Coduri Dotario Optionale
MrMishu
As dori si eu sa stiu cum pot afla ce reprezinta fiecare cod de pe stickerul care este lipit pe caietul Plan de Service si anume codurile de la dotarile optionale, daca ma poate ajuta cineva ar fi super si multumesc anticipat. codurile ar fi astea :
E2M, 1DO, 5SL, 5RQ, 1KF, 6FB, 1AT, 3FA, 1N3, 1NL, H6L, 4UE, 4R4, 3NW, 3QT, 4X3, 4A3, 8L3, J1D, 7AL, 8gU, 6YO, 9AK, 9VJ, 7QO, 8YM, 8QL, 8X1, 4K3, B43, GO7, QN2, 3L3, 9P1, 7X2, 9W4, 8WB, 7AO, 3GN, QGO, OGG, L13, 7P4, FOA, 3S4, 2UA , acum din carte nu imi dau seama daca este zero 0 sau O masina e fabricatie 2006 si un link unde sa le caut eu ar fi perfect.
Ok am folosit link-ul dat de c.iulian si nu iteleg 2 coduri :
Q07 Suspension range 307
L13 Suspension range 13 installation control only, no requirement forecast
Ma poate ajuta cineva ce reprezinta?
Modificat de MrMishu
Salut,am introdus si eu toate codurile alea.Acum spre rusinea mea nu prea stiu engleza inteleg unele dar mi-ar fi de folos sa imi traduceti in romana care stiti.Va rog,sper sa nu va plictisesc !
YA Weight range 1 installation control only, no requirement forecast
L03 Suspension range 03 installation control only, no requirement forecast
1JL Rear shock absorption
0AQ Front stabilizer
E0A No special edition
2JF Painted bumpers
8RE 4 speakers (passive)
5TC Without decorative inserts
N0U Cut pile seat covering
4F1 Central locking system
4R2 Power windows front, mechanical window regulators rear
4X0 Without side air bag
4UE Air bag for driver and front seat passenger
0Y1 Standard climatic zones
0GG Emission standard EU4
G09 Front shock absorption
1LQ Front disc brakes with integrated adapter
1KB Drum brakes, rear
8L3 Roof antenna
8GD Alternator 90A
8AQ Radio "beta" with removable operating panel
0G4 Cable gearshift
QG1 Service interval prolongation
3U1 Foldable trunk cover
T70 3-cylinder gasoline engine 1.2 L unit 03E.A (aluminum)
5SL Left exterior mirror: aspherical
5RQ Right exterior mirror: convex
1NC Full wheel covers
1G2 Steel spare wheel with original equipment tires
1AN Anti-lock brake system (ABS)
Q2J Comfort front seats
MA5 3-cyl. gasoline engine 1.2 L/47 kW 12V base engine is T70
J1L Battery 280 A (60 Ah)
H8P Tires 165/70 R14 81T
C0D Steel wheels 5J x 14
B0A Component parts set without country-specific design requirement
X4N National sales program Romania
Nu cred ca nu intelegi chiar nimic, uite te ajut goagal:
YA gamă Greutate 1 de control de instalare numai, nicio cerinţă vremea
L03 gamă Suspendarea 03 de instalare de control numai, nicio previziune cerinţă
Absorbţie 1JL spate şoc
0AQ faţă stabilizator
E0A nr ediţie specială
2JF pictate barelor de protecţie
8RE 4 boxe (pasive)
Fără a insertii decorative 5TC
N0U Cut scaun gramada care acoperă
4F1 Inchidere centralizata sistem
4R2 Geamuri electrice fata, spate mecanice fereastră autorităţile de reglementare
4x0 Fără a airbag lateral
4UE airbag pentru sofer si pasagerul din fata
0Y1 Standard zonele climatice
0GG standard de emisii EU4
G09 faţă de absorbţie de şoc
1LQ fr
Multumesc mult Al Bundy cu goagal' asta nu il prea folosesc.
Multumesc inca o data.
8RE 4 boxe (pasive) Adica cum pasive? Pe masina am doar boxe in fata.
Televiziune prin cablu 0G4 schimbătorului de viteze -la ce se refera ?
Modificat de Alin
Boxe pasive inseamna fara amplificator integrat, exsita boxe active care vin cu tot cu amplificator (de ex. majoritatea stitemelor audio pentru calculatoare - amplifictorul e in subwoofer). La astea de pe maisina ta amplificatorul este in Head Unit (in Cd Player adica) ...
La partea a doua m-am amuzat putin cu televiziunea prin cablu :rolleyes:, acolo traduce prost goagalu'. Cable in engleza mai inseamna si televiziune prin cablu, in loc de Televiziune prin cablu 0G4 schimbătorului de viteze trebuia sa fie 0G4 - Schimbator de viteze cu cablu ...
Later edit: Hai ca am mai citit la traducerea goagalului si cateva sunt tari de tot :D.
2JF pictate barelor de protecţie = 2JF Bara fata/spate vopsita
1KB Frane repetate, spate = 1KB Frane cu tambur pe spate
1NC roţi se referă la întreg = 1KB Capace roti
5SL Stânga oglinzilor exterioare: asferice = 5SL Oglinda exterioara stanga: asferica
5RQ dreapta oglinzilor exterioare: convex = 5RQ Oglinda exterioara dreapta: convexa
Modificat de adrian001
