Manuale si alte documente Audi A4
Marian
Haynes service manuals:
- 1.8T 5V (AWM):
----- Engine
13_1_Engine_assembly.pdf
13_47_Sealing_flanges_and_flywheel_drive_plate.pdf
13_67_Crankshaft_remove___install.pdf
13_79_Pistons_and_connecting_rods_assembly.pdf
15_1_Cylinder_head_remove_and_install.pdf
15_37_Valve_gear_service.pdf
15_92_Camshaft_timing_control.pdf
17_1_Camshaft_timing_control.pdf
19_1_Cooling_system_components.pdf
----- Exhaust & Emission
26_1_Exhaust_system_components_remove_and_install.pdf
26_41_Secondary_air_system.pdf
----- General
00_1_Technical_data.pdf
----- OBD
01_1_Technical_data_OBD.pdf
----- Turbocharge
21_1_Charge_air_system_with_turbocharger_checking.pdf
21_16_Charge_pressure_leak_test.pdf
21_44_Charge_pressure_system_with_exhaust_turbocharger_servi.pdf
- 1.8T 5V (AEB & ATW):
----- Engine
13_1_Engine_assembling.pdf
13_36_Sealing_flange_flywheel___driveplate.pdf
13_46_Crankshaft.pdf
15_1_Cylinder_head_bolts.pdf
15_2_Cylinder_head_removing___installing.pdf
15_3_Pistion___connecting_rods.pdf
15_32_Valvetrain_servicing.pdf
17_1_Lubrication_system_components.pdf
26_1_Exhaust_system_components.pdf
26_29_Secondary_air_system_checking.pdf
----- General
----- Turbocharger
21_1_Turbocharger_system.pdf
21_38_Vacuum_control_system.pdf
21_46_Charge_air_system_with_turbocharger.pdf
- 2.8 V6 5V ( AHA & ATQ ):
----- Engine
13_4_Cylinder_block_crankshaft_and_flywheel_service.pdf
15_1_Valve_gear_service.pdf
17_1_Lubrication_system_components_remove_and_install.pdf
17_30_Lubrication_system_components_checking.pdf
19_1_Cooling_system_components_remove_and_install.pdf
26_12_Secondary_Air_Injection_system.pdf
----- General
- Audi B5 1997-2001
----- Body
Exterior
50_1_Front_end.pdf
55_1_Hood.pdf
55_12_Rear_lid_VIN_8D_XA_200_000.pdf
55_24_Rear_lid_VIN_8D_XA_200_001.pdf
55_32_Tailgate_Avant_VIN_8D_XA_200_000.pdf
55_49_Tailgate_Avant_VIN_8D_XA_200_001.pdf
57_39_Central_locking_system.pdf
57_50_Central_locking_system_Avant_repairing.pdf
63_1_Front_bumper.pdf
63_10_Spoiler_remove___install.pdf
63_11_Rear_bumper.pdf
63_16_Rear_bumper_Avant.pdf
66_1_Protective_trim_molding.pdf
66_2_Lower_trim_strip_front_door.pdf
66_5_Lower_trim_strip_rear_door.pdf
66_14_Door_mirrors.pdf
66_22_Rocker_panel.pdf
66_31_Wheelhousing_liner_remove___install.pdf
66_32_Rear_wheelhousing_liner_remove___install.pdf
Interior
69_1_Seatbelt.pdf
69_40_Airbag_service.pdf
70_1_Front_door_trim.pdf
70_23_Rear_door_trim.pdf
70_40_Instrutment_panel.pdf
70_72_General_trim.pdf
70_98_Trm_Avant.pdf
72_1_Front_seats.pdf
72_24_Recaro_seats.pdf
72_57_Rear_seats.pdf
OBD
01_5_Airbag_w_o_side_air_bag_OBD.pdf
01_69_Central_locking_system_OBD.pdf
01_108_Interior_monitor.pdf
----- Electrical Equipment
01_1_Instrument_cluster__On_Board_Diagnostic_through_M.Y._19.pdf
01_1_Radio_OBD.pdf
01_79_Instrument_cluster__On_Board_Diagnostic_from_M.Y._2000.pdf
01_84_Multi_function_steering_wheel_OBD.pdf
1_203_Cruise_control_On_Board_Diagnostic.pdf
27_1_Battery.pdf
27_26_Generator.pdf
27_40_Starter.pdf
27_48_Cruise_control_system.pdf
90_1_Instrument_cluster_location_diagram_through_M.Y._1999.pdf
90_25_Instrument_cluster_location_diagram_from_M.Y._2000.pdf
91_1_Radio_system.pdf
91_69_Multi_function_steering_wheel.pdf
94_1_Three_way_halogen_headlights.pdf
