Sa înțeleg ca am? Iar acela este codul? Deci este vorba de o piesa defecta? Nu contează prețul dacă este vorba despre o piesa defecta nicio problemă punem originala ..doar sa existe și sa trebuiască sa o schimb
Ma ajutati si pe mine cu o lamurire, masina in cauza e un Touran 2010 4motion motor2.0 si din cand in cand apare martorul check engine in bord. Atasez logul, multumesc Tuesday,14,May,2024,11:10:06:00006 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 18.2.0.3 (x64) Data version: 20180212 DS287.0 www.Ross-Tech.com VIN: WVGZZZ5NZBW002513 License Plate: RICI Mileage: 305710km-189959mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 5N-VW36 (7N0) Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 4F 52 53 56 62 69 6C 72 77 VIN: WVGZZZ5NZBW002513 Mileage: 305710km-189959miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb Part No SW: 03L 906 018 FB HW: 03L 907 309 R Component: R4 2.0l TDI H21 9978 Revision: 42H21--- Serial number: 00000000000000 Coding: 00190012043600080000 Shop #: WSC 49620 187 00000 ASAM Dataset: EV_ECM20TDI01103L906018FB 003011 ROD: EV_ECM20TDI01103L906018FB_VW36.rod VCID: 6FED65BEB69D0A3CF1-803A 1 Fault Found: 4807 - EGR System P0401 00 [104] - Insufficient Flow Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 113 Mileage: 302124 km Date: 2024.05.14 Time: 14:13:31 Engine speed: 2134.50 /min Normed load value: 31.8 % Vehicle speed: 70 km/h Coolant temperature: 89 C Intake air temperature: 17 C Ambient air pressure: 980 mbar Voltage terminal 30: 14.300 V Unlearning counter according OBD: 39 Throttle_actuator_commanded_value: 32.84 % EGR Solen.val.: actual value: 15.99 % Charge air pressure specified value: 1212 hPa Charge Pressure Actuator: acknowledgment: 85.66 % Air mass: specified value: 309.7 mg/stroke Air mass: actual value (mg/stroke): 402.8 mg/stroke Readiness: 0 1 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb Part No SW: 5N0 614 109 Q HW: 5N0 614 109 Q Component: J104 C4 450 V25B 0006 Revision: --H28--- Serial number: 00000002838109 Coding: 0010546 Shop #: WSC 01324 020 00200 VCID: 39799BE67059948C1F-806C No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT Component: Climatronic H15 0709 Revision: 00003001 Coding: 0000000002 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_VW36.rod VCID: 7EF348FAE1F773B46A-802A No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb Part No SW: 5K0 937 086 F HW: 5K0 937 086 F Component: BCM PQ35 M 011 0035 Revision: BC011001 Coding: 40180A3B8825F3C0408800843400012443513088736D85605C8000000040 Shop #: WSC 01324 020 00200 VCID: 377D9DDE864D82FCE9-8062 Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB Component: Wischer 26051 012 0203 Serial number: N1955119 203! Coding: 009795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 190510 05 54 0403 Coding: 03304D Subsystem 3 - Part No: 1K8 951 171 Component: DWA-Sensor 00 001 0104 Coding: 000000 Subsystem 4 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Coding: 000000 3 Faults Found: 00883 - Ignition Switch (D) Terminal S 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 108 Mileage: 305258 km Time Indication: 0 Date: 2018.10.05 Time: 17:30:51 Freeze Frame: Term 15 On Voltage: 11.00 V ON ON OFF OFF ON 02198 - Bulb for Tail Light 2; Left (M49) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 40 Reset counter: 129 Mileage: 304584 km Time Indication: 0 Date: 2018.10.05 Time: 12:05:53 Freeze Frame: Term 15 On Voltage: 11.45 V ON ON OFF OFF ON 02199 - Bulb for Tail Light 2; Right (M50) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 254 Reset counter: 129 Mileage: 293016 km Time Indication: 0 Date: 2018.10.05 Time: 21:55:47 Freeze Frame: Term 15 On Voltage: 11.80 V ON ON OFF OFF ON ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb Part No SW: 1T0 919 475 H HW: 1T0 919 475 Component: PARKHILFE PLA H07 0110 Revision: -------- Serial number: 88591014094839 Coding: 310003 Shop #: WSC 01324 020 00200 VCID: 408FF602D383C54458-8014 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 N HW: 5N0 959 655 N Component: J234__200 VW10 HI 1916 Revision: 21014000 Serial number: 003GHP9YF27% Coding: 0012336 Shop #: WSC 01324 020 00200 VCID: 489FEE223BB3FD0490-801C Subsystem 1 - Serial number: 6332MTS611651240 Subsystem 2 - Serial number: 6342MTS636991250 Subsystem 3 - Serial number: 6351HTS6J6AI89KR Subsystem 4 - Serial number: 6361HTS634AI89KR Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb Part No SW: 5K0 953 501 BH HW: 5K0 953 569 L Component: LENKS.MODUL 009 0135 Revision: FF010036 Serial number: 20100519100266 Coding: 118A140000 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 71E963C6A0A91CCCE7-8024 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB Component: E221__MFL-TAS H05 0010 Coding: 820000 2 Faults Found: 147462 - Terminal 15 B1148 12 [008] - Short to Plus Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 37 Reset counter: 126 Mileage: 0 km Date: 2000.01.01 Time: 00:00:00 226057 - Ignition Starter Switch; Terminal S B1147 F1 [008] - Open or Short to GND Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 107 Mileage: 305118 km Date: 2024.05.14 Time: 18:23:08 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 5N0 920 872 A HW: 5N0 920 872 A Component: KOMBI H03 0406 Serial number: 00000000000000 Coding: 110F01 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089 ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod VCID: 306FA6C26B2355C4A8-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb Part No SW: 7N0 907 530 A HW: 1K0 907 951 Component: J533 Gateway H25 0602 Revision: H25 Serial number: 120510F1001635 Coding: F9A27F4640461300006002 Shop #: WSC 01324 020 00200 VCID: 2E53B8BAB9174334BA-807A No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 0AY-907-554-V1.clb Part No SW: 0AY 907 554 D HW: 0AY 907 554 D Component: Haldex 4Motion 0042 Coding: 0000005 Shop #: WSC 00000 000 00000 VCID: 4C97D2322FCB1124B4-8018 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H03 0406 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008 ROD: EV_Immo_UDS_VDD_RM09.rod VCID: 6ADB74AA8D7FEF14A6-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 C HW: 5N0 035 342 C Component: SG EXT.PLAYER H13 0111 Revision: A1001003 Serial number: 7668088721 Coding: 010000 Shop #: WSC 01324 020 00200 VCID: 275D4D9E56ED127C79-8072 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 C Component: RNS-MID H06 5238 Revision: AB001001 Serial number: VWZ6Z7K5145021 Coding: 04000402040000800000 Shop #: WSC 01324 020 00200 VCID: 377D9DDE864D82FCE9-8062 Subsystem 1 - Part No: 1T0 919 859 C Component: EU East V16 8542 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb Part No SW: 5N0 959 701 E HW: 5N0 959 701 E Component: Tuer-SG 009 2101 Coding: 0004286 Shop #: WSC 01324 020 00200 VCID: 377D9DDE464D82FCE9-8062 1 Fault Found: 00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 5N1-909-144.clb Part No SW: 5N1 909 144 L HW: 5N1 909 148 G Component: J500__APA-BS KL.220 0802 Revision: 1AH03831 Serial number: 00101410500001 Coding: 0000258 Shop #: WSC 01324 020 00200 VCID: 3B7581EE7A65A69C0D-806E No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 1K0 907 951 Component: EZE_2 H25 0602 Revision: H25 Serial number: 120510F1001635 Coding: 050B0500 Shop #: WSC 01324 020 00200 VCID: 6FED65BEBE9D0A3CF1-803A Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H01 0220 Serial number: 0123456789ABCDEFGHIJ Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J394EE20SKB13 