Heater element / Incalzire auxiliara - probleme
vasy
 Rog daca se poate interpreta ultima eroare  cu Incalzire auxiliara Defecta...
    Despre ce este vorba la Passat 2.0 TDI 2006 in urma scanarii cu VagCom,si daca mai sesizati ceva nereguli  va rog sa-mi spuneti.
 Odata  Multumesc...
Sunday,31,August,2014,16:05:29:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 77 7D
VIN: WVWZZZ3CZ6E225181   Mileage: 303830km/188791miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 03G 906 021 MS    HW: 028 101 271 9
   Component: R4 2,0L EDC G000AG  9390
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 74489 141 86627
   VCID: 7CFD85543FF078E
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 S    HW: 02E 927 770 AE
   Component: GSG DSG         070 1127
   Revision: 04507000    Serial number: 00000510270252
   Coding: 0000020
   Shop #: WSC 44551 111 44551
   VCID: 234F9E28E2CEE76
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0658326493
   Coding: 0013605
   Shop #: WSC 05311 000 08193
   VCID: 30656164A3384CE
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 62C1DB2CBD54AEE
2 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 -  -
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 109
                    Mileage: 288941 km
                    Time Indication: 0
                    Date: 2013.05.15
                    Time: 09:13:42
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 146
                    Mileage: 303804 km
                    Time Indication: 0
                    Date: 2014.08.28
                    Time: 07:18:25
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000005217573
   Coding: E1888F0700041A00000A00000F00000000095D435C0000
   Shop #: WSC 05311 000 00000
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     010709 054  0402
   Coding: 00209069
   Shop #: WSC 05311
Address 15: Airbags        Labels: 3C0-909-605.lbl
   Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
   Component: 04 AIRBAG VW8   029 2521
   Revision: 09029000    Serial number: 003A2PNXVNS6
   Coding: 0012340
   VCID: 2D5B7810B40A216
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
   Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
   Component: Lenksäulenmodul 005 0010
   Revision: 00005000    Serial number: 3C9953507C
   Coding: 0001014
   VCID: 2A51730C85E436E
Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
   Part No SW: 3C0 920 870 Q    HW: 3C0 920 870 Q
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0033000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 11111 111 11111
   VCID: 31636460A832456
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 135
                    Mileage: 0 km
                    Time Indication: 0
Address 19: CAN Gateway        Labels: 3C0-907-530.lbl
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C05B020DB2
   Coding: 3FFD2C04C62002
   VCID: 21439420F8D2F56
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
   Component:    IMMO         038 0367
   Revision: 00038000    Serial number: VWZCZ000000000
   Shop #: WSC 24562 134 82073
   VCID: 32616B6CAD347EE
   Part No: 3C0 905 861 D
   Component:    ELV          024 0370
   3C0905861D     ELV          024 0370
3 Faults Found:
01176 - Key
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 202336 km
                    Time Indication: 0
                    Date: 2009.01.14
                    Time: 08:35:36
02823 - Requirements for Locking the Steering Column Lock not met
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 7
                    Fault Frequency: 5
                    Reset counter: 147
                    Mileage: 303761 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 14:45:54
02827 - Wake-Up request via ESP
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 147
                    Mileage: 303761 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 14:45:54
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2365
   Coding: 0000181
   VCID: 3669577C415C62E
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 038 0455
   Coding: 0091020851030E763804941570084F0E703800
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
00896 - Trunk Lock Unit (F256)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 98
                    Mileage: 276958 km
                    Time Indication: 0
                    Date: 2012.09.18
                    Time: 17:15:59
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000180
   VCID: 37775A7846569B6
00933 - Electric Window Motor; Passenger Side (V148)
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 135
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 7.14 V
                    Count: 202
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 P
   Component: Radio BVX       016 0023
   Coding: 0042400
   VCID: 336F6E68522E776
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 3C9 959 703
   Component: Tuer-SG         021 2505
   Coding: 0000144
   VCID: F0E52164E3B88CE
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 3C9 959 704
   Coding: 0000144
   VCID: F1E32460E8B2856
Address 77: Telephone        Labels: 3C0-035-729.lbl
   Part No SW: 3C0 035 729 E    HW: 3C0 035 729 E
   Component: Telefon             6009
   Revision: 00008000    Serial number: 0000000675888
   Coding: 0016023
   VCID: 254B8030ECFA196
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 135
                    Mileage: 0 km
                    Time Indication: 0
01305 - Databus for Infotainment
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 134
                    Mileage: 0 km
                    Time Indication: 0
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End   ---------------------------------------------------------------------
00361 - Heater Element for Auxiliary Heater (Z35): Faulty
Possible Symptoms
  • Auxiliary Heater not working
  • Fault Code(s) cannot be cleared
Possible Causes
  • Heater Element for Auxiliary Heater (Z35) faulty
Possible Solutions
  • Check/Replace Heater Element for Auxiliary Heater (Z35)
Special Notes
  • When found in Auxiliary Heater, this Fault Code often cannot be cleared. Usually this Code implies that the Heater Element (Z35) houses the Control Module this Fault Code is stored in, therefor the Heater Element may need to be replaced to fix this.
