Probleme bujii - Passat B6
andrei_70
intre timp masina nu a mai pornit asa ca am dus-o cu platforma in service. Cand am dat-o jos de pe platforma cred ca i-a fost frica si a pornit.
Am schimbat modulul de control bujii, erorile s-au sters, dar astazi refuza sa porneasca din nou (nici macar nu incearca sa invarta electromotorul).
Bateria este buna, bujiile la fel, iar la scanare cu VCDS-ul avem urmatoarele:
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 FG    HW: 03G 906 018 FG
   Component: R4 2.0l PPD1.5 G    0907
   Revision: --H55---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 66565 257 00032
   VCID: 6FEA4B937E8EAB59875-803A
5 Faults Found:
001648 - Glow Plug Module 1; Glow Plug Circuit
               P0670 - 007 - Electrical Malfunction
             Freeze Frame:
                    Fault Status: 01000010
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 166022 km
                    Time Indication: 0
                    Date: 2017.03.11
                    Time: 11:45:53
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.64 V
                    Bin. Bits: 00110000
                    Temperature: 8.0°C
001649 - Cylinder 1 Glow Plug Circuit (Q10)
               P0671 - 006 - Electrical Fault
             Freeze Frame:
                    Fault Status: 01000001
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 166022 km
                    Time Indication: 0
                    Date: 2017.03.11
                    Time: 11:45:53
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.64 V
                    Bin. Bits: 00110000
                    Temperature: 8.0°C
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 006 - Electrical Fault
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 166022 km
                    Time Indication: 0
                    Date: 2017.03.11
                    Time: 11:45:53
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.64 V
                    Bin. Bits: 00110000
                    Temperature: 8.0°C
001651 - Cylinder 3 Glow Plug Circuit (Q12)
               P0673 - 006 - Electrical Fault
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 166022 km
                    Time Indication: 0
                    Date: 2017.03.11
                    Time: 11:45:53
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.64 V
                    Bin. Bits: 00110000
                    Temperature: 8.0°C
001652 - Cylinder 4 Glow Plug Circuit (Q13)
               P0674 - 006 - Electrical Fault
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 166022 km
                    Time Indication: 0
                    Date: 2017.03.11
                    Time: 11:45:53
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.64 V
                    Bin. Bits: 00110000
                    Temperature: 8.0°C
Readiness: N/A
idei ?
Modificat de Irirat
Erorile sunt pe releul de bujii si cele 4 bujii .Daca nu invarte electromotorul problema poate fi de la el , cablaj,sau baterie .Prima data masoara bateria
problema rezolvata, cablul de masa de la alternator.
Multumesc baieti :)
  • 7 months later...
Am si eu eroarea Cylinder 4 Glow plug circuit(Q13) P0674 -000 electrical fault
Sa fie de la bujie?
da, este primul lucru care il verifici
Salut baieti. In primul rand vreau sa rog moderatorii sa mute postarea daca nu este postata in topicul corect. Acum o saptamana mergeam cu masina linistit si la un moment dat aud un bip si vad pe bord sarma spirala aprinsa si un mesaj ,,engine fault workshop" . Nu am oprit si am continuat sa merg si dupa 3 Km sa stins sarma. Nu am scanat atunci si am mai mers vreo 300 de Km. La cateva zile exact aceias eroare si martor aprins. Insa acum ceva mai diferit adica eram la semafor si sa aprins martorul cand stationam. Apoi am plecat 5m si sa stins. Am mai mers 200 de m si iar sa aprins cand am oprit , stingandu-se odata ce am pornit cu masina de pe loc. Am facut o scanare si mai jos aveti rezultatul.  Acum de cateva zile este stins martorul si nu am simtit vreo problema ma refer la putere functionalitate. Ce mi se pare un pic cam anormal este ca in a 5 la 2000 de turatii parca nu are vana cand accelerez mai tare si accelereaza progresiv.
