[Info] Detaliere coduri Modul 09 - Central Electronics
Stormlord
Semnificatia codurilor setabile in cadrul modulului 09 Central Electronics, pentru Polo6R.
Exemplu de citire:
LC,00,0,Selective Central Locking (Single Door Locking) active
LC=Long Coding
,00,=BYTE
,0,=BIT
LC,00,3,Auto-Unlock (Unlocking when Removing the Ignition Key)
LC,00,4,Auto-Lock (Automatic Locking above 15 km/h)
LC,00,5,Central Locking installed
LC,01,7,Central Locking/Rear Lid: Rear Lid Locking/Unlocking via Central Locking
LC,02,0,Central Locking/Rear Lid: Soft-Touch
LC,02,2,Remote Control with "Terminal 15 ON" active
LC,03,0,Comfort Opening for Sun Roof active
LC,03,1,Comfort Closing for Sun Roof active
LC,03,2,Comfort Function for Sun Roof active
LC,03,3,Comfort Function for Power Windows via Lock Cylinder active
LC,03,4,Comfort Function for Power Windows via Drivers Interior Switch active
LC,03,5,Comfort Function for Power Windows via Remote Control active
LC,03,7,Comfort Function active
LC,04,5,Central Locking Re-Locking (after 30 Seconds) active
LC,04,6,Rain Closing active
LC,05,0,Locking/Unlocking Optical Confirmation (Turn Signal) active
LC,05,1,Acoustical Locking Confirmation (Horn) active
LC,05,4,Acoustical Unlocking Confirmation (Horn) active
LC,05,5,Comfort Closing Optical Confirmation (Turn Signal) active
LC,05,6,Anti-Theft-System Sounder/Sirenen Port active (0 = Simple-Horn installed / 1 = Backup-Siren
(LIN) installed)
LC,05,7,Anti-Theft-System Activation Acoustical Confirmation (Horn) active
LC,06,0,Siren Tone Type (0 = frequency modulated / 1 = discontinuoud)
LC,06,1,Siren Alarm Type (0 = 10 Alarms (GB/Irland) / 1 = 1 Alarm (RoW))
LC,06,2,Anti-Theft-System installed
LC,06,3,Anti-Theft-System Deactivation via Ignition Lock active
LC,06,5,Anti-Theft-System Delay Start (0 = with Door Opening / 1 = with Unlocking)
LC,07,0,Central Locking/Rear: Slidung Door Left installed
LC,07,1,Central Locking/Rear: Slidung Door Right installed
LC,07,3,Remote Control inactive
LC,08,0,Rain/Light Sensor (RLS) installed
LC,08,1,Inclination Sensor for Anti-Theft System installed
LC,08,4,Interior Monitoring for Anti-Theft System installed
LC,08,7,Sounder/Siren for Anti-Theft System (via LIN) installed
LC,09,3,Multi-Function-Steering-Wheel (MFSW) installed
LC,09,4,Rear Power Windows installed
LC,09,5,Front Power Windows installed
LC,10,1,Leaving-Home (LH) active
LC,10,2,Coming-Home (CH) active
LC,11,6,Lamp Diagnostics for Back-Up Light active
LC,11,7,Lamp Diagnostics for Lisense Plate Light active
LC,12,0,Parking Lights ON with "Terminal 15 ON"
LC,12,1,Daytime Running Light (DRL) adjustable (Manually AND/OR Instrument Cluster)
LC,12,2,Interior Light after Ignition Key removal active
LC,12,3,Emergency Flashing (Turn Signals) active
LC,12,4,Emergency Brake Flashing (Brake Light) active
LC,12,5,Comfort Turn Signals active
LC,12,6,Turn/Cornering Lights installed/active
LC,13,0,Parking Lights ON only w/o Ignition ON possible
LC,13,1,Parking Lights Function active
LC,13,2,Brake Lights OFF while Terminal 15 OFF
LC,13,3,Brake Light Activation via Body Control Module (BCM)
LC,13,5,Interior Light Enabling via Rear Lid
LC,13,6,Coming-Home (CH) / Leaving-Home (LH) Variant (0 = Fog Lights / 1 = Low Beam)
LC,13,7,Light Sensor Function active
LC,14,0,Headlight Wishers installed
LC,14,1,Rain Sensor Function active
LC,14,2,Service Position for Front Wiper active
LC,14,3,Comfort Function for Rear Wiper active
LC,14,4,Tear Wiping active
LC,14,7,Speed dependent Wiper Stage Activation active
LC,15,0,Push-to-Talk Function via Multi-Function-Steering-Wheel (MFSW) active
LC,15,2,Rear Window Heater Activation (via) CAN active
LC,15,3,Mirror Heating ON while Rear Window Heater ON
LC,15,5,Heated Front Window installed
LC,15,6,Heated Outside Mirrors installed
LC,15,7,Heated Rear Window installed
LC,16,4,Lamp Diagnostics for Low Beam active
LC,16,5,Lamp Diagnostics for Rear Fog Light(s) active
LC,16,6,Lamp Diagnostics for (Separate) Daytime Running Lights (DRL) active
LC,16,7,Lamp Diagnostics for High Beam active
LC,17,3,Horn with "Terminal 15 OFF" inactive
LC,17,4,Battery Seperating Relay active
LC,17,7,Cruise Control System (CCS) installed
LC,18,0~7,00,Light Setup: Standard/Parameter Settings (EEPROM)
LC,19,4,Lamp Diagnostics for Turn Lights active
LC,19,5,Lamp Diagnostics for Fog Lights and/or Cornering/Turn Lights active
LC,19,6,Lamp Diagnostics for Tail Lights aktiv
LC,19,7,Lamp Diagnostics for Brake Lights active
LC,20,5,Energy Management active
LC,21,2,Cornering/Turn Lights via Turn Signal active
LC,21,5,Fog Lights inactive with High Beams active
LC,21,7,Front Fog Lights (with Turn Lights) installed
LC,22,5,Assistent Driving Light (ADL) active
LC,22,6,Interlock Display (Clutch Message) in Instrument Cluster active
LC,23,0,Alternative Voltage Supply for High Beam and Terminal 58d
LC,23,6,Function "Daytime Running Light (DRL)" active
LC,24,4,Transport Protocol f
