  2. FeriM
    Probleme compresor clima
    Skoda Octavia 2 FL 208k km Ieri pe parcursul unui drum de o ora am avut pe partea soferului (ambele deschideri de pe bord) doar aer cald, chiar foarte fierbinte, indiferent cum am setat clima. Pe partea pasagerului a functionat normal (cald/rece, conform setarii). Resetarea din butoane a climei nu a rezolvat nimic, a trebuit s-o opresc. Stiu ca se poate seta diferit clima pentru sofer/pasager, nu e asta. Pe drumul de intoarcere problema a disparut. Am gasit urmatoarele erori. Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR Component: Climatronic H15 0401 Revision: 00005001 Coding: 0000000002 Shop #: WSC 73430 790 00999 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_SK35.rod VCID: 020B3F0F950F1883D5-8056 3 Faults Found: 9473137 - Motor for Left Temperature Flap B108C 71 [008] - Actuator Stuck Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 153 Reset counter: 68 Mileage: 206612 km Date: 2026.02.12 Time: 18:36:23 9473138 - Motor for Left Temperature Flap B108C 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 28 Mileage: 208553 km Date: 2026.02.12 Time: 14:07:29 9474418 - Motor for Front Air Distribution Flap B1091 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 28 Mileage: 208553 km Date: 2026.02.12 Time: 14:12:41 Par sa fie doua probleme diferite, doua componente diferite. Care ar fi componentele implicate (doua motorase/clapete?) si ce problema cauzeaza fiecare? Manifestarea cu aer fierbinte daca mai apare nu e ceva tolerabil. Are rost/pot sa incerc o calibrare cu VCDS? Care e locatia componentelor si accesul la ele? Sunt binevenite si recomandari (PM?) pentru cineva care ma poate ajuta cu rezolvarea lor efectiva in zona Cluj. (Am rezolvat mai demult o problema cu electrovalva compresorului cu ajutor de pe forum si mers intr-un service cu indicatii precise, dupa o luna de recomandari aiurea de la serviceurile locale "specializate" in clima)
  3. tavitara
    In weekend mergi pana la Pitesti si inapoi , macar sa prinzi gropile pana nu le astupa Cand vezi un BMW ca iti face cu ochiul sa te dai la o parte accelereaza putin sa il enervezi Si drumul asta amuzant te va ajuta Te opresti la Bradu la mall-ul ala cu La Cocos si iti iei o cafea de la Gloria Jeans , o fac buna si uite asa te distrezi si ajuti masina
  4. EEXCALADE
    Inj carpite ,drumuri scurte ,mers doar in oras
  5. tavitara
    E foarte util sa vezi treapta de viteza , mai ales cand se blocheaza cutia ca la mine , vezi exact in ce treapta ai ramas 😁
  6. Astăzi
  7. abitul
    Frane - Probleme & Discutii (Tiguan III)
    Eu nu m-as speria prea tare daca nu este f tare scartaitul. L-am avut si la modelul anterior mk2.5/2021 ehybrid si exista si la actualul din mk3/2025 ehybrid. Nu il bag in seama.
  8. Aisin8cayenne
    166 de mii la 140 s au schimbat uleiurile la cutie grupuri cutie transfer când pleci lin, nu se simte nimic, la fel și când pleci tare și se schimbă a viteza după 2600 turații
  9. LoliSor
    Sonda lambda
    Am schimbat sonda dinainte de catalizator (Magneti Marelli), a disparut eroarea cu amestec prea bogat. A aparut acum urmatoarea eroare. Coduri de eroare: P0030 - O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1) Open circuit/short circuit to ground static Vine tot din sonda schimbata sau este cea de dupa catalizator? Ma afecteaza aceasta eroare? Schimba consumul de combustibil?
  10. camelus
    Păi unde să mai caut? injectoare recondiționate, parametrii normali, turbină în parametri normali, EGR original schimbat în urmă cu 20k km…
  11. Xman_ghio
    Pai el are regenerari la 100 km in oras. Mai ales pe frigurile astea parca era perfect normal.