94_17_Front_fog_lights.pdf
94_21_Front_turn_signals.pdf
94_22_Side_mounted_turn_signals.pdf
94_37_Steering_column_switch.pdf
94_41_Ignition_switch_lock_cylinder.pdf
96_1_Center_console_switches.pdf
96_4_Interior_lights.pdf
96_12_Interior_lights_Avant.pdf
96_16_Lock_cylinder_heating.pdf
97_1_Relay_panel__fuse_panel.pdf
----- Fuel injection and ignition
AEB
28_1_Technical_data_spark_plugs.pdf
28_17_Ignition_coil_system_checking.pdf
24_1_Motornic_MFI___Ignition_system.pdf
24_99_Throttle_valve_control_module___checking.pdf
24_123_Turbocharger_boost_control___checking.pdf
24_136_EVAP_system_checking.pdf
24_145_Additional_signal.pdf
01_1_ODB___DTC.pdf
01_59_Readiness_codes.pdf
AFC
28_1_Multiport_Fuel_Injection_and_ignition_system.pdf
28_7_Ignition_system_servicing.pdf
28_13_Ignition_coil_power_output_stage_checking.pdf
28_16_Ignition_coils__checking.pdf
28_19_Crankshaft_Position_sensor_checking.pdf
28_21_Engine_speed_sensor_checking_and_adjusting.pdf
28_25_Engine_Coolant_Temperature_sensor_checking.pdf
28_27_Engine_Control_Module_voltage_supply_checking.pdf
28_29_Knock_sensors_checking.pdf
28_33_Camshaft_Position_sensor_checking.pdf
24_1_Multiport_Fuel_Injection_and_ignition_system.pdf
24_7_Multiport_Fuel_Injection_system_servicing.pdf
24_16_Idle_speed_checking.pdf
24_20_Fuel_system_pressure_and_residual_pressure_checking.pdf
24_24_Fuel_pump_relay_and_relay_triggering_checking.pdf
24_29_Fuel_injectors_checking.pdf
24_33_Fuel_injector_leak_testing_and_delivery_quantity_check.pdf
24_37_Idle_Air_Control_valve_checking.pdf
24_41_Oxygen_Sensor_control_checking.pdf
24_43_Cold_start_driveability_problems__overview.pdf
24_45_Oxygen_Sensor_control_checking_before_converter.pdf
24_49_Heated_Oxygen_Sensor_before_Converter_checking.pdf
24_53_Heated_Oxygen_Sensor_after_Converter_checking.pdf
24_57_Heated_oxygen_sensor_removing_and_installing.pdf
24_58_EVAP_canister_purge_regulator_valve_checking.pdf
24_61_Sensor_for_EVAP_canister_checking.pdf
24_64_Intake_manifold_change_over_valve_checking.pdf
24_67_Exhaust_Gas_Recirculation_checking.pdf
24_70_Exhaust_Gas_Recirculation_valve_checking.pdf
24_71_Exhaust_Gas_Recirculation_temperature_sensor_checking.pdf
24_73_Closed_Throttle_Position_switch_checking_and_adjusting.pdf
24_77_Throttle_Position_sensor_checking_and_adjusting.pdf
24_81_Mass_Air_Flow_sensor_checking.pdf
24_85_Intake_manifold_change_over_checking.pdf
24_88_Auxiliary_input_signals_checking.pdf
24_111_Vacuum_connections.pdf
01_1_On_Board_Diagnostic_Multiport_Fuel_Injection.pdf
AHA
28_1_Motronic_ignition_system.pdf
28_29_Camshaft_adjustment_system__checking.pdf
24_1_Motronic_Multiport_Fuel_Injection_and_ignition_system.pdf
24_128_Throttle_valve_control_module__checking.pdf
24_154_Intake_Manifold_Tuning_system.pdf
24_164_Auxiliary_signals_checking.pdf
01_1_On_Board_Diagnostic.pdf
APB
28_1_Ignition_system__checking.pdf
01_1_Motronic_system_On_Board_Diagnostic.pdf
24_1_Motronic_Multiport_Fuel_Injection_system_servicing.pdf
24_79_Oxygen_sensor_control_checking.pdf
24_139_Electronic_Engine_Power_Control_checking.pdf
24_179_Additional_signals_checking.pdf
ATQ
28_1_Ignition_system_checking.pdf
24_1_Motronic_injection_system_servicing.pdf
24_67_Intake_manifold_change_over.pdf
