Moare motorul in mers 1.6 16v !
axel88
nu mai e am pus alta acum , si am schimbat si releu ala dar degeaba nu mai da am inteles ca ar avea o siguranta ceva dar nu stiu care e pentru ca nu vad pe chestia asta
am aceasi problema. am scanat cu vag com si a dat asta
a incepit dupa ce am curatat clapeta de acceleratie si egr, am tot citit chestii pe forum si multi zic sa-i dau adaptare din vag.com dar nimeni nu spune si procedura
am achizitionat un vag.com dar nu stiu sa-l folosesc  :10[1]:  :tuktuk:
Wednesday,24,December,2014,15:48:59:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Mileage: 154230km-95834mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 154230km/95834miles
Address 01: Engine        Labels: 036-906-032-AXP.lbl
   Part No: 036 906 032 P
   Component: ME7.5.10            3547
   Coding: 00031
   Shop #: WSC 00000
   VCID: 1D3BC134974F0FF69F5-5072
17852 - Potentiometer for EGR (G212)
            P1444 - 35-00 - Implausible Signal
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 E
   Component: ESP FRONT MK60      0103
   Coding: 0011266
   Shop #: WSC 01317 785 00200
   VCID: 2C5D1CF08CF5F67E18B-5072
01423 - Lateral Acceleration Sensor (G200)
            012 - Electrical Fault in Circuit
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0011
   Coding: 12855
   Shop #: WSC 48143
   VCID: 2241F2C8AE31300EA27-5000
No fault code found.
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 825
   Component: KOMBI+WEGFAHRS. BOO V04
   Coding: 01111
   Shop #: WSC 48143
   VCID: E5CB29D47F9F8736875-5072
   Subsystem 1 - Part No: Ident
   Component: Nr. WEGFAHRS.:VWZ6Z0Y2065351
   Ident.-Nr. WEGFAHRS.:VWZ6Z0Y2065351
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0E54880B05D529EE43-5072
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4E Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 01317
   VCID: 840D145094E55E3E30B-4A3A
   Subsystem 1 - Part No: 1J1959801C
   Component: 4E Tőrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 4E Tőrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 4E Tőrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 4E Tőrsteuerger. HR0002r
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
End   ---------------------------------------------------------------------
Si eu am aceasta problema de cand am cumparat masina (2009) si inca nu i-am dat de cap. Cateodata trec cateva saptamani sau luni si nu se intampla nimic, alta data moare de 2- 3 ori pe zi - e random total. Se intampla si cand e pe liber si cand e in sarcina - moare motorul si reporneste imediat, din cauza ca este antrenat de cutia de viteze (banuiesc ca asta nu e bine nici pt distributie). Dupa ce am incercat multe variante si nu am reusit sa rezolv problema, o iau pe alta cale. Daca ma poate ajuta cineva care se procepe - am observat ca de cate ori se intampla sa moara motorul, aud un ticait in bord (parca de releu)  - se poate sa fie aceasta o cauza, sau mai degraba efect al opririi motorului si repornirii lui?  multumesc
