Golf MKVI 1.4 TSI
kadettro
Cum sunt amortizoarele astea destepte? Au niste cabluri prin care e controlata duritatea?
  • Replies 523
  • kadettro
    205
  • Rave
    51
  • The_Ego
    44
  • JUG
    35
Cam asa arata :
Adjustable shock absorber
An adjustable shock absorber using a twin-tube design is employed for the DCC adaptive chassis control. The piston runs in chamber 1 and there is an additional gas chamber in chamber 2.
Function in extension and compression cycle
Check valves on the piston and base plate cause the oil to flow in the directions shown in the diagram during extension and compression.
The oil is fed to the adjustment valve through the ring channel and it flows in the same direction (uniflow) during extension and compression. The oil flows back into chamber 2 from the adjustment valve.
The adjustment valve determines the pressure in chamber 2 and thus the damping.
The cylinder contains chamber 2.
It is only partly filled with oil. There is a gas cushion with a de-foaming spiral above the oil filling. Chamber 2 is used to compensate changes in the oil volume.
The oil flow is controlled by the damping valve units on the piston, on the chamber base and in the adjustment valve. They consist of a system of flat springs, coil springs and valve bodies with oil flow ports.
volkswagen_dcc_adjustable_shock_absorber_extension_cycle.jpg volkswagen_dcc_adjustable_shock_absorber_compression_cycle.jpg
During the extension cycle, the oil flow is controlled by:
  • the adjustment valve,
  • the base valve and
  • to a limited extent the piston valve.
During the compression cycle, the oil flow is throttled by:
  • the piston valve and
  • to a limited extent the base valve.
Astazi au fost montate si pragurile, poze dupa ce spal masina ca e de groaza cu ce e acum pe ea.
Ce parere aveti de asa ceva? E in jur de 300 de euro.
post-14434-0-34794500-1330604305_thumb.j
arata kinky rau...daca iti prisosesc banii,e ok...desi seamamna cu ce ai tu acum,dar cu ace rosii,si pana la 260.brgds
Sa-mi dai si mie un link, te rog. Eu nu am CB+ pe masina si am zis ca daca tot e sa pun macar sa mai dau ceva di sa iau Premium.
Nu cred ca merita trecerea de la plus la premium pentru 150. In conditiile in care il dai pe al tau cu atat.
Sent from the past to be read in the future.
:)), hai ca m-ai pus pe ganduri :P, daca il vrei sigur acum dau comanda pe IC
Stai asa ca nu-i asa...am inteles de la Cristi(Al Bundy) ca trebuie schimbate si cipurile din chei, sa ma interesez cat costa si alea, spar sa nu trebuiasca sa schimb cheile cu totul...
Modificat de kadettro
Nu cred ca merita 300EUR acele albastre si 300km/h pe bord . Mai degraba iti iei RNS 510 sau antifonezi masina sau pastrezi banii pentru soft.
Ai si tu dreptate Andrei. RNS-ul 510 este prezent deja. Urmeaza arcuri atunci cat de curand si soft la Paste, poate vin cei de la Revo cu o oferta atragatoare.
Cel mai bine asa. Iei frumos niste Eibach si obtii ceva placut de vazut si "palpabil".
De-abia astept sa vad si eu primul R argintiu din Romania. :D
S-ar putea sa trebuiasca schimbate cipurile, si oricum, am inteles ca nu se mai face schimbul decat la reprezentanta pe masinile de dupa 2008 parca, nu tin minte exact.
Cand o sa vreau sa pun CB+ o sa ma interesez mai exact, acum am altele pe cap :P
Hai cu o suspensie adevarata ca acum vine vara :))
Doar arcuri ca amortizoarele nu le schimb decat dupa ce "crapa". Vor fi Eibach Pro Kit ca Sportline am inteles ca-s mai dure. Am mers saptamana asta, cred ca pentru prima oara 4 persoane in Golf si nu-mi venea sa cred cat de bine se vedea masina lasata.
Hai ca i-am facut baie si cu ocazia asta cateva poze
post-14434-0-59897100-1330617355_thumb.j
post-14434-0-87981200-1330617364_thumb.j
post-14434-0-52919500-1330617373_thumb.j
post-14434-0-65270700-1330617597_thumb.j
post-14434-0-98292800-1330617606_thumb.j
It's almost complete. Senzatie arata, iar suspensia va fi incununarea schimbarii (dupa jante desigur). Rial-urile sunt de 17"?
Pe pro kit o sa merg si eu pentru ca lucreaza bine cu amortizorul oem, coboara cat trebuie ca sa arate bine si sa nu fie la orice bordurica sau iarna cand mai ninge putin.
Mersi si de pont :D
Modificat de The_Ego
Da, sunt de 17, se vede in prima poza ;)
Asta a fost si intrebarea mea, senzatia si live e ca acele jante ar fi mai mici, eu la prima vedere am crezut ca sunt chiar de 15
Antena shark fin e cea Diversity? Ce stie in plus? :D
Trebuie jante mai mari si..atat :). Frumos, felicitari!
Pe 15" nici nu merg pe motorizarea de 160, din cate stiu eu.
N-as crede, atat timp cat exista 15" pe 2,0 TDI, nu vad de ce n-ar merge pe aceasta motorizare... ramane de vazut, din cate vad, e acelasi etrier ca la mine sau poate ma inseala privirea... si nici discul nu pare mai mare in diametru
LE: vad ca e acelasi disc cu diametrul de 253 mm, deci....
Modificat de GabiB77
Antena shark fin este cea exterioara de pe plafon, iar cea Diversity este cea montata pe luneta.
@GabiB77 - Discurile fata sunt de 312 mm, franele fata sunt aceleasi de pe GTI, roti mai mici de 16 nu merg dupa cum se vede si-n poza e foarte putin spatiu intre janta si etrier.
@mike - Cu antena asta a venit masina mai multe nu stiu.
@The Ego - cu placere
