Activare/montare TPMS - Tire Presure Monitoring System
Sarbu Mihai
completare lista: eu am 3C061109 M si am TPMS din fabrica
Modificat de cridaia
TPMS via ABS will not work with these ABS modules:
3C0 614 095 M *
3C0 614 095 P *
3C0 614 109 *
3C0 614 109 C *
3C0 614 109 J *
3C0 614 109 N *
And these are all ok:
3C0 614 095 A * AE - nu merge
3C0 614 095 Q *
3C0 614 095 S - nu merge
3C0 614 109 A *
3C0 614 109 AF - merge
3C0 614 109 D * - merge
3C0 614 109 P *
3C0 614 109 T * - merge
3C0 614 109 K *
3C0 614 109 M * - merge - pompa pt masinile cu Start-Stop
3C0 614 109 R
Am reactualizat lista.... cu exceptia lui 3C0 614 095 S, care nu merge chiar daca Ross Tech zice ca suporta.... erau trecute toate.
eu am
Address 03: ABS Brakes       Labels: Redir Fail!
Control Module Part Number: 3C0 614 109 AF    HW: 3C0 614 109 AF
  Component and/or Version: J104    C4 440 V2   0015
           Software Coding: 0000296
            Work Shop Code: WSC 00028 028 00001
                      VCID: 62C0447BBDDFB708571
, din lista de sus se pare ca ar merge.., NU AM SENZORI LA JANTE
Ce codare trebuie sa pun ?  Eu as pune si butonul, costa cam 70 ron..
Am activat de pe can gateway Tire Pressure Monitoring si da eroare..
  Address 19: CAN Gateway       Labels: 3C0-907-530-V3.clb
Control Module Part Number: 3C0 907 530 L    HW: 3C0 907 951
  Component and/or Version: J533__Gateway   H13 0152
           Software Coding: FDA07F07500612001002
                      VCID: 2A50EC5B856F2F485F1
1 Fault Found
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
             Freeze Frame
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 109464 km
                    Time Indication: 0
                    Date: 2109.14.18
                    Time: 20:16:28
Modificat de mark21
nu trebuie activat pe Can ... ci pe ABS - din codare.
deci, scoate din lista cu instalate pe Can gateway si codeaza ABS-ul cu TPMS.
am scos, dupa ce am vazut ca da eroare, dar ce codare trebuie sa fac?  in long coding sau new coding..
Acum e.. Software Coding: 0000296
Pe 03-Abs - 07-coding, se adauga +2048
florin.selaru
Vreau sa montez si eu senzori TPMS pe masina dar nu stiu daca modulul de confort suporta sau ce frecventa au senzori pe care vreau sa-i cumpar . VW passat cc 2009 , 125kw .
Address 46: Central Conv.        Labels: 3C0-959-433-46.lbl
   Part No SW: 3C0 959 799 H    HW: 3C0 959 799 H
Pe ce frecventa 315 ? Sau 433 ?
Conform etka nu suporta.
Nu mai bine pui sistemul care foloseste senzorii de ABS?
florin.selaru
Acel sistem este deja activat , dar vroiam sa schimb pe direct. Multumesc. Asta inseamna ca trebuie schimbat modulul de confort daca vreau direct cu senzori. Ce nr are cel care suporta ?
la mine am din fabrica dar cand il activez ramane in bord aprins martorul de presiune.
cum verific unde este problema?
Daca ai din fabrica atunci de ce trebuie sa il activezi?
nu stiu. am avut o roata dezumflata si nu ma avertizat.
dupa ce apas o data imi spune ca este Full loaded, si dupa aceea ramane aprins martorul galben din bord.
se poate ca eu sa gresesc undeva...
Ai sistemul cu senzori de presiune in roti sau foloseste senzorii de ABS?
nu stiu. este original din fabrica.
masina e din 2006. Highline
Modificat de decsei
FA o diagnoza si vezi daca apoare TPMS separat.
florin.selaru
La mine apare tpms separat cu presiune de setat pe fiecare roata . Asta inseamna ca am TPMS cu citire prin senzori ? Ce frecventa ar trebui sa cumpar senzorii , sau cum aflu ce frecventa citeste modulul ?
cel mai usor, din Etka.
daca ai cu presiune separat pe fiecare roata ai cu senzori. Ce vrei sa mai cumperi atunci?
florin.selaru
Cand am cumparat masina nu am avut cei 4 senzori montati pe janta si nu am stiut ce foloseste . Iar acum daca vreau sa cumpar 4 senzori nu stiu ce sa cumpar.
aceasta eroare am citit de la vag com
ce sistem am si unde este problema?
Thursday,15,August,2013,12:36:47:60804
VCDS Version: Release 10.6.0
                Address 65: Tire Pressure       Labels: 3C0-959-433-65.lbl
Control Module Part Number: 3C0 959 433 P    HW: 3C0 959 433 P
  Component and/or Version:    RDK              0391
           Software Coding: 0161211
            Work Shop Code: WSC 10122 599 11337
                      VCID: 3776AE2A3F25
3 Faults Found:
01521 - Sensor for Tire Pressure
             Freeze Frame:
                    Fault Status: 01110100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 13
                    Mileage: 176139 km
                    Time Indication: 0
                    Date: 2013.07.15
                    Time: 15:05:41
00000 - End of output
            000 -  -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 13
                    Mileage: 176139 km
                    Time Indication: 0
                    Date: 2013.07.15
                    Time: 15:05:41
01477 - System Switched Off
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 177108 km
                    Time Indication: 0
                    Date: 2013.08.10
                    Time: 19:34:12
dupa ce l-am sters iar am primit asa
Thursday,15,August,2013,12:39:13:60804
                      VCID: 3776AE2A3F25
Fault Codes have been Erased
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 177633 km
                    Time Indication: 0
                    Date: 2013.08.15
                    Time: 12:41:08
Bogdan Andrei Ciobanu
Masina mea are TPMS bazat pe senzorii ABS si am urmatoarea problema: se aprinde martorul din bord si nu se mai stinge cu butonul de reset and learn.
Initial am crezut ca este vorba de o defectiune a butonului, am fost la service, au resetat ei eroarea (vagcom); ulterior, butonul de pe consola centrala functiona (il apasam 2 secunde, dupa care se auzea sunetul specific si se stingea).
Problema reapare la 1-2 saptamani dupa resetare.
Aveti idee de la ce poate fi?
Va multumesc anticipat.
La diagnoza ce apare ?
Diagnosis signal:
DTC number 02214 (tire pressure warning) is stored in DTC memory.
The tire pressure warning was activated at a kilometer reading of 71328 km.
Dupa ce o sterg si reapare, kilometrajul la care imi apare ca a fost activata ramane 71328.
Am activat si eu fara buton, si culmea.......merge.
Dupa ce am activat, s-a auzit un BING, si nici o erroare.
Mai jos e pompa mea ABS.
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.lbl
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000786320314
   Coding: 0000274
   Shop #: WSC 05311 000 00000
   VCID: 2B51039FF621
No fault code found.
Si o sa ai nevoie de VCDS sa resetezi eroarea cand apare martorul.
    • gyo80ag
