Proceduri VCDS
Seby19
Incearca pana reusesti , daca nu doresti sa pui originala .
marian_nicolae1970
Buna ziua,
Am cumparat o navigatie AM cu android (inainte aveam pe masina un RNS 310)
Dupa montare imi apar urmatoarele erori:
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0172
   Revision:   H14       Serial number: 1021G105080002
   Coding: F9A01F06400603041002
   Shop #: WSC 05314 000 00000
   VCID: 2C5D1CF08FF5F67E18B-8079
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 132777 km
                    Time Indication: 0
                    Date: 2055.14.08
                    Time: 19:09:57
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 101
                    Mileage: 132777 km
                    Time Indication: 0
                    Date: 2055.14.08
                    Time: 19:11:02
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A07748014
   Coding: 012110
   Shop #: WSC 05314 123 12345
   VCID: 2A511AE84501E84EEA7-807F
4 Faults Found:
03426 - Left Audio Channel
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 132777 km
                    Time Indication: 0
                    Date: 2055.14.08
                    Time: 19:09:56
03427 - Right Audio Channel
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 132777 km
                    Time Indication: 0
                    Date: 2055.14.08
                    Time: 19:09:56
01304 - Radio
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 101
                    Mileage: 132777 km
                    Time Indication: 0
                    Date: 2055.14.08
                    Time: 19:11:11
01526 - Emergency Call Button (E276)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 128597 km
                    Time Indication: 0
                    Date: 2050.14.26
                    Time: 14:44:34
Masina este un Passat model B6 2010 1.6 CR
Mentionez ca, comenzile de pe volan, functioneaza, navigatia are microfon incorporat, a downloadat agenda si pot efectua apeluri (sosiri) de pe display.
Cred ca trebuie codat ceva pe undeva :) ma puteti ajuta mai "babeste". Am o interfata (clona) 12.12. Ma pricep un "pic" dar nu stiu pe unde si cum.
 In plus, daca nu intind prea mult coarda, mi-a mai aparut si aceasta eroare:
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Part No SW: 3C0 959 433 AQ    HW: 3C0 959 433 AQ
   Component:    KSG PQ46 ELV 044 0612
   Revision: 00044000    Serial number: VWZCZ000000000
   Coding: 03910A8801864E763000101570084BCE703C01
   Shop #: WSC 05311 123 12345
   VCID: 79F3F5A4302793D6D3D-802C
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Subsystem 2 - Part No: 3C0 951 171 C
   Component: Neigungssensor  004 0611
   Subsystem 3 - Part No: 3C0 951 171 C
   Component: Innenraumueberw.004 0611
01134 - Alarm Horn (H12)
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 132888 km
                    Time Indication: 0
                    Date: 2055.14.09
                    Time: 14:45:52
Am citit despre ea dar nu stiu care este siguranta pe care trebuie sa o verific si firele care ajung la goarna :(
Va multumesc anticipat despre un eventual ajutor.
PS Citesc pe fiecare zi toate informatiile aparute in sectiunea Passat B6 si nu numai aici  :vwrullz:
Modificat de marian_nicolae1970
Alea cu radio si navigatia iti apar din cauza ca ai navigatia after. Alea le am si eu nu e stres. Pina nu pui o scula OEM tot timpul le vei avea.
Salutari!
Am reusit sa activez cateva optiuni descrise de colegi pe acest topic si anume:
-  pozitie stopuri spate (varianta cu mijlocul stins);
- optiunea de inchidere geamuri automat la 2 sec dupa blocarea masini din remote control(cheie);
- blocare automat usi dupa viteza de 15 km/h;
- deblocarea automata a usilor la scoaterea cheii din contact;
Am activat insa si optiune de Rain Light-senzor Closing, care dupa cate am inteles eu (citind in acest topic) are functia de inchidere automata a geamurilor atunci cand mergi cu masina, ai geamul deschis si incepe sa ploua, ne mai fiind nevoie sa-l inchizi din buton.
Intrebare: Oare functioneaza si atunci cand masina e parcata, inchisa si s-a uitat geamul deschis... se ridica automat?
La mine insa nu functioneaza pt ca am facut testul cu msina pornita, geamul coborat, si am aruncat apa dintr-o sticla pe parbriz acolo unde este senzorul (la oglinda).
Cine ma ajuta cu ceva sfaturi????, sau care ati mai incercat , va merge aceasta optiune???
Multumesc anticipat pt raspunsuri!!
RainClosing functioneaza doar cand masina e parcata. Dupa ce inchizi masina si astepti cca 30sec, poti turna apa pe parbris si se inchid geamurile deschise.
Superr!!
Multumesc multttttt humerg.
Asa  nu am incercat, sau cel putin nu am asteptat 30 sec. Fug imediat sa incerc. te anunt daca-mi merge
Functia ai activat-o si pe RLS ssau doar in modulul de confort ?
