garnitura tacheti
copanu
Laurentiu_LWR
merci...problema este ca m-am uitat pe un site si nu imi apare cod pentru ea...
zice ca nu ar fi piesa separata?k e cu totu cu capac?:(
EL266.060 pe erling,si exista si varianta cu tot cu suruburi dar e scumpa rau undeva la 2 mil.Pe original o gasesti numai cu capac 038103469S sau 038103469ad(codul de produs nou)care te costa in jur la 120 euro.Partlist:
cylinder head / 1.9ltr. / diesel eng.:
cylinder head cover
/ ATD,AXR,AJM, AUY,ASZ,ARL
1 038103351D
cylinder head
(1) 038103265FX
cylinder head with valves, camshaft and injector (pump/jet)
/ ATD
(1) 038103265JX
/ AXR
(1) 038103265GX
/ ASZ,ARL
(1) 038103265CX
/ AJM,AUY
2 038103085C
shaft oil seal (shaft rotation: to right)
47X10 /
3 N 0138115
seal
A10X13,5 /
4 N 0160241
sealing plug
M10X1 /
5 N 0119142
locking cover
24 /
(5) N 0119191
locking cover
B25 /
6 N 90115702
washer
12,5X23,5X4,5 /
7 038103714
fitted bolt
M6X54 /
8 N 90188902
stud
M8X35 /
9 N 90905502
stud
CM10AXM8X73 /
10 N 0256663
ball
8V /
11 044103499B
connecting socket
13
tensioning plate / see illustration:
130-30 /
14 038103385A
cheese head bolt
M6X64 /
15 038130085
emulsion tube
16 038103383BL
cylinder head gasket
1,45MM 1 hole /
(16) 038103383BM
1,53MM 2 holes /
(16) 038103383BN
1,61MM 3 holes /
17 038103384
cheese head bolt
M12X166 / ATD,AXR,AJM, AUY,ASZ
(17) 038103384C
cheese head bolt
M12X166 / ARL
18
bearing shell / see illustration:
109-32 /
19
gasket / see illustration:
145-05 /
20
145-05 /
21 038103469S
cylinder head cover
23
gasket / no replacement part
24 038128773
bolt, hex. hd. with shoulder and sleeve
M6 /
(25) 06B103485B
locking cover
26 06A103483D
gasket
27
seal / see illustration:
103-75 /
(28) 038103941E
retainer
front / AJM,AUY,ARL
(28) 038103941E
retainer / F >> 1J-2-750 000*
front / ATD,AXR,ASZ
(28) 038103941L
retainer / F 1J-2-750 001>>*
front / ATD,AXR,ASZ
29 N 0102336
hexagonal head bolt
M8X28 /
30 038103390
lifting bracket
rear /
31 N 10239402
hexagon socket head bolt with collar
M8X22 /
(32) 038103493AB
breather tube
/ ATD,AXR,AJM, AUY
(32) 038103493AC
breather tube
/ ASZ,ARL
33 N 90561801
e destul de nasol,trebuie sa iti dea distributia jos,axele cu came vin in capacul de tacheti,cat despre garnitura acceasta este lichida vine la tub si costa in jur de 150 lei pe original si pe af ceea mai buna varianta este 70-31414-10 REINZ care te costa in jur de 30 lei.Mari meseriasi aia de la service amintit de tine... :lol:
sa nu foloseasca altceva decat reinz sau ELRING 705.705,sunt cele mai bune de pe piata si daca folosesti altceva gen 2+2 de 10 lei tubul risti sa refaci operatiunea peste maxim 1 an.
=> manopera scumpa :(
=> Pasta nu e scumpa, dar mi s-a spus ca e solida (cauciuc) si ca nu este nevoie sa dea distributia jos.
Daca va mai zic ca mi s-a spus ca e cel mai bun meserias din service ... dar nu va mai spun :(
Probabil ca din cauza asta nu gaseau piesa pe calculator ( vroiau sa dea comanda de ea la furnizor si nu o gaseau in calculator )
=> O sa merg la alt service, sa speram ca o rezolv :)
Multumesc pentru informatii !
eu am platit acum aprox 2 ani 250 de lei ca sa remediez asta,insa daca nu scapa mult mai bine astepti si o faci odata cu distributia ca practic e aceeasi manopera.
Din pacate distributia s-a facut acum 25mii km, deci nu mai pot astepta pana la urmatorul schimb + scurgerea de ulei este cam mare ( in 2500 km a curs cam 500 ml - am completat cu ulei ).
am gresit eu exprimarea cu lichida..scuze..
Pana la urma e din cauciuc sau e pasta ? :D
Multumesc !
pozitia 12 din schema de mai sus si ai si poze cu produsul si mai sus,pasta de etansare.
