nu pot recoda modulul abs
Leorot
pentru inceput salveaza coding-ul existent, adica 10753. Uneori mai merge si doar cu refresh.
Modificat de andrei_221
  • Replies 56
  • F l o r i n
    13
  • Al Bundy
    12
  • ovidiu94
  • andrei_221
    5
Deci sa las toate codurile de acolo si sa-i dau do it.
 Sal. Am reusit sa ajung sa fac ce mi-ai spui si apare asta :
Multumesc pentru promptitudine.
Nu te ajuta cu nimic, help-erul.... asa cum ti-a zis Andrei, codeaza cu 10753.
sau compune-ti coding-ul.
ABS
  • 0001025 = Cable-Throttle Engines
  • 0004097 = Drive-By-Wire Engines
ABS/EDS/ASR ABS/EDS/ASR/ESP (Front-Wheel-Drive)
  • Frontbrakes:
    • +0000002 = FS3 54 14"/15" (PR-1LQ/1LR/1LS/1ZF/1ZM/1ZP)
    • +0000514 = FN3 54 15"/16" (PR-1LE/1LJ/1LN/1LQ/1LT/1ZD/1ZE/1ZH)
  • Suspension:
    • +0000000 = Standard/Sport Suspension (PR-2UA)
    • +0000128 = Rough Road Suspension (PR-2UB)
  • Engine I:
    • +0010240 = Gasoline Engine (through 92 kW / 125 HP)
    • +0018432 = Gasoline Engine (from 92 kW / 125 HP) & All Diesel Engines
    • +0018440 = New Beetle (1C/1Y/9C) with 2.5l & 1.8l (ONLY 1C0-907-379-Q)
  • Engine II
    • +0001024 = Drive-By-Wire Engines
    • +0004096 = Cable-Throttle Engines
Notes: See production codes on car data plate. Coding is the sum of the individual options.
Seat Leon Cupra R: Unlike the above coding chart, the Cupra R has a different coding 0019469.
ABS/EDS/ASR/ESP (All-Wheel-Drive)
  • Frontbrakes:
    • +0000006 = FS3 54 14"/15" (PR-1LQ/1LR/1LS/1ZF/1ZM/1ZP)
    • +0000518 = FN3 54 15"/16" (PR-1LE/1LJ/1LN/1LQ/1LT/1ZD/1ZE/1ZH)
    • +0000521 = 2FN 42 17" (PR-1ZT)
  • Suspension:
  • Engine:
O sa incerc sa  codez cu codul existent.Codarea se face in fereastra din screen cu motorul oprit/pornit prin tasta di it?
Codul cum se compune?.. ca habar nu am chestia asta. Ms
codul se compune prin adunare.
cu contactul pus, bagi codul in fereastra si ii dai Do It.
