nu pot recoda modulul abs
Leorot
Masina: passat 6 trepte, motor avf, an 2001.
Problema: stau aprinse in permanenta iconita pentru abs si cea pentru esp, iar semnul exclamarii pentru frana de mana clipeste continuu. Masina porneste si merge.
Am facut o scanare cu vag-com si in plus fata de erorile vechi, am erori pe modulul de abs care necesita recodarea modulului abs. am incercat sa fac recodarea, dar NU MERGE. nu primeste noile valori. mai jos sunt toate erorile gasite, va rog sa ma ajutati sa recodez corect modulul abs.
VAG-COM Version: Release 311.2-N
Ursu
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 019 DS
Component: 1,9l R4 EDC 0000SG 1348
Coding: 00002
Shop #: WSC 00028
WVWZZZ3BZ1P104488 VWZ7Z0Y3198548
2 Faults Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0003
Coding: 17000
Shop #: WSC 00028
3 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
49-00 - No Communications
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
01336 - Data Bus for Comfort System
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B0 920 825 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 05125
Shop #: WSC 00012
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
5 Faults Found:
01320 - Control Module for Climatronic (J255)
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
00463 - Control Module for Digital Sound Package (J525)
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 03 Komfortgerát HLO 0001
Coding: 00258
Shop #: WSC 00028
6 Faults Found:
80-00 - Single-Wire Operation
01332 - Door Control Module: Passenger Side (J387)
01331 - Door Control Module: Driver Side (J386)
End -------------------------------------------------------
  • Replies 56
  • F l o r i n
    13
  • Al Bundy
    12
  • ovidiu94
  • andrei_221
    5
oare pot folosi ultima versiune a softului vcds cu cablul meu facut de un nene mester acum 3-4 ani ?
Offtopic: in nici un caz - clona merge numai cu softul cate ti-a fost dat de vanzator. Daca pui alt soft nu-ti va mai merge....si apropo, cred ca era mai usor sa postezi in aria dedicat aerorilor decat sa deschizi un nou topic. In plus, in cadrul unui topic se trateaza 1 singura problema. Next time, use search.
Dar te loghezi pe el inainte de a recoda? Si faciadaptarea lui G85 imediat dupa recodare fara sa iai contactul ?
Stii sa calculezi codurile de login si de coding ?
Modificat de Al Bundy
Pai aici greseam, nu ma logam. Codurile le voi calcula dupa ce vad ce frane am si folosind video-ul dat de pronet, merci.
Posteaza ce coduri PR ai la frane si altele si iti calculez eu. Si mai ales ce sistem: BOSH 5.3 sau 5.7 ?
Am reusit sa recodez, acum am eroarea 01486, pentru verificare. Franele la mine au codul 1ZC si sistemul de franare l-am pus la ghici, 5.3 dar a mers. In filmuletul de pe youtube apare versiunea sistemului de franare pe bara de sus a programului, la mine nu apare nimic. Am iesit pentru recalibrare cu masina, dar nu dispar cele 2 becuri, desi am facut totul asa cum spun ei in filmulet. Mai incerc...
Nu reusesc... Merg in linie dreapta pana ajung la 20km/h, apoi iau de volan stanga sau dreapta dar nu mai mult de 180 de grade si mentin viteza, dar nimic. Am facut si cercuri complete si semicercuri, si cu viteza constanta si cu viteza variabila si nimic. Ceva nu fac cum trebuie...
Modificat de Leorot
E ok codarea folosita - login 09555, coding 04255 - asta ai pus, nu ?
nu ai treaba, pui contactul, stanga-dreapta, pornesti, mergi un pic cu pana la 20 km.h si faci adaptarea.
ce eroare ai stocata ?
Gata am rezolvat. Ca sa faci calibrarea trebuie inainte de toate sa apesi frana puternic, apoi sa mergi linie dreapta intre 15 si 30 km/h, apoi sa iei de volan intre 1/4 si 1/2, stanga sau dreapta. Acum e totul ok, se poate inchide topicul. Merci tuturor.
La Passat, procedura de calibrare a G85 -ului, este
- Pornesti motorul
- invarti volanul o tura la dreapta, o tura la stanga
- cu rotile drepte, pornesti la drum, cu o viteza sub 20km/h
- te opresti - motorul pornit
-comanda 11(logare)->40168
-grup de valori 060 => setare de baza
-inchide , inapoi
-ia contactul
-asteapta 30 secunde inainte de repornire
A scris un pic mai sus: 01486
ce treaba are G85 cu problema lui ????
Si nu scria in linkul postat de mine?
Instructions
  • Firmly press the Brake Pedal until a certain Brake Pressure (usually right above 30 bar) is reached.
Mi-a scapat eroarea....
legatura ? - era o corectare, nu ai citit procedura descrisa de colegul nostru, pentru.... calibrare ? nu e corecta si nu e normal sa incurajam postarile care nu contin proceduri corecte - din contra, trebuie sa postam procedurile corecte
Calibrarea = calibrare
Eroarea de test = eroare de test
s.a.m.d
NU vad ce nu e corect in procedura descrisa de el .....
un passat 3b i sa stricat pompa de abs si la inlocuit cu altu acum problema mare este ca nu a salvat soft coding(si poate si workshop coding) si nu mai stie de unde sa-l ia un pic de ajutor va rog. vin-ul este :WVWZZZ3BZ3P244996
serie pompa ABS este acelasi cu ce a avut pe masina:480288026595055.mersi
Sal . ma poate ajuta si pe mine cineva cu o solutie, mai ales pentru prima eroare pentru ca nu am schimbat nimic pe masina si nici codat.
Address 03: ABS Brakes        Labels: 1J0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379
   Component: ESP     20    CAN  V002
   Coding: 10753
   Shop #: WSC 01317
   VCID: E7D725458576751
4 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
            57-10 - Electric Circuit Failure - Intermittent
00812 - Brake Pressure Release Solenoid (F84)
Modificat de ovidiu94
LA coding, in balonul de pop-up, ce iti sugereaza?
Sunt mai novice si nu stiu exact la ce te referi. eu am facut azi o scanare si am logul acu decat. Unde ar trebui sa apara pop-up acela. Eu am dat azi un autoscan si nu mi-a aprut nici un pop-up.
Intri pe ABS, de duci la coding si in fereastra ce se deschide , tii mausul pe codinf si trebuie sa apara o fereastra pop-up/
Nu cred ca o sa ii apara helper-ul....
De ce? ca doar fila care o incarca interfata lui are si codingul.
eu imi aduc aminte ca nu iti apare.... o sa mai verific, dar la generatia lui pe ABS, nu apare helper-ul.
 Sal. Am reusit sa ajung sa fac ce mi-ai spui si apare asta :
Multumesc pentru promptitudine.