@ humerg
am facut testul cu masina parcata, geamul deschis, si dupa 30 sec am aruncat apa pe senzor( sub oglida parbriz), dar nimik, nu se inchide geamul :(
@ al-bundy
Unde anume gasesc RLS asta si ce e?..in modulul confort am activat-o. Help me.
Ideea este ca senzor de ploaie sigur am, dar ce am observat de la un timp ca nu pornesc stergatoarele automat daca incepe sa ploua.( inainte parca imi aduc aminte ca porneau, acum 2 ani.. dar numai stiu exact pozitia manetei).  Maneta de stergatoare trebuie sa fie intr-o anumita pozitie????. o fi dezactivat de acolo.. Va rog ajutati-ma cu info...
P.S O alta optiune care am reusit sa o activez este aceea cu semnalizarile fata aprinse 35% atunci cand pozitia este ON.(American style)
Mersi
Modificat de Nutzu84
Dupa ce intri pe centrala electrica, in long coding, selectezi optiune e din casura RLS, acolo ai de codat RainClosing.
Nu gasesc casuta aia RLS, am mers pe fiecare bit si nu am asa ceva.
Atasez mai jos 2 poze cu ce am bifat si activat. Optiunea nu  merge inca.
prima  poza este pe central/conv  si a doua pe central electric [09]
Nu ar trebui sa pun pe valoarea 1 si in canal aceasta functie Rain Closing???, dar nu am gasit optiunea asta pe canal in Adaption
Helpppppp!!!!
post-81714-0-93236200-1427552208_thumb.j
post-81714-0-60510500-1427552234_thumb.j
Pana sa intri aici , poti sa selectezi RLS
Ahaa,  uitandu-ma atent la procedura si la poze m-am prins acum unde sa selectez RLS, merg sa incerc...
Multumesc tuturor!!
Sper sa mearga ca tare imi doresc optiunea asta...
Am reusit sa activez Rain Closing. Multumesc tuturor pentru indicatii!!! Acum functioneaza.
Nutzu84, ma ajuti si pe mine sa-mi activez functia asta de rain closing, care sunt pasii ?? Tks
Activare Rain Closing
[Select]
[46 - Central Conv.]
[07 - Coding]
[Long Coding Helper]
Byte 9: Bifati Bit 1 "Rain Closing (0 = nonrecurring / 1 = permanent)"
[Transfer Coding!]
[Do It!]
[Select]
[09 - Cent. Elect.]
[07 - Coding]
Se selecteaza 2 - 1K0 955 559 AF -- RLS 190808 046 0204
Se selecteaza Coding Helper si se bifeaza Bit 1 "Rain Light Function Active" si Bit 2 "Rain Closing Active"
[Transfer Coding!]
[Do It!]
Multumita colegului moderator @Dany la sectiunea DYI gasesti toate optiunile ce le poti activa la topicul Proceduri VAG-com.
Succes!
P.s Daca nu ai VCDS orig, va trebui sa convertesti tu codul din HEX - Decimal..pentru optiunea asta.
marian_nicolae1970
            000 - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 132888 km
                    Time Indication: 0
                    Date: 2055.14.09
                    Time: 14:45:52
 Revin cu aceasta eroare... nu ma poate sfatui nimeni?
Ba da - vezi ce e cu alarma . Poate e necesar sa o inlocuiesti
Nu poate. Ci sigur trebuie schimbată goarna.
Nu am vrut sa fiu asa dur din prima , ca astepta omul raspuns urgent
marian_nicolae1970
Multumesc de raspuns!
Salut!!
Eroarea asta o am si eu si am incercat sa o sterg dar degeaba, apare iar:
            000 - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 132888 km
                    Time Indication: 0
                    Date: 2055.14.09
                    Time: 14:45:52
De aceea nu imi merge functia Lock/Unlock from Remote Control Blink&Horn. Adica merge dar doar semnal luminos, fara sunet.
Intrebarea mea este unde gasesc goarna aia, pentru ca m-am uitat la motor si nu se vede nimik. Am inteles din ce-am citit ca ar fi undeva prin spate, partea dreapta, sau cel putin la B5.5 acolo este ca am activat la cineva si acolo se auzea.
Please info unde gasesc goarna asta daca e arsa??????.
P.s Alarma este oricum OEM pentru ca eu nu am montat nimik AM.
Mersi
Este sub carenajul rotii din dreapta, prinsa sus pe contraaripa.
Mersi frumos de info Al-bundy....o sa caut si o inlocuiesc ca sigur e arsa..
Avand eroarea :
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 101
Mileage: 132888 km
Time Indication: 0
Date: 2055.14.09
Goarna e arsa cel mai probabil. AS PUTEA sa o inlocuiesc cu una AM (oarecare..o sirena de la alarmele AM)???. A incercat cineva??? Mersi de raspuns si scuze de offtopic
Time: 14:45:52
alarma OEM este comandata de calculatorul confort al masinii.
o sirena AM care are doar 2 fire de alientat (daca o alimentezi la 12v, "CANTA"), nu o poti face functionala cu sistemul OEM al masinii.
  • Marian a închis acest topic