H01 0220 Serial number: 0123456789ABCDEFGHIJ 1 Fault Found: 02071 - Local Databus 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 1 Fault Frequency: 4 Reset counter: 126 Mileage: 305071 km Time Indication: 0 Date: 2018.10.05 Time: 13:35:47 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb Part No SW: 5N0 959 702 E HW: 5N0 959 702 E Component: Tuer-SG 009 2101 Coding: 0004542 Shop #: WSC 01324 020 00200 VCID: 387F9EE24B538D84E0-806C No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3AA-907-801.clb Part No SW: 3AA 907 801 D HW: 3AA 907 801 D Component: J540 EPB4 VW-53083 0006 Revision: H18 Serial number: 00000000005105 Coding: 0023057 Shop #: WSC 01324 020 00200 VCID: 326BACCAAD2F67D4DE-8066 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels:. 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 C Component: RNS-MID H06 5238 Revision: AB001001 Serial number: VWZ6Z7K5145021 Coding: 04000402040000800000 Shop #: WSC 01324 020 00200 VCID: 377D9DDE864D82FCE9-8062 Subsystem 1 - Part No: 1T0 919 859 C Component: EU East V16 8542 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 5N0 959 703 D HW: 5N0 959 703 D Component: Tuer-SG 007 2102 Coding: 0000144 Shop #: WSC 01324 020 1012552 VCID: 387F9EE24B538D84E0-806C No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb Part No SW: 1K0 907 383 F HW: 1K0 907 383 F Component: Anhaenger H07 0070 Revision: 3A001001 Serial number: 00000129913187 Coding: 410D000100000000 Shop #: WSC 01324 020 00200 VCID: 306FA6C2632355C4A8-8064 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 5N0-907-441.clb Part No SW: 5N0 907 441 A HW: 5N0 907 441 A Component: J772__Rearview 0020 Revision: 00H08000 Serial number: 525PA8-J046922 Coding: 0030010 Shop #: WSC 01324 020 00200 VCID: 2D51BFB6B411382C83-8078 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 5N0 959 704 D HW: 5N0 959 704 D Component: Tuer-SG 007 2102 Coding: 0000144 Shop #: WSC 01324 020 1012552 VCID: 39799BE67059948C1F-806C No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb Part No SW: 3C8 035 730 A HW: 3C8 035 730 A Component: Telefon 007 0078 Revision: -------- Serial number: 35909603004948 Coding: 020100000100000000010000 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_UHVPremi A01005 ROD: EV_UHVPremi_A01.rod VCID: 2149538630C9EC4C37-8074 2 Faults Found: 9458449 - Cellular Antenna B1053 11 [009] - Short to Ground [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 11 Reset counter: 180 Mileage: 292953 km Date: 2024.05.14 Time: 11:01:34 13893888 - Function Restricted due to Exessive Voltage U1401 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00 End-------------------------(Elapsed Time: 04:40)--------------------------
5C6 810 773 K pe vremuri aveau in portbagaj o sufa de care sa deschizi in caz de defect... dar s-a renuntat la asta. nu are rost sa iei din dezmembrari, il iei tot pe ultimele zvacniri de viata...
Buna seara, am intrat de ceva vreme in posesia unui golf 6, si am o dilema.Etrierii de pe spate sunt cam obositi, iar set de reparatie nu se poate pune.Cineva a spart carcasele la ambii, pentru a baga ceva spray degripant chiar unde se blocheaza axul levierului ce apartine franei de mana.In dezmembrari am gasit tot de golf 6 variant, dar an 2013, al meu fiind 2009.Sunt mai slim la corp, si portetrierul nu are curbura dupa disc, este practic in unghi de 90 de grade constructia lui.Aceleasi placute nu se potrivesc de pe unul pe altul, aici alta dilema.Nu stiu ce am pe masina acum, nu am fost atent cand am deblocat etrierul de pe dreapta, dar ce am luat este bosch.Oare se potrivesc, ori i-am cumparat degeaba?Imi cer scuze daca a fost discutat deja subiectul, sunt pe fuga cumva.
