Proceduri VCDS
Seby19
dumitrualexander
Multumesc mult! Este cineva in Constanta care ma poate ajuta cu asta?
Buna seara . Uitandu-ma pe o lista cu proceduri am gasit urmatorul lucru Semnalizare spate US style:
[select]
[09 – Centr. Elect.]
[07 – Coding]
[Long Coding Helper]
Byte 22: Bifati casuta „Rear Parking Lights as Blinker active(North America)” (bit 6)
[Transfer Coding!]
[Do It!]
Poate sa imi spuna si mie cineva care este efectul vizual pe care il creeaza?(cum se manifesta?) , deoarece nu am vag-com sa incerc si pe internet nu am gasit nimic relevant legat de optiunea asta.
Se refera la semnalizare. Nu la donuts. Iti va semnaliza tot cu ledurile rosii de la pozitie.
Buna seara.Am facut o diagnoza la masina si mi a dat eroarea asta.Imi puteti spune despre ce e vorba?Multumesc
post-154824-0-11984200-1446943423_thumb.
Modificat de razvynix
Asta e singura eroare sau mai e ceva? Ai incercat sa o stergi?
Buna! am pus pe tester, autoturismul si am urmatoarele probleme...le interpretati voi,va rog.
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  9248
   Revision: --H06---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 80093 222 69422
   VCID: 7AFB1463352A82CEDA7-802F
4 Faults Found:
000387 - Fuel Temp. Sensor A (G81)
               P0183 - 000 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 188328 km
                    Time Indication: 0
                    Date: 2015.09.30
                    Time: 10:08:17
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.31 V
                    Temperature: 38.7°C
                    Temperature: 55.8°C
                    Temperature: 38.7°C
006470 - Control Module 1 for Coolant Fan
               P1946 - 000 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 188372 km
                    Time Indication: 0
                    Date: 2015.10.04
                    Time: 18:39:53
             Freeze Frame:
                    RPM: 1554 /min
                    Speed: 23.0 km/h
                    Load: 7.5 %
                    Voltage: 14.36 V
                    Bin. Bits: 00001000
                    Temperature: 76.5°C
                    Duty Cycle: 9.7 %
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 188399 km
                    Time Indication: 0
                    Date: 2015.10.07
                    Time: 11:18:31
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Inj. Quantity: 2.96 mg/str
                    Temperature: 38.7°C
                    (no units): 0.0
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 189025 km
                    Time Indication: 0
                    Date: 2015.11.06
                    Time: 10:11:06
             Freeze Frame:
                    RPM: 840 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Temperature: 38.7°C
                    (no units): 0.0
Readiness: 1 1 0 0 0
da asta e singura.Am sterso
@laurentiu79 -verifica senzorul de temperatura combustibil/conector cablaj.Sterge erorile si vezi daca mai apar.Eventual muta injectorul de pe 3 pe 2 si vezi daca se muta si eroarea pe 2.
Ventilatoarele merg normal?
@razvynix-probleme cu pornirea cumva? Sau alte simptome?
Salutare din nou....am revenit cu print screen-uri....
Daca poate cineva sa ma ajute ar fi super :)
Exact codarea asta am avut-o si eu cu toate ca mașina a venit din fabrică cu acumulator varta AGM. Mie mi-a acceptat codarea cu firma si seria de pe bateria originală numai ca, dacă umblu la long coding, Pe bit 3 parcă, mașina știe că are baterie wet. Ma tot chinui sa schimb acolo să-i aduc la cunoștință că are baterie AGM și nu-mi da voie. Zice ca error 31 coding out of range. Sfaturi?
Și încă o chestie: dau sa intru în coding la abs-din start imi spune ca:
+0002048=tyre pressure monitoring (pr7k6) active / installed. Și mai departe mă sfătuiește să scriu un mail lui ross-teck cu o scanare completă ca să obțin propper coding value. Oare am asa ceva? Cum verific dacă există fizic? Sau dacă nu am, cum dezactivez treaba asta?
Și încă o chestie: dacă intru cu long coding la motor ( cam atâta pot face la motor ca am interfata vechiuta) îmi zice că electric coolant pump not installed / inactive. Oare nu are așa ceva din producție mașina mea sau a renunțat careva la ea? Ca eu știam că ar trebui sa aibe. Unde ma uit sa vad dacă există fizic? Sau sa constat lipsa ei? :)
Nu.Aia e o valoare care se adauga la codingul existent ptr a adauga functia.Sunt 2 tipuri de tyre pressure: unul foloseste senzorii ABS altul foloseste senzori instalati in roata/pe valva.
Si 2-e vb de pompa electrica ptr lichid racire...la tine e pe curea/lant.
Modificat de spido
M-ai lămurit.... Deloc. Știu că eu am pompă mecanică pe curea dar mai știu că sunt unele mașini care au O A DOUA POMPĂ, care e electrică și (dacă nu mă înșel) plimba lichidul prin ceva calorifer atașat egr-ului.
DEci, NU AI. Pe passat B6 nu exista pompa electrica de recirculare.
Modificat de Al Bundy
Multam fain!
Modificat de lucianNT
cauta in aria Prestari servicii.
Salutare !
Am nevoie de un coleg veteran in alde VCDS si codari can
Am o problema cu codarea unui can versiunea h , nu ii dau de cap !Poate nu e cine stie ce inginerie dar chiar nu ii dau de cap ! am nevoie si de o codare pentru climatronic b7 , dar , urgenta e pe CAN .
In Long Coding acum este FF817F06400202002002
Din Brasov va rog sau in Bucuresti in cel mai rau caz , daca pot sa ajung cu masina .
Initial , m am uitat sa vad care e treaba cu eroarea de mai jos , dupa o scanare generala s a facut cam rosie lista .
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 006 - Electrical Fault - Intermittent
Alte erori stocate care poate sunt din cauza codarii proaste a Can ului
01342 - Engine Control Module 2 (Slave 1)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 37102 km
                    Time Indication: 0
01044 - Control Module Incorrectly Coded
VAG Number C0 907 530 Q Component J533 H13 0172
pot fi gasit la 0755 847 634
Bifeaza doar modulele existente pe masina.
Crede ma ca asta am incercat in ultima ora , m am calmat , mai bine las pe altcineva sa isi faca treaba decat sa fac alte prostii !
Modificat de free_runner
absolut nici una....
@razvynix sterge eroarea si las-o in pace...
asta pana s-o duce de tot ELV-ul.... si acolo ramane.
rezolvat !
a ramas doar cea de comunicatie pe clima si senzor calitate
Se poate face din VAGCOM sa se plieze oglinzile laterale atunci cand inchizi masina si sa se deschida cand deschizi masina?
Pe masina am oglinzi actionate electric dintr-un buton pe usa sofer, butonul de reglat oglinzile.
Daca DA atunci CUM?
Modificat de Teo-Costin
la masina ta, NU - doar de la Passat B7 in sus.
[select]
[07 – Coding]
[Transfer Coding!]
[Do It!]
Multumesc.M-ai lamurit. Donuts aveam deja pe masina, si pe internet am gasit alti pasi prin care scria ca se activeaza Donuts, de-aia eram nelamurit.
Modificat de Alexxdam
dumitrualexander
Salut! Stiu ca nu e topicul potrivit, dar asta e unul din cele mai populate.
Ma poate ajuta cineva cu un sfat legat de eroarea asta, va rog:
008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
               P2098 - 002 - Too Lean - Intermittent
Am atasat si log-ul din VCDS.
O seara buna!
Log-Log.txt
  • Marian a închis acest topic
