Demontare plafon si stalpi fata spate
nushi
Salut colegi, inca odata vin cu o mare rugaminte la voi , la un passat b6 plafonul sa dezlipit in zona lampii din plafon fata ..... presupun ca nu mai pot face nimic deat sa-l dau jos si sa schimb materialul, problema este cum il dau jos ... ma poate ajuta cineva? va rog
daca ar fi fost pentru un b6 ar fi fost super .... maine ma apuc de demontat ... sper sa reusesc
Removing and installing roof grab handles
Note
  • Removal and installation is described for the right vehicle side. Follow same instructions for the left side as appropriate.
Pull down front right grab handle 2 and open the two cover caps using a small screwdriver.
Unscrew the two bolts 1 (2 Nm) and detach grab handle from adapter plate in roof.
Pull down rear right grab handle 4 and open the two cover caps using a small screwdriver.
Unscrew the two bolts 3 (2 Nm) and detach grab handle from adapter plate in roof.N68-10173.png
Removing
Open panorama sunroof, if fitted.
Switch off ignition.
Remove front interior and reading lights:
  • Vehicle with no panorama sunroof → Electrical system › Rep. Gr.96Lights and switches in roof trim; Front interior and reading lights (vehicle with no panorama sunroof).
  • Vehicle with panorama sunroof → Electrical system › Rep. Gr.96Lights and switches in roof trim; Front interior and reading lights (vehicle with panorama sunroof).
Vehicle with no panorama sunroof, remove roof mounted grab handles
Remove upper A-pillar trims
Release upper B-pillar trim from retainers
Remove sun visor
Release cover caps from mirror arrows using wedge -3409- .
Pull off connector 1 and remove bolts 2 (1.6 Nm).
N70-10430.png<p>
In vehicles with panorama sunroof, release surrounding clip profile 1 from retaining clips 2arrow with release tool -T10236- and removal wedge -3409- .
Note
  • Clip profile is fastened with a total of 20 clips.
Release moulded headliner, in area of C-pillar, inwards arrow out of locking devices.
Pull moulded headliner 1 downwards out of remaining clips.
Remove windscreen → General body repairs, exterior › Rep. Gr.64Glazing; flush-bonded windows; Removing windscreen
Remove moulded headlining from vehicle through opening for windscreen.
Installing
Guide moulded headlining into vehicle through opening for windscreen.
Install windscreen → General body repairs, exterior › Rep. Gr.64Glazing; flush-bonded windows; Installing windscreen
Install in reverse order of removal.
Modificat de misufha
ooo multumesc, am vazut ca sunt niste fire pe plafon sper sa nu rup ceva
Demontare airbag cortina
WARNING
  • Refer to safety precautions when working on the airbag
Disconnect vehicle battery → Electrical system › Rep. Gr.27Disconnecting and reconnecting battery.
Remove front and rear interior and reading lights → Electrical system › Rep. Gr.96Lights and switches in roof headliner
Remove storage tray with console in moulded headliner
Remove sun visors:
  • Single
  • Double
Remove roof grab handles
Remove B-pillar upper trims
Remove C-pillar trims, saloon:
  • Vehicles without sunblind
  • Vehicles with sunblind
Remove roof end strip trim, saloon
Vehicles with interior mirror and rain sensor:
Remove interior mirror
Lower moulded headliner (saloon)<p>
WARNING
  • Electrostatic discharges may result in unintentional triggering of airbag. Therefore, the mechanic must electrostatically discharge him/herself before disconnecting the igniter and earth wires. This can be done by briefly touching the body or striker plate of the door.
Separate wiring harness from curtain airbag.
Remove bolts 1 and 2 (6 Nm).
Unscrew the five bolts arrows (6 Nm).
Remove the two bolts 3 (6 Nm).
Si inca un link! Sper sa te descurci! http://forums.vwvort...ead.php?3488355
  • 4 years later...
Salut,nu a reusit nimeni sa remedieze aceasta problema?
Si mie a inceput sa mi se desprinda in jurul consolei de lumina,si ma intrebam daca nu se poate relipi local.
P.S:Plafonul pe unde se poate scoate?Am auzit ca trebuie demontat parbrizul sau luneta.
Salutare!
Aveti idee cum pot demonta barele longitudinale de pe plafon? Masina este variant/break passat b6.
Trebuie demontata toata tapiteria de pe plafon  pentru a avea acces la piulite/suruburi sau exista vreo metoda mai simpla?
Va multumesc anticipat!
