  2. marius1982.11
    VW CC 3.6 VR6
    De ce nu? pt ca 2k euro impozit anual, daca nu esti scutit cumva. In rest da, e ce trebuie. Sa o folosesti sanatos si fara incidente. Fain interior, mai ales daca ai copii mici.
  3. Salut, Am un passat cc din anul 2008 cutie automata si nu imi mai functineaza acc, esp, abs, reglaj suspensie si frana de mana( se trage doar daca a pas a doua oara si doar pe partea soferului) Am schimbat motorasul de frana de mana pe dreapta si tot nu functioneaza. Prind module am gasit codari aiurea( frana de mana avea o codare de genul 001000 ce nu exista) Am codat cum trebuie prin toate modulele mai putin in ABS imi cere cod de securitate iar cele oferite in vcds nu merg. https://www.youtube.com/watch?v=xziv5410qgI ( aici are aceeasi problema si o rezolva din codare) Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb Control Module Part Number: 3C0 614 109 R HW: 3C0 614 109 R Component and/or Version: J104 C4 440 V3 0013 Software Coding: 0002349 Work Shop Code: WSC 00012 000 00000 VCID: 2D51BCB3B41137F958-8078 6 Faults Found: 01542 - Yaw Rate Sensor (G202) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Voltage: 12.00 V Bin. Bits: 00010001 Count: 166 Hex Value: 0x0000 01423 - Lateral Acceleration Sensor (G200) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Voltage: 12.00 V Bin. Bits: 00010001 Count: 167 Hex Value: 0x0000 01279 - Longitudinal Acceleration Sensor (G251) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Voltage: 12.00 V Bin. Bits: 00010001 Count: 188 Hex Value: 0x0000 01542 - Yaw Rate Sensor (G202) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Voltage: 12.00 V Bin. Bits: 00010001 Count: 166 Hex Value: 0x0000 01423 - Lateral Acceleration Sensor (G200) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Voltage: 12.00 V Bin. Bits: 00010001 Count: 167 Hex Value: 0x0000 01279 - Longitudinal Acceleration Sensor (G251) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Voltage: 12.00 V Bin. Bits: 00010001 Count: 188 Hex Value: 0x0000 Address 5C: Lane Maintain. Labels: 3C0-907-217.clb Control Module Part Number: 3C0 907 217 B HW: 4E0 907 217 C Component and/or Version: J759 HCA 0160 Software Coding: 0022002 Work Shop Code: WSC 08901 995 97642 VCID: 224B5F8FFDCFF881F5-8076 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Address 10: Park/Steer Assist Labels: 3C8-919-475.clb Control Module Part Number: 3C8 919 475 HW: 3C8 919 475 Component and/or Version: PARKHILFE 8K H07 0007 Software Coding: 100101 Work Shop Code: WSC 05314 000 00000 VCID: 71E960C3A8A913193C-8024 1 Fault Found: 16347 - Control Module - EEPROM Error 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 0 Time Indication: 15 Freeze Frame: Temperature: 0.0°C Address 13: Auto Dist. Reg Labels: 3C0-907-567.clb Control Module Part Number: 3C0 907 567 J HW: 3C0 907 567 J Component and/or Version: AC201 RDW A 031 0232 Software Coding: 0010000 Work Shop Code: WSC 05311 000 08193 VCID: 326BAFCFAD2F680105-8066 3 Faults Found: 01314 - Engine Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:30:14 Freeze Frame: Count: 4 01316 - ABS Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 5 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:30:14 Freeze Frame: Count: 11 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 220 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:35:63 Freeze Frame: Count: 12 Address 14: Susp. Elect. Labels: 3C0-907-376.clb Control Module Part Number: 3C0 907 376 HW: 3C0 907 376 Component and/or Version: DAEMPFUNGS-SG H07 0069 Software Coding: 030180 Work Shop Code: WSC 05314 000 00000 VCID: 66C3039F9167C4A159-8032 2 Faults Found: 01319 - Control Module for Distance Control (J428) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Freeze Frame: Bin. Bits: 00000000 00000001 01316 - ABS Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:26:16 Freeze Frame: Bin. Bits: 00000000 00001010 Address 53: Parking Brake Labels: 5N0-907-801.clb Control Module Part Number: 3C8 907 801 A HW: 3C8 907 801 A