RNS 310 / 315 - Amundsen
mark21
Intr-adevar, am modulul acela...ce e de facut mai departe?
Sunday,10,September,2023,22:58:04:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.0.0 (x64)
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WVWZZZ1KZ5W061365   License Plate:
Mileage: 265700km-165098mi   Repair Order:
Chassis Type: 1K-VW35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77 7D
VIN: WVWZZZ1KZ5W061365   Mileage: 265700km-165098miles
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
55-Headlight Range -- Status: Not registered 0001
56-Radio -- Status: Not registered 0001
77-Telephone -- Status: Not registered 0011
7D-Aux. Heat -- Status: Not registered 0011
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 FM    HW: 028 101 190 3
   Component: R4 2,0L EDC G000SG  6179
   Revision: 12345678    Serial number: VWZ7Z0D0310440
   Coding: 0000072
   Shop #: WSC 01392 785 00200
   VCID: 73E56ACB12B5210BCE-8026
   VINID: 9E69EAAAA05BA859C01810C614BFB62E2F
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0006786
   VCID: 3A7B87EF755F9043CD-806E
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 68DF0DA75B73D2D36B-803C
00710 - Defroster Flap Positioning Motor (V107)
            000 - -
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000896375
   Coding: E78B8F0600041823001400001400000000
   Shop #: WSC 12345 123 12345
   VCID: 408FF5071383CA9383-8014
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     080709 054  0402
   Coding: 00209069
   Shop #: WSC 12345
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 01 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0HGS7B
   Coding: 0012337
   Shop #: WSC 01371 785 00200
   VCID: 3169A0C3A829531B7C-8064
   Subsystem 1 - Serial number: 6332MSME69267803
   Subsystem 2 - Serial number: 6342MSME147C1207
   Subsystem 3 - Serial number: 6351HSME11444103
   Subsystem 4 - Serial number: 6361HSME54054003
3 Faults Found:
00589 - Airbag Igniter 1; Passenger Side (N131)
            001 - Upper Limit Exceeded - MIL ON
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 B    HW: 1K0 953 549 B
   Component: Lenksäulenmodul 500 0010
   Coding: 0002042
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    004 0030
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 871 B
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0017103
   Shop #: WSC 80093 222 69422
   VCID: 295948A380F92BDBB4-807C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K1051704EE
   Coding: E9807F06400002000002
   Shop #: WSC 73430 790 12345
   VCID: 69D908A34079EBDB74-803C
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 265408 km
                    Time Indication: 0
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
Address 37: Navigation (J794)       Labels:| 1K0-035-27x-37.clb
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H05 0010
   Serial number: VWZAZ2L3304345
   Coding: 000004100100000000011000
   Shop #: WSC 00015 115 12345
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: 60CF15877B43AA93A3-8034
4 Faults Found:
1048632 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 265704 km
                    Date: 2000.00.00
                    Time: 22:49:03
1048582 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 265704 km
                    Date: 2000.00.00
                    Time: 22:49:03
1048652 - Telephone Microphone
          B1048 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 265704 km
                    Date: 2000.00.00
                    Time: 22:49:03
1048641 - Control Module Incorrectly Coded
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 265704 km
                    Date: 2000.00.00
                    Time: 22:49:04
                    Correction for sound system: OK
                    CD-Changer: OK
                    Status of antenna 2 for radio: OK
                    Digital radio (DAB): OK
                    Antenna diagnostic: OK
                    Telephone baseplate diagnostic: OK
                    Speaker status: OK
                    Rearview camera: OK
                    Telephone Transceiver: Malfunction
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0147
   Coding: 0000054
   VCID: 326BAFCFAD2F680305-8066
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.3       1401
   VCID: 2F6DA6BBBE1D45EB6A-807A
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No SW: 1K0 959 433 J    HW: 1K0 959 433 J
   Component: 01 KSG PQ35 G2  031 0308
   Revision: 00031000    Serial number: 00000000000000
   Coding: 81C802087F2D8505484FC6F000
   Shop #: WSC 00000 785 00200
   VCID: 377D9EDB464D8D2B32-8062
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
            004 - No Signal/Communication
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Coding: 0000054
   VCID: 3365AACB5235610B0E-8066
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   VCID: 74E769D717BB2633D7-8020
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
   VCID: 306FA5C7A3235A1373-8064
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 77: Telephone        Labels: 1K0-035-729-UNI.lbl
   Part No: 1K0 035 729 E
   Component: CIB PAH  HW 202 SW  0308
   Coding: 0000364
   VCID: 2B55B2AB8A0539CB46-807E
01530 - Radio Mute Switch
            009 - Open or Short to Ground
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D51BCB3B41137FB58-8078
2 Faults Found:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
01299 - Diagnostic Interface for Data Bus (J533)
            005 - No or Incorrect Basic Setting / Adaptation
End-------------------------(Elapsed Time: 02:19)--------------------------
Il elimini si modifici cablajul microfonului pentru RNS315
PS: Bifeaza in CAN: 55-Headlight Range, 56-Radio, 7D-Aux. Heat
Modificat de z e n i t h
In ce consta eliminatul? Ii scot mufa? Unde se afla pozitionat modulul?
