Proceduri VCDS
Seby19
Salutare, exista vreo procedura din vag-com prin care pot sa vad daca EGR-ul functioneaza in parametrii sau nu? Unde ar trebui sa afiseze chestia asta? daca se poate binenteles.
Mersi mult.
Vezi in parameterii pe engine (measuring blocks)
silviu_catalin
buna seara ati putea sa ma ajutati cu urmatoarea problema :
Address 55: Xenon Range        Labels: 5M0-907-357-V1.lbl
   Part No SW: 5M0 907 357     HW: 5M0 907 357
   Component: AFS-Steuergeraet    X016
   Revision:   H09       Serial number:
   Coding: 0000001
   Shop #: WSC 10178 599 82250
   VCID: F1E32460E8B2856
   Subsystem 1 - Part No: ID-L fehlt
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
5 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 2
                    Fault Frequency: 11
                    Reset counter: 180
                    Time Indication: 0
01042 - Control Module; Not Coded
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 178
                    Time Indication: 0
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 178
                    Time Indication: 0
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 178
                    Time Indication: 0
01539 - Headlights Not Adjusted
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 178
                    Time Indication: 0
tin sa mentionez ca eroarea a aparut in lipsa tensiunii de alimentare masina a ramas fara baterie 2 saptamani
Nu-ti vede calc de pe farul stang.
Modificat de Al Bundy
silviu_catalin
si ce as putea sa fac in privinta ?
Schimbat cu cel de pe farul drept si vazut daca se muta eroarea.
silviu_catalin
e ciudat ca eroarea sa format la lipsa tensiune pana atunci mergea perfect.cum as putea sa recodez sau ce ar trebui facut
NU citisi raspunsul de mai sus?
salut! un coleg de al meu ,si-a facut la msina niste modificari cu vag-com: printre acestea si-a activat zgomotul de la deschidere si inchidere masina;
el mi-a zis ca se poate face acest lucru chiar daca nu ai alarma pe masina .intrebarea mea este : se pOAte face lucrul acesta chiar daca nu ai vreo goarna din aia montata pe masina? Zgomotul e unul subtirel, placut ,nu ca cele comune de pe alarmele AM.
se poate face......s-a mai discutat...... foloseste functia "search".
vasilesatumare
Stie cineva daca se poate seta din vag-com, limita de viteza la care sa se aprinda farurile pe pozitia de automat? Limita actuala setata de fabrica ii undeva la
140 km/h?
Exista astfel de procedura in vag-com?
Cum sa faca ceva BEEP daca nu exista fizic pe masina?
140 km/h?
NU se poate cobora sau urca acest prag.
nu merge daca nu ai alarma, sa activezi cu VCDS-ul.... ca nu are cine sa produca sunetul.
ca poti monta o alarma AM care sa reproduca sunetul celei OEM... sau poti monta goarna OEM, sa cablezi si codezi masina - dupa care va merge - DA, se poate
Stie cineva daca se poate seta din vag-com, limita de viteza la care sa se aprinda farurile pe pozitia de automat? Limita actuala setata de fabrica ii undeva la 140 km/h...
Daca scazi sub 140 se sting automat?
vasilesatumare
daca vitrza scade sub 140 dupa vro 20sec se stinge faza scurta si se aprinde DLR
Se sting automat daca scade viteza sub 60kmh pentru cateva minute. Scrie in manual.
marinesq_iulian
De ceva timp am observat ca pe navigatie la punctele cardinale in loc de "Est" apare "O". Nu stiu daca este din vina mea sau nu.
Ma poate ajuta cineva?
Scuze daca sunt offtopic dar ma intersersa daca se poate rezolva cu VCDS-ul.
ai schimbat limba pe spania cumva? schimba pe engleza si vezi ...
marinesq_iulian
A fost tot timpul pe engleza.
PAi nu prea stim de cand a aparut, de ce.... mai multe detalii nu poti sa dai?
marinesq_iulian
A aparut cam de prin ianuarie. Pur si simplu m-am trezit ca nu mai apare "Est". Nu stiu daca i-am facut ceva sau nu. Probabil trebuie facut vreun update la softul navigatiei sau din VCDS ceva.
Sa inteleg ca nu a mai patit nimeni de nu prea se gasesc solutii.
Se poate totusi daca masina are alarma OEM ? Mi s-a intamplat sa uit masina deschisa
Sa se poata ce?
Sa se poata ce?
Zgomotul de la deschidere si inchidere masina;
daca ai instalata alarma OEM si e functionala, se poate activa bip la inchidere si bip-bip la deschidere.
  • Marian a închis acest topic
