Codare ACC (Adaptive Cruise Control) cu cutie de viteze manuala
MihaiXp
Am incercat sa codez 01 Engine pt. ACC, dar nici un cod nu este acceptat.
Are cineva vreo idee?
La scanare se obtine:
Chassis Type: VW Passat 3C
Scan: 01 13
Address 01: Engine Labels: User\03G-906-021-NK.lbl
Part No SW: 03G 906 021 NK HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 9972
Revision: --H02--- Serial number: VWZCZ000000000
Coding: 0000172
Shop #: WSC 49484 126 63497
VCID: 75EA642265A9
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 1
Mileage: 123321 km
Time Indication: 0
Date: 2010.12.17
Time: 11:24:54
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 11001100
Torque: 0.0 Nm
Torque: 351.4 Nm
Readiness: 0 0 0 0 1
Address 13: Auto Dist. Reg Labels: User\3C0-907-567-E.lbl
Part No SW: 3C0 907 567 E HW: 3C0 907 567 E
Component: AC201 RDW 1 030 0118
Revision: 00030000 Serial number: 00000000004023
Coding: 0010000
Shop #: WSC 65536 546 923456
VCID: 2D5A8C42CD79
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 11
Mileage: 123321 km
Time Indication: 0
Date: 2010.12.17
Time: 11:25:33
Freeze Frame:
Count: 34
01315 - Transmission Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 11
Mileage: 123321 km
Time Indication: 0
Date: 2010.12.17
Time: 11:25:33
Freeze Frame:
Count: 4
Pe restul modulelor nu e nici o eroare!
La 01 Engine faultul provine de la faptul ca o componenta nu e codata corect sau nu accepta ACC. De obicei in caz de retrofit, ABS-ul nu ,,vede'' ACC pt. ca nu e compatibil. Dupa schimbarea ABS cu unul compatibil ACC, eroarea se poate sterge.
La 13 ADR, prima eroare dispare dupa rezolvarea 01 Engine, a doua eroare este din codarea ACC (e codat pt. cutie automata) care cauta AT. A doua eroare se elimina prin codarea ACC, problema e ca numai ACC din noile generatii supoarta codarea de cutie manuala.
Pt. activarea ACC pe modulul 01 Engine sunt 2 coduri, functie de tipul de motor si tipul de ACC. Unul pt. ADR simplu si unul pt ACC cu distance regulation (30903). Codul pt. ADR nu este 13647, aceasta fiind cauza pt. care nu se activeaza ADR pe acest motor. Activarea ADR se poate face cu VAS5054A.
Modificat de draganuta
salut,
o intrebare :
se poate monta acest dispozitiv pe o skoda 2 2.0 cu DSG
in caz ca merge instalat...pe ce "cod" de modul ABS ar merge pus.
in caz ca acesta pe care il am (modul ABS) nu e compatibil cu modulul ACC, se poate schimba ?
ok mersi...oricum ....mam documentat...am vazut ca e posibil....din cauza ca nu e trw abs-ul
Modificat de TrayPower
Intr-adevar, functioneaza numai pe ABS TRW. Pt. a beneficia de ACC masina trebuie sa aiba Frana de parcare electronica (deci ABS compatibil cu frana de parcare electronica). Avand in vedere ca nu exista Skoda cu o astfel de frana, rezulta ca pe nici o Skoda nu se poate monta ACC (si nici nu s-a montat).
  • 4 years later...
in urma cu ceva timp mi-a murit acc-ul pe un passat b6. Am fost cu masina la vw si mi-au spus ca radarul e defect si trebuie inlocuit. Se poate anula in vreun fel radarul dar totusi sa raman cu functionalitatile de pilot (pilotul clasic de pe vw) ?
Da. Ma gandesc ca trebuie codat fara acc si doar sa ramana cruise control.
trebuie schimbata maneta mai intai.
Buna, ma poate ajuta cineva cu scoaterea ACC-ului din soft? A murit distronicul si chiar nu dispun de acea minunata suma de aprox 2000eur sa in inlocuiesc cu unul nou. Unul second nu am gasit sub nici o forma.
daca este cineva care ma poate ajuta sa il anulez, va rog... :)
multumesc.
Ce radar ai avut? Ce cod? Nu trebuie exact ce ai avut.
Ai avut si Front assist?
hmmm... codul acuma nu il stiu, il am scris acasa. Front assist? ce inseamna? franare la intalnirea de obstacole? ca daca da, da am si asa ceva, sau cel putin am avut :)) daca puteti sa ma ajutati va rog...chiar am ajuns in prag de disperare as putea sa spun. orice ce eroare mai imi da masina, nu pot sa o vad din cauza acestei erori minunate "ACC FAULT" x(
On 28.02.2011 at 8:17, draganuta a scris:
Cineva a incercat sa imi activeze cruise control (13647) si mi-a aparut eroarea
P1647 - 000 - - - MIL ON eu avand ACC cu distance regulation si a pus 30903 dar acum in vcds 19 gateway no response from controller...
