[Dezmembrez] Mk1, Mk2 si Jetta Mk2
Chychy
carburator pierburg 2e functional 100% - 150 de lei - nu mai e valabil
Modificat de Chychy
  • Replies 223
  • Chychy
    95
  • nedelx
    11
  • sergiup
    10
  • alex_87
    5
carburator pierburg 2e functional 100% - am primit. impreuna cu anexe. revin cu feedback dupa ce-l montez pe masina.
Multumesc pentru promtitudine.
de oglinda ma uit azi
Motor 1.9 TDI – 1600ron complet
Cutie 5+1 GTI cod ACD perfecta – 350 ron
Debimetru aer BOSCH 1.3 NZ – 100 ron
Bobina inductie 1.3, 1.6, 1.8 - 50 ron
Delcou + sensor hall 1.6, 1.8 – 100 ron
Electromotor pt motor 1,4; 1,6; 1,8; 2,0 – 100 - 100 ron
Trager golf Mk2 - 50 lei
Luneta Mk2 – 60 ron
Radiator apa original VW (1.6, 1.8, 1.6d, 1.9 tdi, 2.0 16v) – 150-200 ron
Carlig remorcare Golf 2 + instalatie electrica – 250 ron
Electro-ventilatoare - 100 ron
Aripi originale fara rugina - 70 ron
Capota Mk2 – 100 ron
Punte + tambure cu abs completa - 150lei
Sistem ventilare (aeroterma completa) Mk2 si Mk3- 100lei
Bord complet Mk3- 250 lei
Rezervor Mk2 si Mk3 - 50lei
Pompa servo-directie 1400, 1600, 1800, 1900 si 2000 – 150 ron
Alternatoare; 1,6; 1,8; 1,9; 2.0 cmc Mk2 si Mk3 - 150 lei
Instalatia electrica motor 2.0 16v abf fara imobilizator – 200 de lei
Contact - 50 ron
Vas lichid anti-gel Mk2 si Mk3 – 20 ron
Vas spalare parbriz Mk2 si Mk3 – 20 ron
radiator aeroterma incalzire – 50 ron
fuzete fata cu senzori abs – 150 ron/pereche
Planetare motor 1,6 si 1,8 Mk2 si 2.0 16v – 100ron/buc
Suspensie fata sau spate (telescop + arc) Mk2 si Mk3 - 150 ron/set
Pompa frana (cu servo) – 100 ron
Mocheta fata + spate Mk2 si Mk3– 50 ron
Compresor aer pt inchidere centralizata – 80 ron
Trapez stanga/dreapta (brat) – 50 ron/buc
Cabluri: frana de mana, acceleratie, ambreiaj, capota, - 30 ron
Etrieri fata – 50 ron/buc
Etrieri spate – 220 ron/set
Cadru motor fara brate (H) - 100 lei
Admisie completa 2.0 16v abf – 250 lei
Calculator 2.0 16v – 100 lei
Downpipe 2.0 16v cu tot cu sonda lambda – 70 lei
Instalatie motor PL cu tot cu calculatoare – 100 lei
Pompa de presiune cu tot cu vas Kr sau PL – 150 lei
Macarale electrice spate Mk2 4usi cu tot cu instalatie – 200
ceasuri de bord de KR - 100 lei
tubulatura admisie cap hidraulic - clapeta acceleratie cu tot cu burdufe - 50 de lei
stopuri mari mk1 .......60 de lei 3 buc
luneta mk1.......30 de lei
ceasuri de bord mk1 model 83 de diesel.....30 de lei
casete directie fara servo mk2.....50 de lei
stopuri normale mk 2.....40 de lei
consola g2 cu loc pt casete....50 de lei
pompa de benzina si regulator presiune pt carburatie - 60 de lei
radiator 1.8 benzina - 100 de lei cu tot cu ventilator
electromotor 1.8 benzina - 90 de lei
trapa completa
faruri jetta (partea dreapta nou)
electromotor 1.6 td - 150 de lei
turbina garett t3 fara galerie - 200 de lei
pompa de injectie 1.6 td cod JR - 250 de lei
injectoare 1.6 td cod JR - 100 de lei
discuri frana pline fata si placute noi noute - 130 de lei
caut una pereche aripi fara rugina, dar sa fie negre
Modificat de nedelx
negre nu am, alte culori te ajut cu cea mai mare placere
m-ar costa vopsitul mai mult decat aripa, oricum multumesc.
Luneta Mk2 – 60 ron
Contact - 50 ron
trapa completa
radiator de td cu tot cu ventilator - 150 de lei
turbina garett t3 - 180 de lei
Modificat de Chychy
Discuri frana si placute =130 lei...pachetu? 2 discuri 4 placute? sau cum ca nu inteleg....as fi interesat daca ma poti lamuri. mersi anticipat!
da, sunt 2 discuri si 4 placute, nu au mai mult de 200 de km rulati, am trecut la 280 si le-am dat jos
poze pe maine la farurile de jetta
farurile de jetta, cel nou este marca TYC si celalalt Boson sau ceva de genu
post-79052-0-67526000-1350235372_thumb.j
Modificat de Chychy
Imi cer Scuze Chycy dar a intervenit o problema nu mai pot lua franele ..imi cer scuze.
poti sa pui o poza?
mersi
si eu il rog de cateva luni sa puna o poza cu ceasurile alea si cu stopurile. sper sa aiba timp si sa le puna candva :)
si in sfarsit pozele.....
adaugam oglinzi electrice mk2 cu instalatie si buton.....200 de leipost-79052-0-32915700-1350537744_thumb.jpost-79052-0-70304100-1350537752_thumb.jpost-79052-0-21713400-1350537802_thumb.jpost-79052-0-37652800-1350537828_thumb.jpost-79052-0-08938300-1350537837_thumb.jpost-79052-0-75993600-1350537847_thumb.jpost-79052-0-51823700-1350537856_thumb.j
au functionat pe o masina cumparata pt piese, doar sticla este sparta deoarece a cazut ceva pe ele
aha. geamul nu ma deranjeaza. daca-s bune atunci sa facem cumva sa vina la mine (@sebi: daca n-ai si le vrei spune). stoapele sunt crapate sau au doar fisuri fine de la vreme? intreb pt ca in poza nu se vede foarte bine si ma tenteaza si alea. ma gandeam sa facem un pachet pt tot.
sunt doar de praf, fara crapaturi sau alte probleme. pret la pachet 70 de lei
