Proceduri VCDS
Seby19
Al Bundy
Sal.,
Nu te supara dar cum pot stii ce tip de ABS am ?
La ce sa ma uit pe VCDS ?
Multumesc .
O seara buna .
Adrian, asta ai de facut
Steering angle sensor (G85)
Requirements:
Start the engine.
Rotate the wheel one turn to the right and then a turn to the left.
Drive a short distance in a straight line on level ground no faster than
20 km / h (just a few meters).
As soon as you stop the wheel easily without changing the position of the steering wheel (wheel straight).
Keep the steering wheel is not turned on.
Do not extinguish the engine.
Voltage in the system at least 12.0 V.
[select]
[03 - Brake Electronics]
[Coding-II - 11] or (if unavailable Coding-II)
[security Access - 16]
Enter 40168, provides access to the basic setting.
[Do it!]
[basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON / OFF / Next]
When properly performed basic setting, field 2 should indicate "OK".
[Done, Go Back]
To make sure that the basic setting done correctly, check the sensor again.
[Measuring Blocks - 08]
Group 004
[Go!]
Check box 1, the value must be between -1.5 and 1.5 °.
[Done, Go Back]
[Close Controller, Go Back - 06]
Marginal adaptation of the steering
(The engine still in motion)
Hold the steering wheel to the straight ahead position (± 10 °) for a minimum of 5 seconds.
Turn the wheel to the left until it stops and hold at the end of the second.
Turn the wheel to the right until it stops and hold at the end of the second.
Straighten the steering wheel and stick to the straight ahead position (± 10 °).
Turn off the engine and ignition.
Turn on the ignition.
Wait 5 seconds.
Steering light should go out. If not, do a short test drive.
As avea nevoie de un "mic" ajutor.Am fost cu VCDS pe masina si am incercat cumva sa fac sa mearga cele 2 butoane din dreapta de pe volan ( cele doua sageti cu care te poti plimba prin meniu).Eu am incercat sa le fac sa mearga atunci cand am telefonul activ pe masina si sa il pot comanda si din butoanele de pe volan. problema este ca ceva s-a intamplat si a ramas doar pe connecting si pot apasa de o mie de ori pe ok sau pe butonul de trece re la alt meniu de genul radio, busola, MFD.Chestia e ca nu mai apare acel afisaj unde pot vedea consum, km, consum instant etc.Pot vedea doar chestia cum incearca sa se conecteze cu un telefon dar nu pot face nimic.
Ca si eroare mia dat :
  Address 19: CAN Gateway       Labels: 3C0-907-530.lbl
Control Module Part Number: 3C0 907 530 L    HW: 3C0 907 951
  Component and/or Version: J533__Gateway   H13 0152
           Software Coding: F9A17F06404602002002
            Work Shop Code: WSC 05314 123 12345
                      VCID: 2A51730C85E436E
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 192006 km
                    Time Indication: 0
                    Date: 2117.14.05
                    Time: 20:59:36
La fel si la radio, navigatie si telefon.
Ce pot sa fac? M-am uitat peste toate si am incercat sa le codez ca si inainte dar nu merge deloc aceeasi eroare apare de fiecare data, iar MFD nu apare.Mersi mult
Nu stiu cum sa revin, acolo e problema.Am setat la sound system pe acolo, apoi la speaker monitoring si pe la chestia aia cu afisajul highline sau sportline sau premium dupa care am setat la volan sa fie 0000114 apoi 0000312 si am revenit la 0000112 cum era inainte si tot degeaba.Sa scot borna de pe baterie oare sa o las vreo 5 min? Ar merge cu chestia asta?
Vezi ca ai fiserul Debug in folderul VCDS
Acolo gasesti ceea ce ai modificat
se poate cumva reface ceea ce am modificat? Prin ceva comanda in vcds?
Sau cum as putea sa le dau un fel de reverse?
Ti-au raspuns colegii mai sus!
Din debug iei codarea anterior modificarilor tale. Ai acolo modificarile dupa ora si data si aplici codarea de dinainte.
Asta iti spuneam
Vezi ca ai acolo coddingul dinainte de modificare ,il iei cu copy si ii dai paste la actual codding in LC
Succes
Am inteles.Voi purcede spre masina :)
Dar as avea inca o nelamurire la care nu am primit raspuns pana acuma. Cum pot sa fac sa functioneze butoanele pentru a putea sa umblu prin agenda telefonica dar pe BC? In MFD puteam sa ma misc cu butoanele dar cand eram conectat cu tel nu puteam raspunde si nici sa dau inchidere la apelant de pe volan doar de pe RNS. Sa fie problema ca nu poate comunica cu calculatorul de coloana?
