Proceduri VCDS
Seby19
F l o r i n
Gresesti - EDC17 s-a pus pe motoarele CR, nu e cazul tau. Tu ai motor PD cu EDC16.
nu e garantat ca interfata originala citeste altceva, e doar o ipoteza - poti incerca
diferenta intre km stocati pe ceasuri si in ECU - e normal sa fie - din cauza modalitatii diferite de stocare.
Din cauza modalitatii diferite de calculare, nu de stocare.
F l o r i n
da, corect - m-am exprimat incorect - stocheaza diferit.
F l o r i n
no, nu-i bai... posteaza si tu scanarea de pe Engine te rog sau un autoscan - ca ai interfata....
Tuesday,05,May,2015,19:00:00:33490 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.3.0 Data version: 20140905 VIN: TMBJE73T7A9026905 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3T (1K0) Scan: 01 03 08 09 10 15 16 17 19 25 36 42 44 46 52 56 62 72 77 VIN: TMBJE73T7A9026905 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 QP HW: 03G 906 021 AB Component: R4 2,0L EDC G000SG 2893 Revision: --H11--- Serial number: Coding: 0000072 Shop #: WSC 33361 790 00000 VCID: 7DF78FAF2473BCF6F0B-8028 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ Component: ESP MK60EC1 H30 0107 Revision: 00H30001 Coding: 843D601609240000211406E4901E0042350000 Shop #: WSC 33361 790 00999 VCID: 7AFD84B3F55D8BCED59-802F 1 Fault Found: 02214 - Tire Pressure Warning 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 206 Mileage: 115013 km Time Indication: 0 Date: 2059.14.19 Time: 17:14:45 Freeze Frame: Count: 0 Count: 32768 Count: 4608 Count: 397 Count: 50735 Count: 254 Count: 65287 Count: 0 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR Component: Climatronic H15 0401 Revision: 00005001 Coding: 0000000002 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_SE36.rod VCID: 820D7C53158D430E0D9-80D7 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 087 E HW: 1K0 937 087 E Component: BCM PQ35 H+ 103 0575 Revision: 00103 AG Coding: 40010AB8F853F1C040080080110081E4437100AE536D81605C0140000000 Shop #: WSC 33361 790 00999 VCID: 3363699792B7BA8656F-8066 Subsystem 1 - Part No: 3T1 955 119 Labels: 1KX-955-119.CLB Component: Wischer 15011 22 0602 Coding: 00D7B7 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 200110 05 54 0402 Coding: 0730ED Subsystem 3 - Part No: 7N0 951 171 Component: DWA-Sensor 00 002 0205 Subsystem 4 - Part No: 1K8 951 605 Component: LIN BACKUP HO H10 9003 2 Faults Found: 00153 - Windshield Wiper Motor; Driver Side (V216) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 205 Mileage: 114831 km Time Indication: 0 Freeze Frame: Term 15 Off Voltage: 12.85 V OFF OFF Term 50 Off OFF OFF 01134 - Alarm Horn (H12) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 4 Fault Frequency: 1 Reset counter: 53 Mileage: 105522 km Time Indication: 0 Date: 2050.14.25 Time: 08:19:50 Freeze Frame: Term 15 Off Voltage: 14.35 V OFF ON Term 50 Off OFF OFF ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V1.clb Part No SW: 1Z0 919 475 B HW: 1Z0 919 475 Component: PARKHILFE 4K H06 0006 Revision: -------- Serial number: 66641002201112 Coding: 100008 Shop #: WSC 33361 790 00999 VCID: 4089365BD301111EDBD-8015 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 3T0 959 655 A HW: 3T0 959 655 A Component: J234__LBE VW10 HI 1916 Revision: 18013000 Serial number: 003EAP0HU1P$ Coding: 0016965 Shop #: WSC 33361 790 00999 VCID: 3F8B35A76EFF6EE6A27-806A Subsystem 1 - Serial number: 6332MTS633470060 Subsystem 2 - Serial number: 6342MTS634190060 Subsystem 3 - Serial number: 6351HTS6VA8O76KJ Subsystem 4 - Serial number: 6361HTS60GEO76KJ Subsystem 5 - Serial number: 63727TS6I64L76KJ Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF Component: J0527 056 0111 Coding: 0000732 Shop #: WSC 33361 790 00999 VCID: 78F99EBB0B5199DEA3D-802D Subsystem 1 - Part No: 3T0 959 537 Labels: 3C8-959-537.CLB Component: E221__MFL-URO H07 0012 Coding: 00000130 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 3T1 920 841 E HW: 3T1 920 841 E Component: KOMBI H05 0305 Serial number: 00000000000000 Coding: 111B00 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052 ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod VCID: 3567578F94C3A4B678B-8060 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb Part No SW: 1K0 907 530 AD HW: 1K0 907 951 Component: J533 Gateway H16 0233 Revision: H16 Serial number: 4520K1011707DA Coding: E9A0FF06000602009302 Shop #: WSC 33361 790 00999 VCID: 69DFCBFF40FB30562C3-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H05 0305 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005 ROD: EV_Immo_UDS_VDD_RM09_SE36.rod VCID: EADD34F30DFDBB4EA59-80BF No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl Part No SW: 3C8 959 760 HW: 3C8 959 760 Component: J810 0801 Revision: 00002000 Serial number: 00000000000000 Coding: 0000003 Shop #: WSC 33361 790 00999 VCID: F2ED2C93ED2D738E1D9-80A7 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb Part No SW: 7N0 959 793 A HW: 7N0 959 793 A Component: TSG FA H03 0200 Revision: Serial number: 0000009924111 Coding: 011D0220DE00121002 Shop #: WSC 33361 790 00999 VCID: 4089365BD301111EDBD-8015 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K0 909 144 J Component: EPS_ZFLS Kl. 195 3001 Revision: 00H17000 Shop #: WSC 33361 790 00999 VCID: 316F639FA8AB8896243-8064 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb Part No SW: 7N0 959 792 A HW: 7N0 959 792 A Component: TSG BF H03 0200 Revision: Serial number: 0000009883839 Coding: 011D0220DE00121002 Shop #: WSC 33361 790 00999 VCID: 3F8B35A7AEFF6EE6A27-806A No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb Part No SW: 3T0 035 161 B HW: 3T0 035 161 B Component: Radio-SWING 008 0028 Revision: -----11S Serial number: SKZ4Z2J1139817 Coding: 0D0004000004 Shop #: WSC 33361 790 00999 VCID: 295F8BFF407BF056EC3-807C No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 7N0-959-795.clb Part No SW: 7N0 959 795 HW: 7N0 959 795 Component: TSG HL H02 0200 Revision: Serial number: 0000009896751 Coding: 010C00200000221002 Shop #: WSC 33361 790 00999 VCID: 010FF35F988BD816943-8054 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 5P0-862-335.lbl Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E Component: FSE_2P8x H40 0190 Revision: 00000000 Serial number: 00000005177894 Coding: 0010444 Shop #: WSC 33361 790 00999 VCID: 3A7D44B375DD4BCE959-806F No fault code found. End
F l o r i n
mama... m-a luat durerea de ochi..... hihihi
ai ECU EDC16u34 - scrie si in scanare... vezi la Engine.
deci, nu avem de ce sa ne contrazicem....
Cum am spus si mai sus nu-mi face pacere sa ma contrazic, eu aveam nelamurile mele si am vrut parerea unor persoane care stiu mai multe
decit mine. Iti multumesc din nou pentru lamuriri.
Cum am spus si mai sus nu-mi face placere sa ma contrazic, eu aveam nelamurile mele si am vrut parerea unor persoane care stiu mai multe
Modificat de fagaras93
F l o r i n
Nu este nicio problema, stai linistit. E bine cand avem dezbateri constructive.
Am facut o cautare pe internet si am descoperit diverse cazuri in care si alte persoane au citit in ecu 8km ca si mine. Este o alta posibilitate de a afla km reali de la masina? abs, airbag....
F l o r i n
Nu, nu exista.
verifica intrarile in service, la reprezentanta - daca esti proprietarul masinii.
Ok, o sa incerc. Multumesc inca o data.
Offf, calculeaza diferit, nu stocheaza diferit.
Offtopic: Si cand i-am spus...cafeaua...cafeaua.
Buna ziua, am si eu o problema la masina imi apare sa codez corect radio , navigatia si telefonul si nu stiu cum anume sa fac , ca si erori am 01530 si 01042, daca ma poate ajuta cineva cum anume sa scap de aceasta problema , va multumesc ...