Proprietati chimice: nerezistent la solventi, Tip ambalaj: cartus, continut: 200 ml, Material: Silicon, Gama de temp.: -60
Am o mica nelamurire... daca in zonele marcate in foto se gasesc usoare urme de ulei trebuie schimbata garnitura sau din ce cauza apar?
Multumesc,
post-12687-0-68113900-1309015625_thumb.j
cand ai completat sau ai facut schimbul de ulei a curs din greseala pe langa gura de umplere?Posibil ca garnitura busonului sa fie coapta si pe acolo sa iti arunce stropi mici de ulei.Daca nu e semnificativa pata de ulei nu e problema.De regula daca te lasa etansarea capacului tachetilor..ori se prelinge ulei pe chiulasa ori gasesti locasul bujiilor plin de ulei.
GABIVVX,te rog frumos,pune o lista sau un criteriu dupa care se diferentiaza masinile care au garnitura si care folosesc pasta.Am mesterit la un Ford,2001,1.6 16v,si capacul avea garnitura.
la g4- 1.4 16 v,1.6 16 v.Solutia a fost aleasa la masinile care au axa cu came in capacul tachetilor pt ca daca montau garnitura normala de cauciuc exista pericolul ca odata cu uzura,deformarea,imbatrinirea cauciucului garniturii sa se formeze un joc care putea duce la detararea slabirea distributiei.La astra g 1.4 16v spre exemplu are garnitura normala,la g4 1.8 t are garnitura normala,la g4 2.0 are garnitura normala,la g4 1.6 8 v are garnitura normala,la g4 1.8 t gti garnitura normala,Peugeot 206 1.6 16 v garnitura normala,passat 3c2 2.0 TDI 16 V garnitura normala.
Multumiri! :icon_thumright:
Modificat de zebrocksky
Rectific-axele cu came montate in capacul tachetilor.
Dupa mine..e o solutie destul de tampita montarea axelor cu came direct in capac,si sistemul de culbutori compensatori e destul de tampit(rar am intalnit motor de g4 16valve sa nu bata tachetii,basca peste asta se transmit si bataile si zgomotele de la tacheti in capac si apare senzatia de motot galagios :( )
  • 3 years later...
La masina din semnatura gasesc ulei la baza bujiei 2 de la stanga la dreapta,se poate prelinge de la capac?
Salutare domnilor,
Pentru că tot trebuie să-mi schimb pompa de apă, ceea ce implică demontarea distribuției, am decis să rezolv și scurgerea de ulei minoră dar enervantă de deasupra bujiei cilindrului 1, ceea ce implică demontarea carcasei axelor cu came care sunt simultan și capace culbutori la 1,4 16V. Uleiul intră pe la neetanșeitatea filmului de izolare de fabrică (tot cu ceva silicon)  la tunelul   bujiei 1.
Nu mă mir că s-a dus etanșarea la bujia 1 e cea mai aproape de vibrațiile produse de distribuție, iar mașina e din 2001.
A mai făcut cineva operațiunea? Am înțeles că trebuie să folosesc o pastă siliconică mai bună decît 2+2 gen renzosil, permatex, elring. Dacă nu găsesc să mă aventurez cu 2+2 ?
Mai am două întrebări:
1.Cît de gros să fac filmul de pastă? Subțire sau mai gros?
2. La ce cuplu se strîng apoi șuruburile carcasei ?
Silicon OE
– Degrease the sealing surfaces.
– Apply a thin coating of sealant -D 188 003 A1- uniformly on the clean sealing surface of the cylinder head cover
  Note
The sealant must not be applied too thickly, as otherwise excess sealant may penetrate into the oil bores and possibly cause engine damage.
10 Nm + torque a further 1/4 turn (90°)
Modificat de EEXCALADE
Mulțumesc pentru indicații! N-am găsit pastă OE, dar am găsit renzosil (echivalent).
Asta e cel mai bun la ce iti trebuia tie,erling 777.790
Modificat de GABIVVX
Am ulei in locasul de la 2 bujii. Care ar fi cauza? Ce poate sa se intample rau?
1.4 16v AKQ
Modificat de irinel1988
creste nivelul sau doar e umed? si eu am avut la Golf-ul 4 ulei la o bujie si la fiecare schimb de ulei curatam, probleme nu am avut dar nici nu am vrut sa "stric" etansietatea de fabrica.
@irinel1988 Sa ars siliconul dintre capac si chiulasa sau in urma unei reparatii nu a fost facuta bine etansarea
Se invecheste solutia de etansare.
La urmatoarea schimbare a distributiei pui mecanicul sa iti dea jos capacul de tacheti si sa etanseze din nou cu Victor Rainz sau Erlingul din poza mea de sus.
Poti merge linistit cu uleiul in locasul bujiilor,nu se intampla nimic.