  12. @mad_kat daca o sa ai ocazia sa vezi un Rexton produs intre 2022 si 2024 ( non FL) o sa vezi ca pe schimbatorul de viteze inca se vede M-ul de sub D, daca este luminat cu o lanterna. Adica au lasat aceiasi piesa doar ca au dezactivat modul Manual. DIn ce am citit pe alte forumuri ar fi la baza reglementari europene de poluare dar si tranzitia la short shifterul nou cum il am eu , au facut o generatie de tranzit intre schimbatorul mare cu M si cel mic short fara M. Asta cu vazutul vitezei , este un nive to have , nu este neaparat un must, te obisnuiesti repede .
  13. Vreau sa inlocuiesc modulul Central Locking 1C0962258AA (ZV min) cu 1C0962258N (ZV Max) pt. imperechere cu telecomanda originala 1J0959753N (1C0962258AA (ZV min) nu are optiune de imperechere telecomanda). Problema este ca 1C0962258N (ZV Max) are 3 mufe, iar 1C0962258AA (ZV min) are doar 2 mufe. In mufa a treia suplimentara (T15), la pinii 7 si 10 este conectata antena R47. Ma gandesc sa conectez o antena monopolara (homemade) dintr-un cablu de cupru ecranat cu lungimea de 17 cm (frecventa ar trebui sa fie 433 MHZ). Credeti ca poate functiona?
  14. EEXCALADE
    Problema nu e la DPF .
  15. mad_kat
    @Bebeee - modul S de la Audi chiar face ceva - la hidramate nu este asa drastic raspunsul - intr-adevar doar dadaea pe S inaintea unei depasiri mai dificile sau pe serpentine - si cutia facea toata treaba - la hidramate insa, schimbarea - mai ales retrogradarea din butoane este ceva mai eficace. Iar pe polei din butoane se poate da frana de motor calumea (experimentat ultima oara acum doau saptamani) Sa nu aud de HDC - ala e bun doar in offroad - si uneori nici acolo. Sa stii in ce treapta esti e bine uneori - daca la 60kmh ai nevoie de o accelerare si o repriza mai buna - stiind daca e in a 3-a sau a 4-a, stii la ce te astepti si daca ai nevoie de kickdown/ retrogradare sau nu. W insa - daca au pastrat logica de la 722.6 este chiar fain - in D pleaca de pe loc in treapta a 2-a si in R are o a doua treapta, ceva mai lunga. @Doomy nu stiam ca au schimbat codul de cutie dupa 2022. Chiar ma bucuram ca au pastrat logica de comanda de la cutiile clasice.
  16. IoaneMxC
    Nu stiu cum e la DPF aftermarket, dar eu cand mi s-a dus EGR-ul la al meu Golf 6, am pus aftermarket...M-a tinut undeva la 15-20k km si s-a dus iar. So, never again aftermaket la asa ceva.
  17. GinelSB
    Octavia 4 - discutii generale
    Salut! Eu am Octavia Style automata si mai tot timpul la drumuri lungi( de la 2 ore in sus), imi amorteste piciorul stang. Inainte am condus Octavia 3 si Superb 3, neavand nicio problema!
  18. Baxxon
    incearca sa pleci lin , nu brusca acceleratia , foloseste-o gradual, cel putin pana se incalzeste , n-ar trebui sa simti prea tare cum schimba cutia , deci nu ca un soc. Cati km are masina ?
  19. Ieri
  20. Eugen B
    La masina de drive test, am condus 1 ora, vreo 60 km, scaunele mi s-au parut mai basic, muncitoresti, banale; eu am o slabiciune pentru scaune confort, am mai avut masini si intotdeauna am optat pentru scaunele confort, asa ca la configurare am ales varianta cu scaune cu reglaj electric, extensie la sezut, incalzite, ventilate, la drum lung nu resimt nici un disconfort.