WVWZZZAUZFW021381 Nu am din construcție la golf 7 2014 nici un fel de închidere de protectie pentru usita acces motorina A mai pățit cineva ? Ce pot face? Se poate monta din dezmembrări? Este anormal ? Mai are cineva aceasta problema? WVWZZZAUZFW021381 Nu am din construcție la golf 7 2014 nici un fel de închidere de protectie pentru usita acces motorina A mai pățit cineva ? Ce pot face? Se poate monta din dezmembrări? Este anormal ? Mai are cineva aceasta problema? WVWZZZAUZFW021381 Nu am din construcție la golf 7 2014 nici un fel de închidere de protectie pentru usita acces motorina A mai pățit cineva ? Ce pot face? Se poate monta din dezmembrări? Este anormal ? Mai are cineva aceasta problema? WVWZZZAUZFW021381
Passat Variant - se scurge apa de pe hayon in portbagaj
F l o r i n a postat în topic iniţiat de cipo din Passat B8
Cosmin, are aproape 2 ani postul de mai sus... -
Am mai întâlnit și eu acesta situație, turație modificata din soft tot pt volant cu joc. Ai pus un soft pre diesel gate?
Nu exista asa ceva. E defect actuatorul. Da-mi seria sasiu și verific ce cod are.
F l o r i n a postat în topic iniţiat de Mama Omide din Passat B6
Nu. Codare cu 011 sau 012...plus setarea de baza. Comanda mufe noi originale, ca să remediezi corect problema -
Ne punem panouri,pompe de caldura,ne luam masini electrice si nu mai platim combustibil,gaz,curent …devenim independenti …ce film frumos ! Si statul ce mai “mananca” ? In momentul cand majoritatea vor avea ev-uri (panouri ) vor aparea diverse taxe ,energie mai scumpa…..nu vor permite sa fim independenti,niciodata nu am fost . -
Xman_ghio a postat în topic iniţiat de lupo_bv din Tehnic
@Savescu Lenuta Nu trebuie sa faci nimic special - doar sa ii faci intretinerea cutiei (si motorului) corespunzator. Cauta un mecanic bun in zona ta si respecti indicatiile lui/ei. La oprire eu fac asa: masina stationeaza (motorul pornit), piciorul pe frana, comut din D in P, opresc motorul (tinand inca piciorul pe frana); dupa oprirea motorului se cupleaza automat frana de mana electrica. Deci iarasi nimic SF, ci doar sa tii piciorul pe frana pana cand ai parcat si in timp de comuti din D in P si cand ai oprit motorul. La fel ca si @Cristi S. fac la semafor: in general raman in D. Doar cand stau "bara la bara" (de ex. in vama la greci cand am asteptat 1 ora) am comutat pe manual si lasat in viteza 1 ca sa nu preselecteze si sa "streseze" celalalt ambreiaj. Va trebui sa inveti sa auzi cand isi face motorul regenerare DPF ca sa nu il opresti si sa mai faci un drum de 5-10-15 minute ca sa finalizeze cu succes regenerarea. Si la o saptamana/10 zile sa iesi cu masina la un drum lung si condus mai vioi ca sa nu se infunde DPF. -
Cristi_V a postat în topic iniţiat de cristi511 din Octavia 4
Ce înseamnă forjate maxim? Aceste motoare au putere și cuplu maxim pe o plaja lunga de turații. -
Asa si un 3.0 poate fi tot un downsize fata de un 5.0 🙂 Motoarele 1.4-1.6-1.8 sunt dimensionate ok. Cele 1.2 si 1.0 erau subdimensionate si forjate maxim ca sa scoata toata puterea posibila si imposibila. -
Downsizingul si introducerea supraalimentarii (turbocompresor) sunt strans legate. Deci si 1.5 TSI este tot un downsizing. Fara legatura cu downsizingul poate ca 1.0 TSI nu este suficient de puternic sa duca multumitor o caroserie de 1300 kg + incarcatura. Dar nici un 1.5 MPI nu ar fi multumitor. Poate ca un 2.2-2.5 MPI ar avea performata unui 1.5 TSI? -
@halamadridOoo, ma bucur ca mai sunt cinefili pe forum! 😀 Hai sa inviem topicul de filme si sa povestim aici:
Bebeee a postat în topic iniţiat de cristi511 din Octavia 4
Da, corect si asta. Dar oricum pentru consumatorul final este un plus motorul de 1.5. -
Video-ul din Bay Area - California a devenit viral in 24h, au aparut si o multitudine de articole referitoare la aceasta situatie. Nu este un caz izolat, in decurs de o 1 saptamana 5 superchargere din Houston au fost vandalizate, au inceput acum o saptamana in cartierul Montrose din Houston s-au taiat 18 din cele 19 cabluri de la Tesla charger, iar conform reportajului politia din Houston a creat si o unitate specializata pe furturi de metale. Tesla charger sunt foarte apreciate de utilizatorii de Tesla, sunt raspandite, ofera o experienta de incarcare buna, ca timp (baterii mari in masini, incarcare cu puteri mari), ceea ce da posibilitatea unui utilizator sa poata folosi un EV aproape identic cu un ICE. Despre cat de jos a ajuns America acum...nu este subiectul topicului.
