2010 Audi A5 Sportback Quattro
Kostas
La numere te-ai uitat...poate si alea erau ca ale tale... :blah_: :lol: :lol:
Mihai.Nechifor
Si mai are si sticker ca al tau pe aripa fata blah_.gif. Sau mi se pare mie?blah.gif
Ce-mi mai place 3.0 TDI :) ... la fel de mult ca o saorma :))
Dupa 400 km de mers pe A2 si E80 foarte aglomerat
Modificat de Kostas
Ce reprezinta iconita acea cu verde care are un cap de pompa?
Efficiency program
One of the most important factors in achieving maximum fuel efficiency is the driver himself: a significant amount of fuel can be saved by sensible handling of the car – the driver and his driving style can reduce fuel consumption by up to 30 percent.
Audi has developed the driver information system with efficiency program in order to realise this fuel-saving potential without compromising driving pleasure. Depending on the driving situation, it provides valuable tips and information to enable the most efficient driving style.
At a glance, the driver information system provides the driver with the on-board computer data most relevant to fuel consumption for the journey underway. For example, the system provides a direct comparison of fuel consumption at the given time and average fuel consumption.
The enlarged display for the gearshift indicator signals to the driver when to change gear in order to drive as economically as possible. A large, colour-coded display indicates clearly whether the right gear is engaged, or whether shifting would be practical for the sake of efficiency.
Activated comfort and auxiliary features such as the air conditioning or seat heating also increase fuel consumption. A specially developed display in the driver information system tells the driver which systems in the vehicle require additional energy and how high their share of fuel consumption is.
The efficiency program continuously analyses energy consumption and gives the driver situation-specific tips on how to optimise fuel efficiency based on the given driving situation and driving style. The driver is thus made aware if, in terms of energy consumption, it is advisable to close an open window while the air conditioning is switched on.
Mai exact te ajuta sa faci masina sa consume mai putin.
Daca mergi cu geamul deschis iti scrie mare acolo: Air resistance! Please close the window. (iti spune care geam e deschis si sa il inchizi sau sa inchizi trapa)
Modificat de Kostas
Mda...These are the voyages of the starship Enterprise. Its continuing mission: to explore strange, new worlds; to seek out new life and new civilizations...
A... da... pot sa mai activez anumite functii optionale pe masina dar nu am ce face cu ele :)
Zilele astea activez wifi-hotspot cu sim vodafone in ea :)
Modificat de Kostas
:)) bine ca spune si care geam e deshis!
eventual o pictograma cu butoanele de pe usa,sa indice care e butonul pt a inchide acel geam :))
era dotare optionala chestia cu wifi hotspot? utila cand iesi cu laptop-ul in natura. pt telefon...nu merge sa ai direct pe el net?
pictograma nu are... masina presupune ca esti destul de inteligent incat sa stii sa citesti si sa intelegi ce spune :)
da chestia cu wifi e optionala, voi baga un sim vodafone de date in slotul dedicat si ... online :)
"pictograma nu are... masina presupune ca esti destul de inteligent incat sa stii sa citesti si sa intelegi ce spune" dar nu asa inteligent incat sa iti dai seama ca ai geam deschis/care geam ?!
aaa deci SIM pui pt a avea masina net,nu neaparat pt wifi. atunci are mai multa logica. nu mai trebuie nici laptop,vezi direct pe bord mailuri,stiri,porn! :))
cred ca daca as avea astfel de masina as conduce cu bentita cateva zile,mi-as prinde urechile in cate functii poate sa aiba.
si consumul...de invidiat!
nu, nu vezi pe MMI. Pui sim pentrut telefon in masina si wifi hotspot
crede-ma ca si eu mi-am prins urechile prima data... nu puteam sa ma dau jos din ea. De multe ori ma apuca si la 4-5 dimineata cu VAG-COM in masina sa activez diverse functii care nu le avea by default.
consumul chiar este un mare plus la acest motor. noile motoare de 245 cp (A6 si A7) consuma si mai putin :)
Modificat de Kostas
Tare reclama :))
Oricum masina care o ai e cea mai buna pentru tine, e o vorba mare asta. Atata timp cat e a ta e cea mai buna. Sper la alta mai tare dar de unde bani... cand voi gasi copacul ala de face bani o sa va chem pe toti.
Modificat de Kostas
the_punkreas2003
:))) Prea tare reclama! Probabil A5-ul va suna singur la 112, sa vina pompierii :))
E ceva interesant si cam atat, orice telefon cu wifi poate functiona ca un acces point (sau hotspot, spuneti-i cum vreti).
Desi pt net mobil cea mai buna solutie la ora actuala este modemul USB. Oricum unde nu este semnal 3G internetul merge dezastruos (practic nici nu il poti folosi).
Masina ta are multe alte calitati si dotari care fac din ea o nava spatiala. Sigur, si pretul este pe masura, dar merita pana la ultimul eurocent. Din pacate nu multi ne permitem masinute de-astea :(
Asta spuneam si eu... daca ai net pe telefon nu mai ai nevoie de inca o cartela, inca un abonament. Iti functioneaza telefonul ca un acces point. Sau poti sa ai cartela introdusa direct in modemul USB. Oricare solutie e mai buna cel putin la fel de buna ca si cea in care propria masina iti devine un acces point.
N-am inteles ce ai vrut sa spui cu umts900... Ca sa ai net acceptabil trebuie sa ai 3G, indiferent ca e pe 900 sau 1800 (de curand s-a implementat tehnologia 3G si pe frecventa de 900). Degeaba ai telefon 3G daca nu ai acoperire 3G.
Cum am mai spus e un gadget interesant, nu am zis ca e ceva nasol :) e frumos si interesant si cam atat. Si poate cateodata e mai comod sa ai acces point permanent decat sa tot umbli prin meniul telefonului care mai poate ramane fara baterie sau sa porti mereu de grija unui modem usb si sa nu mai stii in care buzunar l-ai pus... etc.
Modificat de SHARANEL
Asta era si ideea Sharanel, sa am wifi nonstop, am pus contactul am wifi, am scos cheia, s-a oprit si netul si wifi. Butonez destul de mult in masina si mi-e greu de multe ori. porneste wifi, porneste hotspot, baga modemul in laptop, scoate laptopul porneste wifi... asa cu asta e mult mai usor. E doar un gadget care vreau sa il am.
Modificat de Kostas
Doar storcator de "bani" pardon am vrut sa zic de fructe, are si tigaie pt facut clatite.
Nici gand :)
Update: De azi masina mea are olginzi heliomate cu fire trase pe culori si pini fix ca in fabrica. Lucrarea a durat 5 ore cu ELSA in fata si munca de chinez la greu.
Urmeaza rabatabile electric. Pentru asta se vor schimba urmatoarele: cotiera din usa soferului, butonul reglare oglinzi, conductorul cu fibra optica pentru buton si mecanisul de pliere al oglinzilor.... alta munca de mexicani care va dura la fel de mult.
Felicitari pentru transformare... Modificarea urmatoare cu adaugarea functiei de rabatare m-ar interesa si pe mine.... cine se baga sa faca modificarea asta? ai facut-o singur?
Am un prieten care e fan Audi si omul stie orice despre aceste masini. M-a ajutat el. Cativa dintre noi il stim ca mergem la el la spalatorie mereu. Daca ai ceva de facut la Audi si nu stii sa faci atunci iti recomand sa mergi la el :)
Modificat de Kostas