Nu inteleg ce fac gresit. Am reusit sa nu mai am nicio eroare pe modulul CAN, am eliminat (scos ambele mufe) din 1K0 035 729 E (77-Telephone), l-am eliminat si din lista de instalari din CAN. Intru pe long coding pe navi, imi accepta codarile pe care le fac fara probleme, insa nu se activeaza BT-ul sub nicio forma, nu apare in setari…desi e debifat din long coding; am eroarea asta pe navi intr-adevar dar nu stiu daca asta e problema de nu apare BT-ul in setari ca fiind activ.
EDIT: A functionat pana la urma, l-am lasat asa vreo 15-20 minute, m-am reintors la masina si a functionat. Multumesc foarte mult de ajutor!
Modificat de Leet
Salutare, am montat acum 2 ani pe un Touran din 2005, un RNS 310 impreuna cu can-ul 1K0907530Q si am crezut ca e totul in regula, bateria fiind noua si circuland zilnic, acum am constatat ca nu e deloc in regula cand mi s-a descarcat bateria dupa ce am lasat masina 2 zile. Am verificat si am consumatori...pe langa rns, am montat si un modul de bluetooth aftermarket care merge in loc de magazie, nu pe aux, a fost destul de scump fata de cele din China(in jur de 230 lei). De asemenea am observat in timp ca nu intotdeauna se opreste bluetoothul si ca ecranul rns-ului mai porneste o secunda. In afara de asta mentionez ca rns 310-le provine tot de pe o masina de a mea(golf 6) pe care nu a facut figuri, de asemenea am montat rcd 300-le original inapoi cu modulul acela de bluetooth si totul functioneaza cum trebuie.
Intrebare: nu este can-ul potrivit? Multumesc.
LE:
Am gresit, m-am uitat undeva unde mi-am notat, dar se pare ca pana la urma am montat pe masina 1K0 907 530 AD, am verificat aatazi cu vcds.
Am un Golf 6 cu navi RNS310 cu modul BT sub scaun iar atunci cand ma contectam la BT nu se auzea nimic. Cert e ca in meniul navigatiei nu aveam optiunea de cautare telefon ci doar sa bifez BT audio on sau off.
Vazand ca nu merge sa fac streaming audio am facut update la 351 si apoi la 357 iar acum cand apas butonul media imi apare ,,no medium available”
V-ati mai intalnit cu problema asta?
Salut. Am un RNS315 cu bluetooth incorporat dar folosit cu modul bluetooth de sub scaun. Modulul de sub scaun s-a stricat si a fost facuta codarea ca sa se foloseasca modulul incorporat. Se conecteaza telefonul , merge streaming , cand suna telefonul aud interlocutorul dar el nu ma aude, pentru ca microfonul e conectat tot la modulul de sub scaun.
Intrebarea mea : este o metoda sa fac niste punti intre pinii de la mufa mare de sub scaun sau in spate la RNS astfel incat sa functioneze si microfonul fara sa cumpar alt cablaj si sa demontez jumatate de masina sa leg la microfonul din plafon?
NU. cablul de la microfon ce duce acum in modulul de bt trebuie dus in navigatie.
Am si eu o Skoda Octavia combi de 81Kw 1Z5 cu Amundsen + RNS315 si doresc sa stiu daca pot sa-i pun camera pe spate si un port de USB pentru a conecta o memorie USB.
Multumesc anticipat.
Modificat de jeanb
Camera da, usb nu.
Multumesc,
Imi puteti spune codul OEM pentru camera si accesorii ca sa stiu ce caut? (I-mi puteti trimite o oferta sau ceva preturi orientative pe pm sau email: nelub_2005@yahoo.com ?)
Am intrebat de USB deoarece pe mai multe site-uri am vazut cablu cu un port usb si un conector care spun ei ca s-ar conecta la RNS315. Si de ca tot omu am crezut ca pot face o imbunatatire....
Modificat de R_a_z_v_a_n
Renunta la QUOTE pentru postul anterior.
@jeanb, da-mi link pe whatsapp,  sa vad portul usb de care vb. Tot acolo o sa imi dai seria sasiu si iti trimit oferta solicitata. Nr meu de telefon il gasesti in profil
Am un 3c0035279, oare se poate pune usb? Mulțumesc!
Usb ? Nu..
A mai pățit cineva ca la pornirea mașinii, să apară asta:
Software update needed
Please insert download data carrier
Displayul rămâne alb, nu se poate opri nici din buton, nici la scoaterea cheii din contact. Merge atât radioul cât și playerul (melodiile de pe card).
Navigația (RNS 310) are făcut 03xx_unlock de acum 2 ani. Până azi a mers perfect în tot acest timp. Orice idee e binevenită!
Salut! Stie cineva daca ptr a schimba ornamentul de plastic,de la butonul de volum la rns 315,trebuie desfacuta bucati? Vreau sa schimb plasticul de care invart volumul si nu-l cumpar decat daca se achimba fara a o demonta. Multumesc!