24_76_Oxygen_sensor_control_checking.pdf
24_128_Tank_ventilation_checking.pdf
24_134_Electronic_engine_power_control_checking.pdf
24_165_Additional_signals_testing.pdf
01_1_Motronic_On_Board_Diagnostic.pdf
01_15_Check_DTC_Memory_and_Erase_DTC_Memory.pdf
01_56_Output_Diagnostic_Test_Mode.pdf
01_66_Basic_Setting.pdf
01_71_Code_Control_Module.pdf
01_74_Read_Measuring_Value_Block.pdf
01_76_Readiness_code.pdf
ATW
28_1_Ignition_system.pdf
24_1_Motronic_fuel_injection_system_servicing.pdf
24_71_Oxygen_sensor_control.pdf
24_107_Tank_ventilation.pdf
24_113_Electronic_Engine_Power_Control_checking.pdf
24_155_Additional_signals.pdf
24_177_Vacuum_diagram.pdf
01_16_DTC_memory_checking.pdf
01_19_Diagnostic_Trouble_Code_table.pdf
01_49_Output_Diagnostic_Test_Mode.pdf
01_58_Basic_Setting.pdf
01_62_Code_Control_Module.pdf
01_64_Readiness_code.pdf
01_65_Read_Measuring_Value_Block.pdf
AWM
24_71_Oxygen_sensor_control_checking.pdf
24_114_Tank_ventilation_checking.pdf
24_120_Electronic_engine_power_control_checking.pdf
24_163_Additional_signals_checking.pdf
24_187_Vacuum_diagram.pdf
01_12_Diagnostic_Trouble_Code_memory_checking.pdf
01_51_Output_Diagnostic_Test_Mode.pdf
01_66_Basic_setting.pdf
01_77_Readiness_code.pdf
Fuel System
20_1_Fuel_supply_system_servicing_guidelines.pdf
20_6_Fuel_supply_system_front_wheel_drive_1.8T___2.8.pdf
20_53_Quattro_fuel_system_servicing_1.8T___2.8.pdf
20_107_Fuel_supply_system_biturbo_2.8.pdf
20_130_EVAP_system_servicing.pdf
20_186_Mechanical_throttle_control_servicing.pdf
20_204_E_gas_servicing.pdf
Heating and AC
01_1_AC_system_On_Board_Diagnostic.pdf
01_115_AC_system_electrical_testing.pdf
01_153_Rear_window_heating_electrical_testing.pdf
87_21_Refrigerant_system_components.pdf
87_76_AC_compressor_bracket.pdf
87_84_Ribbed_drive_belt_for_AC_compressor_4_cyl.pdf
87_120_Climate_control_components_in_passenger_compartment.pdf
87_151_Heating_and_ventilation_system_servicing.pdf
87_181_Evaporator_housing_assembly.pdf
87_184_Vacuum_system_hose_layout.pdf
87_185_Vacuum_system_servicing.pdf
Maintenance
1_Engine_overview.pdf
Brake system
00_1_Techincal_data.pdf
45_1_General_information_ABS.pdf
45_6_ABS_Bosch_5.0.pdf
45_18_ABS_Bosch_5.3.pdf
45_24_Suspension_mount_ABS.pdf
45_41_ESP_service.pdf
46_1_Front_brake_service.pdf
46_20_Rear_brake_service.pdf
46_29_Parking_brake_cable_front_wheel_drve.pdf
46_34_Parking_brake_cable_all_wheel_drive.pdf
46_38_Parking_brake_lever.pdf
46_46_Brake_pedal_remove___install.pdf
47_1_Leak_test.pdf
47_2_Front_calipers.pdf
47_8_Double_piston_front_caliper.pdf
47_13_Rear_calipers.pdf
47_23_Hydraulic_changing___bleeding_fluid.pdf
47_29_Master_cylinder_23.8mm.pdf
47_41_Master_cylinder_25.4mm.pdf
Brake system OBD
01_1_OBD.pdf
01_11_Erase_DTC_s_memory_end_output.pdf
01_25_Can_bus.pdf
1_35_Description_of_systems.pdf
01_45_ABS_EDS_Bosch_5.0.pdf
01_52_Check_control_module_01.pdf
01_56_Code_control_module.pdf
01_120_ABS_EDL_ASR_Bosch_5.3.pdf
01_128_Check_control_module_01.pdf
01_135_Check_control_module_07.pdf
01_140_Read_measure_value_block_08.pdf
01_149_Output_DTM_03.pdf
01_217_ESP_Bosch_5.3.pdf
01_242_Basic_setting_04.pdf
01_301_ESP_electrical_testing.pdf
01_356_ESP_DTC_Table.pdf
Suspension wheel steering
40_1_Front_axle_components.pdf
40_11_Running_change_from_connecting_link_ball_joint_1999.pdf