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Serban
Friday,03,November,2017,14:45:25:62939
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 69 72 77
VIN: WVWZZZ3CZAE212272
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BT    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  6214
   Revision: 13H13---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 01979 002 00007
   VCID: 78FF0E6B0B2690DEAC3-802D
2 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 219425 km
                    Time Indication: 0
                    Date: 2015.14.28
                    Time: 15:40:37
             Freeze Frame:
                    RPM: 782 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Lambda: 11.0 %
                    Lambda: -0.8 %
                    Voltage: 0.304 V
                    Bin. Bits: 00000000
009571 - Turbocharger Boost Control Position Sensor Circuit
               P2563 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 220046 km
                    Time Indication: 0
                    Date: 2016.14.05
                    Time: 10:01:42
             Freeze Frame:
                    RPM: 161 /min
                    Speed: 2.0 km/h
                    Voltage: 12.46 V
                    Lambda: 70.2 %
                    Lambda: -11.8 %
                    Bin. Bits: 00001110
                    Voltage: 2.052 V
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AE    HW: 3C0 614 109 AE
   Component: J104    C4 440 V1   0015
   Revision: --026---    Serial number: 00000706213964
   Coding: 0000260
   Shop #: WSC 05311 000 00000
   VCID: 61C9430FB8BC7116FBD-8034
No fault code found.
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 7EF31873E102AEEEE6F-802B
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 AC    HW: 3C8 937 049 AC
   Component: Bordnetz-SG     H64 3205
   Revision: 00H64000    Serial number: 00000004231418
   Coding: E1888F0700041A32470A00000F00000000095D435C00012C000000000000
   Shop #: WSC 05124 123 12345
   VCID: 72EB3C436D5AFA8E927-8027
   Subsystem 1 - Part No: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 150910 010  0603
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     101010 054  0403
   Coding: 16777215
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08791026474554
   Coding: 110001
   Shop #: WSC 05314 123 12345
   VCID: 326BFC436DDABA8E527-8067
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__005 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PKRW402
   Coding: 0012341
   VCID: 4C9782BB2F3ECC7E38B-8019
   Subsystem 1 - Serial number: 6332MTS633432550
   Subsystem 2 - Serial number: 6342MTS615012590
   Subsystem 3 - Serial number: 6351HTS6J15FF9KR
   Subsystem 4 - Serial number: 6361HTS6U52FF9KJ
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 DA    HW: 5K0 953 569 BA
   Component: LENKS.MODUL   016 0140
   Revision: FF010042    Serial number: 20140710301176
   Coding: 118A250002
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 6BD5212782702B46511-803E
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 872 G    HW: 3C0 920 872 G
   Component: KOMBI         H03 0305
   Coding: 161F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 29591B2F480CF956E3D-807C
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P10930028C
   Coding: F9A07F46000602002002
   VCID: 2F6DF537BEE897663D9-807A
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 7AFB1463352A82CEDA7-802F
   Subsystem 1 - Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3C0 959 701     HW: 3C0 959 793
   Component: TUER-SG FT    002 0305
   Revision: 13101005    Serial number: 0001614589
   Coding: 0000B5
   Shop #: WSC 05311 115 00000
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: E5C1D71FE4949D36875-80B0
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001678836
   Coding: 000090
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.308 0802
   Revision: 1AH03729    Serial number: 00102800150801
   Coding: 0000258
   Shop #: WSC 19460 666 12345
   VCID: 3B75D1677A907BC6811-806E
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 0091020051034E763004BC3F70084F0E707C01
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H05 1501
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3C0 959 702     HW: 3C0 959 792
   Component: TUER-SG BT    002 0305
   Revision: 15101005    Serial number: 0001592367
   Coding: 0000B4
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: E6C3D0131992962E8EF-80B3
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001682825
   Coding: 000090
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   011       Serial number: 00000000418711
   Coding: 0000056
   VCID: 2C57E23B8FFEEC7E18B-8079
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K8314896
   Coding: 0500040004
   Shop #: WSC 05314 000 00000
   VCID: 65C1571F6C941D36075-8030
00468 - CD-ROM Drive (R92)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 5
                    Fault Frequency: 37
                    Reset counter: 139
                    Mileage: 219425 km
                    Time Indication: 0
                    Date: 2015.14.28
                    Time: 15:40:02
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 306FF64B63D6889E243-8065
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A07877728
   Coding: 012120
   VCID: 2A5BE423450AF24EEA7-807F
End   ---------------------------------------------------------------------
Ai 2 probleme, cu una scapi mai ieftin, cu limitatotul facut de cei de la diesel geek, la cealalta vezi actuator, vacuum, fire.
