Golf 6/Jetta - Bluetooth
ferro
success ! ... partial macar...
cu codarea 512120 a reusit in sfarsit sa se activeze bluetooth-ul si am reusit sa fac pairing cu telefoanele
insa, cu aceasta codare imi dau erori la 19-CAN Gateway, 37-Navigation si 77-Telephone, conexiunea insa functioneaza bine, butonul de pe volan raspunde si inchide conversatia, muzica se opreste si se aude convorbirea, iar microfonul functioneaza.
Monday,23,September,2013,18:13:46:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 69 72 77
VIN: WVWZZZ1KZAM641979
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 B    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 9632
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00114014030400080000
   Shop #: WSC 42811 124 104077
   ASAM Dataset: EV_ECM16TDI02103L906023B 003009
   ROD: EV_ECM16TDI02103L906023B.rod
   VCID: 2545F5A79721
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 113B200D092600FB881404EB90220041300000
   Shop #: WSC 00066 000 00000
   VCID: 78FBECD37013
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000002
   Shop #: WSC 00066 000 00186
   ASAM Dataset: EV_Climatic A01005
   ROD: EV_Climatic_VW36.rod
   VCID: 6DD5CD870F51
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 084     HW: 5K0 937 084
   Component: BCM PQ35 B    008 2019
   Revision: BA008001
   Coding: 40180E3A982D02C040080080040000E403700088537D8160648000000000
   VCID: EFE9578F855D
   Subsystem 1 - Part No: 1K1 955 119 F
   Component: Wischer 18110  21  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH
   Component: RLS 091009 05  54  0402
   Coding: 0330AD
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 1K9 919 475     HW: 1K9 919 475
   Component: PARKHILFE 8K  H07 0001
   Revision: --------    Serial number: 90340926903386
   Coding: 110002
   VCID: F8FB6CD3F013
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    036 0604
   Serial number: 003C2D0HBBD$
   Coding: 00003235
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   VCID: F7F96FEFFD0D
   Driver's Airbag Crash Sensor:
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3203634BZZZZZZZZZZZZ
   Passenger Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 7D64644BZZZZZZZZZZZZ
   Driver's Rear Airbag Crash Sensor:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 152F731DZZZZZZZZZZZZ
   Passenger's Rear Airbag Crash Sensor:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 711B721DZZZZZZZZZZZZ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           056 0111
   Coding: 0000502
   VCID: 78FBECD37013
   Subsystem 1 - Part No: 5K0 959 542
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K0 920 870 G    HW: 5K0 920 870 G
   Component: KOMBI         H03 0305
   Coding: 170B00
   Shop #: WSC 00066 000 00147
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 316D11F7D3E9
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 141009F1000264
   Coding: E9A07F46400602002002
   Shop #: WSC 42811 124 81158
   VCID: 69DDB9973BB9
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 202
                    Mileage: 166136 km
                    Time Indication: 0
                    Date: 2107.14.06
                    Time: 20:02:02
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0305
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EADF469BBEBF
Address 37: Navigation (J794)       Labels: 3C0-035-270.clb
   Part No SW: 3C0 035 270     HW: 3C0 035 270
   Component: RNS310        H12 0227
   Revision: 10000000    Serial number: VWZ1Z2I8909606
   Coding: 000004010400000000000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: VW_RNS310 A02007
   ROD: VW_RNS310_VW36.rod
   VCID: D7B90F6F1DCD
1048659 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - Mechanical Failure
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 205
                    Mileage: 166136 km
                    Date: 2043.14.06
                    Time: 20:02:01
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0307
   Revision: 12101005    Serial number: 0000064181
   Coding: 0000B4
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   VCID: 285BFC93E033
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004391598
   Coding: 000090
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F69178FC5DD
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0307
   Revision: 14101005    Serial number: 0000065496
   Coding: 0001B4
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide_VW36.rod
   VCID: 295DF997FB39
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389__TSG-HR  006 1401
   Serial number: 00000004396241
   Coding: 000090
Address 62: Door, Rear Left
Cannot be reached
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000124083830
   Coding: 410D000100000000
   VCID: 306B14F3D8E3
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A08029491
   Coding: 512120
   VCID: 2A5F069BFE3F
End   ---------------------------------------------------------------------
ah.... codarile 012120 si 412120 nu au functionat
Modificat de delfinut
Salutari, scuze daca altcineva a mai pus aceasta intrebare dar am tot rasfoit acest topic si nu am gasit raspunsul pe care il caut.