Florin ma poti ajuta cu calculul te rog ca nu stiu la engine, engine 1 si suspension ce sa pun. Uitesi pr masinii :
PRCode: 1AT = Electronic stabilization program (ESP)
PRCode: 1G2 = Steel spare wheel with original equipment tires
PRCode: 1GA = Front shock absorption basic design 1
PRCode: 1HQ = Labels for country group 15
PRCode: 1JA = Rear shock absorption basic design 1
PRCode: 1KQ = Disc brakes rear
PRCode: 1LQ = Front disc brakes with integrated adapter
PRCode: 1NL = Covers for alloy wheels
PRCode: 2JC = Comfort bumpers
PRCode: 2PX = Leather trimmed sports steering wheel
PRCode: 3SQ = Right swivel seat in cab with lumbar support
PRCode: 3V1 = Child bench seat
PRCode: 3YR = Door pockets with insert mats
PRCode: 4K3 = Radio remote controlled central locking operated from inside and safe securing
PRCode: 4R4 = Power windows with comfort operation andcircuit breaker
PRCode: 4UE = Air bag for driver and front seat passenger
PRCode: 4X1 = Side air bag front
PRCode: 5MD = Decorative aluminum inserts
PRCode: 5RQ = Right exterior mirror: convex
PRCode: 5SL = Left exterior mirror: aspherical
PRCode: 8AC = Radio beta
PRCode: 8GD = Alternator 90A
PRCode: 8L3 = Roof antenna
PRCode: 8RE = 4 speakers (passive)
PRCode: C7Y = Alloy wheels 6.5J x 16
PRCode: H6U = Tires 205/55 R16 91W
PRCode: J1L = Battery 280 A (60 Ah)
PRCode: MN7 = 4-cyl. gasoline engine 1.4 L/55 kW 16V multi-point injection base engine is T1Q/T99/TK0
PRCode: N2Z = Seat covering for special editions
PRCode: QG1 = Service interval prolongation
PRCode: QG3 = Without service interval prolongation
PRCode: T1Q = 4-cylinder gasoline engine 1.4 L unit 036.D (aluminum)
PRCode: U21 = Suspension range 120
Codul ar arata cam asa :
ABS
         Frontbrakes: +0000002 = FS3 54 14"/15" (PR-1LQ/1LR/1LS/1ZF/1ZM/1ZP)
        Suspension:  ????
        Engine I      : ???
        Engine II +0001024 = Drive-By-Wire Engines
        Frontbrakes: +0000006 = FS3 54 14"/15" (PR-1LQ/1LR/1LS/1ZF/1ZM/1ZP)
        Suspension:  ???
        Engine: ???
Ms.
Modificat de ovidiu94
Suspension:
Frontbrakes:
Engine I:
Engine II
11266
si abs? Sunt tare confuz
Codul se calculeaza  Suspension + Frontbrakes + engine I + Engine II = COD ?????
alegi in functie de ce sistem ai pe masina
De exemplu daca ai doar ABS simplu, alegi unul din cele 2 coduri.
daca ai ESP si tractiune fata, alegi a doua sectiune ( care se aplica si la tine) :  si alegi ce tip de motor ai, ce tip de suspensie, etc
daca ai ESp si tractiune integrala alegi a 3a sectiune.
Eu nu stiu de unde scoateti voi codarile astea? Ca si eu sunt in ceata
Voi v-ati uitat ca pe masina lui apare MK20 si nu MK60 ?
Cel putin asa ii spune interfata.
hm, da la asta nu am mai fost atent.
O sa vad maine codarea la un Golf IV 2001 cu motor de 1.6 si ESP.  ar trebui sa fie identica la dotare si la codare. Si ne dam seama atunci ....
....deci, hai sa-l ajutam un pic.
Bora - Tdi - MK20 - coding 18945
Golf 1.6 - MK20 - coding 10241
Bora - MK20 - coding 10753
codeaza cu 10241 - care se aplica la masina pe benzina, pana in 125cp
despre codarea mea ce spuneti (masina din semnatura) doar ABS are
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ABS2.lbl
   Part No: 6Q0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0001097
   Shop #: WSC 31414 000 00000
   VCID: 4683947B322728285A7
dupa codingul postat mai sus de F l o r i n care am inteles de la Al Bundy ca e pt. MK60 cum am eu codarea la mine ar trebui sa fie 4097, ce nu e bine sau ce nu inteleg eu ?
LE - am gasit o procedura de pe platforma golf pe care mi-am salvat-o in pdf de pe siteul rosstech, si aici la fel zice cum a postat F l o r i n
VW Golf (1J) Brake Electronics (MK60).pdf
Modificat de SergiuD
e pentru MK60 dar de golf, tu nu ai polo ?
ba da, dar nu am gasit pt polo pe rosstech si ma gandeam ca nu conteaza masina ci tipul de abs...
deci e ok cum e acum codat ?
din moment ce merge ok ABS si nu ai erori, e ok codarea.
banuiesc si eu ca ar fi ok, ma interesa daca gasesc undeva codarile pentru polo 9N...