  • 6 months later...
Salut.
Acum ceva timp in urma (sa fie vreun an jumate) mi-a aparut eroare in VCDS pe bujia 1 (open circuit). Bineinteles, ca am cautat pe internet despre eroare, si-am gasit mai multe cauze... Problema e ca de-atunci, motorul are momente, cand il pornesc, tremura foarte tare, dar dupa cum am zis, are momente, nu intotdeauna... Acum, am facut iar o scanare si imi da pe toate 4 Open circuit... Tremurul asta sa fie de la bujii, sau de la volant?! (mentionez ca are o bataie aproape insesizabila)...
Aaa... cand era destul de rece afara, acum vreo 3-4 luni sa zic, la prima pornire scotea si fum, acum cand e destul de cald dimineata (peste 15 grade), nu scoate...
Mersi.
F l o r i n
daca tremura si acum, cand este destul de cald, nu e de la bujie.
Buna ziua,am un passat b6 2.0 tdi si  la 6-7 luni   am bujiile arse .Stie cineva care ar fi problema?Multumesc.
  • 7 months later...
Buna ziua!  Cum stiu care este bujia arsa (Glow 2). a doua de la distributie de la stanga la dreapta?
               P0672 - 000 - Electrical Fault
Modificat de vladucianu
1 e cea de langa distributie
E bine sa inlocuiesti toate bujiile
Buna ziua
Acum 2 saptamani mi s-a aprins martorul motor ( check engine ). Am facut o diagnoza si mi-a aparut eroarea P0670.
Am schimbat releul de bujii, dar a doua zi s-a aprins iar martorul motor, iar la diagnoza am avut erori pe toate cele 4 bujii P0671, P0672, P0673, P0674.
Am schimbat bujiile, erau intradevar arse, dar azi s-a aprins iar martotul motor iar s-a aprins aceiasi eroare pe toate bujiile.
Stie cineva cum sa rezolv problema cu bujiile?
e vorba de un passat 2.0 tdi, cod motor BMA
posteaza erorile EXACT asa cum apar pe VCDS.
diagnoza a fost facuta la un sevice multimarca in germania, cu tester Hella
pe priima diagnoza am
fehlercode / motor / motor-elektronik 1
1 fehler
fehlercode: P0670
Glühzeitsteuergerät
- stromkreis fehlerhaft
iar pe a 2 a diagnoza
4 fehler
fehlercode : P0671
Glühkerze zyl. 1
fehlercode : P0672
Glühkerze zyl. 2
fehlercode : P0673
Glühkerze zyl. 3
fehlercode : P0674
Glühkerze zyl. 4
ce cod avea releul vechi ? ce cod are releul nou ?
Alimentarile releului sunt OK ?
Modificat de Al Bundy
releul vechi era original vw iar cel nou a fost schimbat in service cu unul bosh.
alimentarile releului nu au fost verificate.
le-as verifica singur dar nu stiu ce trebuie facut.
azi am masurat cu un multimetru curentul care vine prin fisa bujiei.
plusul l-am luat de la bujie iar minus de pe motor
in prima secunda dupa ce pun contact imi arata 11v , apoi scade la 4.8
bujiile mele sunt de 4.4v
cei 11 v cand pun contactul imi ard mie bujiile?
