Proceduri VCDS
Seby19
Ai mai jos versiunea in germana.Acum traduc in engleza si daca iti merge asta in germana o pun si pe cea in engleza.
1.copie folderul 03G-906-021-BMM.xls in folderul C:\Ross-Tech\VCDS\Labels\User
2.schimba extensia .xls cu .LBL ( sa fie asa:03G-906-021-BMM.LBL )
3.Asta e tot. :icon_thumleft:
Succes.
Folderul 03G-906-021-BMM.LBL  se poate dechide cu NOTEPAD
03G-906-021-BMM.xls
Multam.
Mare domn!
Cu placere. Sa -mi spui daca iti merge ca sa-ti dau versiunea engleza.
jeanbacuta
Sunt datele recomandate de producator.Vezi in imagine.Ce am incercuit cu rosu ( xxx-xxxx-xxx-.LBL) iti atata datele care le-am incercuit cu verde.
O zi buna!
post-74110-0-26947300-1367489261_thumb.j
Acum am inteles, Iti multumesc !
O seara buna !
Stie cineva unde este pozitionat crankshaft sender la passat B6 2.0 tdi ?
Cutie / arbore cotit !
La DSG poate fi in cutie?
Salut.
Stie cineva cum pot scapa de eroarea asta?
005785 - Powertrain Data Bus
               P1699 - 000 - Missing Message from Steering Wheel Electronics
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 4
                    Mileage: 229638 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:08:59
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.39 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 0 0 0 0 1
Pe ros tech scrie:
18107/P1699/005785 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON - se refera la semnalizare?? daca da functioneaza ok
  • Cruise Control not working - NU AM CRUISE CONTROLL
Possible Causes
  • Wiring and/or Connector(s) from/to Steering Wheel Electronics (J527) faulty -nu am comenzi pe volan - iar celelalte (semnalizari/ stercatoare faza lunga functioneaza ok.)
  • Cruise Control System Switch (E45) faulty -cum spuneam nu am.
Possible Solutions
  • Check Wiring and/or Connector(s) from/to Steering Wheel Electronics (J527) -ce conectori?
  • Check/Replace Cruise Control System Switch (E45) - nu am
Eu cred ca ai codat calculatorul cu CRUISE CONTROL si cu COMENZI VOLAN, dar tu nu le ai pe masina.
Tre sa verifici, si sa faci alta codare !
Verifica si vezi daca am dreptate sau nu !
MIL este martorul de la motor, cel galben.
F l o r i n
Malfunction Indicator Light - corect.... martorul modulului respectiv.
Eroarea, pe ce module o gasesti stocata ? daca nu ai CC, atunci codeaza modulele pe care gasesti eroarea asta, in mod corespunzator.
cobrax2
1.copie folderul 03G-906-018-DT.xls in folderul C:\Ross-Tech\VCDS\Labels\User
2.schimba extensia .xls cu .LBL ( sa fie asa:03G-906-018-DT.LBL )
3.Asta e tot.
Succes.
Apoi poti sa il deschizi cu notepad ca vezi datele recomandate pentru fiecare Group.
03G-906-018-DT.xls
O întrebare : daca am activat cornering pe proiectoare de ce atunci cand virez se aprinde un bec din interiorul farului si nu proiectorul? Pași de activare i-am respectat cu sfintenie, si am verificat si rasverificat sa fie conform cu ceea ce scrie aici pe forum la DIY. Ceva păreri, sau indrumari daca aveți? Sper sa nu fie o magarie aceasta întrebare. Mersi mult.
Acolo ai la Byte 23 sigur ai selectat turn light via fog light?
Ca poate e turn light via high beam light.
Modificat de xDaniel
Chiar daca am bixenon? Stiu sigur ca nu am selectat via high beam. Doar via fog lights
B6 cu bi-xenon au lampi de cornering integrate in faruri cu becuri separate H7 si nu e necesar sa activezi cornering pe proiectoare. Probabil ca ceva circuite se bat cap in cap din moment ce ai activat functia de cornering pe proiectoare si te-as sfatui s-o dezactivezi.
Aha deci! Amu is linistit. Mă duc sa sterg setarea. Mersi mult
F l o r i n
e pacat ca la masinile cu bixenon adaptativ, sa pui cornering pe proiectoare - asta se face doar la cele cu faruri stock....
Da sunt un "grossen idioten". Am remarcat eu greșit, eu facusem DRL via fog light :)) Doamne ce bolovan is. Si eu tot căutăm si bifam la cornering. Mii de scuze.
Cornering pe faza lunga, nu e deranjant..? Am incercat si eu, dar parca e prea deranjat, mai ales seara..
Pai Florin sublinia faptul ca e pacat sa faci cornering pe proiectoare (la cei care au bi-xenon, cornering-ul pe faza lunga iese din discutie, nu se poate de nici un fel si oricum ar fi o tampenie dupa parerea mea) daca masina vine din fabrica dotata cu bec (H7) in farul bi-xenon, pentru aceasta functie de cornering. Eu din cate am observat nu este deranjant deloc in momentul in care se aprinde becul pentru iluminare "colt", oricum iluminarea nu este atat de puternica precum la faza lunga din becurile cu halogen.
se poate sa ai dreptate, din cate imi amintesc am facut ceva la cruise control chiar dupa ce am cumparat cablul de diagnoza (cand inca eram invatacel).
Vreau sa va intreb daca, dupa ce ați facut procedura pentru directie sa fie mai ușoară sau mai tare daca mă pot exprima așa, ați observat ceva diferente notabile ? Mersi mult
  • Marian a închis acest topic