Component and/or Version: J540 EPB3 VW-10498 0003 Software Coding: 0000057 Work Shop Code: WSC 05311 000 00000 VCID: 285F4DA79BF312D1AB-807C 4 Faults Found: 01087 - Basic Setting Not Performed 000 - - - MIL ON Freeze Frame: Fault Status: 11110000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Time Indication: 0 Freeze Frame: Voltage: 0.00 V Count: 43 - Hex Value: 0x4040 Hex Value: 0x00A2 Hex Value: 0x1010 00003 - Control Module 014 - Defective - MIL ON Freeze Frame: Fault Status: 11111110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:32:01 Freeze Frame: Voltage: 12.00 V Count: 46 Speed: 0.0 km/h Hex Value: 0x1251 Hex Value: 0x0021 Hex Value: 0x0104 01542 - Yaw Rate Sensor (G202) 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 180 Mileage: 337900 km Time Indication: 0 Date: 2020.02.14 Time: 21:32:01 Freeze Frame: Voltage: 12.00 V Count: 89 Speed: 0.0 km/h Hex Value: 0x1251 Hex Value: 0x0021 Hex Value: 0x0104 01279 - Longitudinal Acceleration Sensor (G251) 005 - No or Incorrect Basic Setting / Adaptation - MIL ON Freeze Frame: Fault Status: 11110101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Time Indication: 0 Freeze Frame: Voltage: 0.00 V Count: 101 - Hex Value: 0x4040 Hex Value: 0x00A2 Hex Value: 0x1010
  4. Hayate
    VW CC 3.6 VR6
    De ceva timp, vizionand clipuri pe Youtube mi-a incoltit un gand: de ce nu? Mai ales ca intotdeauna mi-am dorit un CC facelift. Asa ca am cautat pe mobile.de si am gasit masina pe care am adus-o personal din Germania: VW CC ,motor 3.6l VR6, fabricatie 05.2012 Ca si dotari, din ce imi amintesc din configuratorul VW nu are geamuri duble pe fata, priza 220V, alarma si carlig de remorcare. In rest, le bifeaza pe toate: - Park Assist - Side Assist - Lane Assist - Front Assist - Adaptive Cruise Control - Faruri Bi-Xenon cu Dynamic Light Assist - Navigatie RNS 510 - Bluetooth - Scaune din piele Nappa, electrice, cu memorie, incalzite, cu masaj si ventilatie - Scaune spate incalzite - Lumini ambientale in usi - Footwell lights - Door warning lights - Privacy glass _ Perdeluta electrica luneta - Keyless acces - Portbagaj cu deschidere electrica si pedala virtuala - Incalzire si ventilatie stationara Webasto - Oglinzi incalzite, iluminate, rabatabile electric cu oglinda heliomata pe partea soferului - Climatronic - Ceasuri de bord color - Trapa panoramica - Sistem audio Dynaudio Masina s-a comportat bine pe tot parcursul drumului din Germania pana in Romania. Ce i-am facut pana acum? Am schimbat pompa de apa si antigelul, uleiul, filtrul de ulei, filtrul de aer si am reconditionat etrierul de pe dreapta spate. Planuri de viitor: Jante Interlagos 18", volan R-Line si ceasuri de bord 3D Va las mai jos cateva poze cu masina. Drumuri bune!
  5. corad0
    Si de cine vrei sa vorbim? De aia care nu merg cu rulota? Dezbateam un subiect...😄 nu inteleg.. Am vazut si eu live pe autostrada in UK TIR, cap tractor care avea remorca (trailer) rulota. Ceva asemanator, am atasat o poza. Bani iti trebuie si daca inchiriezi si daca ai rulota ta si daca mergi 1 saptamana si daca mergi 1 luna, locatia de campare este iar foarte importanta, distanta de calatorie si costurile variaza, totul in functie de pretentii, detalii..bani ai nevoie, oricum, mai multi sau mai putini, nu a spus nimeni ca e un hobby ieftin.
  6. Astăzi
  7. mishu1981
    Sfaturi achizitie Kodiaq 2
    Eu am comandat sportline 2.0 TDI pe 14 februarie si dealerul mi-a comunicat acum 2 luni ca masina e programata a intra in productie la inceputul lunii noiembrie. In urma cu o săptămana am sunat din nou si mi s-a comunicat ca poate am noroc anul asta sa intru in posesia masinii, asta din cauza comenzilor foarte multe. Termenul din contract 28-42 sapt.
  8. halamadrid
    Simt nevoia sa ma repet. Voi vorbiti de aia cu bani. Caz in care, iti cumperi ce jucarie vrei, inclusiv o chestie numita rulota. Am vazut motorhome-uri si la 2 milioane, un autocar transformat intr-o casa de lux pe roti.
  9. Al Bundy
    Inchidere centralizata - Probleme
    NU.
