Proceduri VCDS
Seby19
Am un prieten care si-a montat pe Touran un RNS510....la scanare, a ramas cu aceste erori, care cel putin una, nu  cred ca are legatura dar m-a rugat sa ma interesez:
Address 09: Cent. Elect.       Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 1K0 937 049 N    HW: 1K0 937 049 N*
  Component and/or Version: Bordnetz-SG     H34 0803
           Software Coding: 018B8F020004100000120C000000000000087F075C
            Work Shop Code: WSC 00000 000 00000
           Additional Info: 1T0955119C  Wischer VW358  ˙˙˙˙ 0401
                      VCID: 3A7030B64A058FCC
2 Faults Found
00924 - Relay for Headlamp Cleaning System (J39)
        009 - Open or Short to Ground
00834 - Signal for Activation of Heated Rear Window
Address 37: Navigation       Labels: 1T0-035-680.clb
Control Module Part Number: 1T0 035 680 H    HW: 1T0 035 680 H
  Component and/or Version: RNS-MID       H61 3970
           Software Coding: 0001040004000080000C
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: ------------------------- ------ ()
                      VCID: 336E1D926D6F7E84
1 Fault Found
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication
             Freeze Frame
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 247
                    Mileage: 230595 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:54:25
O alta chestie interesanta, spune ca are modul BT pe masina xxx xxx 729 E si nu il gaseste nici cum (a verificat toata partea dreapta, din fata pana in spate si nu l-a gasit).
Partea interesanta acum incepe....... si-a montat modul BT 7xx xxx 730 H, functioneaza, dar la scanare apare tot xxx xxx 729 E
Cum e posibil ( banui doar ) ? .....si unde ar trebuie sa fie amplasat cel vechi ( pentru ca sub scaun pasager, nu exista.... a fost montat cel nou acolo ) ?
Am rezolvat ! Activat day light, rain auto close, semnalizari aprinse , etc., toate fct perfect. Multumesc!!! Hale bune!
din ce an e masina ta?
eu nu am reusit rain auto close..singura de altfel.
Da, am rezolvat si merge, geamurile se ridica dupa ce incui masina daca dai cu apa pe senzor. Ideea e ca mai trebuie bifata o casutza mai jos pe care scrie cv de genul "rain sensor off". pana nu bifezi acolo nu merge.
Buna seara.
Am un passat 2009 cbab highline fff dotat de la kessy pana la xenon trapa tot plus CB model nou.
Am citit pana la pagina 56 si cateva pagini in urma pana la 172 si nu am gasit nimic concret din ce imi trebuie adica:
1) cum fac acele sa isi faca test cand pun contactul ca la passat cc!?
2)am activat coming home si leaving home dar leaving homul nu merge :( iar daca il dezactivez nu merge nici comming home...
Daca puteti sa ma ajutati detin o interfata vcds 12.12 si mesteresc cat de cat..
Stima
La punctul 1 trebuie sa iti suporte clusterul staging...daca suporta 17Instruments-Adaptation-Staging si apoi Active...
La Passat B6 facelift - sigur nu o sa ii mearga activarea staging..... din pacate. Doar clusterele de Passat CC suporta aceasta functie.
Nu ai senzor de lumina banuiesc.... de asta se comporta asa.
Multumesc pt punctul 1
Iar pentru punctul 2 am senzor ploaie lumina oglinda heliomata xenon adaptiv tot ce se putea pune pe un passat inafara de scaune cu memorie si carlig... functia de comming si leaving imi apar in CB si cu vcds le vad. :-/
pot sa le reset de undeva inafara din CB??
Nu mai zic ca la passatu' lui taicamiu (model identic) nici nu apar in cb, le-a avut dar au disparut subit si nu mai funct de o vreme, cu vcds le am activat dar nimic.
multumesc
Modificat de Sebastyan. G
Astazi am prins un passat cc si am intrat cu vcds pe instrument coding si pe adption si nimic de staging... iar ce am vazut pe acolo e identic cu ce am pe passatul facelift al meu... deci nici daca as cautao nu as da de ea :)) Si am mai vazut ca pe CB ii arata temp la ulei.
Pot sa fac macar asta la un passat facelift?
Stima si daca ma ajutati cu postul de mai devreme ca si lui nu ii mai arata pe CB commingul si leavingul desi are xenon si senzori si de toate.
Multumesc!!!!
2 Faults Found
1 Fault Found
             Freeze Frame
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 247
                    Mileage: 230595 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:54:25
ma puteti ajuta cu aceste erori ?
multumesc,
Ai siguranta arsa de la spalatoarele de faruri.
Butonul de dezaburire sau firele ce duc la lunate intrerupte.
LA navi strege si vezi daca mai apare.
Nu stiu, am tot incercat N variante. Nu am reusit. Din toate procedurile posibile, asta e singura care nu vrea :tuktuk:
Modificat de illusions
problemele sunt la acel Touran de care vorbeam si in PM.
  • ii spun sa verifice siguranta
  • spune ca dezaburirea functioneaza
  • la Navi - se poate sterge eroarea, dar reapare.
Multumesc,
Solutia la navi cred ca este schimbarea cAn-ului.
Deci la problema mea nu se gaseste rezolvare?!? :(
Stima
LA cc se paote activa STAGING, daca asta e problema ta.
Asta am inteles.. dar e problema cu comming home-ul si leaving home-ul si taicamiu si prietenul meu aveau functia au senzori lumina dar nu mai functioneaza iar pe BC nu le mai gasesc...
Mentionez cu vcds cand dau la 09 si apoi coding le vad activate.
Mai ai meniul de convenience? Decupleaza bateria ptr cateva minute.
Functiile respective erau la light and vision in setings in bc... si nu mai sunt.
Am sa decuplez din nou bateria... dar degeaba cred ca am si schimbat-o cu una noua (ca cea veche nu mai dadea randament). Dar o voi face din nou :-)
Problema...passat 2006 motorasul stanga de la frana de mana are eroare cu 2 martori de-mi deslipesc retina si un avertizor acustic super enervant.
Va rog daca cineva stie daca pot dezactiva acel enervant bipait continuu si cum... (mentionez ca a ramas motorasul blocat pe deschis deci pot circula cu epava)..multumesc anticipat.
Incerarca prin dezactivarea modulului de parking break din can gateway.
parking brake - nu cred ca o sa ii mearga - abs-ul o sa vada lipsa acestuia.
cauta un etrier la mana a doua, sa rezolvi problema
Buna! cum pot da un test la spalatoarele de faruri la un passat b6??? ca nu le gasesc la 09 elect. pot da test doar la stergatoarele de parbriz si duzele de la parbriz masina fiind berlina.
Stima
Tot in centrala trebuie sa le gasesti.
  • Marian a închis acest topic