Nici macar autoscan nu mai merge!
Ce este de facut?
Ce fel de interfata avea? Originala sau clona?
Clona cu siguranta!
Modificat de Manuel N.
Atentie la quote! Se sanctioneaza - citeste regulamentul. First/last warning!
Aici poate sa fie o problema.....
Ce este de facut?
Ce este acel 13647 din paranteza ?
Si nu inteleg cum sa activezi CCS pe masina cu ACC?
Modificat de Al Bundy
Nu am nici cea mai mica idee , dar am impresia ca nici el nu avea !
am aici un log salvat ...
Monday,02,November,2020,18:50:57:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ3CZ9E508838   License Plate:
Mileage: 187520km-116519mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 2E 37 42 44 46 47 4F 52
          53 55 56 5C 62 72 77
VIN: WVWZZZ3CZ9E508838   Mileage: 187520km-116519miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 1010
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 CL    HW: 03L 907 309
   Component: R4 2.0l TDI F001AG  9977
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 28193 002 1048576
   VCID: 71E960C368A9130EF4-8024
2 Faults Found:
               P1647 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 187517 km
                    Time Indication: 0
                    Date: 2015.03.26
                    Time: 17:52:28
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000000
                    (no units): 0.0
053283 - Please Check Fault Codes in Control Module for Automatic Distance Regulation
               U1023 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 187517 km
                    Time Indication: 0
                    Date: 2015.03.26
                    Time: 17:59:07
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 0.0
                    Bin. Bits: 00000100
                    (no units): 1.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 051     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1818
   Revision: 04843012    Serial number: 00000806030282
   Coding: 0000020
   Shop #: WSC 05311 000 00000
   VCID: 50AFC547C3E33A06DB-8004
No fault code found.
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 Q    HW: 3C0 614 109 Q
   Component: J104    C4 440 V3   0011
   Revision: --025---    Serial number: 00000785702009
   Coding: 0026901
   VCID: 2C57B1B78F0B3EE687-8078
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 5K0 907 044 A    HW: 5K0 907 044 A
   Component: Climatronic   120 0202
   Revision: 00002001
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_VW46.rod
   VCID: 295948A348F92BCE7C-807C
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000008472752
   Coding: E2E28F8B00041A0047978F0017000000000BFB4764400165170000000000
   Shop #: WSC 05124 123 12345
   VCID: 3365AACB5235611EC6-8066
   Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 080408 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     170608 054  0402
   Coding: 00209133
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 C    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0009
   Revision: --------    Serial number: 61730816506599
   Coding: 100107
   Shop #: WSC 05314 000 00000
   VCID: 3B7582EBBA65A95E1E-806E
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 M    HW: 3C0 907 567 M
   Component: AC201  RDW A    031 0243
   Revision: 00031000    Serial number: 00000000053634
   Coding: 0010000
   Shop #: WSC 50989 136 95387
   VCID: 356194D35C417F2EE8-8060
00272 - Function Disabled due to Electromagnetic Interference
            012 - Electrical Fault in Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11101100
                    Fault Priority: 7
                    Fault Frequency: 7
                    Reset counter: 248
                    Mileage: 187517 km
                    Time Indication: 0
                    Date: 2015.03.26
                    Time: 17:60:55
             Freeze Frame:
                    Count: 47
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__306 VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPAJ8ECP
   Coding: 0012342
   VCID: 7AFB47EF35DF505645-802E
   Subsystem 1 - Serial number: 6333FTS632771608
   Subsystem 2 - Serial number: 6343FTS625561608
   Subsystem 3 - Serial number: 6353ETS6MS1KTVNH
   Subsystem 4 - Serial number: 6363ETS6EDR0TVNP
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0025
   Revision: 00030000    Serial number: 3C5953507CR
   Coding: 0201721
   VCID: 74E769D717BB26261F-8020
   Subsystem 1 - Part No: 3C8 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H2ÿ 0021
   Coding: 00000226
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
   Part No SW: 3C8 920 870 A    HW: 3C8 920 870 A
   Component: KOMBI         H19 0023
   Coding: 140F00
   Shop #: WSC 05311 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 F    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2200R08416805F
   Coding: FDA57F0650061B9002
   Shop #: WSC 50989 141 86386
   VCID: 24475997E7DBF6A64F-8070
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 187158 km
                    Time Indication: 0
                    Date: 2015.03.26
                    Time: 16:22:47