Mersi mult inca odata pentru sugestii colegilor.
1. Ce tip de IC ai: rosu/albastru sau rosu/alb?
2. Ce tip de comenzi la volan ai: de tip vechi (8 butoane) sau de tip nou?
1. IC - Rosu Alb
2. De tip vechi 8 butoane. (atasat e o poza de exemplificare )
post-46152-0-61448100-1380271890_thumb.j
Modificat de skorpyon_83
Daca iti merg comenzile up/down in MFD inseamna ca merge comunicatia intre comenzi si calculatorul de coloana. Posibil ca modulul BT sa astepte comenzi de gen stanga/dreapta de la un volan de tip nou, pentru a naviga in agenda. Eu, avand cluster rosu/albastru si volan cu 8 butoane, n-am putut testa un modul BT de tip nou. LE: chiar si cu un modul BT de tip vechi, nu pot folosi tasta Phone de pe volan, doar comenzile up/down si butonul OK.
Modificat de EWS
Dar pe Skoda O2 Fl primea tot asa comada din maneta de stergatoare si comanda era tot asa " sus - jos" iar "OK" era sub maneta. De asta ziceam ca e straniu ca la maneta sa mearga iar pe butoane de volan nu. Poate nu fac eu codarea cum trebuie la steering wheel habar nu am.
Ai si comenzi la volan si comenzi pe maneta de stergatoare, cumva?
La Passat nu am la maneta doar pe volan. La maneta am comenzi doar pe Skoda de pe care am luat bluetooth-ul si l-am mutat pe passat
posteaza log sa vedem ce modul de BT ai.... si poate printscreen dupa LC.
Modulul BT stiu ca e acesta : 7P6-035-730-C,
Dupa inlocuire nu am facut nicio codare in LC l-am last asa. (nu stiu ce cod avea).
Momentan sunt la servici si nu am la mine VCDS.
L.E. inainte am avut acest modul BT : 1K8 035 730 B (il foloseam doar ca handsfree si atat) din acest motiv am vrut sa fac acest retrofiting la un modul BT cu mai multe optiuni.
Stai linisit.
Modul 7P6 035 730.... nu recunoaste calculatorul/volanul cu 8 butoane.
Acest model pe passat merge doar cu volan nou si/sau calculator nou.
Am avut si eu exact aceiasi problema, am facut rost de modul respectiv, si pe masina mea nu a mers, pe alt passat cu volan nou si pe golf cu volan nou, merge impecabil.
Am inteles.Asta nu ar fi problema mare, problema mare e ca nu mai pot accesa submeniurile din BC vad doar " No paird phone found" "Help" si "Phone Search ". De pe volan nu pot sa dau pe acel buton ce ma ducea inainte pe radio, pe busola, si pe MFD (acuma vad ca am nimerit odata sa imi arata consum, viteza etc) dar sus scria MFI si tot asa nu pot accesa submeniurile.Am facut un loj pe care il postez.Nu stiu cum sa fac sa pot vedea submeniurile si sa pot interschimba intre ele.
