Golf 6/Jetta - Problema receptie antena
kustom_kulture_addict
Modulul....nu circuitul imprimat pe luneta
Am urmatoarele erori, daca se poate sa imi spuneti care ar fi problema, si cum s-ar putea rezolva:
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 BX
   Component: RNS-MID       H02 5238
   Revision: AB001001    Serial number: VWZ6Z7H9148119
   Coding: 04000400040000820000
   Shop #: WSC 39845 142 999999
   VCID: 3777339C86B345A6659-8062
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V13  8350
00862 - Antenna for GPS Navigation (R50/R52)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 254
                    Reset counter: 96
                    Mileage: 210495 km
                    Time Indication: 0
                    Date: 2026.14.01
                    Time: 19:09:25
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 96
                    Mileage: 210495 km
                    Time Indication: 0
                    Date: 2026.14.01
                    Time: 19:09:25
Probleme la antena - cumpara o antena GPS after market si o montezi separat
detin un golf 6 2.0 110 CP,2009 si sunt unul din ghinioniștii al cărui semnal face figuri...
Precizez ca am avut probleme cu furtunasul de la stropgel spate(s-a rupt in mansonul de cauciuc si imi curgea apa prin usa spate(hayon)...
Credeti ca asta ar fi factorul care a influențat defecțiunea la antena?!??
Problema a apărut in momentul in care am ieșit cu masina din spălătoria auto.
Multumesc!!!:)
Buna dimineata. In urma testarii la un Golf VI, 2009, mi-a aparut:
3 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 68
                    Mileage: 176915 km
                    Time Indication: 0
                    Date: 2012.08.27
                    Time: 17:45:34
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 108
                    Mileage: 178789 km
                    Time Indication: 0
                    Date: 2012.11.03
                    Time: 19:38:55
00821 - Antenna 2 for Radio (R93)
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 176745 km
                    Time Indication: 0
                    Date: 2012.07.29
                    Time: 11:54:49
Din discutiile anterioare n-am sesizat o rezolvare general valabila. Fac mentiunea ca si al meu radio pierde semnalul in afara localitatilor.
Ma gandeam ca poate nu-i neaparat o treaba de soft ci de ...un electrician cu aparat de masura care sa o ia pe fir.
Multumesc anticipat.
garantat nu e o problema de soft.
Posibil sa fie dus modulul antenei.
...modulul antenei? Adică ce si unde...
On 28.10.2014 at 12:36, kustom_kulture_addict a scris:
Buna ziua. Am urmatoare problema. Un Golf 6 al matusii mele  echipat cu unitatea RCD 210 are porbleme de receptie in afara localitatii. Simptomele se manifesta in modul urmator: in localitatea receptia posturilor radio este buna dar odata ce masina iese din localitatea nu se mai aude aproape nimic. In urma scanarii cu VCDS am descoperit urmatoarea eroare :00856-Radio Antenna :Short to Ground. Am  desfacut unitatea RCD 210 si am verificat conectarea cablurilor. Am verificat sigurantele. Am desfacut panourile de plastic de pe usa portbagajului. Acolo am verificat conexiunile de la modulul antenei. Totul pare in regula. Pe centrul portbagajului se prezinta ceea ce eu consider a fi o conexiune de masa(ground) oxidata. Am curatat-o just to be safe. ulterior am descoperit ca celebrul furtun de la spritzuitoarea spate este fisurat chiar sub camasa de cauciuc din dreapta . Intrebarea mea este : se poate ca lichidul de parbriz care se prelinge printre firele respective sa aiba o legatura? Astept solutii...:) cu multumiri..
am aceeasi problema si eu(identica,chiar si cu furtunul...)si nu stiu ce sa mai fac cu semnalul de la radio...
Va rog daca a reusit cineva sa rezolve problema,mai ales tu kustom_kulture_addict,spuneti-mi ce sa fac...
Urâta treaba...nu e normal la o masina 2009 sa ai astfel de probleme,nu aveau cele mai vechi,anii 80-90...
pe mine unu ma disperat trb asta,nu stiu ce sa mai fac,stau cu plasticele de la hayon desfăcute,tot sper sa găsesc buba...
