Proceduri VCDS
Seby19
Interfata ta, clona probabil, este de vina. Incearca cu alta.
Din cauza ca interfata folosita este o CLONA ?
Da , cred ca este clona. Si nu ii nimeni prin arad sa ma ajute ?
Hello.
Ajutati-ma va rog cu o interpretare:
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 CR    HW: 03G 906 018 CR
   Component: R4 2.0l PPD1.5 G    9970
   Revision: --H05---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 00191 264 15243
   VCID: 77FD0D5706389FA6A59-8022
3 Faults Found:
19558 - Motor for Intake Manifold Flap (V157)
            P3102 - 006 - No Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 115
                    Mileage: 185535 km
                    Time Indication: 0
                    Date: 2015.10.03
                    Time: 19:21:09
             Freeze Frame:
                    RPM: 736 /min
                    Text:     32    Nm
                    Speed: 0.0 km/h
                    Text:  0.0    %
                    Voltage: 12.32 V
                    Text:    184    Nm
                    Text:      0    Nm
19557 - Motor for Intake Manifold Flap (V157)
            P3101 - 009 - Open or Short to Ground - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 1
                    Fault Frequency: 7
                    Reset counter: 113
                    Mileage: 185523 km
                    Time Indication: 0
                    Date: 2015.10.02
                    Time: 19:56:21
             Freeze Frame:
                    RPM: 800 /min
                    Text:     24    Nm
                    Speed: 0.0 km/h
                    Text:  0.0    %
                    Voltage: 10.96 V
                    Text:   1016    Nm
                    Text:     80    Nm
18080 - Coolant Fan Control 1
            P1672 - 009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 7
                    Reset counter: 113
                    Mileage: 185523 km
                    Time Indication: 0
                    Date: 2015.10.02
                    Time: 19:56:22
             Freeze Frame:
                    RPM: 800 /min
                    Text:     24    Nm
                    Speed: 0.0 km/h
                    Text:  0.0    %
                    Voltage: 14.01 V
                    Load: 9.8 %
                    Temperature: 86.0°C
Readiness: N/A
Vezi ca ai postat gresit. Raspuns ai primit in alt topic. Nu mai posta aceeasi pb in mai multe topic-uri!
Exista topic dedicat ptr erori.
VW passat b6 3c 2.0 tdi 170 cp
Salut,sunt nou pe forum poate ma ajuta si pe mine cineva cu un sfat.Povestea masinii mele incepe chiar asa :Am cumparat masina de la un dilar din Germania toate frumoase timp de 2 saptamani dupa care dintr-o data mi-sa aprins simbolul de la bujii ci clipea si nu mai aveam turbo daca opream si porneam iar mergea am sesizat ca daca mergeam cu ea turata peste 2500 merge fara probleme cum o tineam putin sub 2000 imediat simteam lipsa de putere si in ca.40sec se aprinde becul de bujii. Am mers cu eq la mecanic a zic ca e din cauza DPF si a zis ca trebuie sa ii faca o regenerare din calculator a mers cu ea turata intr-a 2 3000 cam 20min a zis ca inainte ia aparu filtru 80% iar acum e gol. Ok am plecat de la e am mers cu ea cam 50 km dupa care aceeasi problema. Am fost iar la el si a schimbat senzorul de presiune sau ceva de genu de la DPF iar regenerare. Am plecat si iar a doua zi dupa 50km acceiadi problema. Am zis sa merg cu ea la reprezentanta ca sant nemti si stiu. Am facut programare la programare mi-a zis ca ma incadrez in actunea de o aveau iei si am intrebat ce actiune despre ce e vb.nu parca nu vruiau sa spuna intr-un final au spus ca de injectori ca daca nu functioneaza bine ii schimba fara banii ok da parca tot dubios era de cand am vazut la tv cu problema ca au inselat norma de poluare. Cand sa pornesc dimineata problema su cu frana de mana nu se dezactiva plus ca se aprinsese si becul de la PDF si cel de la motor pana la urma am reusit sa plec am duso la service si le-am zis si de frana. am loato seara si au zis ca acum am injectori noi ok da cu PDF-UL pt. Care am venit a pai sa vedeti masina fuctioneaza perfect da lipseste o componenta din filtru de particule din cauza asta nu se poate rezolva zice ceva ca dupa filtru pe teava mai trebuia sa aiba ceva si piesa aia lipseste si ca trebuie inlocuit sau trimis la o firma de se ocupa cu regenerare. Ok am plecat tot cum am dus-o bine inteles dupa ce am platit pentru un furtun care zic iei ca ar fi fost crapat si l-au inlocuit 260 euro sa pleci cu masina tot asa. A doua zi am zis sa merg tot la primul mecanic la care am fost i iam povestit ce au zis aia de la VW a zic ca imi da filtru jos si il curata el la temperatura de 800 °c iam zis ok fa masina sa mearga ma suna sa imi zica ca e o alta problema a incercat sa stearga erorile si nu merg m-a intrebat ca ce au facut aia de la VW. In fine cunoaste pe cineva acolo a fost cu masina la vw zice ca a instalat soft nou sa incerce a 2 zi tot fara rezultat a zis ala de la vw ca trebuie bagata on line cu fabrica si aia de acolo sa dea verdictu ce are.astept de 4 zile sa ne cheme cu masina in service la vw.. tind sa cred ca aia de la vw au facut ceva prima data cand am fost cu ea. REAMINTES SANT IN GERMANIA SI NU II DAU NICI NEMTI DE CAP. ASTEPT RASPUNSURI VA MULTUMESC.
