ParkAssist nu "vede" locurile de parcare
Geisterfahrer
Nu am kessy. Ulterior am citit ca nu de poate fără kessy și e logic, trebuia sa mă gândesc din prima, deci îmi iau gândul
Modulul de pla, e vorba de cel care se afla în bord în partea stângă?
Modificat de AlexJFY
exact - cel de sub bord in stanga, la modelul tau.....
da, nu merge daca nu ai kessy
  On 20.10.2014 at 12:50, Al Bundy a scris:
La cc merg ambele montate.
Expand
Poti te rog sa ne dai ceva detalii?
Eu am PLA 1.5, dar as incerca sa pun 2.0, modulele sunt foarte ieftine, intrebarea este daca ABS-ul este ok, am deja si ACC:
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AG    HW: 3C0 614 109 AG
   Component: J104    C4 440 V3   0015
   Revision: --026---    Serial number: 00000705792058
   Coding: 0024872
   Shop #: WSC 05311 000 00000
   VCID: 63CE6967A287745C65-8037
Da,e compatibil.Senzori spate,holderi,alti senzori Abs spate,modul Pla...cablaje..cam asta ar fi.
Da, Passat CC mai exact:
Production date	2010-07-02
Model year	2011
Am citit pe bronken.de urmatorul paragraf, din care inteleg ca e nevoie neaparat de ABS 3AA...
  Quote
No, the Passat B6 will most likely never be compatible with PLA 2.0.
First of all, for PLA 2.0 you’ll need two additional Ultrasonic Sensors located at the back of the car scanning sidewards. And you’ll need a new PLA 2.0 Controller. So far so good. Adding the new Controller and two new Sensors wouldn’t be much of a problem... BUT...
The new PLA 2.0 Controller Board requires additional Information which needs to be provided by the ABS Controller via CAN. So you would have to exchange the Passat B6 ABS with a Passat B7 ABS (The Passat B7 is equipped with PLA 2.0). But the B7 ABS won’t fit in the B6 So you’re screwed.
Long story short as far as I know theres no chance for that to happen. But when there is, be sure to find the solution here
Expand
Probabil merita incercat, dar era ideal sa stiu sigur daca a mai reusit cineva.
pe un CC am facut eu trecerea acum vreo 2 ani , dar nu mai stiu userul.
Merge fara probleme. Am facut multe treceri. Daca ai neclaritati te ajut.
In principiu: 1. Abs de B7/cc facelift (toate stiu pla 2.0. Daca ai ACC trebuie o pompa care sa stie ACC. Daca nu gasesti, pot sa iti fac eu orice pompa de b7 sa stie ACC).
2.unitate pla 2.0
3. Senzori abs 2.0 spate
4. Cei 2 senzori pla bara spate.
Ca sa pui ABS de B7, trebuie si EPB de B7. Automat trebuie butonul de frana de mana schimbat.
epb b7 plus buton epb b7 merge cu abs de b6
Epb b6 cu buton epb b6 nu merge cu abs de b7
Modificat de Yogurd
  On 04.11.2018 at 15:54, EsTeTicu a scris:
Model year	2011
Expand
nu, intreabarea nu era pentru tine, ci pentru Spido - nu trebuie sa schimbi niciun senzor ABS pe spate.... la Passat.
Deci ABS si EPB trebuie schimbate obligatoriu, asta era de fapt intrebarea, daca am vreo sansa fara, in cazul asta nu prea merita deranjul... multumesc de confirmare!
nu, nu ai sanse, din pacate....
  • 3 years later...
Am un B6 cu ParkAssist, apas butonul, vede locul de parcare, imi indica sa schimb in R apoi nu mai face nimic. A mai patit cineva?
pai si apoi trebuie sa continui tu manevra
Pai o pun in R, las usor ambreiajul dar volanul nu se invarte cum am vazut pe  youtube. Probabil are vreo problema la ParkAssist.
Modificat de Manuel N.
Atentie la quote! Se sanctioneaza folosirea nejustificata!
