codari vag roomster
vlad31
In urma unei incercari esuate de activare a unor functii pe un roomster, vin sa v-a intreb: ce functii poti activa pe acest tip de masina si care sunt codarile?
Am incercat niste codari care sunt si pe golf 5, dar se pare nu au mers.
Mileage: 444850km/276416miles
Address 01: Engine Labels: Redir Fail!
Part No: 045 906 019 CJ
Component: 1,4l R3 EDC 0200SG 9517
Coding: 00102
Shop #: WSC 73430
VCID: 5FC6268AF755
TMBME25J985014879 SKZ7Z0G4310862
5 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-00 - -
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels:
VCID: 55AA04A28569
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 5J0 820 045
Component: Klimaanlage X0850
VCID: E2C0AF7E4427
65535 - Internal Control Module Memory Error
00-00 - -
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q2 937 049 F
Component: 0000 BN-SG. 2S36
Coding: 17422
Shop #: WSC 73430
VCID: 3F86C60A1715
01598 - Drive Battery Voltage
27-00 - Implausible Signal
Address 15: Airbags Labels:
VCID: 55AA04A28569
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 000D GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 73430
VCID: F0E4D5369ACB
No fault code found.
Address 44: Steering Assist Labels:
VCID: 55AA04A28569
Note: Excessive Comm Errors
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 5J0 959 433
Component: 03 Komfortgerát 0001
Coding: 00019
Shop #: WSC 73430
VCID: F0E4D5369ACB
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 5J0 035 161 HW: 5J0 035 161
Component: Radio FO3 010 0029
Revision: 00010000 Serial number: SKZ7Z3G0018750
Coding: 0000200
Shop #: WSC 73430 790 00000
VCID: DFC6A68A7755
GYORGYAN(GYO)
salutare ma poate lamuri si pe mine cineva cu care se pricepe la vag si la coduri ce anume trebuie sa repar sa inlocuiesc sau etc..... am facut o scanare si mi-a aratat urmatoarele erori ..........
Address 01: Engine Labels: 038-906-019-AXR.LBL
Controller: 038 906 019 DF
Component: 1,9l R4 EDC 0000SG 1260
Coding: 00002
Shop #: WSC 01317
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: Redir Fail!
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 01317
3 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory
00778 - Steering Angle Sensor (G85)
014 - Defective
Address 17: Instruments Labels: 1J0-920-xx5-17.LBL
Controller: 1J0 920 825 C
Component: A4-KOMBIINSTR. VDO V09
Coding: 05122
Shop #: WSC 91975
IMMO-IDENTNR: VWZ7Z0Y3194636
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 46: Central Conv. Labels: 1J0-959-799.LBL
Controller: 1J0 959 799 AH
Component: 2K Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Daca ma puteti ajuta va rog............va multusmesc !!.....