  21. Aisin8cayenne
    nu smucește, se simte cum cuplează, adică se simte ca a schimbat viteza, nu pot să zic ca este smucitura, dar dacă ești atent simți sub mașină cum cuplează. Energic, 30% din accelerație, nu kick down, nici plecat lin… În Drive, în sport nu se simte nimic, ci doar când e accelerația mai energică (față de lin) și mașina schimbă în plajă 1900-2300 turații)
  22. corad0
    VW Phaeton 3.0TDI
    @tavitaraAsa e, n-are legatura greutatea, am avut ambele cutii pe Cayenne (prima generatie facelift 2009) tot 6HP, mai exact Aisin AW TR-60SN care era "bulletproof" pana la 300 000 km din ce spunea producatorul, la fel ca si ZF6 HP, apoi pe Cayenne Turbo cea de-a 2-a generatie 8HP, am prezentat ambele modele pe forum, se pot gasi topicurile. Cutia ZF in 6 trepte este foarte fiabila, am avuto pe mai multe modele de BMW, rezistenta la cuplu mare si poti trage dupa tine platforme/rulote etc, fara probleme. E normal sa se scoata din uz, trebuie sa faci lucruri care sa nu mai tina o viata, vorba aia, Mercedes era sa moara cu producerea modelului 124, puteai sa-l conduci pe viata fara sa se strice. Pai ce facem nene cu service-ul? Dam oamenii afara? 🙄 Phaeton este 95% aceasi masina la baza, chiar si dupa 15 ani de facelifturi, aparand pe piata in 2002, facuta pana in 2016, nu meritau investitii ulterioare, mai ales ca nu s-a vandut dupa asteptari. Cayenne-ul in schimb, a fost schimbat total in 2010, de la designul exterior la cel interior, chiar si mecanic este diferit, optionale etc. Era normal sa faca o schimbare, mai ales ca a fost best-seller. Cayenne a salvat brandul Porsche de la moarte, sa nu uitam asta! Am contribuit si eu consistent la asta! Phaetonul nu s-a vandut asa cum s-a preconizat, chair daca masina a fost proiectata dupa ideea de "best automobile in the world", asa ca nu a meritat investitii ulterioare. Chiar si asa, este singura masina care a primit buget de dezvoltare 1.5 miliarde euro si a avut o fabrica dedicata, doar pentru ea. Mint, si Bugatti a primit aceasi "reteta"! Deh, doar un om nebun care isi dorea perfectiunea ar fi putut sa faca asa ceva: Ferdinand PIECH! ❤️ Pe W12, 6.0 au avut cutii in 5 trepte...pe ultimele modele Phaeton produse, au reconstruit cutii de viteze SH, tot pentru a reduce costurile, au investit prea multi bani in acest model si rezultatul nu era cel pe care il asteptau, asa cum am mai spus, vanzarile la nivel de planeta au fost sub asteptari, deci==> ESEC! 😭 Oricum astea W12 au fost modele exclusive, in total au construit cam 100 000 modele, cumulat Audi A8, VW Phaeton, VW Touareg, Bentley Continental si GT/Flying Spur, modele pe care a fost disponibil acest motor. In prezent, nu mai avem parte de aceste motoare "opera de arta", exclusive...decat un derivat din W12, pe Bugatti W16 quad turbo. Un alt model care pierde bani, la fiecare model vandut, la fel cum a fost Phaetonul, dar nu mai conteaza, face parte din ELITA VAG..."ne scoatem parleala din vanzare de GOLF/Passat! DAR UITE CE PUTEM CONSTRUI!" ❤️ Nu va mai fi niciodata posibil asa ceva, indiferent de brandul auto! Cine va mai aloca asemenea bugete vreodata? 🥴 Motorul V6 3.0 TDI a fost prezent pe "mai toata gama premium VAG", de la Touaregul tau, Tavi, la A4/A6/A5/A7/A8/Q5/Q7/Cayenne (ambele generatii), Panamera, Macan, Phaeton etc... un motor potent, economic si fiabil, folosit "in masa/industrial". E adevarat ca are coduri diferite, in functie de modelul pe care e folosit si exista mici diferente, dar la baza e acelasi motor! Daca il ingrijesti conform, tine o viata, cred ca ai putea sa il dai chiar tu exemplu, cati km are Touaregul tau? 