40_17_Front_drive_axles_remove___install.pdf
40_39_Front_struts_remove___install.pdf
40_54_Wheel_bearing_housing_remove___install.pdf
40_68_Front_mounting_bracket_remove___install.pdf
40_77_Subframe_remove___install.pdf
40_91_Lower_track_control_link_remove___install.pdf
40_97_Lower_guide_link_remove___install.pdf
40_101_Stabilizer_bar_remove___install.pdf
42_1_Rear_axle_front_wheel_drive.pdf
42_24_Rear_struts_remove___install.pdf
42_39_Rear_axle_all_wheel_drive.pdf
42_65_Rear_struts___upper_control_arm_remove___install.pdf
42_77_Upper_control_arm.pdf
42_84_Lower_control_arm_remove___install.pdf
42_93_Rear_drive_axle_remove___install.pdf
42_106_Wheel_bearing_housing_remove___install.pdf
44_1_Wheel___Tires.pdf
44_6_Wheel_alignment.pdf
48_1_Steering_gear_components.pdf
48_5_Steering_gear_remove___install.pdf
48_22_Steering_fluid_check___bleeding.pdf
48_27_Power_steering_pump___reservoir.pdf
48_38_Power_steering_pump_testing.pdf
48_44_Power_steering_pump_remove___install.pdf
48_62_Air_bag.pdf
48_71_Steering_column_remove___install.pdf
48_84_Steering_column_remove___install.pdf
Transmission
5sp Automatic Transmission 01V
00_1_Transmission_id.pdf
00_20_Rear_final_drive_id.pdf
00_22_Capacity.pdf
00_26_Roll_or_tow_starter.pdf
00_27_Service_notes.pdf
9_128_Rear_differential_remove___install.pdf
32_1_Torque_converter.pdf
37_1_Select_lever_mechanism.pdf
37_71_Transmission_remove___install.pdf
37_133_ATF_checking___changing.pdf
37_143_Power_transfer_overview.pdf
37_148_Transmission_assembly.pdf
38_1_Oil_Pan___Oil_Strainer_assembly.pdf
39_1_Final_drive_gear_oil.pdf
39_5_Front_final_drive_service.pdf
39_40_Gear_oil_differential.pdf
39_45_Center_differential_service.pdf
39_73_Drive_shaft_service.pdf
39_94_Rear_gear_oil_check.pdf
39_95_Torque_tube_remove___install.pdf
39_102_Torque_tube_assembly.pdf
39_113_Oil_seal_flange_shaft.pdf
39_117_Rear_final_drive_remove___install.pdf
39_124_Rear_final_assembly.pdf
39_136_Rear_differential_assembly.pdf
39_152_Drive_pinion_assembly.pdf
39_166_Drive_pinion___ring_gear_adjust.pdf
01_70_Readiness_code.pdf
24_134_Evaporative_Emission_system_checking.pdf
01_61_Read_measure_value_block.pdf
48_14_Tie_rod_remove___install.pdf
48_17_Steering_gear_assembly.pdf
48_26_Steering_gear_adjustment.pdf
5sp Automatic Transmission 01V OBD
01_1_Transmission_OBD.pdf
01_11_Electrical___electronic_components___location.pdf
01_34_OBD.pdf
01_43_DTC_memory.pdf
01_45_DTC_s_table.pdf
01_163_Output_DTM.pdf
01_180_TCM_code.pdf
01_186_Read_measuring_value_block.pdf
01_187_Read_measuring_value_block_E_17.pdf
01_228_Read_measuring_value_block_E_18_2.pdf
01_263_Can_Bus.pdf
01_273_Electrical_testing.pdf
5sp Manual Transmission 01A all wheel drive
00_7_Rear_final_drive_id.pdf
00_10_Transmission_layout.pdf
00_12_Calculations.pdf
00_14_General_repair_instructions.pdf
30_1_Clutch_mechanism_service.pdf
30_20_Clutch_release_mechanism_service.pdf
34_1_Shift_linkage_service.pdf
34_18_Transmission_remove___install.pdf
34_38_Transmission_oil_level_check.pdf
34_39_Cover_torsen_differential_remove___install.pdf
34_43_Transmission_assembly.pdf
34_68_Torsen_differential_assembly.pdf
34_79_transmission_selector_mechanism_assembly.pdf
35_1_input_shaft_assembly.pdf
