Martorii ABS si ESP nu se sting
adici
Am un coleg care are acel program pe laptop, dar nu are tel deschis. Incerc de dimineata sa sun la el. Am citi ca martorul EPC ar avea legatura cu becurile de frana si (sau ) switch-ul de la pedala de frana. Am  obesrvat ca becurile se aprind, dar e posibil sa fie totusi ceva defect in el. ???
da, e posibil sa fie de la switch-ul de frana.... de aceea cel sigur este cu o diagnoza. Poate sa ai contact imperfect in switch-ul de frana, catre ECU.
astept sa postezi rezultatul - sa-l iei pe stick sau pe mail, sa-l postezi asa cum apare.
Ok . multumesc mult Florin.
erorile de la EGR sunt cauzate in primul rand de faptul ca am scos mufa ( sta martorul aprins de 3 ani jumatate) -----------------------------------------------------------------------
4 Faults Found:
17851 - Potentiometer for EGR (G212): Signal too Low
            P1443 - 35-00 -  -
17848 - EGR Valve (N18): Open Circuit
            P1440 - 35-00 -  -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
            P1649 - 35-10 -  - - Intermittent
16955 - Brake Switch (F): Implausible Signal
            P0571 - 35-00 -  -
Readiness: 1010 0101
Address 03: ABS Brakes       Labels: 1C0-907-37x-ESP-F.LBL
   Part No: 1C0 907 379 G
   Component: ESP FRONT MK60      0101
   Coding: 0011266
   Shop #: WSC 01391
4 Faults Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
00285 - ABS Wheel Speed Sensor; Front Right (G45)
01435 - Brake Pressure Sensor 1 (G201)
            008 - Implausible Signal - Intermittent
Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01391
2 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
            37-00 - Faulty
            37-00 - Faulty
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0004
   Coding: 12855
   Shop #: WSC 01391
No fault code found.
Address 17: Instruments       Labels: 1J0-920-xxx-17.LBL
   Part No: 1J0 920 826 A
   Component: KOMBI+WEGFAHRS. RB8 V17
   Coding: 01113
   Shop #: WSC 00000
   WVWZZZ1JZ2W493285     VWZ6Z0A3823951
2 Faults Found:
01316 - ABS Control Module
Address 19: CAN Gateway       Labels: 6N0-909-901.LBL
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01391
3 Faults Found:
00778 - Steering Angle Sensor (G85)
Address 46: Central Conv.       Labels: 1C0-959-799.LBL
   Part No: 1C0 959 799 B
   Component: 1A Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 01391
   Part No: 1C1959801A
   Component: 1A Tõrsteuer.FS KLO 0004
   Part No: 1C1959802A
   Component: 1A Tõrsteuer.BF KLO 0004
   Part No: 1C0959811A
   Component: 1A Tõrsteuer.HL KLO 0004
   Part No: 1C0959812A
   Component: 1A Tõrsteuer.HR KLO 0002
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00934 - Shareware Version. To Decode all DTCs
            35-10 - Please Register/Activate - Intermittent
Modificat de petrus_0707
Salutare
Revin si eu cu o problema, Am un golf 4, 1,4-16valve, cod motor AKQ din 2001. mi s-a aprins ledul de abs, nu l-am bagat in seama, si la o frana mai puternica m-am dus ca pe schiuri, atunci am vazut ca nu e de joaca si am mers la un service unde mi s-a spus ca este motorasul de la modulul abs, care se schimba cu totul. toate buna si frumoase pana mi-au spus pretul unuia nou si m-a linistit. pe urma am gasit pe net un modul la 400 ron. singura problema e ca al meu de pe masina are seria 1J0 614 117 D si pe acela de l-am gasit pe net se termina cu C, cat de mult conteaza diferenta asta? e posibil ca montand-ul pe masina sa nu il recunoasca calculatorul, sau este ok? Va multumesc!
nu am verificat nimic, eu stiu de la service, ca mi-au coectat un laptop si asta mi-au zis...pai si siguranta modulului o gasesc pe capacul bateriei,nu in modulul cu sigurante?
deci omule, raman dator cu o naveta de bere, de la siguranta era, nu era nici macar arsa, doar usor impuscata pe o lama, am curatat-o si acum merge abs-ul foarte bine :), inca odata Multumesc
mergand in linie dreapa cu vreo 110 .. dintr-o data s-a aprins martorul de bord care se aprinde cand cuplezi si decuplezi ESP.
