Multumesc
Dupa montarea celui nou o sa mai imi afiseze la bord eroarea? Sau doar dupa codare o sa dispara? Ca ma gandeam sa iau unul din dezmembrari sa il montez si sa vad daca chiar e stricat cel vechi. Multumesc
Modificat de Tny87
Noi nici măcar nu știm ce eroare e.
F l o r i n
Da, merge și A ul.
Intai trebuia sa diagnostichezi și verifici corect, nu sa cumperi unul sa probezi...
Pe MFD imi apare ACC error si start-stop error. Pe vcds urmatoarele:
16 minutes ago, F l o r i n said:
Da, merge și A ul.
Am fost la un electrician si mi-a verificat siguranta si daca vine curent la mufa radarului. Siguranta este buna iar la mufa vine curent(nu ma pricep dar am vazut ca l-am un pin s-a aprins creionul de tensiune). Raspunsul lui a fost ca e stricat radarul.
Și celelalte fire sunt OK ?
Nu a verificat... A zis ca nu are rost sa verifice tot cablajul ca sigur e defect radarul
Asta da electrician. Și dacă îi duci alt radar și tot nu merge, ce face ?
Mda... La si dat jos sa verifice mufa... Deci e decalibrat... Oare ce sa fac? Sa ma duc sa verifice tot cablajul? Din erorile din vcds asta rezulta? Ca e din cauza cablajului? Multumesc
Din eroare rezultă ca nu comunică cu el. Nu ca e decalibrat. De ce nu comunică ? Nu are alimentare, nu are masa, fire can intrerupte, radar defect.
Modificat de Al Bundy
F l o r i n
Funny.... am avut Q8 2022 cu problema la cablaj radar. Azi l-am predat, dupa remediere defect și recalibrarea sistemelor
Inteleg... Maine ma duc la alt electrician si îi zic sa verifice absolut tot ce mi-ați zis. Multumesc
Am cumparat modelul cu A. Imi puteti spune cum il codez cu VCDS. Asa ca pentru un incepator. Multumesc
il codezi dupa celalalt.
Salutare! Am pus parbriz de B7 cu camera pe B6. Am cumpărat capacele de plastic de B7 și nu merg puse din cauza oglinzi. Trebuie sa iau alta oglinda sau capace de B6?
Răspund tot eu. Este nevoie de oglinda de B7
Vă salut! Cum as putea sa codez (daca se poate coda) camera din parbriz ca sa-mi recunoasca semnele de circulație? Daca activez funcția din meniu imi da eroare de genul ca e limitat.  Am atasat poza cu codul navigatiei si al camerei. Va multumesc!