😊 N-as putea sa spun acelasi lucru despre noile motoare cu AD-blue in schimb. Ah, pe Touareg 7L s-a pus si V10 TDI, tot cu 6HP si W12. Vorba aia, n-o sa mai vedem masini exclusive facute la nivelul ala de detalii si calitate, niciodata! 😉 BTW, Touareg s-a scos total din productie! 😭 Acum daca vrei 3.0 V6 probabil va trebui sa te uiti in ograda AUDI, la alte preturi! Din pacate, pe modelele VW e ISTORIE! Intradevar pe Bentley au introdus ZF8HP in 2012, sper sa nu gresesc, dar au vandut un "Phaeton" la de 3 ori pretul, fara sa comenteze nimeni ca e prea scump, vorba aia, sigla! In prezent pe Bentley gasesti 3.0 V6 benzina, motorul folosit pe Audi, hibrid chiar. ❤️ Legat de bord, am detaliat pe pagina lui Baloo, n-are treaba bordul de 7L, da, "seamana, da nu rasare", materialele folosite in Touareg sunt sub (nu vorbesc de restul interiorului) de la ceasurile de bord cu geam si rame de plastic (comparat cu cele de Phaeton/Bentley care sunt de sticla/metal) pana la mai orice material folosit la crearea interiorului masinii, in schimb e copy/paste cu Bentley, s-au facut in aceasi fabrica, s-au folosit aceleasi materiale, vorba aia ...MASINA PREMIUM, am postat clipuri si detalii pe pagina masinii mele, dar e simplu sa folosesti google, se gasesc toate detaliile online:
  23. camelus
    injectoare recondiționate și în parametrii, turbina în parametrii, revizii la 10000km. Din păcate nu am timp cat mi-aș dorimca sa pot să plec la drum Pot lua în calcul și varianta unui DPF nou aftermarket, cel original are un preț prohibitiv…. Insa, nu găsesc niciun feedback despre cele aftermarket.
  24. Dolfin
    Nu exista intretinere preventiva la DPF, tu trebuie sa te asiguri ca motorul functioneaza corect in parametrii, acolo poti sa faci intretinere preventiva, ulei schimbat mai des, de ex. sau proactiva cand simti ca urmeaza sa apara o problema (corectii injectoare, oscilatie presiune in rampa, etc). Stai departe de curatare DPF, orice metoda din piata, chimica sau termica.
  25. Asa e @Bebeee nu prea conteaza treapta in care esti , ca info vad ca pleaca doar cu a doua de pe loc , daca trec manual pe treapta 1 imediat schimba a doua daca depasesc 10kmh , cred ca este doar pentru offroad treapta 1 , sau pentru tractat.
  26. Bebeee
    Asa putin important ii sa sti in ce treapa e la mers normal. Si padele alea, poate la ceva offroad te ajuta, in rest, daca ai nevoie dai kickdown si aia e. In rest stie cutia ce trebuie sa faca. Pe fostul RS3, am tot experimentat reprizele, verificand cu Dragy, si pe modul Auto S, era cea mai rapida si eficienta in accelerare.
  27. camelus
    Mulțumesc pentru răspuns! Am s-o mai urmăresc/evaluez varianta de curățare preventivă…. Dacă mai sunt colegi cu păreri, sunt binevenite😊
  28. @marius1982.11 Modurile ei care le pot selecta sunt : SPORT , WInter si Normal (D) In oricare din aceste moduri dau de padela + sau - , trece in treapta selectata -> in loc de D arata Treapta . Winter si SPORT au becuri separate in bord care indica activarea. Nu arata D2 sau S2 sau W2 . General vorbind SsangYong sau KGM , au ascuns sub pres modul manual al cutiilor rexton de la lansarea primului model de G4 Y400 din 2018 in sus : @mad_kat stiai tu ceva , numai ca odata ce au schimbat codul de cutie intre 2022 si 2024 au ascuns si modul M . Cele care au modul M si au fost vandute in Romania nu au Adblue - asta daca am eu informatia corecta . Si inca ceva -> @marius1982.11 tot la protectie este inclusa si asta : nu poti comuta modul SPORT fara 1 [cenzurat] din 4 la temperatura antigel.
