Retrofit Climatic de Golf 6 pe Golf 5
Radu Marcel
Daca spui ca este mai usor la clima mea....da-mi te rog o solutie, caci luni mi s-au lipit ochii de parbriz prin Bucuresti.Poate din experienta ta, ma vei ajuta cu un sfat.
On 10/13/2015 at 20:04, georgekeemo a scris:
salut ,dupa 2006 ,s-a trecut la dirijarea aerului automat via motoras electric din cauza asta nu a mai fost nevoie de alte modificari. a mea fiind 2004 ,sunt necesare cateva modificari fizice:D
Aceasta va fi solutia?
da, aceea este.
Sau uite aici
Chiar daca este tot pe O2 , cred ca aceasta este rezolvarea.....polar fis advenced
On 12/14/2014 at 15:19, Alimar 1976 a scris:
@ Florin  Sau aici
***** Improvements / Update description for RED cluster *****
[+] Fixed problem with reading parameter "Ignition Angle" and "Angle Delay", by which did not display negative values
[+] Fixed problem with Parktronic OPS where vehicles with front and rear sensors, would not start by pressing the activation Parktronic
[+] Fixed problem with Parktronic OPS which did not work for volume reduction in the RNS-510
[+] Fixed problem with Parktronic OPS by which did not work in some vehicles Skoda
[+] Fixed problem with Parktronic OPS by which did not display front sensor values ??in some vehicles Skoda
[+] Improved compatibility with the emulation function of BT white FIS with steering wheel installed on red FIS vehicles
[+] Improved Italian, Portuguese and Polish translations
[+] Fixed windows rise up to enable automatic closing of windows
[+] Fixed problems with some diagnostic functions, giving the message FUNCTION NOT AVAILABLE
[+] Fixed issue that caused the automatic shutdown settings windows, One touch opening, and emulation climatronic
[+] Added parameter DPF (miles traveled since last regeneration)
On 14 November 2014 at 8:22 PM, Al Bundy said:
BA da, ai de facut modificarea cu pinii 16 si 20.
Incerc astazi sa montez un modul climatronic de Golf 6 pe o Jetta 2008. Schimbarea pinilor este exclusa deoarece pinul 20 este mare iar 16 este mic.
Mai mult decat atat, incercand sa tai firele si sa le schimb intre ele mufa in partea din spate nu permite sa vad ce culoare are pinul 16. Pinul 20 este negru cu verde.
Va rog sa imi spuneti culoarea pinului 16.
Declipseaza mufa si vezi numaratoarea exacta a pinilor
NU este exclusa schimbarea [pinilor, asa se face, se taie pinul mic si se pune unul mare pe fir.
scoti firul negru/verde de pe 20. scoti rosu/galben de pe 16, tai pinul, pui pin mare si il bagi in 20.
N-a mai fost nevoie, o sa posteze Catalin procedura... O combinatie de 2 butoane si a pornit AC-ul
Procedura este urmatoarea:
1. Se apasa simultan butoanele AC + dezaburire parbriz pentru calibrarea clapetelor. Am atasat si o poza:
2. Se apasa simultan butoanele AC si dezaburire luneta pentru Compresor First Run.
Eu am pe masina CAN 1K0-907-530-L si imi afiseaza pe display-ul RNS-ului setarile de pe clima.
Este nevoie deoarece nu-i tine minte setarile la scoaterea cheii din contact.
Merci de interventie, Cristi, asta nu era scris pe nicaieri (sau ne-a scapat)
Deci, practic, nu trebuie schimbate firele 16 cu 20, ci doar firul rosu-galben din pinul 16 trebuie pus in pinul 20, iar cel negru-verde ramane in aer?
cele mai multe informatii sunt pe aria B6 - cautati acolo, este scris tot ce trebuie.
Corect, cu specificatia ca se taie pinul de pe firul 16 si se pune un a,lt pin pe el care se potriveste in 20.
On 13.10.2015 at 6:38 PM, facility said:
Salut,am facut si eu schimbarea de modul climatic sau dublu climatronic la golful meu 5. Am montat panoul climatic fara a face vreo modificare de pini sau ceva si merge perfect .directioneaza aerul unde trebuie (in sensul ca nu trebuie dirijat de vreo tija care se învârte sau roteste) si chiar daca iau contactul si scot cheia si repornesc dupa jumate de ora sau a doua zi reia de unde a ramas (adică isi mentine memoria,gradele ,locul unde era directionat aerul inainte sa opresc masina) cu alte cuvinte merge perfect. Tin sa mentionez ca modulul climatice vechi e fabricat în 2007 iar cel de mk6 in 2011:)
salutare! ma poate ajuta cineva cu un sfat ? am un golf 5 break din 2008 cu aer conditionat normal sau climatic si as vrea sa stiu daca pot schimba robineti astia uriti cu ceva de genul de golf 6..colegul de mai sus  spune ca  merge,dar as vrea exact sa stiu ca sa dau comanda de el sa nu l cumpar degeaba ..stima!
Buna dimineata!Daca inlocuiesc can-ul 7N0 907 530 AN cu 1K0 907 530 C imi mai afiseaza pe HU comenzile climei?(OT ..... nu imi va consuma bateria, am polar fis BT)Multumesc.
F l o r i n
nu, nu iti va afisa.
Va rog frumos! Imi raspunde si mie cineva la intrebarea de mai sus?:rolleyes:
Modificat de b300fun
On 30 mai 2016 at 11:33, F l o r i n a scris:
Dupa update....afiseaza.
ai clima noua si ai facut update la can gateway la K cu 0178 - si afiseaza ? e bine de stiut... am facut multe de update-uri la can gateway, din pacate toti aveau clima veche.
Da, afiseaza dupa update cu clima  de golf 6 in schimb in schimb clima nu comunica cu interfata originala(no response from controler)
Generatii diferite can-clima
ciudat - trebuia sa comunice - indiferent de varianta de can. Inainte de update, comunica ?
Nu cred
Nu am verificat inainte de update
Posibil non-comunicarea sa fie cauzata de fis link....cind o sa am timp o sa-l elimin si sa vad ce se intimpla.O sa revin cu informatii.
Salut. Am un golf 5 2007. Curand am schimbat panoul de climatronic cu unul de golf 6 cod 5k0 907 044 ES si nu pot sa intru pe el cu vcds 12.12.
Can-ul este 1k0  907 530 K sa fie de la can? sau mai trebuie sa modific ceva fire? Schimbare cu pinul 16pe 20 am facut-o.
A mai intalnit cineva problema asta?