La 01530-pb la mute switch. Cat priveste codarea-se face functie de ce ai tu pe masina
-nr.boxe, craddle tel, sistem de sunet etc. Ptr prima eroare cand dai pe mute de pe volan, merge?
Da merge , am 10 difuzoare , rns 510 si PTR tel am acea talpa si Atașat este touchul muștii exact cum se numește
Funcționează totul , am 10 difuzoare , si PTR tel am sistemul cu aceea talpa si cu touch screen si mai am rns 510 pus de mine
scuze pentru scris dar scriu de pe telefon si dacă poți sa m-a ajuți as vrea sa te sun sa îmi poți explica mai bine, ms mult
Sterge erorile si vezi ce mai ramane. Poste fi codat ceva incorect. Ai schimbat ceva de vurand sau ai montat navi sau bt? Ok ne auxim si la tel.
Vezi daca e bifata adresa de navi pe can.
Debifeaza 56-radio.
Le: dupa ce am scris am recitit tot mesajul tau. Inceraca totusi cand postezi sa scrii cat de cat sa intelegem.
Salut,mi-am instalat si eu astazi VCDS si am facut o scanare , am gasit 2 erori care apar din nou ,chiar daca le sterg, cam ce ar trebui sa verific la
oglinda dreapta si la frana de mana? In afara de aceste 2 erori, mi s-a intamplat ceva bizar de dimineata, am pornit motorul si dupa un minut s-a oprit singur,am mai incercat sa il pornesc de cateva ori si nimic, am scos capacul de plastic de la motor, am miscat toate mufele la care ajungeam, si apoi am incercat din nou si a pornit, dar astazi la scanare nu mi-a aprut nimic la motor, ce poate sa fie?
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 AR    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1501
   Revision: 72009005    Serial number: 00000883598513
   Coding: 0000180
   Shop #: WSC 05311 000 00000
   VCID: 7F071D252EE65D1
00110 - Right Mirror Turn Signal Lamp (L132)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 5
                    Fault Frequency: 9
                    Reset counter: 116
                    Mileage: 194393 km
                    Time Indication: 0
                    Date: 2002.14.20
                    Time: 22:34:08
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 C    HW: 3C8 907 801 C
   Component: J540 EPB3  VW-13618 0005
   Revision:   010       Serial number: 00000000003586
   Coding: 0000057
   VCID: 2A511C7185E4089
03200 - Switch for Electric Parking Brake (E538)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 124
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.00 V
                    Count: 93
                    Hex Value: 0x1160
                    Hex Value: 0x0082
                    Hex Value: 0x0101
00110 - Right Mirror Turn Signal Lamp (L132)  - semnalizare oglinda dreapta
03200 - Switch for Electric Parking Brake (E538) - buton frana
Ambele de inlocuit daca circuitul electric este ok
Modificat de EEXCALADE
Dar amandoua functioneaza ,deci pot sa le las asa sau trebuie neaparat sa le schimb?
Daca merg nu ar trebui sa dea eroare. La semnalul oglinzii poate sa intre apa-sa fie fisurat. Cu butonul-vezi sa nu te lase cand ti-e lumea mai draga-mai ales daca il folosesti des.
Pe autostrada s-a aprins check engine-ul. Cand am ajuns acasa, am scanat cu VCDS-ul si am gasit eroarea asta:
008598 - Oxygen (Lambda) Sensor B1 S1 P2196 - 000 - Signal too High (Rich) - Intermittent - MIL ON
Masina merge bine, nu am sesizat nimic ciudat ( am facut 1000 de km pe autostrada dupa ce s-a aprins). E pe duca sonda Lambda ?
Mersi
svg_gabriel10
Posibil, cu timpul se decalibreaza... dar poate fi si murdara. Cand zice "signal too high" nu sunt 100% sigur, dar cred ca se refera la rezistenta electrica.
S-ar putea sa fie MAF murdar.
Daca vrei sa o scoti tu, ai MARE grija ca astea se mai rup, sau se strica filetul.
Mai asteapta pareri de la cei mai priceputi decat mine!
Modificat de svg_gabriel10
  • Marian a închis acest topic
