Faruri G7
codz
Farurile Led vin fara spalator, indiferent de nivelul de echipare sau de tipul lor. Doar daca alegi pachetul de iarna vei avea spalator in bara.
Seat-ul Leon cu faruri Full Led vine vine fara spalatoare. Skoda Rapid vine cu faruri Xenon fara spalatoare. Cred ca si Golf-ul cu faruri Led Mid vine fara spalatoare. Doar farurile Led High vin cu spalatoare atat la Golf cat si la Passat si restul.
Daca o masina este obligata sau nu sa ofere spalatoare de faruri standard nu tine de modul de iluminare folosit, halogen, xenon sau led, ci de puterea emisa de faruri. Si asta se aplica doar la faza scurta, nu si la faza lunga:
It is a widespread fallacy that headlamp washers are only compulsory for xenon lights. This is wrong on several counts. The latest generation of xenon, the 25-Watt version, doesn’t actually need one at all. Meanwhile, halogen and LED headlamps do need one if their light sources emit more than 2000 lumens. Indeed, this is required for ECE approval. (Under the DOT regulations in North America headlamp washers are not mandatory at all.) These do not refer specifically to xenon, but as no approved halogen lamp exceeds this threshold value and as this also is the case with most LED systems, only xenon headlamps are, in fact, affected in practice. They emit around 3000 lumens.
  On 29.03.2019 at 12:37, Rave a scris:
Expand
Nope, la Golf doar daca le platesti, eu am Led Top fara Pachet Iarna si fara spalatoare de faruri.
La Passat, intr-adevar, vad in configurator ca "instalatie spalare faruri" vine impreuna cu Led High.
  On 27.03.2019 at 16:47, mihai_tmn a scris:
Fain...dar sunt cateva probleme.
1) Conform legii, in Romania, nu ai voie sa circuli cu echipamente de iluminat neomologate, astea nu stiu daca sunt omologate
2) Farurile cu LED/Xenon trebuie sa aiba auto-leveling cu senzori de inclinatie a masinii , si care regleaza automat inaltimea farurilor
3) Farurile cu LED/Xenon trebuie sa aiba sistem de spalare
4) Pretul , din ce am vazut ete de aprox 900 de euro "la reducere"
5) Daca se strica ceva, se schimba cu totul... asta nu e foarte distractiv, la pretul asta.
Punctele 2 si 3 nu stiu daca au neaparat de a face tu tehnologia LED/Xenon sau cu intensitatea luminii (mai mare la acestea)
Expand
Salut Mihai!
O sa raspund punctual cu ce am aflat pana acum
Farurile de la Osram sunt omologate de producator. nu au nevoie de o noua omologare.
Nu au auto leveling pt ca au motor intern de reglaj, acesta facanddu-se de la rotita din interiorul masinii
Nu au nevoie de spalator pt ca au 35W putere. Ce este peste 35 W are nevoe de spalator.
Ca fiabilitate, nu am primit altceva in afara de garantia de 2 ani, dar dintr-o alta discutie am inteles ca ele vin echipate cu sursa principala de lumina cu becuri OSRAM D8S. Becurile astea am inteles ca se pun pe "xenoanele de fabrica" la masinile de generatie noua.
Pretul de 900E reprezinta costul total pt setul de faruri. un retrofit la xenon OEM cred ca sare de 1500 (cu senzor, spalatoare, manpera) si muuult timp. Astea sunt plug and play.
Daca se strica ceva in 2 ani ai garantie. Daca se strica dupa, norocul fiecaruia. din ce am mai citit pe net am inteles ca s-au intors extrem de putine la garantie.
Revin cand mai aflu cate ceva.
Salutare.  Spuneti-mi si mie va rog ce face becul ăsta ca nu gasesc nicaieri.
Am un golf 7 hatchback an 2013, 2.0 tdi , HL,cu faruri exact ca in imagine.
Marcel Onofrei
Am luat un Golf 7 cu faruri full LED si pana imi ajunge masina, tot stau si ma uit pe youtube la diferite clipuri.
Am observat ca in primul clip aici: https://youtu.be/h0BeQn0E23M?t=9 cand are luminile de avarie, nu se aprind amandoua "virgule" din fata dintr-un singur far.
Dar in clipul asta :  https://youtu.be/gC6jbF6Ur6M?t=4 aici totul merge ok.
Amandoua sunt R Line si au pachetul de faruri + stopuri full LED.
Imi puteti explica diferenta?
Thank you very much!
Modificat de Marcel Onofrei
Marcel Onofrei
Aaaaa, ce confuzie am facut. Deci asta e diferenta intre MID si TOP.
Multumesc mult @Rave
După îndelungi documentari și review-uri, am decis sa cumpăr farurile de la Osram Ledriving. În weekend sper sa apuc sa le montez și sa revin cu impresii.
Numai bine!
F l o r i n
Fiind Osram, mai mult ca sigur sunt ok
Cat au costat pana la urma?
Sa revi si cu poze dupa montaj sa vedem cum arata pe masina ?
Merci!
Modificat de Xman_ghio
prețul a fost de 4229 lei. Pe e-mag le-am găsit la cel mai bun preț.
Malin C. Melinte
Salutari !
A reusit cineva sa puna bec led pe faza lunga respectiv DRL (in cazul farurilor pe halogen). Am incercat sa pun bec led,functiona DRL,dar nu mai functiona faza lunga. Sugestii ?
spiderman07
4somke? spune-ne dupa ce le montezi cum sunt. eu le-am pe cele care arata ca la R, dar am facut un mic accident si s-au rupt suportii de fixare. revin la cele stock pentru ca se vedea foarte prost cu ele si nu gasesc 1 singur far.
sigur! ? tot Osram ai avut și tu?
Modificat de loghy
quote post anterior
spiderman07
nu. pe acestea le-am avut. din pacate nu sunt calitative deloc.
headlights-3d-led-drl-suitable-for-vw-golf-7-vii_5986316_5990530.jpg.28b478e47ce4605d3c8f0109199806e9.jpg
am înțeles. probele a mea principala era cu omologarea. cele Osram sunt singurele omologate ECE pe care le'am găsit. la calitate nu aveam termen de comparație și aici am mers pe brand.
@spiderman07 ale tale nici nu aveau cele doua benzi de led-uri (cele doua L intoarse ?, nu? Vad ca sunt cele cu led-urile pe orizontala jos. Cele OSRAM arata mult mai aproape de cele originale
spiderman07
@Xman_ghio ba da. aveau acele U(se aprindeau ambele) ce funtionau ca DRL. si partea de jos, functioneaza ca semnalizare(dinamica). la design imita foarte bine cele de pe Golf R(nu facelift). a mea e din 2015.
Salut! azi am montat farurile. sa vedem cum se comporta la ceas de seara ?
o prima problema sesizata. farurile s-au aburit ușor în partea de jos, unde este semnalizarea după aproximativ 4 ore de condus cu ele pornite
mai jos găsiți și doua poze, precum și un link în care se poate vedea cam ce lumina fac
La drum lung (cateva ore cu farurile pornite) la temperaturi cum avem acum 10-15 grade/ploaie si farurile mele originale se aburesc putin jos. Probabil de la diferenta de temperatura (LED-urile genereaza caldura si afara este frig). Nu cred ca este o problema; dupa ce farul se raceste dispare si "abureala" ?
F l o r i n
si cele originale, la octavia 3, etc.... unde au banda led, aburesc. Deci, nu mai este o panica, in ziua de azi.... Si Touareg-ul, etc.