35_17_input_shaft_adjustment.pdf
35_21_drive_pinion___hollow_shaft_assembly.pdf
35_44_Reverse_idler_gear_remove___install.pdf
39_1_Final_drive_flange_seal.pdf
39_7_Final_drive_flange___driveshaft_seals.pdf
39_13_Speedometer_speed_sensor.pdf
39_16_Differential_remove___install.pdf
39_21_Front_final_differential_assembly.pdf
39_34_Final_drive_ring_gear___pinion_shaft.pdf
39_41_Total_shim_thickness.pdf
39_68_Final_driveshaft_service.pdf
39_77_Final_drive_flange_driveshaft.pdf
39_84_Final_drive_rear_oil_level_check.pdf
39_85_Final_drive_flange_housing_remove___install.pdf
39_104_Rear_final_drive_remove___install.pdf
39_111_Rear_final_drive_assembly.pdf
39_114_Differential_remove___install.pdf
39_121_Differential_assembly.pdf
39_134_Pinion_shaft_remove___install.pdf
39_146_Pinion_shaft___ring_gear_adjustment.pdf
39_148_Final_drive_gear_set.pdf
5sp Manual Transmission 012-01 front wheel drive
00_1_Manual_transmission_ID.pdf
00_7_Transmission_calcalutions.pdf
00_8_Drivetrain_overview_Fronttrak.pdf
00_10_General_repair_instructions.pdf
30_1_Clutch_mechanism___serving.pdf
30_17_Clutch_release_mechanism.pdf
34_1_Shift_linkage___servicing.pdf
34_36_Transmission_oil_level_checking.pdf
34_62_Transmission_selector_mechanism.pdf
34_88_Transmission_disassemble___assemble.pdf
35_1_Input_shaft.pdf
35_17_Input_shaft_adjusting.pdf
35_21_Pinion_shaft.pdf
35_44_Reverse_idle_gear.pdf
39_1_Drive_flange_seal.pdf
39_7_Speedometer_vehicle_speed_sensor.pdf
39_10_Differential_remove___install.pdf
39_15_Differential_disassemble___assemble.pdf
39_29_Pinion_shaft___ring_gear_adjustment.pdf
6sp Transmission 01E
34_54_Bearing_house___Torsen_differential.pdf
34_89_Bearing_house_assembly.pdf
34_97_Bearings_for_torsen_differential_service.pdf
30_27_Clutch_release_mechanism.pdf
30_36_Clutch_service.pdf
39_4_Final_speedometer_sender.pdf
39_6_Final_seal_grooved_ball_bearings_for_flange_driveshaft.pdf
39_15_Final_differential_remove___install.pdf
39_17_Final_drive_differential_assembly.pdf
39_33_Final_drive_pinion___ring_gear.pdf
39_39_Final_drive_pinion_adjustment.pdf
39_52_Final_drive_ring_gear_adjustment.pdf
39_64_Final_driveshaft_service.pdf
39_80_Final_read_oil_level.pdf
39_81_Final_drive_flange_housing_remove___install.pdf
39_88_Final_drive_flange_housing_assembly.pdf
39_98_Final_drive_flange_oil_seals.pdf
39_102_Final_drive_rear_remove___install.pdf
39_109_Final_drive_rear_assembly.pdf
39_112_Final_drive_differential_remove___install.pdf
39_120_Final_drive_differential_assembly.pdf
39_134_Final_drive_pinion_assembly.pdf
39_146_Final_drive_pinion___ring_gear_adjustment.pdf
00_1_6sp_Transmission.pdf
00_5_Rear_final_drive_id.pdf
00_7_Transmission_layout.pdf
00_10_Overall_ratio_calculation.pdf
00_11_Repair_instruction.pdf
34_1_Shift_control_mechanism.pdf
34_39_Oil_level_transmission_checking.pdf
34_40_Transmission_assembly.pdf
34_109_End_cover_service.pdf
34_127_Transmission_housing_service.pdf
35_1_Input_shaft_assembly.pdf
35_13_Drive_pinion___hollow_shaft_assembly.pdf
Audi B5 1997-2001 - Manual interactiv (Fr)
01.PDF
02.PDF
03A.PDF
03B.PDF
03C.PDF
04.PDF
05A.PDF
05B.PDF
06A.PDF
06B.PDF
07A.PDF
07B.PDF
08.PDF
09.PDF
10.PDF
11.PDF
12.PDF
13.PDF
14.pdf
17.PDF
18.pdf
AIDE.PDF
AIRELLE.pdf
EXPERT.PDF
INTERNET.PDF
SOMMAIRE.pdf