PS: data viitoare posteaza doar eroarea aia, nu toata scanarea.
Modificat de MRC
@vasy: chiar era nevoie de un topic nou? Este arie dedicata pentru erori, in plus respectiva eroare are si solutia aici pe forum - se da jos unitatea si se refac lipiturile la rezistente. Search it!
In urma unei scaneri cu VAG COM am observat ca imi apare ca si defect radiatorul pt incalzirea auxiliara la Passat-ul b6 din semnatura. Am demontat plasticele din partea stanga a consolei centrale si furtunele de ghidaj pt caldura dar nu reusesc sa dau jos radiatorul deoarece imbinarea dintre plasticele ce formeaza bordul este chiar in drept cu radiatorul de incalzire aux. Va rog sa-mi sugerati cei care ati mai intalnit problema aceasta cum ati reusit sa scoateti afara modulul. Multumesc!!!
Modificat de vwbora1314m
Tocmai asta e ca si un prieten are un golf 5 si avea aceiasi problema, dar la el a fost relativ simplu de scos deoarece radiatorul este dupa imbinare si A trebuit luat jos doar lateralul de la consola centrala si apoi a iesit usor. Chiar dupa linkurile acestea ne-am ghidat cand l-am inlocuit pe a lui, dar la mine e putin diferit si nu se poate scoate asa.
Trebuie sa tragi putin de plasticele alea, e o ureche acolo la imbinarea lor care o sa se rupa dar nu afecteaza nimic. Alfel, solutia este demontarea bordului.
Oare nu incepe sa trancane nmk apoi daca rup imbinarea aia?
            014 - Defective
problema rezolvata cu lipirea  celor cinci rezistente si 4 ore de munca ...
Felicitari  :icon_thumleft:
da, este ceva de munca.... dar merita - mai ales cand vine frigul.....
  On 04.11.2014 at 19:32, Mihaita Baloi a scris:
            014 - Defective
De ce 4 ore? In maxim 1 ora e demontata, lipita si montata la loc.
mda.... una este la noi, care le demontam zilnic... alta este la un user care nu desface toata ziua la masina... nu se grabeste, mai o cafea... o pipa...
la Golf 5, Octavia 2... merge mai repede.
Ai dreptate pentru prima data am desfacut mai mult de cat trebuia    acum este foarte usor 1 ora este de ajuns :winter:
desfaci consola dintre scaune si ri dici din spate si apoi iese foarte simplu  eu nu am rupt nimic
Salutare ! am si eu probleme la 1 Fault Found:
            014 - Defective la un PASSAT B6 din 2007
am citit mai sus ca se poate repara prin inlocuirea lipiturilor dar nu stiu cum sa scot incalzitorul ma ajuta cineva cu informatii eventual poze ? MULTUMESC 1
Se desfac plasticele de sub bord, inainte de asta scoate borna de la baterie, mai ai un suport de aluminiu de desfacut din suruburi, cablurile de la incalzitor, tubulatura de aer de la picioare si cam atat. Trebuie dupa aia sa tragi un pic de un plastic de sub bord ca sa iasa caloriferul.
Am probleme la Heater Element for Auxiliar Heater am scanat și zice ca este defect știe cineva Cum se demontează? Am găsit ceva pe forum dar pentru golf și soda pentru passat B6 nu prea
NU era nevoie de topic nou pentru asta, e la fel ca la celelalte.
Mulțumesc Al Bundy! Am fost la un mecanic am desfăcut pe partea stângă dar nu am dat de radiator băiatul meseriaș de altfel numai ca nu a desfăcut pana acum așa ceva așa ca o sa caut pe cineva care se pricepe prin Zona județul Bacău. Dacă ști pe cineva sau știe cineva ?
  • 7 months later...
Unde gasesc un mecanic bun pentru reparatie incalzire auxiliara in Bucuresti?Multumesc!
poate electrician...  :icon_thumleft:
suntem mai multi colegi in Bucuresti, care te putem ajuta - vezi in aria Prestari servicii
Mutumesc, Forin. O sa caut acolo.
Scuze "Mutumesc Florin."
Si eu am avut probleme cu incalzirea auxiliara cand am cumparat masina.Am scos rezistenta am mers la un electrician si a lipit cele 5 piese ,si functioneaza perfect,azi erau 8 grade afara si am dat clima la HI   si a pornit rezistenta.
da, acesta este Z35 - se poate repara, asa cum s-a discutat de foarte multe ori.