  10. Ieri
  11. bodincatalin
    Jurnal DSG6
    Salut, dețin un Passat B6 din 2010 motor 2000 CBAB cutie DSG in 6 trepte.Atunci cand merg în coloană ,bară la bară începe să smucească la plecare (nu foarte tare) iar când schimbă din treapta 2 în 3 sau când se reduce din 3 în 2 face la fel.Câteodată rămâne turata în treapta trei când se reduce din treapta 4.Am pus testerul VAG dar nu îmi da nici o eroare. Am schimbat ulei și filtru din cutie. Care ar putea fi cauza? volant(se cam aude) ? Sau ambreiajele din cutie ? Mulțumesc
  12. corad0
    @tavitara Nu esti ciudat, si mie imi place cat mai "izolat"! Socializarea cu straini o facem doar "online" din spatele unor ecrane..nu stiu daca e neaparat bine insa am avut incredere in prea multi "prieteni" care m-au dezamagit si mi-a ajuns. Mie imi place caracatita, mai ales aia "carnoasa"...cu sos merge de minune! Ce sa mai zic, legat de serialul "La Piovra"🐙, am avut mari fani in familie daca mi-au pus numele asta...😁
  13. tavitara
    Da , am prins cativa pui de crap pana in 2 kg maxim , mi-am cerut scuze si le-am dat drumul imediat , dar sunetul naturii si locul ala ascuns dupa dealuri au fost mai faine E un drum de pamant cu piatra care urca si coboara 3-4 km de dealuri si brusc intra intr-o padure de stejari din aia veche - iar cand iesi din padure iti apare lacul ala in fata .... Sambata si duminica am inteles ca vin multi , de aia eu cer voie sa vin in timpul saptamanii desi nu e voie , sa fiu singur Asa sunt eu mai ciudat , ma simt mai bine in natura cu animalele salbatice decat cu oamenii , imi ajung ai mei , nu simt nevoia sa socializez cu straini Tare nu imi place cand vad caracatita pe farfurie , nu as putea manca asa ceva , mai ales dupa ce am vazut filmul ala de oscar cu caracatita
  14. traiantkd
    Asa mare cerere sa fie? 😃
  15. corad0
    @marius1982.11"asta pana cand nu vine careva cu boxa portabila si semintele, berea la PET" As adauga fum de la mici si manele la maxim, niste puradei sa urle pe fundal ar fi un bonus! ❤️ @halamadrid"Nu stiu cine isi permite sa stea 100 de zile/an plecat in vacanta" Ohooo cati bani se invart in lumea asta, ai fi surprins! Mai ia-i in considerare si pe seniorii iesiti la pensie! Strainii in varsta au strans averi, se bucura de viata, merg cu lunile in vacanta! Altii au venituri pasive, nu mai e nevoie de munca! Hoteluri si restaurante pline in lumea asta, indiferent de sezon si indiferent de cat de scumpe sunt locatiile, ca sunt la mare, la munte, nu conteaza, lumea merge si la ski si la plaja si la hiking si la mountain bikeing. Sa vezi cati merg cu caiacu' pe plafon! Unii chiar traiesc! Opresc de multe ori la benzinarie, se da jos cate o fosila din GT3 RS, d-ala de Nurburgring, cu bari in spate, abia se ridica din scaun, abia alimenteaza, te si gandesti...asta ce o fi fost la viata lui? Ii vezi pe autostrada la volan in supercaruri, in rulote...unii te miri ca mai au voie sa conduca la cat sunt de batrani! 🤪 Citeam un articol care spunea ca principala boala a batranilor din tarile vestice este Alzheimer. Traiesc o viata sanatoasa, fac sport si atunci corpul rezista, in schimb dementa isi face aparitia...in Anglia asa se si numeste boala: Dementia. Esticii daca prind 60 de ani sa zica sarumana! Nu mai sunt vremurile alea cand mamaie si tataie mancau din gradina si munceau la camp si aveau conditie fizica si traiau pana la 90 de ani! Salut! (din pacate) "Degeaba ai 7000 de franci venitul lunar daca te costa 5000-6000 de franci sa iti duci traiul." Nu ii plange tu pe elvetieni! Glumesti? Unde e aurul nazistilor? "It is estimated that nearly 91 tonnes (100 short tons) of Nazi gold were laundered through Swiss banks, with only 3.6 tonnes (4 short tons) being returned at the end of the war." Au returnat 4 tone cica... HA-HA! ❤️ Un apartament cu 2 camere in zona Lucern e vreo 2000 de franci/luna chirie. Si chiar sa fie adevarat, sa te coste 5000 CHF pe luna traiul, desi nu te costa atat decat daca platesti rate la Ferrari si mananci doar la restaurant, da' sa zicem, tot ramai cu 2000 CHF/luna in mana, cu un singur salariu mediu, e putin??? 