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 397998E370599B4E0C-806C
   Subsystem 1 - Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
   Component: SG EXT.PLAYER H13 0062
   Revision: A1001003    Serial number: 7667012710
   Coding: 010000
   VCID: 254144932CE10FAE58-8070
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 B
   Component: RNS-MID       H03 5238
   Revision: AB001001    Serial number: VWZ6Z7H8171082
   Coding: 04010000010000A20000
   VCID: 377D9EDB864D8D3EFA-8062
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 187158 km
                    Time Indication: 0
                    Date: 2015.03.26
                    Time: 16:22:49
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1531
   Revision: 71009005    Serial number: 00000034388531
   Coding: 0000181
   VCID: 408FF5071383CA864B-8014
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.076 0401
   Revision: 1AH02234    Serial number: 00081020108402
   Coding: 0000258
   VCID: 366393DF41477436E1-8062
Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0001860E763604941570084F0B607801
   Shop #: WSC 05311 123 12345
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3C0 035 456 K    HW: 3C0 035 456 K
   Component: 08K Audioverst.     0001
   Revision: 00001000    Serial number: 00000000191427
   VCID: 285F4DA79BF312C663-807C
00870 - Bass Speaker Front Left (R21)
            011 - Open Circuit
Address 4F: Centr. Electr. II (J533_)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Revision: --------    Serial number: 2200R08416805F
   Coding: 00000001
   Shop #: WSC 00000 000 1979136
   VCID: 66C3039F9167C4B691-8032
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1531
   Revision: 71009005    Serial number: 00000506488601
   Coding: 0000180
   VCID: 4189F0031889C38E44-8014
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   008       Serial number: 00000000037123
   Coding: 0000057
   Shop #: WSC 05311 000 08193
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0133
   Revision: 00H04000    Serial number:
   Coding: 3490952
   VCID: 3467A9D7573B6626DF-8060
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0002
   Coding: 00000053
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0002
   Coding: 00000053
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 187158 km
                    Time Indication: 0
                    Date: 2015.03.26
                    Time: 16:22:49
Address 5C: Lane Maintain.        Labels: 3C0-907-217.clb
   Part No SW: 3C0 907 217     HW: 4E0 907 217 C
   Component: J759  HCA           0100
   Revision: 00H07008    Serial number: 8002086010000D
   Coding: 0032002
   VCID: 60CF1587B343AA866B-8034
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000442450
   Coding: 0000144
   VCID: 3169A0C3A829530EB4-8064
00930 - Locking Module for Central Locking; Rear Left (F222)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 57
                    Reset counter: 32
                    Mileage: 180825 km
                    Time Indication: 0
                    Date: 2015.03.26
                    Time: 17:46:06
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
   Component: J388   TUER-SG HR   0309
   Revision: 43004101    Serial number: 00000000439966
   Coding: 0000144
   VCID: 326BAFCFAD2F6816CD-8066
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 3C8 035 730     HW: 3C8 035 730
   Component: Telefon             2800
   Revision: 00012000    Serial number: 0000000074489
   Coding: 0020045
00992 - Consumption Cut-Off Active
            000 - - - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 30
                    Mileage: 187486 km
                    Time Indication: 0
                    Date: 2015.03.26
                    Time: 20:06:55
End---------------------(Elapsed Time: 02:55, udsna)-----------------------
Ca idee, cu eroarea ta, normal era sa schimbi radarul, care este defect. In felul acesta, va functioja si acc ul
Sa scap de eroarea
005703 - Check Coding of ECUs on Powertrain Data Bus trebuie sa inlocuiesc  30903 cu 00000? Din ce imi amintesc asta era in
[Select][01 - Engine][Login - 11]
@F l o r i n exista posibilitatea sa dezactivez radarul si sa mearga doar cruise control simplu?
Da, se poate face,  se recodeaza mai multe module, etc...dupa care se codeaza cu tempomat
  • 3 years later...
Nastase Marius Florian
Salutare tuturor. Vin si eu cu o problema, am schimbat motorul la masina, sa montat totul doar ca singura problema ce mia ramas este eroarea asta 053283 - Modul comandã pentru reglare automatã distanþã U1023 - 000 - citeºte codurile de defecte - intermitent împrejurãri cod: Stare defect: 00100000 Prioritate defect: 6 Frecvenþa defect: 1 Resetare contor: 255 rulaj: 385421 km Indicator de timp: 0 Data: 2063.14.31 timp: 02:23:60 împrejurãri cod: RPM: 0 /min vitezã: 0.0 km/h (fãrã denumire): 0.00 (fãrã denumire): 0.00 (fãrã denumire): 3.0 valori binare: 00000111 (fãrã denumire): 32.0 practic ACC nu mai functioneaza . Ma poate ajuta cineva
iti spune exact ce sa faci... citeste erorile din modulul de ACC