Am instalat pe masina un kit Bluetooth cu codul 5NO 035 730 A si RNS 510 si din pacate "nu vede Iphone"
As vrea sa-l inlocuiesc cu un alt kit cod 1k8 035 730 D care stiu sigur ca este compatibil cu Iphone.
Din ce am citit pe anumite site-uri se pare ca cel din urma nu imi mai permite sa accesez agenda sau efectuez apeluri  din RNS500 ci doar din telefon.
Ma poate lamuri cineva ?
Multumesc !
E un 9W2 care intr-adevar nu-ti arata agenda pe RNS, ai nevoie de un 9W7 cel mai bine
Multumesc mult pentru raspuns si promptitudine.
Acum vin cu urmatoarea intrebare : cum imi dau seama care este 9W2 si care 9W7 ?
Stima !
Tocmai mi-am inlocuit vechiul modul BT cu unul nou  (cod 7P6035730K) datorita faptului ca cel vechi nu era compatibil cu Iphone.
Montajul a fost joaca de copii, modulul nou mi-a recunoscut imediat telefonul, se aude impecabil in momentul in care sun/sunt sunat.
Problema este ca in momentul in care il folosesc in modul BT-Audio, sunetul se aude doar in boxele din partea dreapta :(
Daca conectez telefonul la mufa de auxiliar nu mai am aceasta problema.
Ma poate ajuta cineva sa-mi dau seama ce se intampla ?
Multumesc !
DA, trebuie sa mai tragi un fir de la bluetooth la HU, deoarece nu e tras.
Salut, masina este un golf 6 2012 trendline(united) fara comenzi volan si cdb+ ,avand montat rcd310 ( ecran negru scris alb).. Intrebarea este ce kit BT pot achizitiona de pe siteul polonez intrucat sa fie compatibil cu rcd si sa pot folosi iPhone 5 si galaxy s4.? Multumesc celor care vor intervenì....
tu neavand nici MFD+ ( CBD+), nici radio cu touch, nu are rost sa dai bani pe modul plus, ca oricum nu ai unde sa-ti afiseze agenda si apelurile ...., iar premium nu poti sa folosesti fara MFD+ . poti sa-ti pui un modul standard, care merge cu orice telefon de ex. 1K8 035 730 A/B/C/D.
Multumesc pentru raspuns......acesta are si voice control ?( evident doar pentru apeluri telefon) eu neavand buton dedicat pentru a raspunde..cer scuze daca intrebarile sant de amator...
nu stiu sa-ti zic daca are comanda vocala, dar poti sa raspunzi sau sa suni de pe tel....
Avand in vedere ca nu ai un buton pe care sa il apesi ca sa activezi voice commandul (eu am pe volan un buton pe care il apas si apoi pot sa "vorbesc" cu masina, am mai vazut si plafoniera cu astfel de butoane, dar ma indoiesc ca masina ta are asa ceva) chiar daca ar avea voice command tot nu l-ai putea folosi.
Deci singura solutie pentru tine cu bluetooth este sa raspunzi de pe telefon (iar iphone 5 cand raspunzi de pe telefon o sa foloseasca audio telefonului si nu bluetooth, deci daca te suna cineva pe iphone, dai answer de pe telefon, apoi trebuie sa selectezi VW bluetooth ca sa poti vorbi in masina)
Ar fi ca alternativa BT parrot ( care are telecomanda propie)dar as fi preferat cel vw + rcd( pentru estetica si compatibilitate )...o sa valutez care varianta este mai ok..va multumesc si va doresc o zi buna...
Eu as merge pe rcd/ rns 510 + 7P6035730J. Vad ca cel cu terminatia L a disparut de pe carsystems
LE: este si cel cu L dar nu mai este tot la 199.
Modificat de aurelmarius
Pun si eu urmatoarea situatie pe tapet, poate ma poate ajuta cineva :
Am facut upgrade la modulul de bluetooth intrucat cel vechi nu era compatibil cu Iphone.