Este vb de o Bora 1,6 AUS.
din mers am oprit motorul si l-am repornit cu ambreajul, si becul s-a stins.
a mai aparut odata aceeasi eroare la vreo 2 zile cand stateam la semafor cu piciorul pe frana.. dar apoi cand am pus masina in miscare s-a stins.
ce ar trebui sa verific sa nu am probleme la iarna..!?
multumesc
Salut, cu referile postul de mai sus, azi am ajuns la o scanare VCSD
2 faults Founs
01423 - Lateral Acceleration Sensor (G200)
             57 - 10 Elecric Circuit Failure - Intermittent
             27 - 10 Implausible Signal - Intermittent
Ce recomandati stimati colegi?
trebuie reparat senzorul G200 sau inlocuit
Mecanicul zicea ca e undeva sub scaunul sofer.. true ???
si la bora..?
... he he .. pot sa ma duc sa ii zic vreo douua.. :-)
thanks
La Golf4, Bora, Skoda Octavia 1 si Tour, Seat Leon, Toledo, Audi A3.... s.a.m.d....
tot vb de esp si abs aprinse uitati ce am patit la masina din semnatura dupa ce am schimbat la mecanic desigur arcurile si amortizoarele nu se mai sting cei 2 martori mentionati mai devreme oare trebuie refacut unghiul oare o si atins mecanicul vreo legatura vreun fir nu mi dau seama
Sa fi sigur de problema trebuie o scanare
Modificat de robert r.
ideea e ca am franat puternic am accelerat in curbe pe drum cu zapada nu functioneaza daca erau doar martorii aprinsi era una dar nu functioneaza efectiv :( am verificat sigurante inclusiv cele de la baterie tot nimic. cred ca urmeaza scanarea!
fa o diagnoza si posteaza eroarea stocata. In functie de asta iti zicem ce ai de facut.
Cu respect. Am avut si eu o problema cu martorii esp,abs si epc aprinsi la bord.
Sau stins abs si esp ,ramanand aprins epc. dupa o scanare a rezultat :
(ce ar fi?)
4 Faults Found:
            P1443 - 35-00 -  -
            P1440 - 35-00 -  -
            P0571 - 35-00 -  -
   Coding: 0011266
   Shop #: WSC 01391
4 Faults Found:
   Coding: 11000
   Shop #: WSC 01391
2 Faults Found:
            37-00 - Faulty
            37-00 - Faulty
   Coding: 12855
   Shop #: WSC 01391
   Coding: 01113
   Shop #: WSC 00000
2 Faults Found:
   Coding: 00006
   Shop #: WSC 01391
3 Faults Found:
   Coding: 00259
   Shop #: WSC 01391
   Part No: 1C1959801A
   Part No: 1C1959802A
   Part No: 1C0959811A
   Part No: 1C0959812A
2 Faults Found:
sterge erorile si posteaza erorile care raman
Schimba switchul de la pedala de frana si verifica egr, Daca nu e in parametri, se schimba EGR.
Am schimbat switch-ul, a reaparut problema cu martorii esp si abs. Am schimbat bateria (una noua) , s-au stins martori. Am mers ~1000 km dupa care s-au aprins iar (abs +esp). Dupa o noua repornire, ramane aprins abs-ul iar dupa cateva scunde sau 20~30m se stinge. Dupa alte porniri , nu se mai aprinde. ( are momente).
La egr, am decuplat mufa de 3 ani (aveam fluctuatie la relanti)
Astept pareri de la voi.
pai au fost zise niste pareri, ar trebui sa incerci sa stergi erorile postate deja pe net si sa vedem care iti mai raman.
Din puntul de vedere al erorilor postate ai o problema la EGR-care se pare ca are si raspunsul din moment ce ai decuplat-o...fluctuatia de relanti se rezolva daca schimbi egr-ul si in felul asta poti cupla inapoi mufa dar sa ai grija ca sigur s-au oxidat contactele, postarea care ai pus-o mai indica ca switchul de frana F este stricat din nou...probabil ca nu ai pus unul oem sau ai avut ghinion si s-a dus din nou si acesta. Abs-ul se aprinde, dupa care iar se stinge si iar se aprinde deoarece ai o eroare la senzorul dreapta fata de ABS, si mai iti apare o eroare la switchul de la usa soferului. De aceea colegul ti-a spus sa stergi toate erorile si sa vezi care reapar ca poate unele sunt salvate de un secol in calculatoarele masinii
am facut o diagnoza! initial mi a dat senzorul roata stanga fata dar cand s a uitat mai bn electricianul era rupt cablu sau intrerupt cv de genu a refacut acolo legaturile si totu a revenit la normal ...am mers 1 luna fara abs esp! ideea e ca diagnoza e sfanta :D
