Rezervor vacuum
Alex_YUM
In compartimentul motor am ca o bila verde care cica ar fi rezervor de vacuum. Care este rolul acestui rezervor?
rolul lui e ca sa uniformizeze intr-o masura variatiile vacuumului si ca distribuitor pentru diferitele functii care sunt actionate de vacuum,clapeta de aer cald etc si ce mai ai pe acolo.o alta functie este de "acumulator de vacuum" de a oferi ceva vacuum ultil pentru actionare si dupa ce motorul e oprit,o vreme.
In principal compensatoriu sau, citez:
Depending on the engine type this reservoir has two different functions.On some earlier Polo versions it was used for ignition timing control and then it was used for sustaining the operation of the choke vacuum pulldown unit.It is this latter function which is mostly seen now.However if the pulldown unit itself is in good condition and correctly connected to a vacuum supply the choke system will still work tolerably well without the green sphere.Basically its one further complication added to the over complex Pierburg carburetter.
Va multumesc mult. Tind sa cred asta "Basically its one further complication added to the over complex Pierburg carburetter." :)