Modificat de andreibu99
constantin_stefan
In luna decembrie am avut o problema la bujia numarul 2 si la EGR. Am fost la un service, s-a schimbat bujia, s-a curatat EGR-ul. Toate bune si frumoase pana in martie, cand primesc urmatoarele:
Quote
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QD    HW: 03L 907 309
   Component: R4 2,0L EDC G000AG  6209
   Revision: 13H10---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 84224 794 616680
   VCID: 77FD5DDD06CD43F2E4-8022
3 Faults Found:
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 377399 km
                    Time Indication: 0
                    Date: 2013.05.22
                    Time: 12:52:58
             Freeze Frame:
                    RPM: 1104 /min
                    Speed: 0.0 km/h
                    Voltage: 11.55 V
                    Temperature: 2.7°C
                    Bin. Bits: 10110000
                    Time: 2.52 s
                    Temperature: 2.7°C
001027 - EGR Valve (N18)
               P0403 - 000 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 10
                    Reset counter: 255
                    Mileage: 380745 km
                    Time Indication: 0
                    Date: 2013.07.05
                    Time: 10:41:47
             Freeze Frame:
                    RPM: 1219 /min
                    Speed: 39.0 km/h
                    Load: 0.0 %
                    Load: 100.0 %
                    Lambda: 98.6 %
                    Mass Air / Rev.: 525.0 mg/str
                    Temperature: 90.0°C
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 000 - Signal too High (Rich) - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100000
                    Fault Priority: 2
                    Fault Frequency: 44
                    Reset counter: 255
                    Mileage: 378914 km
                    Time Indication: 0
                    Date: 2013.05.27
                    Time: 07:20:05
             Freeze Frame:
                    RPM: 2507 /min
                    Speed: 127.0 km/h
                    Lambda: 48.9 %
                    Mass Air / Rev.: 615.0 mg/str
                    Voltage: 0.825 V
                    (no units): 16.0
                    Voltage: 0.975 V
Schimbat iar bujia 2. In iunie, primesc urmatoarele:
Quote
   Coding: 0000078
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 381331 km
                    Time Indication: 0
                    Date: 2013.08.13
                    Time: 11:25:36
             Freeze Frame:
                    RPM: 897 /min
                    Speed: 0.0 km/h
                    Voltage: 13.30 V
                    Temperature: 9.9°C
                    Bin. Bits: 10110000
                    Time: 2.34 s
                    Temperature: 10.8°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 40
                    Reset counter: 255
                    Mileage: 381352 km
                    Time Indication: 0
                    Date: 2013.08.13
                    Time: 13:31:14
             Freeze Frame:
                    RPM: 1909 /min
                    Speed: 97.0 km/h
                    Lambda: 48.1 %
                    Mass Air / Rev.: 600.0 mg/str
                    Voltage: 0.825 V
                    (no units): 16.0
                    Voltage: 0.975 V
009754 - Coolant Pump 2
               P261A - 000 - Open circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 383198 km
                    Time Indication: 0
                    Date: 2013.10.29
                    Time: 20:47:27
             Freeze Frame:
                    RPM: 805 /min
                    Speed: 0.0 km/h
                    Voltage: 12.54 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011111
                    Bin. Bits: 00000000
                    Temperature: 72.9°C
Nu stiu daca are vreo legatura, insa de atunci cand pornesc racirea la AC se aude un harait ciudat.
Putin ajutor va rog?
Multumesc anticipat!
Nu, nu are legătură.
La bujia 2,verificat circuitul
Schimbat pompa secundara de apă și sonda lambda, dacă ștergi erorile și revin în scurt timp
Stie cineva cu ce fel de cheie desfac bujiile passat b6 bmp am o bujie arsa
Daca nu stii nici cu ce cheie se desfac nu te apuca tu sa le schimbi, ai sanse mari sa le rupi
Daca s-a dus una, schimba-le pe toate ca si restul sunt varza, manopera o singura data.
Modificat de calin.g
   Stiu ca se rup usor si trebuie cheie dinamometrica sa le desfaci. Daca nu merge, nu fortezi, pui ulei si mergi cu masina o saptamana, apoi mai incerci odata.
cu o tubulara de 10 un pic mai speciala,iti trebuie un magnet daca ai sa le scoti dupa ce le desfiletezi...eu zic ca se desfac usor nu se rup,cel putin la motoarele astea
