Proceduri VCDS
Seby19
salut, revin cu detalii legate de erorile aparute la scanare, poate ma poate ajuta cineva
Saturday,21,January,2012,18:06:38:10074
VCDS Version: Release 10.6.4
Address 44: Steering Assist Labels: 5N1-909-144.clb
Control Module Part Number: 5N1 909 144 G HW: 5N1 909 148 F
Component and/or Version: J500__APA-BS KL.080 0401
Software Coding: 0000258
Work Shop Code: WSC 00028 028 00001
VCID: 366722EB38D7
2 Faults Found:
00566 - Steering Assistance Operation
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 240
Mileage: 55784 km
Time Indication: 0
Date: 2012.01.21
Time: 01:21:31
Freeze Frame:
Hex Value: 0x5301
Hex Value: 0x4301
Hex Value: 0x1B01
Hex Value: 0x5601
Hex Value: 0x4601
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 55784 km
Time Indication: 0
Date: 2012.01.21
Time: 01:21:31
Freeze Frame:
Term 15 On
RPM: 826 /min
Speed: 0.0 km/h
(no units): 7.0
Voltage: 14.30 V
FA procedura pentru steering limit stop:
Perform Steering Limit Stop Adaptation
  • Make sure the Ignition is ON and the Engine is Running.
  • Center Steering Wheel (±10°) and hold it centered for about 5 Seconds.
  • Turn Steering Wheel completely to the Left and hold there for about 2 Seconds.
  • Turn Steering Wheel completely to the Right and hold there for about 2 Seconds.
  • Center Steering Wheel (±10°).
  • Switch Engine and Ignition OFF.
  • Switch Ignition ON.
  • Wait about 5 Seconds.
  • Steering Assist Warning Lamp should turn OFF (If it doesn't, perform a short Test Drive).
  On 17.01.2012 at 21:42, TVS a scris:
A mea are terminatia C in coada,deci imi trebuie una cu o terminatie dupa C,dar care? D,E,F....Cum stiu care e dupa iulie 2007?Multumesc.
Am gasit una pe ebay cu N ,09.06.2010,sigur e cu 30 bytes .Acum intrebarea este unde este pozitionata aceasta centrala si daca este greu de schimbat?
Am ratat-o pe aia cu N asa ca am o intrebare pentru cunoscatori:
VW Teilenummer: 3C0907530 G S0140 HH10
Baujahr des Spenderfahrzeug: 07.04.2008
Este pe 30 bytes?
Mersi.
Modificat de TVS
Cred ca mai mult de 7 bytes nu ai deoarece codul pus de tine este de CAN-GATEWAY nu de centrala electrica.
Tu pana la urma de ce ai nevoie> de BCM sau de CAN ?
Modificat de Al Bundy
  On 21.01.2012 at 19:44, Al Bundy a scris:
Salut.
Procedura asta daca o fac fara a avea martorul luminos aprins in bord are vre-un efect? ...
Merci
FLORIN
ce efect sa aibe ?
NU! Daca nu ai martorul aprins inseamna ca sistemul de directie este deja calibrat!
Modificat de D@ny
OK. Multumesc.
Modificat de D@ny
salutare
va rog sa ma ajuytati si pe mine cu un sfat, asta in urma prostiei din capul meu
m-am conectat azi la masina cu vag-com si am uitat sa opresc wireless-ul, iar acum, nu mai merge
"interface not found"
ce ii mai pot face???
sunt plin de nervi pe mine pt cat de dobitoc am putut sa fiu
va multumesc
:offtopic:
Reinstaleaza aplicatia si vezi dupa....
am reinstalat, degeaba
imi vine sa sparg laptopul, da n-are nici o vina....stim cu totii cine a fost prostul
sper sa se mai poata face ceva
Sal , mi s-a aprins becul check engine , la service a dat urmatoarea eroare: Sistem catalizator (bank 1 sensor 2) amestec ? insuficient (?-nush exact daca carburant ), iar cand s-a uitat pe aparat ..bank 1 sensor 1 activ bank 1 senzor 2 inactiv. Sonda lambda inainte de catalizator a fost schimbata de 5 luni.
  On 24.01.2012 at 21:03, Al Bundy a scris:
Vreau sa activez functia cornering pe proiectoare, am inteles ca se poate doar la masinile de dupa iulie 2007,masini care au probabil can-ul pe 30bytes.Nu pe can se fac toate aceste proceduri?
Din ce stiam eu functia asta se poate activa doar daca ai:
3C0937049 AD,AE -> 23 Bytes
3C0937049 AH,AJ -> 30 Bytes
  On 26.01.2012 at 18:15, gabrielsanda a scris:
daca e clona si s a conectat la net aproape sigur interfata trebuie rescrisa(sunt baieti care fac asa ceva), asa am patit si eu prima data:)) dar vanzatorul mi a schimbat o, bine ca nu i am zis ca am uitat de net :lol: , deci mare atentie, cel mai sigura e o interfata originala
Nu se strica fizic , se repara 100%
Rescriere Atmega
  On 26.01.2012 at 19:29, cuiuda a scris:
Nu merge cormering pe 23 bytes.
daca e cineva care detine interfata vag-com in ploiesti, rog sa ma contacteze si pe mine
multumesc
Oare nu poate lamuri nimeni si pe mine?deci,pentru activarea cornerig pe proiectoare,procedura care se poate activa doar la mașinile de după Iulie 2007 ,ce piesa trebuie schimbată,Can Gateway cu codul 3c0907530 k l m n... Sau Bordnetz cu codul 3co937049...ah,aj cum zicea un coleg mai sus.multumesc.
  On 27.01.2012 at 19:32, TVS a scris:
Bordnetz, bineinteles, si sa fie pe 30 bytes.
Modificat de D@ny
ms florin, ca deobicei de ajutor, am sa sun maine sa vad daca e cineva disponibil pana o repar eu pe a mea, colegul caruia mi-ai dat nr de tel, nu imi rasp la tel, am sa mai incerc si maine
ms inca odata
Multumesc,dacă poți sa îmi spui si ce litere au la sfârșit cele pe 30,ca sa știu ce sa caut.ce am eu are j la sfârșit.Cumva ah,aj cum spune colegul cuiuda?
DA, doar pe AH si AJ merge functia.
  • Marian a închis acest topic
