A sarit airbagul singur
Al3X_G4
Salutare.
Am un prieten cu un passat 3b 1.9 tdi 116 cp din 2000.
In timp ce mergea normal cu masina airbagul din dreapta cel din scaun a sarit .....(bine ca nu a sarit cel de la sofer).
Ce trebuie facut ? Ce motive ar avea sa sara singur.?
Codurile de la vag-com : 00532 | 01227 | 01218 | 18017
00532 - Supply Voltage B+
00532 - Supply Voltage B+: Signal too Low
Possible Causes
* Wiring/Connectors from/to Control Module faulty
* Power Supply (Battery/Generator) faulty
Possible Solutions
* Check/Repair Wiring/Connectors from/to Control Module
* Check Power Supply (Battery/Generator)
Special Notes
* When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
* When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
* Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
* Common with 16946/P0562/001378 - System Voltage: Too Low stored in other control modules.
01218 - Side Airbag Igniter; Front Passenger Side (N200)
01218 - Side Airbag Igniter; Front Passenger Side (N200): Resistance too High
Possible Symptoms
* Malfunction Indicator Lamp (MIL) active
Possible Causes
* Wiring/Connectors from/to Side Airbag Igniter, Front Passenger Side (N200) faulty
* Side Airbag Igniter, Front Passenger Side (N200) faulty
Possible Solutions
* Check Wiring/Connectors from/to Side Airbag Igniter, Front Passenger Side (N200)
* Check Side Airbag Igniter, Front Passenger Side (N200) faulty
o Check Measuring Value Blocks (MVB)
01227 - Crash Data Stored for Side Airbag; Passenger Side si 18017/P1609/005641 - Crash Shut-Down Activated
Possible Symptoms
* Fault Code cannot be cleared
Possible Causes
* Crash Signal activated (i.e. Accident with Airbag Deployment)
Possible Solutions
* Set Readiness, the Fault Code should be cleared automatically during this Process.
Special Notes
* In case of an Accident the Airbag Control Module sends a Crash Signal which orders the Engine Control Module to stop the Engine. In Addition this Fault Code will be stored. The Engine may be restarted after cycling the Ignition, the Fault Code should not have any further Influence.
Da am vazut si eu erorile astea .. dar care ar putea fi cauza? Ma tot gandesc la cel declansator nu? n200 ala sa fie problema?
A fost omu` cu masina la VW .. si surpriza nu prea stiu ei din ce cauza a sarit dar au zis ca trebuie schimbat :
airbag : 1300lei
calculator: 2300 lei
Nu merge resetat ? Cei de la Vw au zis ca e din 2000 si modelul ala nu se poate reseta.. asa e?
Calculatorul merge rescris dar el o sa functioneze in continuare doar ca ramane aprins martorul in bord.Cam ciudat sa sara din senin.
Se poate reseta si nu mai apare nici un bec in bord .
