Dictionar prescurtari, abrevieri, simboluri !
warranty_4_cars
warranty_4_cars
Daca va place ideea adaugati si voi denumiri si definitii !
J338 - unitate control clapeta acceleratie sau throttle valve control unit
EPC - Electronic Power Control
J248 - ECU TDI (cel putin 1994 - 1997)
N75 - Valva reglare presiune turbina - TDI
G28 - senzor turatie motor sau engine speed sender
J104 - unitate control ABS
Modificat de s_c
  • Replies 106
  • Marian
  • TitvsCaivs
    6
  • warranty_4_cars
    5
  • Rapier
    4
EGR - valva recirculare a gazelor
N80 - electrovalva comanda EGR
G62 - senzor temp. apa
NLS - senzor ac injectie :D
Modificat de s_c
TDI = turbocharger direct injection
SDI = Saugdiesel Direct Injection
dci = direct commonrail injection
fsi = fuel stratified injection
la jtd td vine de la turbodiesel, iar j vine cica de la unijet?
gti = Gran Tourismo Injection
warranty_4_cars
J248 - Diesel direct injection system control unit
Modificat de s_c
warranty_4_cars
G70 - Air mass meter
N80 - Activated charcoal filter system solenoid valve
G66 - Knock sensor II
warranty_4_cars
ABS - Anti-lock brake system
DC - Distance control
ADC - Automatic distance control
EDC - Electronic diesel control
  • 6 months later...
MPI = multi-point injection (injectie multi-punct, se foloseste de obicei referitor la motoare pe benzina)
HTP = High Torque Performance (denumire specifica Skoda aratand capacitatea motorului 1.2 de a furniza cuplu mare la turatie scazuta: 112 Nm/3.000 rpm)
DSG=Direct Shift GearBox
EBV, ASR, CanBus, EDS, MSR si alti termeni detaliati AICI
WOT - wide open throttle si inseamna apasarea pana la fund a acceleratiei (daca nu ma insel). Mama, cat m-am chinuit pana am aflat ce inseamna :rolleyes:
TCS = Traction Control Sistem (sistem electronic de control al tractiunii) ,la masinile SEAT, asemanator cu ASR-ul de la Skoda
Salutari!
O intrebare de incepator :) : ce inseamna PD referitor la motoarele TDI?
Zorro Classic
PD - Pumpe Duese (pompa-injector) - sistem specific VAG de injectare a carburantului pe fiecare injector
Cand aveti dubii incercati si Acronym Finder
foarte misto site-ul ala...de cand cautam ceva sa ma dcumentez in privinta multor abrevieri
ce inseamna TSI??? ca am uitat si ma enerveaza ca nu stiu.
:( am auzit persoane care credeau ca motoarele TSI merg si cu benzina si cu motorina din cauza reclamei de la tv ;)
Twincharger Stratified Injection ?
Tineti'va bine: de unde abrevierea MK pentru denumirea volkswagen'urilor?(MK IK, MK V)?
Din cate stiu eu e vorba de termenul "Mark" (serie, generatie), respectiv Mark1,2,3...etc
Eu as zice ca vine de la "make" (ca substantiv) din engleza, care aici ar insemna "marca", la fel ca intelesul lui "mark".
"Mark can be used to indicate series or model number of a production line. Because a mark is often made to measure height or progress, by metonymy the word mark is used to mean a level of development, and level designations like "Mark I", "Mark II" etc. come to be used as proper names. Examples include the Lincoln Continental Marks Series, various Mark 1 and Mark I computers. Mk. sometimes abbreviates such nominal uses of Mark.
In other words, "Mark" (or Mk.) refers to the development of something, say, a prototype. The first product would be known as Mark 1. Then changes would be made, the second, revised product would be known as Mark 2. If more changes are added, the third product is called Mark 3, and so on, and so forth."
Sursa: http://en.wikipedia.org/wiki/Mark_(designation)
Deci, de la "mark" vine. :lol:
Modificat de ViVi