Noul modul are si functia de streaming audio prin BT direct de pe telefon.
Nedumerirea mea este faptul ca in momentul in care vb la telefon se aude absolut perfect in toate difuzoarele masinii pe cand in momentul in care vreau sa pun muzica prin BT se aude doar in difuzoarele de pe partea dreapta. Cineva tot de aici mi-a explicat ca mai trebuie tras un fir din modulul BT in RNS dar nu inteleg logica de ce totusi in modul convorbire se aude perfect in toate difuzoarele iar cand play-ez muzica, nu....
Multumesc !
Atunci cand modulul BT transmite sunetul unei convorbiri, trimite semnal mono. HU trimite mai departe semnalul mono in toate difuzoarele, dublandu-l in ambele canale (stanga/dreapta).
Cand se transmite muzica, HU asteapta semnal diferit pentru fiecare canal in parte, iar cum tie iti lipseste un fir corespunzator canalului stanga, nu vei auzi sunetul acelui canal
Multumesc mult pentru raspuns, m-am lamurit acum. Se pare ca nu scap de tragerea cablului cu pricina :)
Verifica daca ai trase firele intre pinii 8, 9 (la mufa modulului BT) catre pinii 12 si 6 (din mufa 3 de la RNS/RCD).
P.S. Te rog sa nu mai folosesti butonul quote cand raspunzi unui mesaj imediat anterior
Daca se aude mono, sigur nu are firul tras,
Tocmai ce mi-am comandat ieri un kit 7P6035730L de la polonezi. I-am rugat sa-mi faca factura pe firma si mi-au scazut si 23% tva-ul, in total m-a costat 820 lei cu tot cu transport. Astept sa vina si  ma apuc de montat.
Poate sa imi spuna cineva la masina din semnatura pe ce parte se trage microfonul ? As vrea sa-l montez in plafoniera unde este locul lui insa nu prea stiu cum o sa-l trag prin stalpul masinii.
Daca a mai montat cineva si imi poate oferi o idee as fi recunoscator.
Prin oricare parte il poti trage. Din fabrica vine prin dreapta, insa eu l-am tras prin stanga pentru ca mai umblasem pe acolo. Nu este absolut nicio diferenta. A grija doar la montarea mufei microfonului in plafoniera, sa o prinzi in suportul ei.
P.S. De asemenea, cand tragi firul microfonului prin stalpul A ai mare grija la airbag, daca ai. Sa nu cumva sa-l infasori in jurul airbagului. Monteaza-l in asa fel incat daca va fi vreodata cazul ca acesta sa intervina sa nu fie blocat cumva de cablul microfonului.
De asemenea, fa rost de o sarma mai groasa, gen cum sunt cele care se folosesc la instalatiile electrice interioare prin pereti, pentru a trece usor cablul pe sub capitonajul plafonului.
In rest este foarte usor.
BAFTA!
Modificat de Valentin
Multumesc pentru sfaturi Valentin.
Pentru a da jos capacul de pe stalp trebuie doar declipsat sau este prins si in suruburi ?
Am gasit si un tutroial la ei pe site: http://www.carsystems.home.pl/instrukcje/bluetooth%20golf%20VI.pdf
Nu cred ca o sa fie mare diferenta la jetta.
Scoate cu mare grija sigla/capacelul airbag-ului si vei gasi acolo un surub. Trebuie desfacut ala dupa care se declipseaza. Piciorusele capacelului ala se rup foarte usor si marginea se deformeaza la fel de usor, ei spun ca se inlocuiesc la fiecare desfacere. Am reusit sa-l scot de cateva ori, dar pana la urma tot n-am scapat sa-l schimb
LE: Tutorialul este ok. Este similar si Passat-ului, mai putin locatia modulului. Ai grija sa incalzesti interiorul in prealabil sa fie mai usor cu desfacutul. Niciodata in viata mea nu mi-am montat ceva pe masina vara, intotdeauna s-a nimerit sa fie doar iarna, pe ger si zapada :). Ai grija la plastice
la jetta mk6 nu are capacel din ala ca la golf 6, pur si simplu se declipseaza, e simplu
    • sdR+
