Panoul electric Mk2
19E
Acesta este panoul electric de la Mk2-ul meu...si mi se pare putin cam cu lipsuri...sa fie normal oare asa??
e normal sa existe lipsuri , acum nu stiu sa zic daca "numarul de lipsuri" pt masina ta e ok sau e cam mare. in printip daca nu ma insel acest panou este cam identic pt toate mk2 iar numarul de relee depinde de tipul masinii si de accesoriile de pe ea. poate ma insel dar eu cam asa stiu povestea !
Fuses
Fuse No. Description Ampere Rating
1 Headlight, low beam, left 10
2 Headlight, low beam, right 10
3 Instrument panel lights, license plate lights 10
4 Glove compartment light, rear window wiper 15
5 Windshield wiper/washers 15
6 Fresh air blower 16-valve only: Air conditioning 20
7 Taillights, side marker light, right 10
8 Taillights, side marker light, left 10
9 Rear window defogger 20
10 Fog lights 15
11 Headlight, high beam, left, High beam indicator light 10
12 Headlight, high beam, right 10
13 Horn
16-valve only: Radiator cooling fan 10
14 Back-up lights, washer nozzle heaters 10
15 16-valve only: Engine electronics, idle stabilizer valve, cold start valve 10
16 Instrument panel warning lights, 16-valve only: multi function indicator 15
17 Emergency flasher switch, turn signals 10
18 Fuel pump, oxygen sensor heater 20
19 Radiator cooling fan, air conditioning 30
20 Brake lights, cruise control 10
21 Interior lights, digital clock
16-valve only: Luggage compartment light, multi function indicator, central locking 15
22 Radio, cigarette lighter 10
Relays
Relay No. Description
1 Air conditioning
2 Rear window wiper/washer
3 Digifant control unit (except 16-valve)
4 Load reduction relay
5 Intermittent wiper or Open
6 Emergency flasher
7 Fog lights or Open
8 Intermittent wiper or Open
9 Seat belt warning system
10 Fog lights or Open
11 Horn
12 Fuel pump (except diesel)
Glow plugs (diesel only)
13 Radiator cooling fan after run control unit (except diesel)
14 Starter interlock (except diesel)
Diesel: Air conditioning fuse (20A)
15 Open
16 Open
17 16-valve only: Power window relay
18 Daytime driving lights (Canada only)
19 Automatic transmission
20 Open
21 Power window relay or Open
22 Open
23 Air conditioning, power seat fuse
16-valve only: Air conditioning, heater fuse
24 Power window fuse
deci ala cu 67 e de la stergatoru din spate
ala cu 18 e Intermittent wiper or Open
19 Fog lights or Open
72 Horn
21 Fuel pump (except diesel)
am si eu un releu , nr 65 scrie pe el, cand am cumparat masina proprietarul mi l-a dat separat, stie careva dintre voi ce rol are?
cateva poze facute cu webcamu !! nu se vede prea bine :P
pai eu am CIS :( , sau K-jetronic, cum vrei sa-i zici, deci nu are nici un rol la mine?
vinde-l daca iti prisoseshte.
io am cumparat un releu aiurea pt pompele de benzina cu 450.000 nou. il am si acu, ca l-am pus pe ala vechi in panou.
cu mai mult de 300 nu pot sa-l dau. cred ca la fel si tu (in cazul in care e nou si functioneaza)
dupa cum se vede pe el , a fost folosit, sper sa mearga :biggrin:
