Probleme servodirecție electromecanica
kalu
Da. Posteaza si modulele pe care apar aceste erori.
Modificat de Al Bundy
Saturday,08,February,2014,18:59:05:36838
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ4D000103   Mileage: 167340km/103980miles
01-Engine -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
44-Steering Assist -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 997 056 M    HW: Hardware No
   Component: MED9.5.10       G00 9265
   Revision: 00000000    Serial number: VWZ7Z0C8702770
   Coding: 0000072
   Shop #: WSC 01506 264 00679
   VCID: 377637583FCB
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
            P1699 - 008 - Implausible Signal
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0019074
   Shop #: WSC 00011 000 00000
   VCID: 3A702E6C0CD9
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 K
   Component: ClimatronicPQ35 063 0201
   Shop #: WSC 00000 000 00000
   VCID: 2F660F38C79B
4 Faults Found:
00576 - Terminal 15
            001 - Upper Limit Exceeded - Intermittent
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus - Intermittent
00709 - Sunlight Photosensor 2 (G134)
00926 - Terminal 30
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H29 0701
   Revision: 00029000    Serial number: 00000000292100
   Coding: 018D0F0600041800001400001400000000
   VCID: 3874346432D5
   Part No: 1K1 955 119 A
   Component: Wischer VW350  011  0301
   Coding: 00065493
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0L AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD052B2B
   Coding: 0012364
   Shop #: WSC 31414 000 00123
   VCID: 2A501E2CFC79
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 009 0030
   Coding: 0000012
   VCID: 30640C44DAA5
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 860 K
   Component: KOMBIINSTRUMENT VDD 3350
   Coding: 0001101
   Shop #: WSC 01506 264 96331
   VCID: 30640C44DAA5
01309 - Power Steering Control Module (J500)
            004 - No Signal/Communication
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2100103A02F0EF
   Coding: 3D3F0340070002
   Shop #: WSC 31414 000 00121
   VCID: 2756E718EF6B
2 Faults Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 132
                    Mileage: 167345 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:21:27
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 132
                    Mileage: 167345 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:21:32
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO                3350
   VCID: 30640C44DAA5
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 F
   Component:      Navigation     0030
   Coding: 0000101
   Shop #: WSC 05314 000 00000
   VCID: 3C7C287406ED
00862 - Antenna for GPS Navigation (R50/R52)
            011 - Open Circuit
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0102
   Coding: 0000052
   VCID: 30640C44DAA5
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0545
   Coding: 00E802087F2D8404084F0100
   VCID: 30640C44DAA5
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 31620940D1AF
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 G
   Component:        Radio        0030
   Coding: 0040400
   VCID: 2952E120F97F
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 05 0108
   Coding: 0000016
   VCID: 30640C44DAA5
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 31620940D1AF
End   ---------------------------------------------------------------------
Saturday,08,February,2014,19:09:23:36838
Chassis Type: 1K0
37-Navigation -- Status: Malfunction 0010
   Coding: 0000072
   VCID: 377637583FCB
   Coding: 0019074
   VCID: 3A702E6C0CD9
   VCID: 2F660F38C79B
2 Faults Found:
   VCID: 3874346432D5
   Coding: 00065493
   Shop #: WSC 00000
   Coding: 0012364
   VCID: 2A501E2CFC79
   Coding: 0000012
   VCID: 30640C44DAA5
   Coding: 0001101
   VCID: 30640C44DAA5
   Coding: 3D3F0348070002
   VCID: 2756E718EF6B
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 132
                    Mileage: 167345 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:21:27
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 172
                    Mileage: 167345 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:21:32
   VCID: 30640C44DAA5
   Coding: 0000101
   VCID: 3C7C287406ED
            011 - Open Circuit
   Coding: 0000052
   VCID: 30640C44DAA5
Cannot be reached
   Component:    KSG              0545
   VCID: 30640C44DAA5
   Coding: 0000052
   VCID: 31620940D1AF
   Coding: 0040400
   VCID: 2952E120F97F
   Coding: 0000016
   VCID: 30640C44DAA5
   Coding: 0000016
   VCID: 31620940D1AF
Am si eu aceeasi problema la un golf 5 din 2004 motor 1.9 diesel.M-a lasat servodirectia in mers,a bipuit de 3 ori si acum se invarte foarte greu volanul.Pe tester imi apare eraore la G269 sensor,care am inteles ca e pozitionat pe caseta de directie.
A rezolvat cineva aceasta cauza pana acum?
Modificat de perpeleac
Prin schimbarea casetei, da. Se rezolva.
salutare, am inteles ca pt golf5/jetta sunt 2 generatii de casete sau 3..stie cineva mai exact cum se verifica generatia casetei?(dupa perioada de fabricatie,codul de motoras,prindere?)
Prima si cu a doua generatie de caseta se deosebesc de a treia prin prinderea in 4 suruburi spre deosebire de aceasta din urma care se prinde in 3 suruburi de punte.
Prima generatie s-a folosit in primul an de productie al golfului 5, si anume 2004, a doua a continuat din 2004 pana in 2008, iar a treia a ajuns doar pe ultimele golfuri 5, modelele din 2009.
Robert gabriel
Salut baieti am si eu o problema grava, de vreo luna de zile am ramas fara servo directie, martor volanul rosu am schimbat caseta cu totul a mers cateva ore sa zic toata ziua, am puso pe a mea inapoi, aceiasi chestie stergand eroarea isi revenea, dar la fel cateva ore am schimbat mecanicul si am schimbat pe bucati acel torch senzor daca nu gresesc si motorasul, aceiasi situatie cremaliera am schimbato la fel, am schimbat senzor de pe coloana voloan la fel, erori in prima faza avea masa pe undeva, dupa operatiunea respectiva alta eroare nu vede unghiurile nu stie unde este stanga unde este dreapta nici acele grade nu le arata pe tester. Vreau sa mentionez ca cele spuse sunt ce mia spus mecanicul si ce am vazut si cu ochii mei. Nimic diferit, acolo am ramas. Am schimbat alt mecanic,care defapt el mia schimbat senzorul de pe coloana volan sau asa ceva, bun, un prim pas nu neaparat spre bine e ca inainte dupa stergerea erorilor nu mai aparea nimic si cand incepea la pornire direct rosu, e acum dupa interventia acestui baiat dupa stergerea erorilor ramane galben si merge servo directia dar nu la capacitatea ei maxima si numaidecat aparitia celui rosu este prezenta si la vreo doua trei porniri ma lasa iar, mentionez ca acea adaptare 5 sec drept 5 sec drapta 5 sec stanga am facuta de nenumarate ori nu stiu ce este cu cea in mers nu cred ca sa facut vreodata si asta este tragicul meu regret ca mi-am pierdut speranta in aceasta masina. Scuzati-mi greselile dar sunt disperat de o luna numai prin service-uri stau si nimeni nui da de cap
Posteaza un autoscan sa vedem erorile.
Robert gabriel
Adica sa ii cer datele care le da pe tester nu?
Salut.
Am si eu o problema cu servo (Volan rosu)   . pe tester imi da Power Steering Control Module (J500) pe vcdc,   iar la alt tester nu vede nimic ( nu poate sa intre , nu comunica )   la sevice am verificat ,fire , mufe , am demontat modulu si cica  nu mai merge si nu se poate repara si trebuie sa cumpar alta caseta sau sa gasesc motoru cu modul sa il schimbe. Dupa lungi cautari am gasit modulu si motoru ,dar cei de la dezmembrari mi-au spusc ca nu o sa imi mearga daca le pun pe alta caseta  . Ce imi recomandati sa fac ?  stima
banuiesc ca nu iti vede modulul 44- servodirectie..... nu il poti accesa sau il accesezi si ai anumite erori ?
daca nu il poti accesa, au fost verificate deja sigurantele, cablajul, etc - atunci iti cauti alta caseta.... trebuie sa cumperi una compatibila. Sunt mai multe generatii.... de aceea trebuie sa cauti una compatibila, in functie de ce ai tu acum pe masina.
Salut.
Daca sunt generatii diferite nu merg schimbate componentele intre ele. si daca pui generatie mai noua ca a ta se schimba si cablajul.
Orice ati face NU va cumparati/montati caseta de directie la AUTOESTET (http://www.autoestet.com/ro/), mai bine dati banii unui cersetor ca tot aia e! Cei mai mari tepari din BUCURESTI
Oricum, vad ca kaspersky numa lasa sa accesez site-ul, are virusi.
Cu componente de caseta electrica generatia 3 va pot ajuta eu.Toate sunt functionale mai putin carcasa care are urechile rupte.Caseta provine de pe un SEAT LEON an fabricatie 2011.
Care e diferenta intre cablajele gen 2 si gen 3? Am vazut si eu in ELSA ca trebuie schimbate, insa par identice (atat ca sectiune, cat si ca traseu).
Diferenta o da lungimea firelor si mai e diferenta mufei mici (cea de comunicare).
Adica sunt mai lungi sau mai scurte cele de gen. 3?
E vorba de pozitia motorasului.Cel de generatia a doua este pozitionat ca si cablaj invers decat cel din generatia a treia.
Deci daca tu ai caseta din generatia trei si vrei sa pui una de generatie doi nu ajung firele deci la generatia trei sunt mai scurte.
Eu am inlocuit o caseta generatia 3 cu una din generatia 2 si am lungit firele prin lipirea lor cu pistolul de lipit si izolatie din acea care se incalzeste si se strange pe fir.
Am inteles. Multumesc de explicatii.
Eu sunt in situatia inversa, vreau sa inlocuiesc generatia 2 cu generatia 3. In contextul asta, inteleg ca pot folosi cablajul de gen 2, inlocuind doar conectorul T5e (comunicarea CAN si alimentarea in panoul de sigurante) - conector care difera la gen 3 fata de gen 2.
pai si eu cum aflu ce generatie este caseta mea  ?   ( vw golf 5 . 1.6 FSI   bag an 2004 )  este generatia 1 banuiesc  ?
Modificat de blynky
no, posteaza codul de pe ea....
acum nu am cum pt ca este pe masina , pot sa iti dau codul dupa modul 1k1909143l
da, este generatia 1.
  • loghy changed the title to Martor servodirectie aprins