Am schimbat si amplificatorul antena(sau cum s-o numi asta) si degeaba.
In protectia de cauciuc dintre haion si caroserie ati verificat?
Modificat de loghy
Pai a trebuit sa desfac chiar si plasticul din dreapta spate (stalp) ca sa inadesc furtunul de spritzuitoare,deci am demontat c-am tot prin spate(pt cei care nu stiu,acolo se afla mufe si pt antena radio si pt furtunul acela,deci nu trebuie schimbate la nevoie cu totul(din botul masinii).
Am observat ca cel care a avut masina inainte a dat cu banda izoliera pe firul antenei(paretea care este in acel mansion),era crapata camasa izolatoare a firului dar nu avea intrerupere...
Am taiat firul si l-am "sudat" la loc...dar eu tind sa cred ca problema ar sta in  "Frequency modulation (FM) frequency filter in positive wire -R179",piesa care se afla am vazut in partea dreapta a hayonului(pe acolo se scurgea apa care curgea prin ruptura furtunului...
Sper ca m-am facut inteles,si sper sa gaseasca cineva o rezolvare ca m-a disperat toata trb asta...
Modificat de loghy
quote post anterior
Cablul de antena (continuitatea ) poti sa-l verifici foarte usor cu un ohmetru  Ai doua amplificatoare pe partea de sus a haionuluili sau unul acolo si antena de pe plafon?
Am un singur amplificator...cel din poza de mai sus si nu am antena pe plafon.
Momentan nu am un ohmetru dar o sa merg la un electrician sa imi verifice cel mai probabil...
Modificat de Adelin g6
Cel mai mai bine ,asa am vrut sa spun de prima data ...fara scule nu prea poti rezolva mare lucru.Succes!
Multumesc mult pentru raspuns si implicare :)
Daca totushi cineva care detine astfel de probleme ii asteptam cu detalii...
@Adelin g6
am si eu probleme  cu antena de la radio la Golf 6, mi s-a spart si mie furtunul ala si a curs lichid, iar de vreo luna , nu mai prind radio decat in oras, am verificat si eu cablul din mansonul de cauciuc si era crapat si am inlocuit bucata cu probleme insa tot nu prind radio cum trebuie si in meniu imi scrie la ambele antene ca sunt OFF.
Ma gandeam si eu sa caut amplifictorul ala 5k0035552  din dreapta sus si sa il inlocuiesc, insa poate tu ai gasit alta solutie si ai rezolvat problema.
Mersi
Am montat o navigație China , nu are decât o singura mufa. Mașina pe original are 2 mufe care vin de la hayon. Care din ele o conectez ?
Care vine de la antena FM ?
cumpara un adaptor de la doua antena la una - ca sa te ajute la receptia radio - si asa destul de slaba la unitatile chinezesti
amandoua mufele sunt de FM
Salut, uite am patit si eu la masina mea, rns 510, am plecat din bucuresti, totul perfect, cand am iesit din bucuresti nu a mai mers radio, imi sta blocat pe un singur canal. Si am impresia ca se misca si greu navigatia. De dimineata totul mergea perfect, am dat restart fortat, restart fabrica tot, am pus tester si mi-au aparut erorile astea
0335 antena 2 intrerupere
0358 antena la radio intrerupere
035e antena pentru navigatie(gps) scurtcircuit masa
ce pot sa fac in situatia asta ?
Modificat de R_a_z_v_a_n
Renunta la QUOTE
Am tot cautat .. dar nu gasesc adaptor dela 2 la 1. Unde am gasit imi ia extrem la transport .. 80 lei.
Am eu mufe fakra de pe la slte masini si unitati hu.
Cum le conectez.. in paralel sau trebuie ceva condensatori.. ca la un spliter ?
Nu, iti trebuie condensator, nimic..
Am pus una din mufe. Dupa cateva zile ma declar multumit de receptia radio.