adrian001 a postat în topic iniţiat de cristi511 din Octavia 4
Sau mai degraba e mai ieftin sa ai un singur motor pe care sa il setezi la diferite puteri (uneori doar din soft, alterori cu diferente minime hardware) si sa il vinzi la preturi diferite. -
Probabil ca si-au dat seama intr-un final ca toata nebunia cu downsizeingul este o prostie. -
AnNemic a postat în topic iniţiat de Mama Omide din Passat B6
O sa schimb mufele, astea aparent nu mai clipseaza cum trebuie, par puțin deformate. Sunt conștient ca are un rol important mufa. Îmi poți spune, te rog, cum sa codez modulul? Abs e codat ok, fără erori. În afara de a introduce acel 0000012 la coding, mai trebuie făcut ceva? Mersi de ajutor! -
Al Bundy a postat în topic iniţiat de Mama Omide din Passat B6
garnitura trebuie sa o lasi sa nu intre apa. Daca ai pus acelasi cod de modul, si daca abs e codat ca inainte la fel trebyuie sa codezi si modulul. -
Al Bundy a postat în topic iniţiat de Retzius din Modele Electrice
Nu ai privit cu atentie videoclipul..... -
Ce relevanță are videoclipul? Sunt și benzinării goale. Asta înseamnă că mașinile circulă și nu stau la alimentat. Și mai înseamnă și că sunt suficiente stații de încărcare astfel încât să nu se creeze cozi. Eu chiar îmi doresc că bateriile să devină tot mai performante și fiecare om să-și producă singur energia, fără să mai stea la cheremul companiilor petroliere. Îi felicit pe cei care își cumpără mașini electrice și astfel susțin cercetarea în domeniu. Odată cu dezvoltarea tehnologiei, pentru tot mai mulți o să merite o mașină electrică.
Salutari, va scriu azi cu o intrebare referitoriu la coding pentru fauri Golf 6. Sunt din Canada si detin un Golf 6 TDI combi din 2013, cu faruri stock Halogen. Am cumparat recent fauri de la VLAND cu DRL care sunt LED, si bine inteles, pe site nu scrie nimica despre errori de BULB OUT la bord. Am facut niste cercetari online, si nu am gasit un raspuns definitiv referitor la coding. Stiu ca se poate schimba cu VCDS sau ODBeleven mergand la 09 - Central Electrics, si schimband codul din Byte 18. Problema ei ca parca dupa model anul 2010, Byte 18 arata 00, care este cod generic si codul adevarat este ascuns, si numai cu VCP sau ODIS se poate vedea codul adevarat. Zicand asta, am verificat masina mea cu OBDeleven, si arata 00, deci nu vreau sa schimb codul din byte 18 fara sa aflu care este codul original. Sar putea sa am aces la VCP incurand, deci probabil ca voi afla care este codul original. Din ce am citit, pentru ROW (rest of world), ar fi 03 sau 06 parca, dar in orce caz, si daca aflu codul original, nu stiu care ar fi codul modificat pentru faruri cu LED DRL, deci am venit aici sa intreb, fiind ca modele de Golf 6 in Europa a venit cu mult mai multe variante de faruri fata si spate, si poate gasesc mai multa informatie aici. Am atasat un link cu farurile VLAND care le am cumparat. https://www.vland-official.com/en-ca/products/yuanzheng-led-head-lamps-for-volkswagen-golf-mk6-2010-2014?_pos=2&_sid=6f1a6641b&_ss=r Va multumesc