  • 9 months later...
salutare  baieti..am si eu o problema...am schimbat volanul..si  din greseala am scos si spira de la airbag-esp g85..
mia aparut vestitele erori(cele doua,
-00778-steering angle sensor(g85)...66-10-not matched-intermittent
-01044-control module incorrectry coded.... 35-00 - -
...iar la soft coding era 00000
m-am logat in modulul abs cu 09555 iar dupa aia am intrat pe coding cu codul 04255(am  urmat pasii de la cei de la ross tech)...si am scapat de cele doua erori
dar acum am eroarea
-01486-system function test activated...35-00 - -
am incercat procedura....apas frana ,dupa care merg cu 20 km.h si  dau stanga si dreapta la 90 grade de volan..dar nimic..nu am scapat de eroare..si imi sta abs aprins in bord..
ce alta procedura sa urmez?
mentionez ca am audi a4 din 2001 motor ajm 1.9 tdi
am postat o foto cu fereastra coding...abs..am modul abs bosch 5.3
post-100689-0-61763300-1417949282_thumb.
Nu faci bine procedura, fa ca niste"opturi"cand rotesti volanul(iti trebuie un spatiu m ai mare).
Dupa ce o sa se stinga martorul(o sa se incheie procedura) sa te uiti ca iti m ai ramane o eroare pe care trebuie sa o stergi.
Uitasem, sa faci toata procedura fara mufa de diagnoza pe masina.
Modificat de romytaxy
mariusamplifier
Buna ziua. Am intalnit urmatoarele erori pe un VW Bora 1.9TDI PD, tractiune integrala.
Friday,05,August,2016,10:47:03:62939
VCDS Version: Release 11.11.2 (x64)
                Address 03: ABS Brakes       Labels: 1J0-907-37X-ESP-A.LBL
Control Module Part Number: 1J0 907 379 AB
  Component and/or Version:  ESP     20   CAN  V005
           Software Coding: 00214
            Work Shop Code: WSC 31414
                      VCID: 71E9334F3BB23BB
3 Faults Found:
01044 - Control Module Incorrectly Coded
            35-00 -  -
01279 - Longitudinal Acceleration Sensor (G251)
            57-00 - Electric Circuit Failure
00778 - Steering Angle Sensor (G85)
            37-00 - Faulty
Ma poate ajuta cineva sa recodez modulul ? Va multumesc
  • 6 months later...
Buna ,
    Ma poate ajuta va rog un coleg , am o problema la un passet b5 din 2004, motor 1,9 tdi avf,  6 trepte manuala.Avea eroare de g85 defect, a fost inlocuit cu altul second aceeasi serie.Acum pot sterge eroarea, pun  09555, 042555, fac procedura de aliniere g85,  040168, si procedura de mers  cu volan drept maxim 20km/ora, oprit pe loc verificat cu volan 0 grade si codat,dupa cateva incercari imi arata ca este aliniat si martorii din bord nu se sting.Parerea ma este ca nu e codarea abs corecta.Ma poate ajuta un  coleg?
La etichetadin port bagaj unde ar trebui sa fie modelul de frana  am codul   2PQ. passatul este 3B modelul.
Merci,
care din urmatoarele coduri:
FNRG-60 (Teves/ATE) [PR-1LA/1LG]
FN2/HP2 (Dual-Piston) [PR-1LX] & Brembo [PR-1ZL]
FN3 (Teves/ATE) [PR-1LB/1LE/1LF/1LT/1ZC]
C54 (Lucas) [PR-1LZ]
le ai in portbagaj ?
La Passat B5.5 nu are atatea optiuni - are login 09555 si coding 04255. Dupa ce te loghezi si codezi, login cu 40168, setare de baza la g85 si cam atat.
Daca nu merge, ai probleme cu interfata - poate e o clona si nu face treba - sau in alta parte...sau nu faci procedura cum trebuie