Revin am uitat ca scriu ca s-au verificat toti senzori si sonda lambda si a zis ca sant ok.
Modificat de Marius Tg.jiu
WoW. Tu intelegi ce scrii, sincer?
Te rog sa citesti si sa respecti regulamentul vwforum!
Am citit doar primul rand, am avut o problema asemanatoare, s-a rezolvat prin a schimba Vacuum Turbo, cu toate ca masina nu avea absolut nimic, doar imi aparea eroarea in bord.
off topic: Editeaza si scrie pe fragmente, nimeni nu o sa-ti citeasca 'acel carnat de propozitie' .
Da am observat unde am gresit scuze. Am modificat mult sa ma fac mai explicit da a iesit un kkt.
Se scrie "observat" și nu ai scris unde trebuie....
O.T.Colegul chiar are nevoie de jutor,fiind in Germania,dar sincer e un "carnat absolut indescifrabil" scris acolo fff greu de citit,aviz celor care nu citesc Regulamentul !!!
O.N.@Marius Tg.Jiu incearca sa obtii o scanare a masinii si sa o postezi in topicul dedicat,concentreaza-te in a explica coerent problema ta si citeste Regulamentul,noi te putem ajuta/indruma dar nu intelegem nimic din ce ai scris acolo.
In prezent am 3 becuri aprinse in bord : cel de la buji, motor, si filtrul de particule.cel de la service mi-a spus k nu le poate sterge, deoarece nu stie ce mi -au facut cei de la VW.
E posibil sa fie din cauza softului,sa fi schimbat cei de la VW softul fara sa imi spuna?
Nu cred ca e cazul sa fi schimbat ceva la soft,incearca o scanare cu VCDS neaparat,ne va fi mai usor de interpretat erorile.
trebuie sa vedem rezultatul diagnozei - sau faci alta si postezi erorile - altfel, cam greu sa iti zicem ce e de facut.
Eu cred ca i-au schimbat softul, masina fiind in actiunea noua dieselgate, de aceea au schimbat si injectoare asa cum anuntasera VW deja.
Passat B6 din 2006 170CP e PD EURO4...nu are nici o legatura cu EURO5-urile implicate in dieselgate :)
calincurticapian
Salut, va rog sa nu ma luati tare, e prima data cand postez aici.
Am o problema care ma stoarce in ultima vreme!!! In urma "jocului" meu cu Vagcomul (prostul care isi baga nasul), mi-a aparut in bord senzorul de bec ars si 3 erori in bord. Problema e functioneaza toate becurile pe masina si....na....habar nu am ce sa ii fac. Va scriu mai jos erorile asa cum mi le da Vagcomul.....
01506 - Bulb for rear fog right (L47)
             012 - electrical fault in circuit
01835 - Bulb for side blinkers right (M19)
02390 - Control / Regulation for Ambience Lighting (E400)
            009 - Open or Short to ground
Please HELP :)
Modificat de calincurticapian
Revino la setarile initiale din vcds-debug-acolo gasesti tot ce ai modificat.
calincurticapian
De 2 ore caut si incerc sa aflu cum sa folosesc debugul, dar.....habar nu am......imi prind urechile. De gasit l-am gasit, am facut si o copie de siguranta dar mai mult......
Ai acolo mai multe fisiere-codding, adaption. Intri in fiecare si vezi modulul accesat, valoarea initiala si cea finala, pe repere de timp. Iei valoarea initiala si o rescrii in modul respectiv. Asta e tot. Daca nu te descurci da-mi un tel si vb.
Ai activat "din greseala" Cold diagnosis pentru side blinkers unde sigur nu ai bec, ci LED si mai cred ca ai activat al doilea bec de ceata spate, care nu exista.
Modificat de svg_gabriel10
  • Marian a închis acest topic