😄 Daca lucreaza si sotia, mai ia si ea inca atat! Si sa ia mai putin, ce mai conteaza, deja salariul in plus e "de cheltuiala" Ia vezi, mai e nasol? Oricum, crezi ca de prosti sunt elvetienii in afara UE? Nu vor sa vina strainii sa le strice "apele", sa lucreze pe 3 lei, sa le strice piata si sa scada pretul imobiliarelor. Da, e scumpa viata in Elvetia, dar nu te impiedica nimeni sa iti faci cumparaturile in Germania, de exemplu! Eu conduceam 30 de minute pana in Germania la LIDL! Faceam cumparaturile pentru 1 saptamana. Mancarea costa jumatate din cat costa in Swiss. In maxim 2 ore esti in orice tara din jur : Italia, Franta, Germania, Austria si Liechtenstein. ❤️ Tocmai de asta au votat si in UK Brexit. Au destui emigranti, le ajunge! Doar ca romanu' "standard" priveste totul doar din punct de vedere financiar. "CATI BANI IMI DA IN MANA?" Nu isi pune problema...."BAH DA EU CE STIU SA FAC?" Nu se gandeste la calitatea vietii, la aerul respirat, la infrastructura, la educatie, la sistemul medical, la calitatea produselor, a mancarii, la faptul ca nu se baga nimeni in fata lui la semafor, fentand coloana si claxonand in momentul in care s-a pus verdele: "HAIDEEE BAAAA, HAI!" De exemplu faptul ca nu ai nevoie sa dai "ciocolata" si "cafea" pe la institutii, nu iti cere nimeni dosar cu sina si cereri scrise si semnate de la ghiseu si treburi de genu' asta. Orice problema o rezolvi online. Afara n-ai nevoie de relatii. Va trebui sa ma crezi pe cuvant. Da, limba poate fi o problema, dar orice se invata daca exista ambitie. Nu e lapte si miere si nimic nu e usor si nimeni nu iti da bani sa stai degeaba! 🙄 @tavitara"Nefiind elvetian eu m-am dus la pescuit" Frumos la balta, ai prins ceva? 😄 Nici eu nu sunt elvetian dar am colindat Elvetia aia de la un cap la altu' mai multi ani, aveam cazare gratis la fratemiu care a locuit multi ani acolo. (vreo 15) Mai mergeam si eu sa sar in "balta" de langa bloc si sa "sorb" o bere, chiar mi-am adus aminte ca erau 3 campinguri mari langa lacu' asta, plin de nemti, italieni, francezi, olandezi, belgieni (plin de turisti din tari nordice, Suedia, Norvegia etc) cu rulotele: Am si cumparat o masina de la un vecin, aflasem ca vrea sa o vanda, era a fiului lui care plecase la studii in America, masina avea 110 000 km, cumparata de noua de la Zurich. Pret de lista 77k CHF, mi-a dat-o la bani de Sandero nou. Mi-au placut intotdeauna break-urile, am avut si e39 break! ❤️ (Am avut si e39 sedan si e60 sedan) Am scris si la pagina 7 a topicului despre ea. Am dat-o dupa niste ani cu vreo 330 000 km, am "cutreierat" toata Europa cu ea! A luat-o un baiat la 2 ore dupa ce pusesem anuntul: Am gasit niste poze pe vremea cand mergeam pe insulele de la Marea Ionica, pentru cei care vor sa vada cele mai frumoase plaje din Grecia, recomand:
  16. Otvos zoltan
    Suspensie pneumatica - Probleme; Retrofit & Mod de funcționare (Touareg 7P)
    Bună ziua tuturor Dețin un Volkswagen Tuareg din 2010 7p 3.0 Disel 176 kw Am o problemă cu amortiza toarele Am Schimbat suspensia pe perne pe spate, Amortiza toarele funcționează în trei niveluri Foarte greu am reușit să duc mașina la nivel Problema e că amortiza toarele spate rămân rigide 0340 - Ventile pentru reglaj amortizare C10FE 01 [00001000] - defect electric Ar putea să-mi zică cineva cum aș putea să rezolv problema Mulțumesc tuturor
  17. dercos
    ''Cine munceste e pierdut!'' Lasand gluma la o parte, sunt foarte multe persoane care au castigat foarte multi bani si se retrag din ''rat race'' dupa 40 de ani. Stiu si eu astfel de persoane, unul din ei vinde lubrifianti ( nu pentru piese metalice :))) catre magazine online si sta toata ziua la golf si vacante.
