Proceduri VCDS
Seby19
Merg activate toate functiile, cauta procedurile pe acest topic!
PS
Am gasit incarcarea alternator, este pe engine, grup 016
Modificat de duduratoy
Am gasit ceva....Sunt corecte ? Nu vreau sa stric ceva :D
Stopuri Spate (donut style)
[Select]
[09 – Centr. Elect.]
[07 – Coding]
[Long Coding Helper]
Byte 9: Debifati toate casutele sau modificati casuta DEC in cifra 0
(zero)
[Transfer Coding!]
[Do It!]Coming Home & Leaving Home
[Select]
[09 – Cent. Elect.]
[07 – Coding]
Byte 0:
– bifati Bit 5 (Assistance Driving Light – Leaving Home active)
– bifati Bit 7 (Coming-Home active)
[Transfer Coding!]
[Do It!]
Inchiderea automata a masinii dupa viteza de 15km/h
[Select]
[46 – Cent. Conv.]
[10 – Adaptation]
Channel 03: Auto Lock after 15km/h (1 = Activate / 2 = Deactivate)
[Test]
[Save]
[Done, Go Back]
Deschiderea automata a masinii dupa scoaterea cheii din contact
[Select]
[46 – Cent. Conv.]
[10 – Adaptation]
Channel 04: Auto Unlock after removing the key (1 = Activate / 2 =
Deactivate)
[Test]
[Save]
[Done, Go Back]
Optional se mai pot seta ca la inchiderea/deschiderea masinii sa se aprinda avariile sau sa se auda un clacson scurt
Optional channels – flash blinkers or sound horn said:
Channel 05: Unlock, horn sounds (1 = Activate / 2 = Deactivate)
Channel 06: Lock, horn sounds( 1 = Activate / 2 = Deactivate)
Channel 07: Unlock, turn signals flash (1 = Activate / 2 = Deactivate)
Channel 08: Unlock, turn signals flash (1 = Activate / 2 = Deactivate)
Inchidere automata a geamurilor tinand apasat butonul doar 2 secunde
[Select]
[46 – Central Conv.]
[07 – Coding]
Byte 6:
– bifati Bit 6 (Comfort function autom. closing)
[Transfer Coding!]
[Do It!]
Functia „cornering” pe proiectoare !
NOTA: Aceasta functie merge activata doar la masiniile produse DUPA iulie 2007  ! Functia „Cornering” (care se activeaza pe proiectoare) merge activata DOAR pe centrala electrica de 30bits!
[Select]
[09 – Cent. Elect.]
[10 – Coding]
Byte 23:
– bifati Bit2 (Internal Turn Light Control Algorithm active)
– selectia la Bit-ul 3-4: 08 Turn Lights via Fog Lights
[Transfer Coding!]
[Do It!]
Codare pentru auto-hold : In functie de an difera codarea:
pana in 2007:
0000010 = Parking Brake without Auto-Hold (North America)
0000011 = Parking Brake without Auto-Hold (Rest of World / PR-UH1)
0000012 = Parking Brake with Auto-Hold (Rest of World / PR-UH2)
0000013 = Parking Brake with Auto-Hold (North America)
2008+
0000056 = Parking Brake without Auto-Hold (Rest of World / PR-UH1)
0000057 = Parking Brake with Auto-Hold (Rest of World / PR-UH2)
[Select]
[46 – Cent. Conv.]
[10 – Adaptation]
Channel 04: Auto Unlock after removing the key (1 = Activate / 2 = Deactivate)
[Test]
[Save]
[Done, Go Back]
Optional se poate seta ca la inchiderea/deschiderea masinii sa se aprinda avariile sa sa se auda un clacson scurt .
(Optional channels – flash blinkers or sound horn)
Activare Rain Closing
[Select]
[07 – Coding]
Byte 9: Bifati Bit 1 „Rain Closing (0 = nonrecurring / 1 = permanent)”
[Transfer Coding!]
[Do It!]
[Select]
[09 – Cent. Elect.]
[07 – Coding]
Se selecteaza 2 – 1K0 955 559 AF — RLS 190808 046 0204
Se selecteaza Coding Helper si se bifeaza Bit 1 „Rain Light Function Active” si Bit 2 „Rain Closing Active”
[Transfer Coding!]
[Do It!]
Noteaza modificarile ptr a putea reveni.In caz ca ceva nu merge bine..
Majoritatea le-am activat la mine si merg fara probleme
Am activat functiile postate mai sus, ideea ca acum cand deschid masina se deschide doar usa soferului, ca sa le deschid pe toate trebuie sa apas de 2 ori butonul de pe cheie :)
nu e cazul, se salveaza automat de catre VCDS
Buna seara,cum pot sa dezactivez si eu telefonul sa nu mil mai arate.Am intrat in long coding la 19 gateway am debifat 77 Telephone,am dat do it,mi-a scris ca sa acceptat codarea si dupa aia da eroare cu codare incorecta.Suportul l-am dat jos si am scos mufele inainte sa debifez.Multumesc anticipat.
Scoate conectorul din modulul BT...nu din adaptorul de pe bord.Ala e sub scasun pasager...
Ok o sa il scot si de acolo.Multumesc
On 1/9/2017 at 22:06, spido a scris:
Dezactiveaza descuiere selectiva.
Imi poti spune cum dezactivez?
Si inca ceva, cum activez bluetooth cu VCDS ?
Intri pe modul confort la long codding si debifezi descuiere selectiva.
Ptr bluetooth ai nevoie de modulul bluetooth ptr a-l activa.
Uitate sub scaunul pasager si vezi codul modulului, dupa aia vezi daca si cum il poti activa
crezi ca il are ?
daca da, trebuia sa fie activat - si sa-l gasesti cu VCDS-ul, modulul 77 - Phone
Am scos mufa de la conector de sub scaun pasager,dezactivat phone cu vcds si acuma num imi mai apare in can.Multumesc pentru ajutor(cei care lucrati pe acolo aveti grija ca tot acolo sunt si mufele de la antena radio).
Unde ai tu mufe de la antena radio sub scaunul pasagerului ?
Aia e antena de la telefon, nu de la radio.
De la radio e ca le-am scos si nici nu a mai mers radiou.... si imi si dadea eroare pe radio...Daca vrei pot sa fac poze sa le scot si sa si postez eroarea,sunt de aceasi culoare ca la cele care merg in spate la radio MFD2.Si printre cele 2 mai e inca o mufa mica care e legata impreuna cu mufa mare care mergea la suportul de telefon.
Modificat de claumedel
Eu am un suport de telefon pe bord, iar navigatia am vazut ca are functie bluetooth, doar ca nu il gaseste telefonul .
Aici ati citit putin? Sunt multe exemple de setari codari pe modul Bluetooth si legat de tipuri si conexiuni cu Rns.
@cretzu-vezi ce modul BT ai sub scaunul pasager-Noteaza codul lui,posteaza-l si-ti spunem ce e de facut.
@AlBundy-am gasit si eu un mk5 cu modul amplificator semnal radio sub scaunul pasagerului.
Golf-ul 5 este cu asa ceva.
  • Marian a închis acest topic