Chassis Type: 3C0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 55 56 62 6C
          72 77
VIN: WVWZZZ3CZ9E100270
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QF    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  3735
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 84224 280 740102
   VCID: 79F39C4030C24D6
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
   Component: J104    C4 440 V2   0013
   Revision: --025---    Serial number: 00000786473192
   Coding: 0002346
   Shop #: WSC 05311 000 00000
   VCID: 2F676218BE06536
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DK    HW: 3C0 907 044 DK
   Component: ClimatronicPQ46 133 0909
   Revision: 00133024    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6DDBB810748AE16
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000009192070
   Coding: FF8A8F0700041A00470000000F000000001B5D4332000120000000000000
   Shop #: WSC 05124 123 12345
   VCID: 336F6E68522E776
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 171008 004  0206
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     080109 054  0402
   Coding: 00479274
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 1T0 919 475 L    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0021
   Revision: --------    Serial number: 06530835207275
   Coding: 300006
   Shop #: WSC 05314 000 00000
   VCID: 448D3DB4C780C0E
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__04A VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPR6XBA6
   Coding: 0013377
   VCID: FAF1034CB5C4C6E
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
   Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507CP
   Coding: 0000112
   Shop #: WSC 05314 002 00002
   VCID: 6FE7A2187E86136
   Part No: XXXXXXXXXXX
   Component: E0221           002 0030
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 871 T    HW: 3C0 920 871 T
   Component: KOMBI         H04 0107
   Coding: 160F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
   VCID: 356B5070945A696
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P08C150693
   Shop #: WSC 05314 123 12345
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 7AF1834C35C446E
   Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 B
   Component: RNS-MID       H11 1300
   Revision: AB001001    Serial number: VWZ6Z7K5207129
   Coding: 060100000400008300
   Shop #: WSC 52175 142 04882
   ASAM Dataset: ------------------------- ------
   VCID: 2E597F1C790C5AE
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000513989119
   Coding: 0000245
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.082 0502
   Revision: 1AH02240    Serial number: 00083350046902
   Coding: 0000258
   VCID: 39735C4070428D6
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 0091020051034E763002941570084FCE707D41
   Shop #: WSC 05311 123 12345
   Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Part No: 3C0 951 171 C
   Component: Neigungssensor  004 0611
   Component: Innenraumueberw.004 0611
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000628489117
   Coding: 0000244
   VCID: 70E5A16463B80CE
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000218049
   Coding: 0000057
   VCID: 285589049BE804E
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0136
   Revision: 00H04000    Serial number:
   Coding: 2311169
   VCID: 346D6D74572070E
   Subsystem 1 - Part No: 7L6 941 329 A
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000035
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000753882
   Coding: 0000208
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 3C0 907 441     HW: 3C0 907 441
   Component: J772__Rearview      0042
   Revision: 00H05000    Serial number:    PA8 J990274
   Coding: 0000007
   Shop #: WSC 34789 142 999999
   VCID: DFC752D80E26036
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000758505
   Coding: 0000208
   VCID: 71E3A46068B2056
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668104046
   Coding: 0200000000010110
   Shop #: WSC 73430 031 00999
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA_VW46.rod
   VCID: 32616B6C65347EE
Exista ceva codare in VCDS unde poti alege daca sa vezi submeniul cu toate cele sau nu ?
Mersi mult
Sa inteleg ca de acuma in colo nu o sa mai pot schimba de pe mfd pe radio, busola?
Am citit ceva pe forum si am inteles ca can-ul meu nu comunica bine cu volanul.Dar oare de ce s-a schimbat aceasta chestie dintr-o data si nu pot sa revin la ceea ce a fost inainte? Intradevar nu mergeau butoane dar nu era blocat pe Phone si puteam sa schimb meniurile intre ele. E cumva nevoie de alt volan? Sa fie oare si de la bluetooth? Sa il dau jos si sa il pun pe al meu cel vechi? Cum as putea remedia problema aceasta?
Sal.,
Poate cineva sa-mi zica si mie ce reprezinta functia din PRINT-ul atasat ?
post-20331-0-27523700-1380309307_thumb.j
Ma refer la acel Front Fog Lighting Dimming (Standard 5C)
                          Decimal Value (Resolution: 1%)
Eu am modificat in casuta Dec1 din 30 in 0 crezand ca becurile de la proiectoare vor arde mai tare .
Eu am becuri cu led si parca nu pre se vede noaptea cum vedeam cu cele normale inainte .
Multumesc de explicatie .
O seara buna .
PS:
Au disparut singure erorile de la senzorul de coloana volan singure .
Fog light egaal proiectoare ceata . Stabdard 5C (hexa) este 92 (dec).
lasa-le asa.
Sal.,
Al Bundy,
Cum sa le las asa ?
Cu 30 sau cu 0 ?
Multumesc .
PS
Si mai am o eroare pe oglinda usii pasagerului .
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000080078315
Coding: 0000244
VCID: 3C7C25E47F4921FE88B-8069
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 253
Mileage: 40227 km
Time Indication: 0
De la ce poate sa fie ?
Ca acum se sterge acum reapare .
De reaparut reapare atunci cand reapar mai multe erori cum a fost cazul cu cele de la senzorul de coloana .
O seara buna .
Modificat de @DRI@N
e oglinda dreapta arsa ...dupa cate stiu e comanda din motorul de geam... deci fire rupte cam rar
  • Marian a închis acest topic