  18. marius1982.11
  19. razvan.ac
    Consum Kodiaq 2 - benzină
    Multumesc, poate ma prind eu mai greu, mea culpa. Oricum e bine de mentionat corect in postare despre ce masina este vorba pentru ca nu e potrivita cu subiectul topicului si nu ne pricepem toti la motorizari, diferente intre modele…
  20. Mihai94TDI
    Stiu, de asta am si întrebat daca se poate face ceva din VCDS
  21. CiprianB
    Am scris mai sus ca e cel de 190 deci Kodiaq 1. Am pus să își facă o idee de cât ar consuma un 2.0 Tsi.
  22. tavitara
    Nefiind elvetian eu m-am dus la pescuit , chiar am descoperit o balta de care nu stiam , 50 de lei 24 de ore - intre 2 crapi poti admira padurea de stejari si batlanii care se joaca pe marginea apei
  23. razvan.ac
    @CiprianBMultumim pentru informatii, dar, spune-mi, te rog, consumul afisat este pentru un urs v 2.0 (Kodiaq II) ? Din poza pare ca informatia este utila intr-un alt topic.
  24. Al Bundy
    Se pare ca tu nu ai explicat de la inceput ce doresti sa faci. Atata timp cat contactul e pus, telecomanda nu functioneaza.
  25. halamadrid
    Nu stiu cine isi permite sa stea 100 de zile/an plecat in vacanta, decat aia cu bani si fara o rutina zilnica ce se numeste munca, sau oricum, nu munca asa cum o percepem majoritatea. Ca tot veni vorba de ei, elvetienii pleaca in vacante in alte tari, unde de banii (multi) pe care ii castiga la ei pot obtine mai mult. Degeaba ai 7000 de franci venitul lunar daca te costa 5000-6000 de franci sa iti duci traiul. In luna de concediu cat esti plecat faci "economie" prin Spania, Italia, Portugalia. Iar de respectat regulile, le respecta la ei acasa, ceva mai putin afara. Fapt remarcat si in ce-i priveste pe scandinavi. La romanasi e invers, afara din tara se tem. 😀
  26. corad0
    Asa e, cam asa am calculat si eu o medie sa zicem de 1 vacanta misto pe an (10 zile) timp de 20 de ani, da, sunt multi bani sa dai pe o masina din asta de vacanta, problema e cu sunt foarte multi care merg cu motorhome-ul si stau 3 luni in vacanta sau fac tururi, viziteaza multe tari intr-un an si atunci e super mega rentabil daca e sa pui pe hartie. Cat ar costa 60-100 de zile pe an de cazare la hotel? Cert e ca, asa cum spuneam trebuie sa ai timp in primul rand, se deduce ca ai deja bani, altfel nici din punctul meu de vedere nu se prea renteaza sa detii asa ceva, mai bine inchiriezi daca tot esti doritor de aventura/camping, ideea e ca trebuie sa iti faci rezervare prin toate campigurile misto cu un an cel putin inainte, mai toate sunt full!
  27. marius1982.11
    Dar nimeni nu te opreste ca din aia 70k, 7k sa ii pui la bursa sau la cripto, sa studiezi si sa scoti inca 70k :)). Si uite asa ai o sansa sa nu privesti cu jind la milioanele Elvetienilor, ca la ei sunt si alte costuri de "intretinere". De ex acolo nu mergi la niciun Dorel sa iti schimbe placutele de frana pe genunchi. Nu, acolo mergi la un servis care te taxeaza cu cateva sute de franci pe ora. Iar amenzile sunt in functie de venit, daca esti milionar, ghinion! Cum zice un celebru in viata. Iti pui bubiala pe masina, imediaat, dar stii cum? iiiiimediat esti "escortat de polis"
  28. halamadrid
    Inteleg ca unii milionari vor sa puna dosul pe colacul propriu de WC, de aia isi plimba motorhome-ul de un sfert de milion de euro prin Elvetia sau prin Europa. Ii inteleg si pe ei. Stiu ca 15% dintre elvetieni sunt milionari. dar sa ne gandim si la restul cetatenilor din Europa. 70.000 de euro inseamna bani multi nu doar pentru romani. Din 70.000 de euro, la o medie de 250-300 de euro noaptea de cazare la un hotel de 4 stele, te cazezi ~250 de nopti, adica 25 de vacante. De taxele din camping economisite iti cumperi ceva frumos.
