Cilindru receptor ambreiaj - ansamblu
covesanu
buna ,
Am o problemma cu un vw passat b6 , a fost dat motorul jos si acum pedala de ambreiaj sta jos.Curge lichid la cilindru receptor pe la conducta.Am scos siguranta si am tras conducta, are oringul ala mic in capat dar nu stiu daca mai trebuie sa fie ceva in interior.Problema este ca a dat altcineva motorul jos si eu acum am observat cand am bagat lichid ca pe acolo curge.
Imi poate da cineva detalii poze ceva la cilindru receptor si conducta imbinarea, sa imi dau seama daca lipseste ceva.Oringul mic in capul conductei il are dar cand introduc conducta si apas pedala iese lichid pe langa.De asta zic ca poate mai lipseste unul?
multumesc,
Daca spui si ce cod motor ai?
Insert master cylinder so that seal 1 and washer make contact behind mounting bracket.
Tighten bolts 2 to specified torque → Chapter.
Press connecting pipe 3 with guide arrow A into notch arrow B on mounting bracket.
A second mechanic is required for the next step.
Push complete pedal cluster forwards to bulkhead and insert bolt arrow.
At the same time, second mechanic must guide pipe/hose line into master cylinder from plenum chamber.
Tighten securing bolts 3 and 4 for master brake cylinder and brake servo.
Then tighten securing bolt 1 for brake fluid reservoir 2.
Push connector onto brake fluid level warning contact on brake fluid reservoir.
Press in clip C in direction of arrow to stop.
Push pipe/hose line B into master cylinder until line audibly engages.
Test pipe/hose line by tugging on it.
Insert grommet D for supply hose A into bulkhead.
Push supply hose A onto connecting pipe of master cylinder to stop.
Remove hose clamp -3094- .
Tighten bolt arrow for securing pedal cluster to dash panel carrier.
Connect clutch pedal to master cylinder. Engage new pins in clutch pedal.
Bleed clutch system after installing master cylinder → Chapter.
Modificat de misufha
